[U-Boot] [PATCH v5 1/1] imximage: Add MX53 boot image support
This patch add the MX53 boot image support.
This patch has been tested on Freescale MX53EVK board and MX51EVK board.
Signed-off-by: Jason Liu r64343@freescale.com
--- Changes for v2: - Address the following comments from Stefano, - Get rid of #ifdef in the imximage.h and .c file and use the runtime check for imximage version - Document the IMXIMAGE_VERSION definiton in doc/README.imximage - Move mx53evk/config.mk and mx53evk/imximage.cfg to MX53EVK board support patch.
Changes for v3: - Address the following comments from Stefano, - Not change the mx51evk file. The code should take VERSION=1 as default, and we do not need to change the actual boards. - add a note in the documentation and raise an error in code if the VERSION command is read after any other suitable commands. - Change command IMXIMAGE_VERSION simply to IMAGE_VERSION - Need recognize the version directly from its structure and not storing the version into the header when do header verify and print. - Use function pointer to simpliy the code when the version of header is recognized Changes for v4: - Address the following comments from Wolfgang, - Keep the imximage_cmds table sorted, - Add braces for (expx) && (expy) gloably, - Return failure to upper call if met errors for function - Add comments for function set_dcd_rst_v1 alike, - Re-orgnize code to avoid deep nesting, Changes for v5: - Remove the blank line before the only one line statement and not using braces for the one line statment for the sake of the same coding style of this file. For example, if (!exp) return ret; --- doc/README.imximage | 12 +- tools/imximage.c | 525 +++++++++++++++++++++++++++++++++++++-------------- tools/imximage.h | 110 +++++++++-- 3 files changed, 487 insertions(+), 160 deletions(-)
diff --git a/doc/README.imximage b/doc/README.imximage index 3378f7e..c74239d 100644 --- a/doc/README.imximage +++ b/doc/README.imximage @@ -57,6 +57,13 @@ Configuration command line syntax: 2. Following are the valid command strings and associated data strings:- Command string data string -------------- ----------- + IMXIMAGE_VERSION 1/2 + 1 is for mx25/mx35/mx51 compatible, + 2 is for mx53 compatible, + others is invalid and error is generated. + This command need appear the fist before + other valid commands in configuration file. + BOOT_FROM nand/spi/sd/onenand Example: BOOT_FROM spi @@ -69,8 +76,9 @@ Configuration command line syntax: Example (write to IOMUXC): DATA 4 0x73FA88a0 0x200
-The processor support up to 60 register programming commands. An error -is generated if more commands are found in the configuration file. +The processor support up to 60 register programming commands for IMXIMAGE_VERSION 1 +and 121 register programming commands for IMXIMAGE_VERSION 2. +An error is generated if more commands are found in the configuration file.
3. All commands are optional to program.
