[U-Boot] [PATCH 1/2] driver/ddr/fsl: Add general MMDC driver
This patch adds basic support for Freescale MMDC(Multi Mode DDR Controller). Currently MMDC is integrated on ARMv8 LS1012A SoC for DDR3L, there will be a update to this driver to support more flexible configuration if new features (DDR4, multiple controllers/chip selections, etc) are implimented in future.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com --- Makefile | 1 + arch/arm/include/asm/arch-fsl-layerscape/config.h | 2 + drivers/ddr/fsl/Makefile | 1 + drivers/ddr/fsl/fsl_mmdc.c | 152 ++++++++++++++++++++++ include/fsl_mmdc.h | 83 +++++------- 5 files changed, 192 insertions(+), 47 deletions(-) create mode 100644 drivers/ddr/fsl/fsl_mmdc.c
diff --git a/Makefile b/Makefile index 99cc8cf..1bf6c6a 100644 --- a/Makefile +++ b/Makefile @@ -647,6 +647,7 @@ libs-y += drivers/power/ \ libs-y += drivers/spi/ libs-$(CONFIG_FMAN_ENET) += drivers/net/fm/ libs-$(CONFIG_SYS_FSL_DDR) += drivers/ddr/fsl/ +libs-$(CONFIG_SYS_FSL_MMDC) += drivers/ddr/fsl/ libs-$(CONFIG_ALTERA_SDRAM) += drivers/ddr/altera/ libs-y += drivers/serial/ libs-y += drivers/usb/dwc3/ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index b0ad4b4..478b7ab 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -18,6 +18,8 @@ #ifndef CONFIG_LS1012A #define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 +#else +#define CONFIG_SYS_FSL_MMDC /* Freescale MMDC driver */ #endif
/* diff --git a/drivers/ddr/fsl/Makefile b/drivers/ddr/fsl/Makefile index 01ea862..00dea42 100644 --- a/drivers/ddr/fsl/Makefile +++ b/drivers/ddr/fsl/Makefile @@ -33,3 +33,4 @@ obj-$(CONFIG_SYS_FSL_DDRC_GEN3) += mpc85xx_ddr_gen3.o obj-$(CONFIG_SYS_FSL_DDR_86XX) += mpc86xx_ddr.o obj-$(CONFIG_SYS_FSL_DDRC_ARM_GEN3) += arm_ddr_gen3.o obj-$(CONFIG_SYS_FSL_DDRC_GEN4) += fsl_ddr_gen4.o +obj-$(CONFIG_SYS_FSL_MMDC) += fsl_mmdc.o diff --git a/drivers/ddr/fsl/fsl_mmdc.c b/drivers/ddr/fsl/fsl_mmdc.c new file mode 100644 index 0000000..eb36cea --- /dev/null +++ b/drivers/ddr/fsl/fsl_mmdc.c @@ -0,0 +1,152 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * Generic driver for Freescale MMDC(Multi Mode DDR Controller). + */ + +#include <common.h> +#include <fsl_mmdc.h> +#include <asm/io.h> + +static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) +{ + int timeout = 1000; + + out_be32(ptr, value); + + while (in_be32(ptr) & bits) { + udelay(100); + timeout--; + } + if (timeout <= 0) + printf("Error: %p wait for clear timeout.\n", ptr); +} + +void mmdc_init(void) +{ + struct mmdc_regs *mmdc = (struct mmdc_regs *)CONFIG_SYS_FSL_DDR_ADDR; + unsigned int tmp; + + /* 1. set configuration request */ + out_be32(&mmdc->mdscr, MDSCR_ENABLE_CON_REQ); + + /* 2. configure the desired timing parameters */ + out_be32(&mmdc->mdotc, CONFIG_MMDC_MDOTC); + out_be32(&mmdc->mdcfg0, CONFIG_MMDC_MDCFG0); + out_be32(&mmdc->mdcfg1, CONFIG_MMDC_MDCFG1); + out_be32(&mmdc->mdcfg2, CONFIG_MMDC_MDCFG2); + + /* 3. configure DDR type and other miscellaneous parameters */ + out_be32(&mmdc->mdmisc, CONFIG_MMDC_MDMISC); + out_be32(&mmdc->mpmur0, MMDC_MPMUR0_FRC_MSR); + out_be32(&mmdc->mdrwd, CONFIG_MMDC_MDRWD); + out_be32(&mmdc->mpodtctrl, CONFIG_MMDC_MPODTCTRL); + + /* 4. configure the required delay while leaving reset */ + out_be32(&mmdc->mdor, CONFIG_MMDC_MDOR); + + /* 5. configure DDR physical parameters */ + /* set row/column address width, burst length, data bus width */ + tmp = CONFIG_MMDC_MDCTL & ~(MDCTL_SDE0 | MDCTL_SDE1); + out_be32(&mmdc->mdctl, tmp); + /* configure address space partition */ + out_be32(&mmdc->mdasp, CONFIG_MMDC_MDASP); + + /* 6. perform a ZQ calibration - not needed here, doing in #8b */ + + /* 7. enable MMDC with the desired chip select */ +#if (CONFIG_CHIP_SELECTS_PER_CTRL == 1) + out_be32(&mmdc->mdctl, tmp | MDCTL_SDE0); +#elif (CONFIG_CHIP_SELECTS_PER_CTRL == 2) + out_be32(&mmdc->mdctl, tmp | MDCTL_SDE0 | MDCTL_SDE1); +#endif + + /* 8a. dram init sequence: update MRs for ZQ, ODT, PRE, etc */ + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(8) | MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_2); + + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(0) | MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3); + + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(4) | MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1); + + out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(0x19) | + CMD_ADDR_LSB_MR_ADDR(0x30) | + MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_0); + + /* 8b. ZQ calibration */ + out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(0x4) | MDSCR_ENABLE_CON_REQ | + CMD_ZQ_CALIBRATION | CMD_BANK_ADDR_0); + + set_wait_for_bits_clear(&mmdc->mpzqhwctrl, CONFIG_MMDC_MPZQHWCTRL, + MPZQHWCTRL_ZQ_HW_FORCE); + + /* 9a. calibrations now, wr lvl */ + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(0x84) | + MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1); + + out_be32(&mmdc->mdscr, MDSCR_ENABLE_CON_REQ | MDSCR_WL_EN | + CMD_NORMAL); + + set_wait_for_bits_clear(&mmdc->mpwlgcr, MPWLGCR_HW_WL_EN, + MPWLGCR_HW_WL_EN); + + mdelay(1); + + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(4) | MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1); + out_be32(&mmdc->mdscr, MDSCR_ENABLE_CON_REQ); + + mdelay(1); + + /* 9b. read DQS gating calibration */ + out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(4) | MDSCR_ENABLE_CON_REQ | + CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0); + + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(4) | MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3); + + out_be32(&mmdc->mppdcmpr2, MPPDCMPR2_MPR_COMPARE_EN); + /* set absolute read delay offset for bytes */ + out_be32(&mmdc->mprddlctl, CONFIG_MMDC_MPRDDLCTL); + + set_wait_for_bits_clear(&mmdc->mpdgctrl0, + AUTO_RD_DQS_GATING_CALIBRATION_EN, + AUTO_RD_DQS_GATING_CALIBRATION_EN); + + out_be32(&mmdc->mdscr, (MDSCR_ENABLE_CON_REQ | CMD_LOAD_MODE_REG | + CMD_BANK_ADDR_3)); + + /* 9c. read calibration */ + out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(4) | MDSCR_ENABLE_CON_REQ | + CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0); + out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(4) | MDSCR_ENABLE_CON_REQ | + CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3); + out_be32(&mmdc->mppdcmpr2, MPPDCMPR2_MPR_COMPARE_EN); + set_wait_for_bits_clear(&mmdc->mprddlhwctl, + MPRDDLHWCTL_AUTO_RD_CALIBRATION_EN, + MPRDDLHWCTL_AUTO_RD_CALIBRATION_EN); + + out_be32(&mmdc->mdscr, (MDSCR_ENABLE_CON_REQ | CMD_LOAD_MODE_REG | + CMD_BANK_ADDR_3)); + + /* 10. configure power-down, self-refresh entry, exit parameters */ + out_be32(&mmdc->mdpdc, CONFIG_MMDC_MDPDC); + out_be32(&mmdc->mapsr, MMDC_MAPSR_PWR_SAV_CTRL_STAT); + + /* 11. ZQ config again? do nothing here */ + + /* 12. refresh scheme */ + set_wait_for_bits_clear(&mmdc->mdref, CONFIG_MMDC_MDREF, + MDREF_START_REFRESH); + + /* 13. disable CON_REQ */ + out_be32(&mmdc->mdscr, MDSCR_DISABLE_CFG_REQ); +} diff --git a/include/fsl_mmdc.h b/include/fsl_mmdc.h index a939d89..a10e40c 100644 --- a/include/fsl_mmdc.h +++ b/include/fsl_mmdc.h @@ -7,63 +7,39 @@ #ifndef FSL_MMDC_H #define FSL_MMDC_H
