RE: [U-Boot-Users] Intel Strataflash in 8-bit mode
Brad Kemp wrote:
All the drivers are derived from my original strataflash driver. There is a problem with 8bit wide detection in the flash_cfi_detect routine. The work around is to hardcode the port width after flash_cfi_detect is called. I believe I understand the problem, but I have no access to 8bit hardware. If some one is willing to help debug the problem with 8 bit wide protection, I will take on fixing the strataflash driver and moving it to the drivers directory. This driver does include support for 64 bit wide flash and access to the write once areas. Is anyone willing and able to work with me? Brad
As mentioned in the orginal post, I have a system based on MPC8245 that uses Intel 28F640J3A in 8-bit mode. I am willing to assist with debugging and testing.
Rune Raknerud
Rune Raknerud
