[PULL] u-boot-usb/master
The following changes since commit 52c0e5f8a39ef022ee5ab2dfd67661d1d34941c7:
Merge branch '2024-11-22-assorted-fixes' (2024-11-22 15:04:54 -0600)
git://source.denx.de/u-boot-usb.git master
for you to fetch changes up to 57e30b09fcfc88da72c310f979b35ed99a9b277c:
usb: onboard-hub: Bail out if peer hub is already probed (2024-11-25 05:40:49 +0100)
---------------------------------------------------------------- Venkatesh Yadav Abbarapu (5): usb: onboard-hub: Add reset-gpio support usb: onboard-hub: Fix the return values of regulator APIs usb: onboard-hub: add support for Microchip USB5744 usb: onboard-hub: Add i2c initialization for usb5744 hub usb: onboard-hub: Bail out if peer hub is already probed
common/usb_onboard_hub.c | 195 +++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 190 insertions(+), 5 deletions(-)