-#define CONFIG_SYS_MMDC_CORE_ODT_TIMING 0x12554000 -#define CONFIG_SYS_MMDC_CORE_TIMING_CFG_0 0xbabf7954 -#define CONFIG_SYS_MMDC_CORE_TIMING_CFG_1 0xff328f64 -#define CONFIG_SYS_MMDC_CORE_TIMING_CFG_2 0x01ff00db - -#define CONFIG_SYS_MMDC_CORE_MISC 0x00001680 -#define CONFIG_SYS_MMDC_PHY_MEASURE_UNIT 0x00000800 -#define CONFIG_SYS_MMDC_CORE_RDWR_CMD_DELAY 0x00002000 -#define CONFIG_SYS_MMDC_PHY_ODT_CTRL 0x0000022a - -#define CONFIG_SYS_MMDC_CORE_OUT_OF_RESET_DELAY 0x00bf1023 - -#define CONFIG_SYS_MMDC_CORE_ADDR_PARTITION 0x0000007f - -#define CONFIG_SYS_MMDC_PHY_ZQ_HW_CTRL 0xa1390003 - -#define FORCE_ZQ_AUTO_CALIBRATION (0x1 << 16) - -/* PHY Write Leveling Configuration and Error Status (MPWLGCR) */ -#define WR_LVL_HW_EN 0x00000001 +/* PHY Write Leveling Configuration and Error Status Register (MPWLGCR) */ +#define MPWLGCR_HW_WL_EN (1 << 0)
/* PHY Pre-defined Compare and CA delay-line Configuration (MPPDCMPR2) */ -#define MPR_COMPARE_EN 0x00000001 +#define MPPDCMPR2_MPR_COMPARE_EN (1 << 0)
-#define CONFIG_SYS_MMDC_PHY_RD_DLY_LINES_CFG 0x40404040
/* MMDC PHY Read DQS gating control register 0 (MPDGCTRL0) */ -#define AUTO_RD_DQS_GATING_CALIBRATION_EN 0x10000000 +#define AUTO_RD_DQS_GATING_CALIBRATION_EN (1 << 28)
/* MMDC PHY Read Delay HW Calibration Control Register (MPRDDLHWCTL) */ -#define AUTO_RD_CALIBRATION_EN 0x00000010 - -#define CONFIG_SYS_MMDC_CORE_PWR_DOWN_CTRL 0x00030035 +#define MPRDDLHWCTL_AUTO_RD_CALIBRATION_EN (1 << 4)
-#define CONFIG_SYS_MMDC_CORE_PWR_SAV_CTRL_STAT 0x00001067 +/* MMDC Core Power Saving Control and Status Register (MMDC_MAPSR) */ +#define MMDC_MAPSR_PWR_SAV_CTRL_STAT 0x00001067
-#define CONFIG_SYS_MMDC_CORE_REFRESH_CTL 0x0f3c8000 - -#define START_REFRESH 0x00000001 +/* MMDC Core Refresh Control Register (MMDC_MDREF) */ +#define MDREF_START_REFRESH (1 << 0)
/* MMDC Core Special Command Register (MDSCR) */ -#define CMD_ADDR_MSB_MR_OP(x) (x << 24) - -#define CMD_ADDR_LSB_MR_ADDR(x) (x << 16) - -#define DISABLE_CFG_REQ 0x0 -#define CONFIGURATION_REQ (0x1 << 15) -#define WL_EN (0x1 << 9) - -#define CMD_NORMAL (0x0 << 4) -#define CMD_PRECHARGE (0x1 << 4) -#define CMD_AUTO_REFRESH (0x2 << 4) -#define CMD_LOAD_MODE_REG (0x3 << 4) -#define CMD_ZQ_CALIBRATION (0x4 << 4) -#define CMD_PRECHARGE_BANK_OPEN (0x5 << 4) -#define CMD_MRR (0x6 << 4) - +#define CMD_ADDR_MSB_MR_OP(x) (x << 24) +#define CMD_ADDR_LSB_MR_ADDR(x) (x << 16) +#define MDSCR_DISABLE_CFG_REQ (0 << 15) +#define MDSCR_ENABLE_CON_REQ (1 << 15) +#define MDSCR_CON_ACK (1 << 14) +#define MDSCR_WL_EN (1 << 9) +#define CMD_NORMAL (0 << 4) +#define CMD_PRECHARGE (1 << 4) +#define CMD_AUTO_REFRESH (2 << 4) +#define CMD_LOAD_MODE_REG (3 << 4) +#define CMD_ZQ_CALIBRATION (4 << 4) +#define CMD_PRECHARGE_BANK_OPEN (5 << 4) +#define CMD_MRR (6 << 4) #define CMD_BANK_ADDR_0 0x0 #define CMD_BANK_ADDR_1 0x1 #define CMD_BANK_ADDR_2 0x2 @@ -73,8 +49,19 @@ #define CMD_BANK_ADDR_6 0x6 #define CMD_BANK_ADDR_7 0x7
+/* MMDC Core Control Register (MDCTL) */ +#define MDCTL_SDE0 (1 << 31) +#define MDCTL_SDE1 (1 << 30) + +/* MMDC PHY ZQ HW control register (MMDC_MPZQHWCTRL) */ +#define MPZQHWCTRL_ZQ_HW_FORCE (1 << 16) + +/* MMDC PHY Measure Unit Register (MMDC_MPMUR0) */ +#define MMDC_MPMUR0_FRC_MSR (1 << 11) + + /* MMDC Registers */ -struct mmdc_p_regs { +struct mmdc_regs { u32 mdctl; u32 mdpdc; u32 mdotc; @@ -157,4 +144,6 @@ struct mmdc_p_regs { u32 mpdccr; };
+void mmdc_init(void); + #endif /* FSL_MMDC_H */
