[U-Boot] [PATCH v3 00/11] S3C24XX: Add support to MINI2416 board
Support for the MINI2416 board based on a Samsung's S3C2416 SoC with 64MB DDR2 SDRAM, 256MB NAND Flash, a LAN9220 Ethernet Controller and a WM8731 Audio CODEC.
Changes for v2: - Coding style cleanup - Removed new serial and rtc drivers - Use of in-tree serial and rtc drivers
Changes for v3: - Rebased on new SPL framework: http://github.com/trini/u-boot WIP/spl-improvements - Removed patch "ARM: fix relocation on ARM926EJS" - Add patch to configure printf() inclusion on SPL - Changed new binary target name from u-boot-ubl.bin to u-boot-pad.bin - Removed magic numbers - Checkpatch clean except: - False positive: ERROR: spaces required around that ':' (ctx:VxV) #692: FILE: include/configs/mini2416.h:165: +#define CONFIG_ETHADDR FE:11:22:33:44:55 - Following preexistent coding style: WARNING: please, no spaces at the start of a line #1716: FILE: include/common.h:631: + defined(CONFIG_S3C24XX) || $
José Miguel Gonçalves (11): Add configuration option to select printf() inclusion on SPL S3C24XX: Add core support for Samsung's S3C24XX SoCs serial: Add support to 4 ports in serial_s3c24x0 serial: Use a more precise baud rate generation for serial_s3c24x0 serial: Remove unnecessary delay in serial_s3c24x0 rtc: Improve rtc_get() on s3c24x0_rtc rtc: Fix rtc_reset() on s3c24x0_rtc rtc: Don't allow setting unsuported years on s3c24x0_rtc S3C24XX: Add NAND Flash driver Add u-boot-pad.bin target to the Makefile S3C24XX: Add support to MINI2416 board
MAINTAINERS | 4 + Makefile | 11 +- README | 3 + arch/arm/cpu/arm926ejs/s3c24xx/Makefile | 56 +++ arch/arm/cpu/arm926ejs/s3c24xx/cpu.c | 57 +++ arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c | 57 +++ arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c | 114 +++++ arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c | 116 +++++ arch/arm/cpu/arm926ejs/s3c24xx/timer.c | 152 ++++++ arch/arm/include/asm/arch-s3c24xx/s3c2412.h | 130 +++++ arch/arm/include/asm/arch-s3c24xx/s3c2416.h | 183 +++++++ arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h | 41 ++ arch/arm/include/asm/arch-s3c24xx/s3c24xx.h | 615 +++++++++++++++++++++++ arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h | 30 ++ arch/arm/include/asm/arch-s3c24xx/spl.h | 29 ++ board/boardcon/mini2416/Makefile | 47 ++ board/boardcon/mini2416/config.mk | 4 + board/boardcon/mini2416/mini2416.c | 104 ++++ board/boardcon/mini2416/mini2416_spl.c | 203 ++++++++ board/boardcon/mini2416/u-boot-spl.lds | 63 +++ boards.cfg | 1 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/s3c24xx_nand.c | 246 +++++++++ drivers/rtc/s3c24x0_rtc.c | 30 +- drivers/serial/serial_s3c24x0.c | 52 +- include/common.h | 12 + include/configs/VCMA9.h | 2 +- include/configs/mini2416.h | 202 ++++++++ include/configs/smdk2410.h | 2 +- 29 files changed, 2540 insertions(+), 27 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/timer.c create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c2412.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c2416.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c24xx.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/spl.h create mode 100644 board/boardcon/mini2416/Makefile create mode 100644 board/boardcon/mini2416/config.mk create mode 100644 board/boardcon/mini2416/mini2416.c create mode 100644 board/boardcon/mini2416/mini2416_spl.c create mode 100644 board/boardcon/mini2416/u-boot-spl.lds create mode 100644 drivers/mtd/nand/s3c24xx_nand.c create mode 100644 include/configs/mini2416.h
The printf() implementation needs 4~5KB of storage space which may not be available when building an SPL for SoCs with scarce internal RAM (8KB or less). This patch adds a new option, CONFIG_SPL_PRINTF_SUPPORT, to deal with this.