diff --git a/tools/imximage.c b/tools/imximage.c index 39f89c2..8e81bdb 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -36,9 +36,10 @@ * Supported commands for configuration file */ static table_entry_t imximage_cmds[] = { - {CMD_BOOT_FROM, "BOOT_FROM", "boot command", }, - {CMD_DATA, "DATA", "Reg Write Data", }, - {-1, "", "", }, + {CMD_BOOT_FROM, "BOOT_FROM", "boot command", }, + {CMD_DATA, "DATA", "Reg Write Data", }, + {CMD_IMAGE_VERSION, "IMAGE_VERSION", "image version", }, + {-1, "", "", }, };
/* @@ -53,8 +54,21 @@ static table_entry_t imximage_bootops[] = { {-1, "", "Invalid", }, };
+/* + * IMXIMAGE version definition for i.MX chips + */ +static table_entry_t imximage_versions[] = { + {IMXIMAGE_V1, "", " (i.MX25/35/51 compatible)", }, + {IMXIMAGE_V2, "", " (i.MX53 compatible)", }, + {-1, "", " (Invalid)", }, +};
static struct imx_header imximage_header; +static uint32_t imximage_version; + +static set_dcd_val_t set_dcd_val; +static set_dcd_rst_t set_dcd_rst; +static set_imx_hdr_t set_imx_hdr;
static uint32_t get_cfg_value(char *token, char *name, int linenr) { @@ -71,67 +85,353 @@ static uint32_t get_cfg_value(char *token, char *name, int linenr) return value; }
-static int imximage_check_image_types(uint8_t type) +static uint32_t detect_imximage_version(struct imx_header *imx_hdr) { - if (type == IH_TYPE_IMXIMAGE) - return EXIT_SUCCESS; - else - return EXIT_FAILURE; + imx_header_v1_t *hdr_v1 = &imx_hdr->header.hdr_v1; + imx_header_v2_t *hdr_v2 = &imx_hdr->header.hdr_v2; + flash_header_v1_t *fhdr_v1 = &hdr_v1->fhdr; + flash_header_v2_t *fhdr_v2 = &hdr_v2->fhdr; + + /* Try to detect V1 */ + if ((fhdr_v1->app_code_barker == APP_CODE_BARKER) && + (hdr_v1->dcd_table.preamble.barker == DCD_BARKER)) + return IMXIMAGE_V1; + + /* Try to detect V2 */ + if ((fhdr_v2->header.tag == IVT_HEADER_TAG) && + (hdr_v2->dcd_table.header.tag == DCD_HEADER_TAG)) + return IMXIMAGE_V2; + + return IMXIMAGE_VER_INVALID; }
-static int imximage_verify_header(unsigned char *ptr, int image_size, - struct mkimage_params *params) +static void err_imximage_version(int version) { + fprintf(stderr, + "Error: Unsupported imximage version:%d\n", version);
- struct imx_header *imx_hdr = (struct imx_header *) ptr; - flash_header_t *hdr = &imx_hdr->fhdr; + exit(EXIT_FAILURE); +}
- /* Only a few checks can be done: search for magic numbers */ - if (hdr->app_code_barker != APP_CODE_BARKER) - return -FDT_ERR_BADSTRUCTURE; +static void set_dcd_val_v1(struct imx_header *imxhdr, char *name, int lineno, + int fld, uint32_t value, uint32_t off) +{ + dcd_v1_t *dcd_v1 = &imxhdr->header.hdr_v1.dcd_table; + + switch (fld) { + case CFG_REG_SIZE: + /* Byte, halfword, word */ + if ((value != 1) && (value != 2) && (value != 4)) { + fprintf(stderr, "Error: %s[%d] - " + "Invalid register size " "(%d)\n", + name, lineno, value); + exit(EXIT_FAILURE); + } + dcd_v1->addr_data[off].type = value; + break; + case CFG_REG_ADDRESS: + dcd_v1->addr_data[off].addr = value; + break; + case CFG_REG_VALUE: + dcd_v1->addr_data[off].value = value; + break; + default: + break;
- if (imx_hdr->dcd_table.preamble.barker != DCD_BARKER) - return -FDT_ERR_BADSTRUCTURE; + } +}
- return 0; +static void set_dcd_val_v2(struct imx_header *imxhdr, char *name, int lineno, + int fld, uint32_t value, uint32_t off) +{ + dcd_v2_t *dcd_v2 = &imxhdr->header.hdr_v2.dcd_table; + + switch (fld) { + case CFG_REG_ADDRESS: + dcd_v2->addr_data[off].addr = cpu_to_be32(value); + break; + case CFG_REG_VALUE: + dcd_v2->addr_data[off].value = cpu_to_be32(value); + break; + default: + break; + + } }