Let's use common MMDC driver for DDR initialization on LS1012ARDB, LS1012AQDS, LS1012AFRDM boards.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com --- board/freescale/ls1012afrdm/ls1012afrdm.c | 116 ------------------------------ board/freescale/ls1012aqds/ls1012aqds.c | 116 ------------------------------ board/freescale/ls1012ardb/ls1012ardb.c | 116 ------------------------------ include/configs/ls1012afrdm.h | 23 ++++-- include/configs/ls1012aqds.h | 24 ++++++- include/configs/ls1012ardb.h | 22 ++++-- 6 files changed, 57 insertions(+), 360 deletions(-)
diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index a94a458..0bbb558 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -18,20 +18,6 @@
DECLARE_GLOBAL_DATA_PTR;
-static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) -{ - int timeout = 1000; - - out_be32(ptr, value); - - while (in_be32(ptr) & bits) { - udelay(100); - timeout--; - } - if (timeout <= 0) - puts("Error: wait for clear timeout.\n"); -} - int checkboard(void) { puts("Board: LS1012AFRDM "); @@ -39,108 +25,6 @@ int checkboard(void) return 0; }
-void mmdc_init(void) -{ - struct mmdc_p_regs *mmdc = - (struct mmdc_p_regs *)CONFIG_SYS_FSL_DDR_ADDR; - - out_be32(&mmdc->mdscr, CONFIGURATION_REQ); - - /* configure timing parms */ - out_be32(&mmdc->mdotc, CONFIG_SYS_MMDC_CORE_ODT_TIMING); - out_be32(&mmdc->mdcfg0, CONFIG_SYS_MMDC_CORE_TIMING_CFG_0); - out_be32(&mmdc->mdcfg1, CONFIG_SYS_MMDC_CORE_TIMING_CFG_1); - out_be32(&mmdc->mdcfg2, CONFIG_SYS_MMDC_CORE_TIMING_CFG_2); - - /* other parms */ - out_be32(&mmdc->mdmisc, CONFIG_SYS_MMDC_CORE_MISC); - out_be32(&mmdc->mpmur0, CONFIG_SYS_MMDC_PHY_MEASURE_UNIT); - out_be32(&mmdc->mdrwd, CONFIG_SYS_MMDC_CORE_RDWR_CMD_DELAY); - out_be32(&mmdc->mpodtctrl, CONFIG_SYS_MMDC_PHY_ODT_CTRL); - - /* out of reset delays */ - out_be32(&mmdc->mdor, CONFIG_SYS_MMDC_CORE_OUT_OF_RESET_DELAY); - - /* physical parms */ - out_be32(&mmdc->mdctl, CONFIG_SYS_MMDC_CORE_CONTROL_1); - out_be32(&mmdc->mdasp, CONFIG_SYS_MMDC_CORE_ADDR_PARTITION); - - /* Enable MMDC */ - out_be32(&mmdc->mdctl, CONFIG_SYS_MMDC_CORE_CONTROL_2); - - /* dram init sequence: update MRs */ - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x8) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_2)); - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x19) | - CMD_ADDR_LSB_MR_ADDR(0x30) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_0)); - - /* dram init sequence: ZQCL */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_ZQ_CALIBRATION | CMD_BANK_ADDR_0)); - set_wait_for_bits_clear(&mmdc->mpzqhwctrl, - CONFIG_SYS_MMDC_PHY_ZQ_HW_CTRL, - FORCE_ZQ_AUTO_CALIBRATION); - - /* Calibrations now: wr lvl */ - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x84) | - CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | WL_EN | CMD_NORMAL)); - set_wait_for_bits_clear(&mmdc->mpwlgcr, WR_LVL_HW_EN, WR_LVL_HW_EN); - - mdelay(1); - - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, CONFIGURATION_REQ); - - mdelay(1); - - /* Calibrations now: Read DQS gating calibration */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3)); - out_be32(&mmdc->mppdcmpr2, MPR_COMPARE_EN); - out_be32(&mmdc->mprddlctl, CONFIG_SYS_MMDC_PHY_RD_DLY_LINES_CFG); - set_wait_for_bits_clear(&mmdc->mpdgctrl0, - AUTO_RD_DQS_GATING_CALIBRATION_EN, - AUTO_RD_DQS_GATING_CALIBRATION_EN); - - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - - /* Calibrations now: Read calibration */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3)); - out_be32(&mmdc->mppdcmpr2, MPR_COMPARE_EN); - set_wait_for_bits_clear(&mmdc->mprddlhwctl, - AUTO_RD_CALIBRATION_EN, - AUTO_RD_CALIBRATION_EN); - - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - - /* PD, SR */ - out_be32(&mmdc->mdpdc, CONFIG_SYS_MMDC_CORE_PWR_DOWN_CTRL); - out_be32(&mmdc->mapsr, CONFIG_SYS_MMDC_CORE_PWR_SAV_CTRL_STAT); - - /* refresh scheme */ - set_wait_for_bits_clear(&mmdc->mdref, - CONFIG_SYS_MMDC_CORE_REFRESH_CTL, - START_REFRESH); - - /* disable CON_REQ */ - out_be32(&mmdc->mdscr, DISABLE_CFG_REQ); -} - int dram_init(void) { mmdc_init(); diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 71eea82..392b6c2 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -28,20 +28,6 @@