Signed-off-by: José Miguel Gonçalves jose.goncalves@inov.pt --- Changes for v3: - new patch --- README | 3 +++ include/common.h | 11 +++++++++++ 2 files changed, 14 insertions(+)
diff --git a/README b/README index 016d8bc..988812c 100644 --- a/README +++ b/README @@ -2576,6 +2576,9 @@ FIT uImage format: CONFIG_SPL_LIBCOMMON_SUPPORT Support for common/libcommon.o in SPL binary
+ CONFIG_SPL_PRINTF_SUPPORT + Enable printf() support in common/libcommon.o + CONFIG_SPL_LIBDISK_SUPPORT Support for disk/libdisk.o in SPL binary
diff --git a/include/common.h b/include/common.h index 55025c0..c10d745 100644 --- a/include/common.h +++ b/include/common.h @@ -805,9 +805,20 @@ int tstc(void); /* stdout */ void putc(const char c); void puts(const char *s); +/* + * The printf() implementation needs 4~5KB of storage space which may not be + * available when building an SPL for SoCs with scarce internal RAM + * (8KB or less). To force printf() inclusion on an SPL we must define + * CONFIG_SPL_LIBCOMMON_SUPPORT and CONFIG_SPL_PRINTF_SUPPORT. + */ +#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_PRINTF_SUPPORT) int printf(const char *fmt, ...) __attribute__ ((format (__printf__, 1, 2))); int vprintf(const char *fmt, va_list args); +#else +#define printf(fmt...) do {} while (0) +#define vprintf(fmt, args) do {} while (0) +#endif
/* stderr */ #define eputc(c) fputc(stderr, c)
This patch adds the support for Samsung's S3C24XX SoCs that have an ARM926EJS core. Currently it supports S3C2412, S3C2413, S3C2416 and S3C2450. Tested on an S3C2416 platform.
Signed-off-by: José Miguel Gonçalves jose.goncalves@inov.pt --- Changes for v2: - Added register bit macros to avoid magic numbers - Removed volatile attribute from register structs - Added s3c24x0_cpu.h to be able to use drivers from s3c24x0 family - Fixed EPLL computation in get_PLLCLK for S3C2416 - Added display of UCLK in print_cpu_info - Use of clrsetbits_le32()
Changes for v3: - Add __noreturn attribute to reset_cpu() - Removed magic numbers - Add arch/arm/include/asm/arch-s3c24xx/spl.h for new SPL framework --- arch/arm/cpu/arm926ejs/s3c24xx/Makefile | 56 +++ arch/arm/cpu/arm926ejs/s3c24xx/cpu.c | 57 +++ arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c | 57 +++ arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c | 114 +++++ arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c | 116 +++++ arch/arm/cpu/arm926ejs/s3c24xx/timer.c | 152 ++++++ arch/arm/include/asm/arch-s3c24xx/s3c2412.h | 130 +++++ arch/arm/include/asm/arch-s3c24xx/s3c2416.h | 183 +++++++ arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h | 41 ++ arch/arm/include/asm/arch-s3c24xx/s3c24xx.h | 615 +++++++++++++++++++++++ arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h | 30 ++ arch/arm/include/asm/arch-s3c24xx/spl.h | 29 ++ include/common.h | 1 + 13 files changed, 1581 insertions(+) create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c create mode 100644 arch/arm/cpu/arm926ejs/s3c24xx/timer.c create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c2412.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c2416.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c24xx.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h create mode 100644 arch/arm/include/asm/arch-s3c24xx/spl.h