-static void imximage_print_header(const void *ptr) +/* + * Complete setting up the rest field of DCD of V1 + * such as barker code and DCD data length. + */ +static void set_dcd_rst_v1(struct imx_header *imxhdr, uint32_t dcd_len, + char *name, int lineno) { - struct imx_header *imx_hdr = (struct imx_header *) ptr; - flash_header_t *hdr = &imx_hdr->fhdr; - uint32_t size; - uint32_t length; - dcd_t *dcd = &imx_hdr->dcd_table; + dcd_v1_t *dcd_v1 = &imxhdr->header.hdr_v1.dcd_table; + + if (dcd_len > MAX_HW_CFG_SIZE_V1) { + fprintf(stderr, "Error: %s[%d] -" + "DCD table exceeds maximum size(%d)\n", + name, lineno, MAX_HW_CFG_SIZE_V1); + exit(EXIT_FAILURE); + } + + dcd_v1->preamble.barker = DCD_BARKER; + dcd_v1->preamble.length = dcd_len * sizeof(dcd_type_addr_data_t); +} + +/* + * Complete setting up the reset field of DCD of V2 + * such as DCD tag, version, length, etc. + */ +static void set_dcd_rst_v2(struct imx_header *imxhdr, uint32_t dcd_len, + char *name, int lineno) +{ + dcd_v2_t *dcd_v2 = &imxhdr->header.hdr_v2.dcd_table; + + if (dcd_len > MAX_HW_CFG_SIZE_V2) { + fprintf(stderr, "Error: %s[%d] -" + "DCD table exceeds maximum size(%d)\n", + name, lineno, MAX_HW_CFG_SIZE_V2); + exit(EXIT_FAILURE); + } + + dcd_v2->header.tag = DCD_HEADER_TAG; + dcd_v2->header.length = cpu_to_be16( + dcd_len * sizeof(dcd_addr_data_t) + 8); + dcd_v2->header.version = DCD_VERSION; + dcd_v2->write_dcd_command.tag = DCD_COMMAND_TAG; + dcd_v2->write_dcd_command.length = cpu_to_be16( + dcd_len * sizeof(dcd_addr_data_t) + 4); + dcd_v2->write_dcd_command.param = DCD_COMMAND_PARAM; +} + +static void set_imx_hdr_v1(struct imx_header *imxhdr, uint32_t dcd_len, + struct stat *sbuf, + struct mkimage_params *params) +{ + imx_header_v1_t *hdr_v1 = &imxhdr->header.hdr_v1; + flash_header_v1_t *fhdr_v1 = &hdr_v1->fhdr; + dcd_v1_t *dcd_v1 = &hdr_v1->dcd_table; + uint32_t base_offset; + + /* Set default offset */ + imxhdr->flash_offset = FLASH_OFFSET_STANDARD; + + /* Set magic number */ + fhdr_v1->app_code_barker = APP_CODE_BARKER; + + fhdr_v1->app_dest_ptr = params->addr; + fhdr_v1->app_dest_ptr = params->ep - imxhdr->flash_offset - + sizeof(struct imx_header); + fhdr_v1->app_code_jump_vector = params->ep; + + base_offset = fhdr_v1->app_dest_ptr + imxhdr->flash_offset ; + fhdr_v1->dcd_ptr_ptr = + (uint32_t) (offsetof(flash_header_v1_t, dcd_ptr) - + offsetof(flash_header_v1_t, app_code_jump_vector) + + base_offset); + + fhdr_v1->dcd_ptr = base_offset + + offsetof(imx_header_v1_t, dcd_table); + + /* The external flash header must be at the end of the DCD table */ + dcd_v1->addr_data[dcd_len].type = sbuf->st_size + + imxhdr->flash_offset + + sizeof(struct imx_header); + + /* Security feature are not supported */ + fhdr_v1->app_code_csf = 0; + fhdr_v1->super_root_key = 0; +} + +static void set_imx_hdr_v2(struct imx_header *imxhdr, uint32_t dcd_len, + struct stat *sbuf, + struct mkimage_params *params) +{ + imx_header_v2_t *hdr_v2 = &imxhdr->header.hdr_v2; + flash_header_v2_t *fhdr_v2 = &hdr_v2->fhdr; + + /* Set default offset */ + imxhdr->flash_offset = FLASH_OFFSET_STANDARD; + + /* Set magic number */ + fhdr_v2->header.tag = IVT_HEADER_TAG; /* 0xD1 */ + fhdr_v2->header.length = cpu_to_be16(sizeof(flash_header_v2_t)); + fhdr_v2->header.version = IVT_VERSION; /* 0x40 */ + + fhdr_v2->entry = params->ep; + fhdr_v2->reserved1 = fhdr_v2->reserved2 = 0; + fhdr_v2->self = params->ep - sizeof(struct imx_header); + + fhdr_v2->dcd_ptr = fhdr_v2->self + + offsetof(imx_header_v2_t, dcd_table); + + fhdr_v2->boot_data_ptr = fhdr_v2->self + + offsetof(imx_header_v2_t, boot_data); + + hdr_v2->boot_data.start = fhdr_v2->self - imxhdr->flash_offset; + hdr_v2->boot_data.size = sbuf->st_size + + imxhdr->flash_offset + + sizeof(struct imx_header); + + /* Security feature are not supported */ + fhdr_v2->csf = 0; +} + +static void set_hdr_func(struct imx_header *imxhdr) +{ + switch (imximage_version) { + case IMXIMAGE_V1: + set_dcd_val = set_dcd_val_v1; + set_dcd_rst = set_dcd_rst_v1; + set_imx_hdr = set_imx_hdr_v1; + break; + case IMXIMAGE_V2: + set_dcd_val = set_dcd_val_v2; + set_dcd_rst = set_dcd_rst_v2; + set_imx_hdr = set_imx_hdr_v2; + break; + default: + err_imximage_version(imximage_version); + break; + } +}
- size = imx_hdr->dcd_table.preamble.length; - if (size > (MAX_HW_CFG_SIZE * sizeof(dcd_type_addr_data_t))) { +static void print_hdr_v1(struct imx_header *imx_hdr) +{ + imx_header_v1_t *hdr_v1 = &imx_hdr->header.hdr_v1; + flash_header_v1_t *fhdr_v1 = &hdr_v1->fhdr; + dcd_v1_t *dcd_v1 = &hdr_v1->dcd_table; + uint32_t size, length, ver; + + size = dcd_v1->preamble.length; + if (size > (MAX_HW_CFG_SIZE_V1 * sizeof(dcd_type_addr_data_t))) { fprintf(stderr, "Error: Image corrupt DCD size %d exceed maximum %d\n", (uint32_t)(size / sizeof(dcd_type_addr_data_t)), - MAX_HW_CFG_SIZE); + MAX_HW_CFG_SIZE_V1); + exit(EXIT_FAILURE); + } + + length = dcd_v1->preamble.length / sizeof(dcd_type_addr_data_t); + ver = detect_imximage_version(imx_hdr); + + printf("Image Type: Freescale IMX Boot Image\n"); + printf("Image Ver: %x", ver); + printf("%s\n", get_table_entry_name(imximage_versions, NULL, ver)); + printf("Data Size: "); + genimg_print_size(dcd_v1->addr_data[length].type); + printf("Load Address: %08x\n", (uint32_t)fhdr_v1->app_dest_ptr); + printf("Entry Point: %08x\n", (uint32_t)fhdr_v1->app_code_jump_vector); +} + +static void print_hdr_v2(struct imx_header *imx_hdr) +{ + imx_header_v2_t *hdr_v2 = &imx_hdr->header.hdr_v2; + flash_header_v2_t *fhdr_v2 = &hdr_v2->fhdr; + dcd_v2_t *dcd_v2 = &hdr_v2->dcd_table; + uint32_t size, version; + + size = be16_to_cpu(dcd_v2->header.length) - 8; + if (size > (MAX_HW_CFG_SIZE_V2 * sizeof(dcd_addr_data_t))) { + fprintf(stderr, + "Error: Image corrupt DCD size %d exceed maximum %d\n", + (uint32_t)(size / sizeof(dcd_addr_data_t)), + MAX_HW_CFG_SIZE_V2); exit(EXIT_FAILURE); }
- length = dcd->preamble.length / sizeof(dcd_type_addr_data_t); + version = detect_imximage_version(imx_hdr);