-static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) -{ - int timeout = 1000; - - out_be32(ptr, value); - - while (in_be32(ptr) & bits) { - udelay(100); - timeout--; - } - if (timeout <= 0) - puts("Error: wait for clear timeout.\n"); -} - int checkboard(void) { char buf[64]; @@ -67,108 +53,6 @@ int checkboard(void) return 0; }
-void mmdc_init(void) -{ - struct mmdc_p_regs *mmdc = - (struct mmdc_p_regs *)CONFIG_SYS_FSL_DDR_ADDR; - - out_be32(&mmdc->mdscr, CONFIGURATION_REQ); - - /* configure timing parms */ - out_be32(&mmdc->mdotc, CONFIG_SYS_MMDC_CORE_ODT_TIMING); - out_be32(&mmdc->mdcfg0, CONFIG_SYS_MMDC_CORE_TIMING_CFG_0); - out_be32(&mmdc->mdcfg1, CONFIG_SYS_MMDC_CORE_TIMING_CFG_1); - out_be32(&mmdc->mdcfg2, CONFIG_SYS_MMDC_CORE_TIMING_CFG_2); - - /* other parms */ - out_be32(&mmdc->mdmisc, CONFIG_SYS_MMDC_CORE_MISC); - out_be32(&mmdc->mpmur0, CONFIG_SYS_MMDC_PHY_MEASURE_UNIT); - out_be32(&mmdc->mdrwd, CONFIG_SYS_MMDC_CORE_RDWR_CMD_DELAY); - out_be32(&mmdc->mpodtctrl, CONFIG_SYS_MMDC_PHY_ODT_CTRL); - - /* out of reset delays */ - out_be32(&mmdc->mdor, CONFIG_SYS_MMDC_CORE_OUT_OF_RESET_DELAY); - - /* physical parms */ - out_be32(&mmdc->mdctl, CONFIG_SYS_MMDC_CORE_CONTROL_1); - out_be32(&mmdc->mdasp, CONFIG_SYS_MMDC_CORE_ADDR_PARTITION); - - /* Enable MMDC */ - out_be32(&mmdc->mdctl, CONFIG_SYS_MMDC_CORE_CONTROL_2); - - /* dram init sequence: update MRs */ - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x8) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_2)); - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x19) | - CMD_ADDR_LSB_MR_ADDR(0x30) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_0)); - - /* dram init sequence: ZQCL */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_ZQ_CALIBRATION | CMD_BANK_ADDR_0)); - set_wait_for_bits_clear(&mmdc->mpzqhwctrl, - CONFIG_SYS_MMDC_PHY_ZQ_HW_CTRL, - FORCE_ZQ_AUTO_CALIBRATION); - - /* Calibrations now: wr lvl */ - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x84) | - CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | WL_EN | CMD_NORMAL)); - set_wait_for_bits_clear(&mmdc->mpwlgcr, WR_LVL_HW_EN, WR_LVL_HW_EN); - - mdelay(1); - - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, CONFIGURATION_REQ); - - mdelay(1); - - /* Calibrations now: Read DQS gating calibration */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3)); - out_be32(&mmdc->mppdcmpr2, MPR_COMPARE_EN); - out_be32(&mmdc->mprddlctl, CONFIG_SYS_MMDC_PHY_RD_DLY_LINES_CFG); - set_wait_for_bits_clear(&mmdc->mpdgctrl0, - AUTO_RD_DQS_GATING_CALIBRATION_EN, - AUTO_RD_DQS_GATING_CALIBRATION_EN); - - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - - /* Calibrations now: Read calibration */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3)); - out_be32(&mmdc->mppdcmpr2, MPR_COMPARE_EN); - set_wait_for_bits_clear(&mmdc->mprddlhwctl, - AUTO_RD_CALIBRATION_EN, - AUTO_RD_CALIBRATION_EN); - - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - - /* PD, SR */ - out_be32(&mmdc->mdpdc, CONFIG_SYS_MMDC_CORE_PWR_DOWN_CTRL); - out_be32(&mmdc->mapsr, CONFIG_SYS_MMDC_CORE_PWR_SAV_CTRL_STAT); - - /* refresh scheme */ - set_wait_for_bits_clear(&mmdc->mdref, - CONFIG_SYS_MMDC_CORE_REFRESH_CTL, - START_REFRESH); - - /* disable CON_REQ */ - out_be32(&mmdc->mdscr, DISABLE_CFG_REQ); -} - int dram_init(void) { mmdc_init(); diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index f69768d..80426f6 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -22,20 +22,6 @@
