[U-Boot-Users] Fix for MII utils
Hi there,
the attached patch addresses two MII related issues: a) mii info <addr> ignored <addr> and always showed info for 32 PHYs b) The "Trick" mentioned in miiphy_info(): " * Trick: we are reading two 16 registers into a 32 bit variable * so we do a 16 read into the high order bits of the variable (big * endian, you know), shift it down 16 bits, and the read the rest." does obviously not work on little endian machines.
* Patch by Steven Scholz, 20 Oct 2003 - "mii info <addr>" now only shows the info for PHY "addr" as the help message already suggests - Endian fix for miiphy_info()
Thanks,
Steven
I wrote:
- Patch by Steven Scholz, 20 Oct 2003
:-( Stupip Netscape... Patch attached now.
Steven
Index: common/cmd_mii.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/cmd_mii.c,v retrieving revision 1.4 diff -p -u -r1.4 cmd_mii.c --- common/cmd_mii.c 1 Jul 2003 21:07:07 -0000 1.4 +++ common/cmd_mii.c 20 Oct 2003 16:53:16 -0000 @@ -81,7 +81,7 @@ int do_mii (cmd_tbl_t * cmdtp, int flag, * check info/read/write. */ if (op == 'i') { - int j; + unsigned char j, start, end; unsigned int oui; unsigned char model; unsigned char rev; @@ -89,7 +89,13 @@ int do_mii (cmd_tbl_t * cmdtp, int flag, /* * Look for any and all PHYs. Valid addresses are 0..31. */ - for (j = 0; j < 32; j++) { + if (argc >= 3) { + start = addr; end = addr + 1; + } else { + start = 0; end = 32; + } + + for (j = start; j < end; j++) { if (miiphy_info (j, &oui, &model, &rev) == 0) { printf ("PHY 0x%02X: " "OUI = 0x%04X, " Index: common/miiphyutil.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/miiphyutil.c,v retrieving revision 1.2 diff -p -u -r1.2 miiphyutil.c --- common/miiphyutil.c 8 Oct 2003 22:33:00 -0000 1.2 +++ common/miiphyutil.c 20 Oct 2003 16:53:16 -0000 @@ -47,19 +47,15 @@ int miiphy_info (unsigned char addr, unsigned char *model, unsigned char *rev) { unsigned int reg = 0; + unsigned short tmp;
- /* - * Trick: we are reading two 16 registers into a 32 bit variable - * so we do a 16 read into the high order bits of the variable (big - * endian, you know), shift it down 16 bits, and the read the rest. - */ - if (miiphy_read (addr, PHY_PHYIDR2, (unsigned short *) ®) != 0) { + if (miiphy_read (addr, PHY_PHYIDR2, &tmp) != 0) { #ifdef DEBUG printf ("PHY ID register 2 read failed\n"); #endif return (-1); } - reg >>= 16; + reg = tmp;
#ifdef DEBUG printf ("PHY_PHYIDR2 @ 0x%x = 0x%04x\n", addr, reg); @@ -69,12 +65,13 @@ int miiphy_info (unsigned char addr, return (-1); }
- if (miiphy_read (addr, PHY_PHYIDR1, (unsigned short *) ®) != 0) { + if (miiphy_read (addr, PHY_PHYIDR1, &tmp) != 0) { #ifdef DEBUG printf ("PHY ID register 1 read failed\n"); #endif return (-1); } + reg |= tmp << 16; #ifdef DEBUG printf ("PHY_PHYIDR[1,2] @ 0x%x = 0x%08x\n", addr, reg); #endif
Added. Sorry it took so long.
Patch missing.
Patch missing.
Hmmm. Sorry. :-(
Steven
Steven Scholz wrote:
Any comments on the patch?
int j;
unsigned int oui; unsigned char model; unsigned char rev;unsigned char j, start, end;
if (argc >= 3) {
} else {
- unsigned short tmp;
- if (miiphy_read (addr, PHY_PHYIDR2, &tmp) != 0) {
- reg >>= 16;
- reg = tmp;
- if (miiphy_read (addr, PHY_PHYIDR1, &tmp) != 0) {
- reg |= tmp << 16;
Steven Scholz