printf("Image Type: Freescale IMX Boot Image\n"); + printf("Image Ver: %x", version); + printf("%s\n", get_table_entry_name(imximage_versions, NULL, version)); printf("Data Size: "); - genimg_print_size(dcd->addr_data[length].type); - printf("Load Address: %08x\n", (unsigned int)hdr->app_dest_ptr); - printf("Entry Point: %08x\n", (unsigned int)hdr->app_code_jump_vector); + genimg_print_size(hdr_v2->boot_data.size); + printf("Load Address: %08x\n", (uint32_t)fhdr_v2->boot_data_ptr); + printf("Entry Point: %08x\n", (uint32_t)fhdr_v2->entry); }
-static uint32_t imximage_parse_cfg_file(struct imx_header *imxhdr, char *name) +static void parse_cfg_cmd(struct imx_header *imxhdr, int32_t cmd, char *token, + char *name, int lineno, int fld, int dcd_len) +{ + int value; + static int cmd_ver_first = ~0; + + switch (cmd) { + case CMD_IMAGE_VERSION: + imximage_version = get_cfg_value(token, name, lineno); + if (cmd_ver_first == 0) { + fprintf(stderr, "Error: %s[%d] - IMAGE_VERSION " + "command need be the first before other " + "valid command in the file\n", name, lineno); + exit(EXIT_FAILURE); + } + cmd_ver_first = 1; + set_hdr_func(imxhdr); + break; + case CMD_BOOT_FROM: + imxhdr->flash_offset = get_table_entry_id(imximage_bootops, + "imximage boot option", token); + if (imxhdr->flash_offset == -1) { + fprintf(stderr, "Error: %s[%d] -Invalid boot device" + "(%s)\n", name, lineno, token); + exit(EXIT_FAILURE); + } + if (unlikely(cmd_ver_first != 1)) + cmd_ver_first = 0; + break; + case CMD_DATA: + value = get_cfg_value(token, name, lineno); + (*set_dcd_val)(imxhdr, name, lineno, fld, value, dcd_len); + if (unlikely(cmd_ver_first != 1)) + cmd_ver_first = 0; + break; + } +} + +static void parse_cfg_fld(struct imx_header *imxhdr, int32_t *cmd, + char *token, char *name, int lineno, int fld, int *dcd_len) +{ + int value; + + switch (fld) { + case CFG_COMMAND: + *cmd = get_table_entry_id(imximage_cmds, + "imximage commands", token); + if (*cmd < 0) { + fprintf(stderr, "Error: %s[%d] - Invalid command" + "(%s)\n", name, lineno, token); + exit(EXIT_FAILURE); + } + break; + case CFG_REG_SIZE: + parse_cfg_cmd(imxhdr, *cmd, token, name, lineno, fld, *dcd_len); + break; + case CFG_REG_ADDRESS: + case CFG_REG_VALUE: + if (*cmd != CMD_DATA) + return; + + value = get_cfg_value(token, name, lineno); + (*set_dcd_val)(imxhdr, name, lineno, fld, value, *dcd_len); + + if (fld == CFG_REG_VALUE) + (*dcd_len)++; + break; + default: + break; + } +} +static uint32_t parse_cfg_file(struct imx_header *imxhdr, char *name) { FILE *fd = NULL; char *line = NULL; char *token, *saveptr1, *saveptr2; int lineno = 0; - int fld, value; + int fld; size_t len; int dcd_len = 0; - dcd_t *dcd = &imxhdr->dcd_table; int32_t cmd;
fd = fopen(name, "r"); @@ -161,126 +461,75 @@ static uint32_t imximage_parse_cfg_file(struct imx_header *imxhdr, char *name) if (token[0] == '#') break;
- /* parse all fields in a single line */ - switch (fld) { - case CFG_COMMAND: - cmd = get_table_entry_id(imximage_cmds, - "imximage commands", token); - if (cmd < 0) { - fprintf(stderr, - "Error: %s[%d] - " - "Invalid command (%s)\n", - name, lineno, token); - exit(EXIT_FAILURE); - } - break; - case CFG_REG_SIZE: - switch (cmd) { - case CMD_BOOT_FROM: - /* Get flash header offset */ - imxhdr->flash_offset = - get_table_entry_id( - imximage_bootops, - "imximage boot option", - token); - if (imxhdr->flash_offset == -1) { - fprintf(stderr, - "Error: %s[%d] -" - "Invalid boot device" - "(%s)\n", - name, lineno, token); - exit(EXIT_FAILURE); - } - break; - case CMD_DATA: - value = get_cfg_value(token, - name, lineno); - - /* Byte, halfword, word */ - if ((value != 1) && - (value != 2) && (value != 4)) { - fprintf(stderr, - "Error: %s[%d] - " - "Invalid register size " - "(%d)\n", - name, lineno, value); - exit(EXIT_FAILURE); - } - dcd->addr_data[dcd_len].type = value; - break; - } - - case CFG_REG_ADDRESS: - if (cmd == CMD_DATA) - dcd->addr_data[dcd_len].addr = - get_cfg_value(token, - name, lineno); - break; - case CFG_REG_VALUE: - if (cmd == CMD_DATA) { - dcd->addr_data[dcd_len].value = - get_cfg_value(token, - name, lineno); - dcd_len++; - } - break; - } + parse_cfg_fld(imxhdr, &cmd, token, name, + lineno, fld, &dcd_len); }
- if (dcd_len > MAX_HW_CFG_SIZE) { - fprintf(stderr, - "Error: %s[%d] -" - "DCD table exceeds maximum size(%d)\n", - name, lineno, MAX_HW_CFG_SIZE); - } } - dcd->preamble.barker = DCD_BARKER; - dcd->preamble.length = dcd_len * sizeof(dcd_type_addr_data_t); + + (*set_dcd_rst)(imxhdr, dcd_len, name, lineno); fclose(fd);
return dcd_len; }
-static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd, - struct mkimage_params *params) -{ - struct imx_header *hdr = (struct imx_header *)ptr; - flash_header_t *fhdr = &hdr->fhdr; - int dcd_len; - dcd_t *dcd = &hdr->dcd_table; - uint32_t base_offset;
- /* Set default offset */ - hdr->flash_offset = FLASH_OFFSET_STANDARD; +static int imximage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_IMXIMAGE) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +}
- /* Set magic number */ - fhdr->app_code_barker = APP_CODE_BARKER; +static int imximage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + struct imx_header *imx_hdr = (struct imx_header *) ptr;
- /* Parse dcd configuration file */ - dcd_len = imximage_parse_cfg_file(hdr, params->imagename); + if (detect_imximage_version(imx_hdr) == IMXIMAGE_VER_INVALID) + return -FDT_ERR_BADSTRUCTURE;
- fhdr->app_dest_ptr = params->addr; - fhdr->app_dest_ptr = params->ep - hdr->flash_offset - - sizeof(struct imx_header); - fhdr->app_code_jump_vector = params->ep; + return 0; +}
- base_offset = fhdr->app_dest_ptr + hdr->flash_offset ; - fhdr->dcd_ptr_ptr = (uint32_t) (offsetof(flash_header_t, dcd_ptr) - - offsetof(flash_header_t, app_code_jump_vector) + - base_offset); +static void imximage_print_header(const void *ptr) +{ + struct imx_header *imx_hdr = (struct imx_header *) ptr; + uint32_t version = detect_imximage_version(imx_hdr); + + switch (version) { + case IMXIMAGE_V1: + print_hdr_v1(imx_hdr); + break; + case IMXIMAGE_V2: + print_hdr_v2(imx_hdr); + break; + default: + err_imximage_version(version); + break; + } +}
- fhdr->dcd_ptr = base_offset + - offsetof(struct imx_header, dcd_table); +static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct imx_header *imxhdr = (struct imx_header *)ptr; + uint32_t dcd_len;
- /* The external flash header must be at the end of the DCD table */ - dcd->addr_data[dcd_len].type = sbuf->st_size + - hdr->flash_offset + - sizeof(struct imx_header); + /* + * In order to not change the old imx cfg file + * by adding VERSION command into it, here need + * set up function ptr group to V1 by default. + */ + imximage_version = IMXIMAGE_V1; + set_hdr_func(imxhdr);