-static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) -{ - int timeout = 1000; - - out_be32(ptr, value); - - while (in_be32(ptr) & bits) { - udelay(100); - timeout--; - } - if (timeout <= 0) - puts("Error: wait for clear timeout.\n"); -} - int checkboard(void) { u8 in1; @@ -71,108 +57,6 @@ int checkboard(void) return 0; }
-void mmdc_init(void) -{ - struct mmdc_p_regs *mmdc = - (struct mmdc_p_regs *)CONFIG_SYS_FSL_DDR_ADDR; - - out_be32(&mmdc->mdscr, CONFIGURATION_REQ); - - /* configure timing parms */ - out_be32(&mmdc->mdotc, CONFIG_SYS_MMDC_CORE_ODT_TIMING); - out_be32(&mmdc->mdcfg0, CONFIG_SYS_MMDC_CORE_TIMING_CFG_0); - out_be32(&mmdc->mdcfg1, CONFIG_SYS_MMDC_CORE_TIMING_CFG_1); - out_be32(&mmdc->mdcfg2, CONFIG_SYS_MMDC_CORE_TIMING_CFG_2); - - /* other parms */ - out_be32(&mmdc->mdmisc, CONFIG_SYS_MMDC_CORE_MISC); - out_be32(&mmdc->mpmur0, CONFIG_SYS_MMDC_PHY_MEASURE_UNIT); - out_be32(&mmdc->mdrwd, CONFIG_SYS_MMDC_CORE_RDWR_CMD_DELAY); - out_be32(&mmdc->mpodtctrl, CONFIG_SYS_MMDC_PHY_ODT_CTRL); - - /* out of reset delays */ - out_be32(&mmdc->mdor, CONFIG_SYS_MMDC_CORE_OUT_OF_RESET_DELAY); - - /* physical parms */ - out_be32(&mmdc->mdctl, CONFIG_SYS_MMDC_CORE_CONTROL_1); - out_be32(&mmdc->mdasp, CONFIG_SYS_MMDC_CORE_ADDR_PARTITION); - - /* Enable MMDC */ - out_be32(&mmdc->mdctl, CONFIG_SYS_MMDC_CORE_CONTROL_2); - - /* dram init sequence: update MRs */ - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x8) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_2)); - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x19) | - CMD_ADDR_LSB_MR_ADDR(0x30) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_0)); - - /* dram init sequence: ZQCL */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_ZQ_CALIBRATION | CMD_BANK_ADDR_0)); - set_wait_for_bits_clear(&mmdc->mpzqhwctrl, - CONFIG_SYS_MMDC_PHY_ZQ_HW_CTRL, - FORCE_ZQ_AUTO_CALIBRATION); - - /* Calibrations now: wr lvl */ - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x84) | - CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | WL_EN | CMD_NORMAL)); - set_wait_for_bits_clear(&mmdc->mpwlgcr, WR_LVL_HW_EN, WR_LVL_HW_EN); - - mdelay(1); - - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_1)); - out_be32(&mmdc->mdscr, CONFIGURATION_REQ); - - mdelay(1); - - /* Calibrations now: Read DQS gating calibration */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3)); - out_be32(&mmdc->mppdcmpr2, MPR_COMPARE_EN); - out_be32(&mmdc->mprddlctl, CONFIG_SYS_MMDC_PHY_RD_DLY_LINES_CFG); - set_wait_for_bits_clear(&mmdc->mpdgctrl0, - AUTO_RD_DQS_GATING_CALIBRATION_EN, - AUTO_RD_DQS_GATING_CALIBRATION_EN); - - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - - /* Calibrations now: Read calibration */ - out_be32(&mmdc->mdscr, (CMD_ADDR_MSB_MR_OP(0x4) | CONFIGURATION_REQ | - CMD_PRECHARGE_BANK_OPEN | CMD_BANK_ADDR_0)); - out_be32(&mmdc->mdscr, (CMD_ADDR_LSB_MR_ADDR(0x4) | CONFIGURATION_REQ | - CMD_LOAD_MODE_REG | CMD_BANK_ADDR_3)); - out_be32(&mmdc->mppdcmpr2, MPR_COMPARE_EN); - set_wait_for_bits_clear(&mmdc->mprddlhwctl, - AUTO_RD_CALIBRATION_EN, - AUTO_RD_CALIBRATION_EN); - - out_be32(&mmdc->mdscr, (CONFIGURATION_REQ | CMD_LOAD_MODE_REG | - CMD_BANK_ADDR_3)); - - /* PD, SR */ - out_be32(&mmdc->mdpdc, CONFIG_SYS_MMDC_CORE_PWR_DOWN_CTRL); - out_be32(&mmdc->mapsr, CONFIG_SYS_MMDC_CORE_PWR_SAV_CTRL_STAT); - - /* refresh scheme */ - set_wait_for_bits_clear(&mmdc->mdref, - CONFIG_SYS_MMDC_CORE_REFRESH_CTL, - START_REFRESH); - - /* disable CON_REQ */ - out_be32(&mmdc->mdscr, DISABLE_CFG_REQ); -} - int dram_init(void) { mmdc_init(); diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index ad81142..dd77bc1 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -9,19 +9,34 @@