diff --git a/arch/arm/cpu/arm926ejs/s3c24xx/Makefile b/arch/arm/cpu/arm926ejs/s3c24xx/Makefile new file mode 100644 index 0000000..d7f5e0d --- /dev/null +++ b/arch/arm/cpu/arm926ejs/s3c24xx/Makefile @@ -0,0 +1,56 @@ +# +# (C) Copyright 2012 INOV - INESC Inovacao +# Jose Goncalves jose.goncalves@inov.pt +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +ifndef CONFIG_SPL_BUILD +COBJS-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +endif + +ifeq ($(filter y,$(CONFIG_S3C2412) $(CONFIG_S3C2413)),y) +COBJS-y += s3c2412_speed.o +else +COBJS-y += s3c2416_speed.o +endif + +COBJS-y += cpu.o +COBJS-y += timer.o + +SRCS := $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm926ejs/s3c24xx/cpu.c b/arch/arm/cpu/arm926ejs/s3c24xx/cpu.c new file mode 100644 index 0000000..a6a90d8 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/s3c24xx/cpu.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <linux/compiler.h> +#include <asm/io.h> +#include <asm/arch/s3c24xx_cpu.h> + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_ICACHE_OFF + icache_enable(); +#endif +#ifndef CONFIG_SYS_DCACHE_OFF + dcache_enable(); +#endif +} + +/* + * Reset the cpu by setting up the watchdog timer and let him time out. + */ +void __noreturn reset_cpu(ulong addr) +{ + struct s3c24xx_watchdog *const watchdog = s3c24xx_get_base_watchdog(); + + /* Disable watchdog */ + writel(WTCON_DISABLE_VAL, &watchdog->wtcon); + + /* Initialize watchdog timer count register with the minimum value */ + writel(0x0001, &watchdog->wtcnt); + + /* Enable watchdog timer; assert reset at timer timeout */ + writel(WTCON_RSTEN | WTCON_ENABLE, &watchdog->wtcon); + + while (1) + /* loop forever and wait for reset to happen */; +} diff --git a/arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c b/arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c new file mode 100644 index 0000000..d2a8b95 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2010 + * David Mueller d.mueller@elsoft.ch + * + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/s3c24xx_cpu.h> + +typedef ulong(*getfreq) (void); + +static const getfreq freq_f[] = { + get_FCLK, + get_HCLK, + get_PCLK, + get_UCLK, +}; + +static const char freq_c[] = { 'F', 'H', 'P', 'U' }; + +int print_cpuinfo(void) +{ + int i; + char buf[32]; + ulong cpuid; + struct s3c24xx_gpio *const gpio = s3c24xx_get_base_gpio(); + + cpuid = readl(&gpio->gstatus[1]); + printf("CPU: %8s (id %08lX) @ %s MHz\n", s3c24xx_get_cpu_name(), + cpuid, strmhz(buf, get_ARMCLK())); + for (i = 0; i < ARRAY_SIZE(freq_f); i++) + printf("%cCLK: %8s MHz\n", freq_c[i], + strmhz(buf, freq_f[i] ())); + + return 0; +} diff --git a/arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c b/arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c new file mode 100644 index 0000000..d584cf2 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/s3c24xx/s3c2412_speed.c @@ -0,0 +1,114 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * Based on U-Boot 1.3.4 from Samsung. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/s3c2412.h> + +#define MPLL 0 +#define UPLL 1 + +/* ------------------------------------------------------------------------- */ +/* + * CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL. + * + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of + * the specified bus in HZ. + */ +/* ------------------------------------------------------------------------- */ + +static ulong get_PLLCLK(int pllreg) +{ + struct s3c2412_sysctl *const sysctl = s3c2412_get_base_sysctl(); + u32 pllcon, f; + u16 mdiv, pdiv, sdiv; + + if (pllreg == MPLL) + pllcon = readl(&sysctl->mpllcon); + else if (pllreg == UPLL) + pllcon = readl(&sysctl->upllcon); + else + hang(); + + mdiv = PLLCON_MDIV_GET(pllcon); + pdiv = PLLCON_PDIV_GET(pllcon); + sdiv = PLLCON_SDIV_GET(pllcon); + + f = (mdiv + 8) * (CONFIG_SYS_CLK_FREQ / ((pdiv + 2) << sdiv)); + if (pllreg == MPLL) + f <<= 1; + + return f; +} + +/* return FCLK frequency */ +ulong get_FCLK(void) +{ + return get_PLLCLK(MPLL); +} + +/* return HCLK frequency */ +ulong get_HCLK(void) +{ + struct s3c2412_sysctl *const sysctl = s3c2412_get_base_sysctl(); + u32 clkdivn; + u16 hclk_div, arm_div; + + clkdivn = readl(&sysctl->clkdivn); + hclk_div = CLKDIVN_HCLKDIV_GET(clkdivn) + 1; + arm_div = CLKDIVN_ARMDIV_GET(clkdivn) + 1; + + return get_FCLK() / (hclk_div * arm_div); +} + +/* return PCLK frequency */ +ulong get_PCLK(void) +{ + struct s3c2412_sysctl *const sysctl = s3c2412_get_base_sysctl(); + u32 clkdivn; + + clkdivn = readl(&sysctl->clkdivn); + + return (clkdivn & CLKDIVN_PCLKDIV) ? get_HCLK() / 2 : get_HCLK(); +} + +/* return UCLK frequency */ +ulong get_UCLK(void) +{ + return get_PLLCLK(UPLL); +} + +/* return ARMCORE frequency */ +ulong get_ARMCLK(void) +{ + struct s3c2412_sysctl *const sysctl = s3c2412_get_base_sysctl(); + u32 clkdivn; + + clkdivn = readl(&sysctl->clkdivn); + if (clkdivn & CLKDIVN_DVS) + return get_FCLK(); + + return (clkdivn & CLKDIVN_ARMDIV) ? get_FCLK() / 2 : get_FCLK(); +} diff --git a/arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c b/arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c new file mode 100644 index 0000000..625e603 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/s3c24xx/s3c2416_speed.c @@ -0,0 +1,116 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * Based on U-Boot 1.3.4 from Samsung. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/s3c2416.h> + +#define MPLL 0 +#define EPLL 1 + +/* ------------------------------------------------------------------------- */ +/* + * CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL. + * + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of + * the specified bus in HZ. + */ +/* ------------------------------------------------------------------------- */ + +static ulong get_PLLCLK(int pllreg) +{ + struct s3c2416_sysctl *const sysctl = s3c2416_get_base_sysctl(); + u32 pllcon; + u16 mdiv, pdiv, sdiv; + + if (pllreg == MPLL) { + pllcon = readl(&sysctl->mpllcon); + mdiv = MPLLCON_MDIV_GET(pllcon); + pdiv = MPLLCON_PDIV_GET(pllcon); + } else if (pllreg == EPLL) { + pllcon = readl(&sysctl->epllcon); + mdiv = EPLLCON_MDIV_GET(pllcon); + pdiv = EPLLCON_PDIV_GET(pllcon); + } else { + hang(); + } + + sdiv = PLLCON_SDIV_GET(pllcon); + + return mdiv * (CONFIG_SYS_CLK_FREQ / (pdiv << sdiv)); +} + +/* return FCLK frequency */ +ulong get_FCLK(void) +{ + return get_PLLCLK(MPLL); +} + +/* return HCLK frequency */ +ulong get_HCLK(void) +{ + struct s3c2416_sysctl *const sysctl = s3c2416_get_base_sysctl(); + u32 clkdiv0; + u16 hclk_div, pre_div; + + clkdiv0 = readl(&sysctl->clkdiv0); + hclk_div = (CLKDIV0_HCLKDIV_GET(clkdiv0)) + 1; + pre_div = (CLKDIV0_PREDIV_GET(clkdiv0)) + 1; + + return get_FCLK() / (hclk_div * pre_div); +} + +/* return PCLK frequency */ +ulong get_PCLK(void) +{ + struct s3c2416_sysctl *const sysctl = s3c2416_get_base_sysctl(); + u32 clkdiv0; + + clkdiv0 = readl(&sysctl->clkdiv0); + + return (clkdiv0 & CLKDIV0_PCLKDIV) ? get_HCLK() / 2 : get_HCLK(); +} + +/* return UCLK frequency */ +ulong get_UCLK(void) +{ + return get_PLLCLK(EPLL); +} + +/* return ARMCORE frequency */ +ulong get_ARMCLK(void) +{ + struct s3c2416_sysctl *const sysctl = s3c2416_get_base_sysctl(); + u32 clkdiv0; + u16 arm_div; + + clkdiv0 = readl(&sysctl->clkdiv0); + if (clkdiv0 & CLKDIV0_DVS) + return get_FCLK(); + + arm_div = CLKDIV0_ARMDIV_GET(clkdiv0) + 1; + + return get_FCLK() / arm_div; +} diff --git a/arch/arm/cpu/arm926ejs/s3c24xx/timer.c b/arch/arm/cpu/arm926ejs/s3c24xx/timer.c new file mode 100644 index 0000000..1a838f8 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/s3c24xx/timer.c @@ -0,0 +1,152 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * Based on arch/arm/cpu/armv7/s5p-common/timer.c and U-Boot 1.3.4 from Samsung. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/s3c24xx_cpu.h> + +#define PRESCALER 15 + +DECLARE_GLOBAL_DATA_PTR; + +static ulong get_current_tick(void) +{ + struct s3c24xx_timers *const timers = s3c24xx_get_base_timers(); + ulong now = readl(&timers->tcnto4); + + if (gd->lastinc >= now) + gd->tbl += gd->lastinc - now; + else + gd->tbl += gd->lastinc + gd->tbu - now; + + gd->lastinc = now; + + return gd->tbl; +} + +int timer_init(void) +{ + struct s3c24xx_timers *const timers = s3c24xx_get_base_timers(); + + /* use PWM Timer 4 because it has no output */ + if (gd->tbu == 0) { + /* set divider value for Timer 4 to 2 */ + clrsetbits_le32(&timers->tcfg1, TCFG1_MUX4_MASK, + TCFG1_MUX4_DIV2); + /* set prescaler value for Timer 4 to PRESCALER */ + clrsetbits_le32(&timers->tcfg0, TCFG0_PRESCALER1_MASK, + TCFG0_PRESCALER1(PRESCALER)); + /* + * Timer Freq(HZ) = + * PCLK / (prescaler_value + 1) / (divider_value) + */ + gd->timer_rate_hz = get_PCLK() / (PRESCALER + 1) / 2; + gd->tbu = gd->timer_rate_hz / CONFIG_SYS_HZ; + } + /* load value for selected timeout */ + writel(gd->tbu, &timers->tcntb4); + /* auto reload, manual update of timer 4 */ + clrsetbits_le32(&timers->tcon, TCON_T4START, + TCON_T4RELOAD | TCON_T4MANUALUPD); + /* auto reload, start timer 4 */ + clrsetbits_le32(&timers->tcon, TCON_T4MANUALUPD, + TCON_T4RELOAD | TCON_T4START); + gd->lastinc = 0; + gd->tbl = 0; + + return 0; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + ulong tmo, tmp; + + if (usec >= 1000) { + /* + * if "big" number, spread normalization + * to seconds + * 1. start to normalize for usec to ticks per sec + * 2. find number of "ticks" to wait to achieve target + * 3. finish normalize. + */ + tmo = usec / 1000; + tmo *= gd->timer_rate_hz; + tmo /= 1000; + } else { + /* else small number, don't kill it prior to HZ multiply */ + tmo = usec * gd->timer_rate_hz; + tmo /= (1000 * 1000); + } + + /* get current timestamp */ + tmp = get_current_tick(); + + /* if advancing the timestamp would roll-up the timer, reset it */ + if ((tmo + tmp + 1) < tmp) + reset_timer_masked(); + else + tmo += tmp; + + /* loop till event */ + while (get_current_tick() < tmo) + /* NOP */; +} + +void reset_timer_masked(void) +{ + struct s3c24xx_timers *const timers = s3c24xx_get_base_timers(); + + /* reset time */ + gd->lastinc = readl(&timers->tcnto4); + gd->tbl = 0; +} + +ulong get_timer_masked(void) +{ + return