- /* Security feature are not supported */ - fhdr->app_code_csf = 0; - fhdr->super_root_key = 0; + /* Parse dcd configuration file */ + dcd_len = parse_cfg_file(imxhdr, params->imagename);
+ /* Set the imx header */ + (*set_imx_hdr)(imxhdr, dcd_len, sbuf, params); }
int imximage_check_params(struct mkimage_params *params) @@ -309,7 +558,7 @@ int imximage_check_params(struct mkimage_params *params) * imximage parameters */ static struct image_type_params imximage_params = { - .name = "Freescale i.MX 51 Boot Image support", + .name = "Freescale i.MX 5x Boot Image support", .header_size = sizeof(struct imx_header), .hdr = (void *)&imximage_header, .check_image_type = imximage_check_image_types, diff --git a/tools/imximage.h b/tools/imximage.h index b4d926d..38ca6be 100644 --- a/tools/imximage.h +++ b/tools/imximage.h @@ -24,12 +24,14 @@ #ifndef _IMXIMAGE_H_ #define _IMXIMAGE_H_
-#define MAX_HW_CFG_SIZE 60 /* Max number of registers imx can set */ -#define MAX_EXP_SIZE 4 +#include <config.h> + +#define MAX_HW_CFG_SIZE_V2 121 /* Max number of registers imx can set for v2 */ +#define MAX_HW_CFG_SIZE_V1 60 /* Max number of registers imx can set for v1 */ #define APP_CODE_BARKER 0xB1 #define DCD_BARKER 0xB17219E9 -#define HEADER_OFFSET 0x400
+#define HEADER_OFFSET 0x400
#define CMD_DATA_STR "DATA" #define FLASH_OFFSET_STANDARD 0x400 @@ -38,8 +40,16 @@ #define FLASH_OFFSET_SPI FLASH_OFFSET_STANDARD #define FLASH_OFFSET_ONENAND 0x100
+#define IVT_HEADER_TAG 0xD1 +#define IVT_VERSION 0x40 +#define DCD_HEADER_TAG 0xD2 +#define DCD_COMMAND_TAG 0xCC +#define DCD_VERSION 0x40 +#define DCD_COMMAND_PARAM 0x4 + enum imximage_cmd { CMD_INVALID, + CMD_IMAGE_VERSION, CMD_BOOT_FROM, CMD_DATA }; @@ -52,13 +62,11 @@ enum imximage_fld_types { CFG_REG_VALUE };
-typedef struct { - uint8_t rsa_exponent[MAX_EXP_SIZE]; /* RSA public exponent */ - uint8_t *rsa_modulus; /* RSA modulus pointer */ - uint16_t exponent_size; /* Exponent size (bytes) */ - uint16_t modulus_size; /* Modulus size (bytes) */ - uint8_t init_flag; /* key initialized */ -} hab_rsa_public_key; +enum imximage_version { + IMXIMAGE_VER_INVALID = -1, + IMXIMAGE_V1 = 1, + IMXIMAGE_V2 +};
typedef struct { uint32_t type; /* Type of pointer (byte, halfword, word, wait/read) */ @@ -73,8 +81,8 @@ typedef struct {
typedef struct { dcd_preamble_t preamble; - dcd_type_addr_data_t addr_data[MAX_HW_CFG_SIZE]; -} dcd_t; + dcd_type_addr_data_t addr_data[MAX_HW_CFG_SIZE_V1]; +} dcd_v1_t;
typedef struct { uint32_t app_code_jump_vector; @@ -84,22 +92,84 @@ typedef struct { uint32_t super_root_key; uint32_t dcd_ptr; uint32_t app_dest_ptr; -} flash_header_t; +} flash_header_v1_t;
typedef struct { uint32_t length; /* Length of data to be read from flash */ } flash_cfg_parms_t;