#include "ls1012a_common.h"
+/* DDR */ #define CONFIG_DIMM_SLOTS_PER_CTLR 1 #define CONFIG_CHIP_SELECTS_PER_CTRL 1 #define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_SIZE 0x20000000 - -#define CONFIG_SYS_MMDC_CORE_CONTROL_1 0x04180000 -#define CONFIG_SYS_MMDC_CORE_CONTROL_2 0x84180000 - +#define CONFIG_CHIP_SELECTS_PER_CTRL 1 #define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
+/* DDR board-specific timing parameters */ +#define CONFIG_MMDC_MDCTL 0x04180000 +#define CONFIG_MMDC_MDPDC 0x00030035 +#define CONFIG_MMDC_MDOTC 0x12554000 +#define CONFIG_MMDC_MDCFG0 0xbabf7954 +#define CONFIG_MMDC_MDCFG1 0xff328f64 +#define CONFIG_MMDC_MDCFG2 0x01ff00db +#define CONFIG_MMDC_MDMISC 0x00001680 +#define CONFIG_MMDC_MDREF 0x0f3c8000 +#define CONFIG_MMDC_MDRWD 0x00002000 +#define CONFIG_MMDC_MDOR 0x00bf1023 +#define CONFIG_MMDC_MDASP 0x0000007f +#define CONFIG_MMDC_MPODTCTRL 0x0000022a +#define CONFIG_MMDC_MPZQHWCTRL 0xa1390003 +#define CONFIG_MMDC_MPRDDLCTL 0x40404040 + + /* * USB */ diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 6e31ca0..08f1117 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -9,14 +9,32 @@
- +/* DDR */ #define CONFIG_DIMM_SLOTS_PER_CTLR 1 #define CONFIG_CHIP_SELECTS_PER_CTRL 1 #define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_SIZE 0x40000000 +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +/* DDR board-specific timing parameters */ +#define CONFIG_MMDC_MDCTL 0x05180000 +#define CONFIG_MMDC_MDPDC 0x00030035 +#define CONFIG_MMDC_MDOTC 0x12554000 +#define CONFIG_MMDC_MDCFG0 0xbabf7954 +#define CONFIG_MMDC_MDCFG1 0xff328f64 +#define CONFIG_MMDC_MDCFG2 0x01ff00db +#define CONFIG_MMDC_MDMISC 0x00001680 +#define CONFIG_MMDC_MDREF 0x0f3c8000 +#define CONFIG_MMDC_MDRWD 0x00002000 +#define CONFIG_MMDC_MDOR 0x00bf1023 +#define CONFIG_MMDC_MDASP 0x0000007f +#define CONFIG_MMDC_MPODTCTRL 0x0000022a +#define CONFIG_MMDC_MPZQHWCTRL 0xa1390003 +#define CONFIG_MMDC_MPRDDLCTL 0x40404040
-#define CONFIG_SYS_MMDC_CORE_CONTROL_1 0x05180000 -#define CONFIG_SYS_MMDC_CORE_CONTROL_2 0x85180000
/* * QIXIS Definitions diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 6046ab7..7c7d868 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -9,20 +9,32 @@
- +/* DDR */ #define CONFIG_DIMM_SLOTS_PER_CTLR 1 #define CONFIG_CHIP_SELECTS_PER_CTRL 1 #define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_SIZE 0x40000000 - -#define CONFIG_SYS_MMDC_CORE_CONTROL_1 0x05180000 -#define CONFIG_SYS_MMDC_CORE_CONTROL_2 0x85180000 - #define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
+/* DDR board-specific timing parameters */ +#define CONFIG_MMDC_MDCTL 0x05180000 +#define CONFIG_MMDC_MDPDC 0x00030035 +#define CONFIG_MMDC_MDOTC 0x12554000 +#define CONFIG_MMDC_MDCFG0 0xbabf7954 +#define CONFIG_MMDC_MDCFG1 0xff328f64 +#define CONFIG_MMDC_MDCFG2 0x01ff00db +#define CONFIG_MMDC_MDMISC 0x00001680 +#define CONFIG_MMDC_MDREF 0x0f3c8000 +#define CONFIG_MMDC_MDRWD 0x00002000 +#define CONFIG_MMDC_MDOR 0x00bf1023 +#define CONFIG_MMDC_MDASP 0x0000007f +#define CONFIG_MMDC_MPODTCTRL 0x0000022a +#define CONFIG_MMDC_MPZQHWCTRL 0xa1390003 +#define CONFIG_MMDC_MPRDDLCTL 0x40404040 + /* * USB */
Let's revert this logic, shall we?
- Copyright 2016 Freescale Semiconductor, Inc.
I think we should use NXP now.