get_current_tick() / gd->tbu; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer_masked(); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/include/asm/arch-s3c24xx/s3c2412.h b/arch/arm/include/asm/arch-s3c24xx/s3c2412.h new file mode 100644 index 0000000..8945308 --- /dev/null +++ b/arch/arm/include/asm/arch-s3c24xx/s3c2412.h @@ -0,0 +1,130 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************ + * NAME : s3c2412.h + * + * Based on S3C2412 User's manual Rev 1.06a + ************************************************/ + +#ifndef __S3C2412_H__ +#define __S3C2412_H__ + +/* Base addresses for S3C2412 specific modules */ +#define S3C2412_INTERRUPT_BASE 0x4A000000 +#define S3C2412_SYSCTL_BASE 0x4C000000 +#define S3C2412_LCD_BASE 0x4D000000 +#define S3C2412_USB_DEVICE_BASE 0x52000000 +#define S3C2412_ADC_BASE 0x58000000 +#define S3C2412_SPI_BASE 0x59000000 +#define S3C2412_SDIO_BASE 0x5A000000 + +#define S3C24XX_UART_CHANNELS 3 +#define S3C24XX_DMA_CHANNELS 4 +#define S3C24XX_SMC_BANKS 8 + +#ifdef CONFIG_S3C2412 +#define S3C24XX_CPU_NAME "S3C2412" +#else +#define S3C24XX_CPU_NAME "S3C2413" +#endif + +enum s3c24xx_uarts { + S3C24XX_UART0, + S3C24XX_UART1, + S3C24XX_UART2 +}; + +enum s3c24xx_dmas { + S3C24XX_DMA0, + S3C24XX_DMA1, + S3C24XX_DMA2, + S3C24XX_DMA3 +}; + +enum s3c24xx_smcs { + S3C24XX_SMC0, + S3C24XX_SMC1, + S3C24XX_SMC2, + S3C24XX_SMC3, + S3C24XX_SMC4, + S3C24XX_SMC5, + S3C24XX_SMC6, + S3C24XX_SMC7 +}; + +/* Interrupt Controller */ +struct s3c2412_interrupt { + u32 srcpnd; + u32 intmod; + u32 intmsk; + u32 priority; + u32 intpnd; + u32 intoffset; + u32 subsrcpnd; + u32 intsubmsk; +}; + +/* System Controller */ +struct s3c2412_sysctl { + u32 locktime; + u32 mpllcon; + u32 upllcon; + u32 clkcon; + u32 _res1; + u32 clkdivn; + u32 oscset; + u32 clksrc; + u32 _res2; + u32 pwrcfg; + u32 _res3[2]; + u32 swrstcon; + u32 rstcon; + u32 _res4[13]; + u32 inform[4]; +}; + +#define PLLCON_MDIV_GET(x) (((x)>>12) & 0xFF) +#define PLLCON_PDIV_GET(x) (((x)>>4) & 0x3F) +#define PLLCON_SDIV_GET(x) (((x)>>0) & 0x3) + +#define CLKDIVN_DVS (1<<4) +#define CLKDIVN_ARMDIV_GET(x) (((x)>>3) & 0x1) +#define CLKDIVN_ARMDIV (1<<3) +#define CLKDIVN_PCLKDIV (1<<2) +#define CLKDIVN_HCLKDIV_GET(x) (((x)>>0) & 0x3) + +static inline struct s3c2412_interrupt *s3c2412_get_base_interrupt(void) +{ + return (struct s3c2412_interrupt *)S3C2412_INTERRUPT_BASE; +} + +static inline struct s3c2412_sysctl *s3c2412_get_base_sysctl(void) +{ + return (struct s3c2412_sysctl *)S3C2412_SYSCTL_BASE; +} + +/* Include common stuff */ +#include <asm/arch/s3c24xx.h> + +#endif /*__S3C2412_H__*/ diff --git a/arch/arm/include/asm/arch-s3c24xx/s3c2416.h b/arch/arm/include/asm/arch-s3c24xx/s3c2416.h new file mode 100644 index 0000000..748e7b8 --- /dev/null +++ b/arch/arm/include/asm/arch-s3c24xx/s3c2416.h @@ -0,0 +1,183 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************ + * NAME : s3c2416.h + * + * Based on S3C2416 User's manual Rev 1.40 + ************************************************/ + +#ifndef __S3C2416_H__ +#define __S3C2416_H__ + +/* Base addresses for S3C2416 specific modules */ +#define S3C2416_USB_DEVICE_BASE 0x49800000 +#define S3C2416_INTERRUPT_BASE 0x4A000000 +#define S3C2416_HSMMC_BASE 0x4A800000 +#define S3C2416_SYSCTL_BASE 0x4C000000 +#define S3C2416_LCD_BASE 0x4C800000 +#define S3C2416_HSSPI_BASE 0x52000000 +#define S3C2416_ADC_BASE 