-struct imx_header { - flash_header_t fhdr; - dcd_t dcd_table; +typedef struct { + flash_header_v1_t fhdr; + dcd_v1_t dcd_table; flash_cfg_parms_t ext_header; +} imx_header_v1_t; + +typedef struct { + uint32_t addr; + uint32_t value; +} dcd_addr_data_t; + +typedef struct { + uint8_t tag; + uint16_t length; + uint8_t version; +} __attribute__((packed)) ivt_header_t; + +typedef struct { + uint8_t tag; + uint16_t length; + uint8_t param; +} __attribute__((packed)) write_dcd_command_t; + +typedef struct { + ivt_header_t header; + write_dcd_command_t write_dcd_command; + dcd_addr_data_t addr_data[MAX_HW_CFG_SIZE_V2]; +} dcd_v2_t; + +typedef struct { + uint32_t start; + uint32_t size; + uint32_t plugin; +} boot_data_t; + +typedef struct { + ivt_header_t header; + uint32_t entry; + uint32_t reserved1; + uint32_t dcd_ptr; + uint32_t boot_data_ptr; + uint32_t self; + uint32_t csf; + uint32_t reserved2; +} flash_header_v2_t; + +typedef struct { + flash_header_v2_t fhdr; + boot_data_t boot_data; + dcd_v2_t dcd_table; +} imx_header_v2_t; + +struct imx_header { + union { + imx_header_v1_t hdr_v1; + imx_header_v2_t hdr_v2; + } header; uint32_t flash_offset; };
-struct reg_config { - uint32_t raddr; - uint32_t rdata; -}; +typedef void (*set_dcd_val_t)(struct imx_header *imxhdr, + char *name, int lineno, + int fld, uint32_t value, + uint32_t off); + +typedef void (*set_dcd_rst_t)(struct imx_header *imxhdr, + uint32_t dcd_len, + char *name, int lineno); + +typedef void (*set_imx_hdr_t)(struct imx_header *imxhdr, + uint32_t dcd_len, + struct stat *sbuf, + struct mkimage_params *params);
#endif /* _IMXIMAGE_H_ */
Hi, Wolfgang,
2011/1/20 Jason Liu r64343@freescale.com:
Changes for v2:
Changes for v3:
Any feedback about this patch?
Le 25/01/2011 08:56, Jason Liu a écrit :
Hi, Wolfgang,
2011/1/20 Jason Liur64343@freescale.com:
Signed-off-by: Jason Liur64343@freescale.com
Changes for v2:
Changes for v3:
Changes for v4:
- Add braces for (expx)&& (expy) gloably,
Changes for v5:
I think Stefano should be added in Cc: as IMX custodian.
Amicalement,
I have already got it. This is the revisited patch that was too fast merged in u-boot-imx.
Jason, I have no remarks on it and for testing purpose I have already merged all pending imx patches into the next branch of u-boot-imx. If there will be no further comments, all these patches will be part of my next pull request.
Stefano
Applied to u-boot-imx, thanks
Regards, Stefano Babic
Hi Jason,
struct stat *sbuf,
I have some doubts that this hard coding (over writing) of imxhdr->flash_offset is correct here.
For booting from i.MX6 parallel NOR or NAND, flash_offset is != 0x400 (FLASH_OFFSET_STANDARD).
In parse_cfg_cmd() we read the correct flash offset valid for the selected boot device from the configuration:
case CMD_BOOT_FROM: imxhdr->flash_offset = get_table_entry_id(imximage_bootops, "imximage boot option", token);
But this correct flash offset is afterwards overwritten by
as mentioned above, which I think is wrong. It doesn't matter for all devices which use FLASH_OFFSET_STANDARD (e.g. SD/SPI NOR etc), but it doesn't seem to work for parallel NOR and NAND.
What do you think?
I will need some time to verify this with a != 0x400 boot device, but as soon as I have this working I will send a patch for the imximage tool.
Best regards
Dirk
Btw.: I'm not sure if the same statement for the v1 header set_imx_hdr_v1() is wrong, too, though?
participants (5)
Albert ARIBAUD
Dirk Behme
Jason Liu
Jason Liu
Stefano Babic