- Generic driver for Freescale MMDC(Multi Mode DDR Controller).
udelay(100);
timeout--;
- if (timeout <= 0)
- struct mmdc_regs *mmdc = (struct mmdc_regs *)CONFIG_SYS_FSL_DDR_ADDR;
- unsigned int tmp;
- /* 1. set configuration request */
- out_be32(&mmdc->mdscr, MDSCR_ENABLE_CON_REQ);
- /* 2. configure the desired timing parameters */
- out_be32(&mmdc->mdotc, CONFIG_MMDC_MDOTC);
- out_be32(&mmdc->mdcfg0, CONFIG_MMDC_MDCFG0);
- out_be32(&mmdc->mdcfg1, CONFIG_MMDC_MDCFG1);
- out_be32(&mmdc->mdcfg2, CONFIG_MMDC_MDCFG2);
- /* 3. configure DDR type and other miscellaneous parameters */
- out_be32(&mmdc->mdmisc, CONFIG_MMDC_MDMISC);
- out_be32(&mmdc->mpmur0, MMDC_MPMUR0_FRC_MSR);
- out_be32(&mmdc->mdrwd, CONFIG_MMDC_MDRWD);
- out_be32(&mmdc->mpodtctrl, CONFIG_MMDC_MPODTCTRL);
- /* 4. configure the required delay while leaving reset */
- out_be32(&mmdc->mdor, CONFIG_MMDC_MDOR);
- /* 5. configure DDR physical parameters */
- /* set row/column address width, burst length, data bus width */
- tmp = CONFIG_MMDC_MDCTL & ~(MDCTL_SDE0 | MDCTL_SDE1);
- out_be32(&mmdc->mdctl, tmp);
- /* configure address space partition */
- out_be32(&mmdc->mdasp, CONFIG_MMDC_MDASP);
- /* 6. perform a ZQ calibration - not needed here, doing in #8b */
- /* 7. enable MMDC with the desired chip select */
- /* 8a. dram init sequence: update MRs for ZQ, ODT, PRE, etc */
- out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(8) | MDSCR_ENABLE_CON_REQ |
- out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(0) | MDSCR_ENABLE_CON_REQ |
- out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(4) | MDSCR_ENABLE_CON_REQ |
- out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(0x19) |
- /* 8b. ZQ calibration */
- out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(0x4) | MDSCR_ENABLE_CON_REQ |
- set_wait_for_bits_clear(&mmdc->mpzqhwctrl, CONFIG_MMDC_MPZQHWCTRL,
- /* 9a. calibrations now, wr lvl */
- out_be32(&mmdc->mdscr, CMD_ADDR_LSB_MR_ADDR(0x84) |
- out_be32(&mmdc->mdscr, MDSCR_ENABLE_CON_REQ | MDSCR_WL_EN |
CMD_NORMAL);
- set_wait_for_bits_clear(&mmdc->mpwlgcr, MPWLGCR_HW_WL_EN,
MPWLGCR_HW_WL_EN);
- mdelay(1);
- mdelay(1);
- /* 9b. read DQS gating calibration */
- out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(4) | MDSCR_ENABLE_CON_REQ |
- out_be32(&mmdc->mppdcmpr2, MPPDCMPR2_MPR_COMPARE_EN);
- /* set absolute read delay offset for bytes */
- out_be32(&mmdc->mprddlctl, CONFIG_MMDC_MPRDDLCTL);
- out_be32(&mmdc->mdscr, (MDSCR_ENABLE_CON_REQ | CMD_LOAD_MODE_REG |
CMD_BANK_ADDR_3));
- /* 9c. read calibration */
CMD_BANK_ADDR_3));
- /* 10. configure power-down, self-refresh entry, exit parameters */
- out_be32(&mmdc->mdpdc, CONFIG_MMDC_MDPDC);
- out_be32(&mmdc->mapsr, MMDC_MAPSR_PWR_SAV_CTRL_STAT);
- /* 11. ZQ config again? do nothing here */
- /* 12. refresh scheme */
- set_wait_for_bits_clear(&mmdc->mdref, CONFIG_MMDC_MDREF,
- /* 13. disable CON_REQ */
- out_be32(&mmdc->mdscr, MDSCR_DISABLE_CFG_REQ);
Removing those macros causes compiling error for ls1012afrdm_qspi ls1012aqds_qspi ls1012ardb_qspi. Please rearrange the change.
York
-----Original Message----- From: york sun Sent: Friday, August 12, 2016 3:45 AM To: Shengzhou Liu shengzhou.liu@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH 1/2] driver/ddr/fsl: Add general MMDC driver
York
Why do you want to remove those macros? They are needed and useful, I compiled it for ls1012a QDS/ RDB/FRDM without any issue, and worked fine on boards.
Shengzhou
I am not suggesting remove the macros. Please try to compile after applying first patch. You will see the errors
York
-------- Original Message -------- From: Shengzhou Liu shengzhou.liu@nxp.com Sent: Thursday, August 11, 2016 08:44 PM To: york sun york.sun@nxp.com,u-boot@lists.denx.de Subject: RE: [PATCH 1/2] driver/ddr/fsl: Add general MMDC driver
York
Shengzhou
It needs to apply both patches before compiling. The second patch will remove the old board level code and apply common mmdc driver. I understand that in theory we should keep every single patch is compileable, but to make it clean to customer I separated them to two patches. Do I really need to combine the two to one patch?
Shengzhou
From: york sun Sent: Friday, August 12, 2016 1:56 PM To: Shengzhou Liu shengzhou.liu@nxp.com; u-boot@lists.denx.de Subject: RE: [PATCH 1/2] driver/ddr/fsl: Add general MMDC driver
York
Shengzhou Liu
Shengzhou Liu
york sun
