[PATCH 1/2] lmb: Fix lmb_add_region_flags() return codes and testing
The function description says this should return 0 or -1 on failures. When regions coalesce though this returns the number of coalescedregions which is confusing and requires special handling of the return code. On top of that no one is using the number of coalesced regions.
So let's just return 0 on success and adjust our selftests accordingly
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- boot/image-fdt.c | 2 +- lib/lmb.c | 10 +++++----- test/lib/lmb.c | 10 +++++----- 3 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/boot/image-fdt.c b/boot/image-fdt.c index 8eda521693dc..eac09059d955 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -73,7 +73,7 @@ static void boot_fdt_reserve_region(u64 addr, u64 size, enum lmb_flags flags) long ret;
ret = lmb_reserve_flags(addr, size, flags); - if (ret >= 0) { + if (!ret) { debug(" reserving fdt memory region: addr=%llx size=%llx flags=%x\n", (unsigned long long)addr, (unsigned long long)size, flags); diff --git a/lib/lmb.c b/lib/lmb.c index 7e90f178763b..8ce58fcb9224 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -450,7 +450,7 @@ static long lmb_add_region_flags(struct alist *lmb_rgn_lst, phys_addr_t base, }
if (coalesced) - return coalesced; + return 0;
if (alist_full(lmb_rgn_lst) && !alist_expand_by(lmb_rgn_lst, lmb_rgn_lst->alloc)) @@ -487,7 +487,7 @@ long lmb_add(phys_addr_t base, phys_size_t size) struct alist *lmb_rgn_lst = &lmb.free_mem;
ret = lmb_add_region(lmb_rgn_lst, base, size); - if (ret < 0) + if (ret) return ret;
if (lmb_should_notify(LMB_NONE)) @@ -583,8 +583,8 @@ long lmb_reserve_flags(phys_addr_t base, phys_size_t size, enum lmb_flags flags) struct alist *lmb_rgn_lst = &lmb.used_mem;
ret = lmb_add_region_flags(lmb_rgn_lst, base, size, flags); - if (ret < 0) - return -1; + if (ret) + return ret;
if (lmb_should_notify(flags)) return lmb_map_update_notify(base, size, MAP_OP_RESERVE); @@ -651,7 +651,7 @@ static phys_addr_t _lmb_alloc_base(phys_size_t size, ulong align, if (rgn < 0) { /* This area isn't reserved, take it */ if (lmb_add_region_flags(&lmb.used_mem, base, - size, flags) < 0) + size, flags)) return 0;
if (lmb_should_notify(flags)) { diff --git a/test/lib/lmb.c b/test/lib/lmb.c index b2c54fb4bcb8..c917115b7b66 100644 --- a/test/lib/lmb.c +++ b/test/lib/lmb.c @@ -473,7 +473,7 @@ static int lib_test_lmb_overlapping_reserve(struct unit_test_state *uts)
/* allocate overlapping region should return the coalesced count */ ret = lmb_reserve(0x40011000, 0x10000); - ut_asserteq(ret, 1); + ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x11000, 0, 0, 0, 0); /* allocate 3nd region */ @@ -748,13 +748,13 @@ static int lib_test_lmb_flags(struct unit_test_state *uts)
/* merge after */ ret = lmb_reserve_flags(0x40020000, 0x10000, LMB_NOMAP); - ut_asserteq(ret, 1); + ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x20000, 0, 0, 0, 0);
/* merge before */ ret = lmb_reserve_flags(0x40000000, 0x10000, LMB_NOMAP); - ut_asserteq(ret, 1); + ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40000000, 0x30000, 0, 0, 0, 0);
@@ -770,7 +770,7 @@ static int lib_test_lmb_flags(struct unit_test_state *uts)
/* test that old API use LMB_NONE */ ret = lmb_reserve(0x40040000, 0x10000); - ut_asserteq(ret, 1); + ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, 0x40000000, 0x30000, 0x40030000, 0x20000, 0, 0);
@@ -789,7 +789,7 @@ static int lib_test_lmb_flags(struct unit_test_state *uts)
/* merge with 2 adjacent regions */ ret = lmb_reserve_flags(0x40060000, 0x10000, LMB_NOMAP); - ut_asserteq(ret, 2); + ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 3, 0x40000000, 0x30000, 0x40030000, 0x20000, 0x40050000, 0x30000);
