[U-Boot] [PATCH] mtdparts: Fix various issues reported by Coverity
Now that sandbox is building cmd/mtdparts.c Coverity has looked at the code and found a number of issues. In index_partitions() it is possible that part will be NULL, so re-work the checks and debug statements to take this into account. We have a number of string buffers that we print to in the exact size of, and use string functions on, so we need to ensure they are large enough to be NULL terminated. In device_parse() it is not possible for num_partitions to be 0 (we would have hit a different error first) so remove logically dead code. Finally, in parse_mtdparts() if we have an error we need to free the memory allocated to dev.
Cc: Lothar Waßmann LW@KARO-electronics.de Cc: Maxime Ripard maxime.ripard@free-electrons.com Reported-by: Coverity (CID: 166334, 166333, 166332, 166329, 166328) Signed-off-by: Tom Rini trini@konsulko.com --- cmd/mtdparts.c | 33 ++++++++++++++++++--------------- 1 file changed, 18 insertions(+), 15 deletions(-)
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 683c48bdad1b..93fd2f3767b8 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -133,9 +133,9 @@ static const char *mtdparts_default = MTDPARTS_DEFAULT; #define MTDIDS_MAXLEN 128 #define MTDPARTS_MAXLEN 512 #define PARTITION_MAXLEN 16 -static char last_ids[MTDIDS_MAXLEN]; -static char last_parts[MTDPARTS_MAXLEN]; -static char last_partition[PARTITION_MAXLEN]; +static char last_ids[MTDIDS_MAXLEN + 1]; +static char last_parts[MTDPARTS_MAXLEN + 1]; +static char last_partition[PARTITION_MAXLEN + 1];
/* low level jffs2 cache cleaning routine */ extern void jffs2_free_cache(struct part_info *part); @@ -240,15 +240,22 @@ static void index_partitions(void) if (dev == current_mtd_dev) { mtddevnum += current_mtd_partnum; setenv_ulong("mtddevnum", mtddevnum); + debug("=> mtddevnum %d,\n", mtddevnum); break; } mtddevnum += dev->num_parts; }
part = mtd_part_info(current_mtd_dev, current_mtd_partnum); - setenv("mtddevname", part->name); + if (part) { + setenv("mtddevname", part->name); + + debug("=> mtddevname %s\n", part->name); + } else { + setenv("mtddevname", NULL);
- debug("=> mtddevnum %d,\n=> mtddevname %s\n", mtddevnum, part->name); + debug("=> mtddevname NULL\n"); + } } else { setenv("mtddevnum", NULL); setenv("mtddevname", NULL); @@ -912,12 +919,6 @@ static int device_parse(const char *const mtd_dev, const char **ret, struct mtd_ return 1; }
- if (num_parts == 0) { - printf("no partitions for device %s%d (%s)\n", - MTD_DEV_TYPE(id->type), id->num, id->mtd_id); - return 1; - } - debug("\ntotal partitions: %d\n", num_parts);
/* check for next device presence */ @@ -1593,8 +1594,10 @@ static int parse_mtdparts(const char *const mtdparts) list_add_tail(&dev->link, &devices); err = 0; } - if (err == 1) + if (err == 1) { + free(dev); device_delall(&devices); + }
return err; } @@ -1730,9 +1733,9 @@ int mtdparts_init(void) if (!initialized) { INIT_LIST_HEAD(&mtdids); INIT_LIST_HEAD(&devices); - memset(last_ids, 0, MTDIDS_MAXLEN); - memset(last_parts, 0, MTDPARTS_MAXLEN); - memset(last_partition, 0, PARTITION_MAXLEN); + memset(last_ids, 0, sizeof(last_ids)); + memset(last_parts, 0, sizeof(last_parts)); + memset(last_partition, 0, sizeof(last_partition)); #if defined(CONFIG_SYS_MTDPARTS_RUNTIME) board_mtdparts_default(&mtdids_default, &mtdparts_default); #endif