We never call lmb_map_update_notify() without checking the result of lmb_should_notify(). Instead of running that function everytime fold it in there and add the additional flags parameter
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/lmb.c | 37 ++++++++++++++----------------------- 1 file changed, 14 insertions(+), 23 deletions(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 8ce58fcb9224..69001ad57373 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -40,7 +40,7 @@ static bool lmb_should_notify(enum lmb_flags flags)
static int __maybe_unused lmb_map_update_notify(phys_addr_t addr, phys_size_t size, - u8 op) + u8 op, enum lmb_flags flags) { u64 efi_addr; u64 pages; @@ -51,6 +51,9 @@ static int __maybe_unused lmb_map_update_notify(phys_addr_t addr, return -1; }
+ if (!lmb_should_notify(flags)) + return 0; + efi_addr = (uintptr_t)map_sysmem(addr, 0); pages = efi_size_in_pages(size + (efi_addr & EFI_PAGE_MASK)); efi_addr &= ~EFI_PAGE_MASK; @@ -64,9 +67,9 @@ static int __maybe_unused lmb_map_update_notify(phys_addr_t addr, log_err("%s: LMB Map notify failure %lu\n", __func__, status & ~EFI_ERROR_MASK); return -1; - } else { - return 0; } + + return 0; }
static void lmb_print_region_flags(enum lmb_flags flags) @@ -490,10 +493,7 @@ long lmb_add(phys_addr_t base, phys_size_t size) if (ret) return ret;
- if (lmb_should_notify(LMB_NONE)) - return lmb_map_update_notify(base, size, MAP_OP_ADD); - - return 0; + return lmb_map_update_notify(base, size, MAP_OP_ADD, LMB_NONE); }
static long _lmb_free(phys_addr_t base, phys_size_t size) @@ -566,10 +566,7 @@ long lmb_free_flags(phys_addr_t base, phys_size_t size, if (ret < 0) return ret;
- if (lmb_should_notify(flags)) - return lmb_map_update_notify(base, size, MAP_OP_FREE); - - return ret; + return lmb_map_update_notify(base, size, MAP_OP_FREE, flags); }
long lmb_free(phys_addr_t base, phys_size_t size) @@ -586,10 +583,7 @@ long lmb_reserve_flags(phys_addr_t base, phys_size_t size, enum lmb_flags flags) if (ret) return ret;
- if (lmb_should_notify(flags)) - return lmb_map_update_notify(base, size, MAP_OP_RESERVE); - - return ret; + return lmb_map_update_notify(base, size, MAP_OP_RESERVE, flags); }
long lmb_reserve(phys_addr_t base, phys_size_t size) @@ -621,7 +615,6 @@ static phys_addr_t lmb_align_down(phys_addr_t addr, phys_size_t size) static phys_addr_t _lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr, enum lmb_flags flags) { - u8 op; int ret; long i, rgn; phys_addr_t base = 0; @@ -654,13 +647,11 @@ static phys_addr_t _lmb_alloc_base(phys_size_t size, ulong align, size, flags)) return 0;
- if (lmb_should_notify(flags)) { - op = MAP_OP_RESERVE; - ret = lmb_map_update_notify(base, size, - op); - if (ret) - return ret; - } + ret = lmb_map_update_notify(base, size, + MAP_OP_RESERVE, + flags); + if (ret) + return ret;
return base; }
Hi Ilias,
* coalesced regions
Thanks for following up on this!
Reviewed-by: Caleb Connolly caleb.connolly@linaro.org
- if (ret >= 0) {
- if (!ret) { debug(" reserving fdt memory region: addr=%llx size=%llx flags=%x\n", (unsigned long long)addr, (unsigned long long)size, flags);
if (coalesced)
return coalesced;
- if (ret < 0)
- if (ret < 0)
return -1;
if (ret)
return ret;
size, flags) < 0)
size, flags)) return 0; if (lmb_should_notify(flags)) {
- ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x11000, 0, 0, 0, 0); /* allocate 3nd region */
- ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40000000, 0x30000, 0, 0, 0, 0);
- ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, 0x40000000, 0x30000, 0x40030000, 0x20000, 0, 0);
- ut_asserteq(ret, 0); ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 3, 0x40000000, 0x30000, 0x40030000, 0x20000, 0x40050000, 0x30000);
Caleb Connolly
Ilias Apalodimas