0x58000000 + +#define S3C24XX_UART_CHANNELS 4 +#define S3C24XX_DMA_CHANNELS 6 +#define S3C24XX_SMC_BANKS 6 + +#ifdef CONFIG_S3C2416 +#define S3C24XX_CPU_NAME "S3C2416" +#else +#define S3C24XX_CPU_NAME "S3C2450" +#endif + +enum s3c24xx_uarts { + S3C24XX_UART0, + S3C24XX_UART1, + S3C24XX_UART2, + S3C24XX_UART3 +}; + +enum s3c24xx_dmas { + S3C24XX_DMA0, + S3C24XX_DMA1, + S3C24XX_DMA2, + S3C24XX_DMA3, + S3C24XX_DMA4, + S3C24XX_DMA5 +}; + +enum s3c24xx_smcs { + S3C24XX_SMC0, + S3C24XX_SMC1, + S3C24XX_SMC2, + S3C24XX_SMC3, + S3C24XX_SMC4, + S3C24XX_SMC5 +}; + +/* Interrupt Controller */ +struct s3c2416_interrupt { + u32 srcpnd1; + u32 intmod1; + u32 intmsk1; + u32 _res1; + u32 intpnd1; + u32 intoffset1; + u32 subsrcpnd; + u32 intsubmsk; + u32 _res2[4]; + u32 priority_mode1; + u32 priority_update1; + u32 _res3[2]; + u32 srcpnd2; + u32 intmod2; + u32 intmsk2; + u32 _res4; + u32 intpnd2; + u32 intoffset2; + u32 _res5[6]; + u32 priority_mode2; + u32 priority_update2; +}; + +/* System Controller */ +struct s3c2416_sysctl { + u32 lockcon0; + u32 lockcon1; + u32 oscset; + u32 _res1; + u32 mpllcon; + u32 _res2; + u32 epllcon; + u32 epllcon_k; + u32 clksrc; + u32 clkdiv0; + u32 clkdiv1; + u32 clkdiv2; + u32 hclkcon; + u32 pclkcon; + u32 sclkcon; + u32 _res3; + u32 pwrmode; + u32 swrst; + u32 _res4[2]; + u32 busprio; + u32 _res5[3]; + u32 pwrcfg; + u32 rstcon; + u32 rststat; + u32 wkupstat; + u32 inform[4]; + u32 uphyctrl; + u32 uphypwr; + u32 urstcon; + u32 uclkcon; +}; + +#define MPLLCON_MDIV_MASK (0x3FF<<14) +#define MPLLCON_MDIV(x) ((x)<<14) +#define MPLLCON_MDIV_GET(x) (((x)>>14) & 0x3FF) +#define MPLLCON_PDIV_MASK (0x3F<<5) +#define MPLLCON_PDIV(x) ((x)<<5) +#define MPLLCON_PDIV_GET(x) (((x)>>5) & 0x3F) + +#define EPLLCON_MDIV_MASK (0xFF<<16) +#define EPLLCON_MDIV(x) ((x)<<16) +#define EPLLCON_MDIV_GET(x) (((x)>>16) & 0xFF) +#define EPLLCON_PDIV_MASK (0x3F<<8) +#define EPLLCON_PDIV(x) ((x)<<8) +#define EPLLCON_PDIV_GET(x) (((x)>>8) & 0x3F) + +#define PLLCON_SDIV_MASK (0x7<<0) +#define PLLCON_SDIV(x) ((x)<<0) +#define PLLCON_SDIV_GET(x) (((x)>>0) & 0x7) + +#define CLKSRC_MSYSCLK_MPLL (1<<4) +#define CLKSRC_ESYSCLK_EPLL (1<<6) + +#define CLKDIV0_HCLKDIV_MASK (0x3<<0) +#define CLKDIV0_HCLKDIV(x) ((x)<<0) +#define CLKDIV0_HCLKDIV_GET(x) (((x)>>0) & 0x3) +#define CLKDIV0_PCLKDIV (1<<2) +#define CLKDIV0_HALFHCLK (1<<3) +#define CLKDIV0_PREDIV_MASK (3<<4) +#define CLKDIV0_PREDIV(x) ((x)<<4) +#define CLKDIV0_PREDIV_GET(x) (((x)>>4) & 0x3) +#define CLKDIV0_ARMDIV_MASK (7<<9) +#define CLKDIV0_ARMDIV(x) ((x)<<9) +#define CLKDIV0_ARMDIV_GET(x) (((x)>>9) & 0x7) +#define CLKDIV0_DVS (1<<13) + +static inline struct s3c2416_interrupt *s3c2416_get_base_interrupt(void) +{ + return (struct s3c2416_interrupt *)S3C2416_INTERRUPT_BASE; +} + +static inline struct s3c2416_sysctl *s3c2416_get_base_sysctl(void) +{ + return (struct s3c2416_sysctl *)S3C2416_SYSCTL_BASE; +} + +/* Include common stuff */ +#include <asm/arch/s3c24xx.h> + +#endif /*__S3C2416_H__*/ diff --git a/arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h b/arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h new file mode 100644 index 0000000..e54a46b --- /dev/null +++ b/arch/arm/include/asm/arch-s3c24xx/s3c24x0_cpu.h @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* To be able to use s3c24x0 drivers */ + +#ifndef __S3C24X0_CPU_H__ +#define __S3C24X0_CPU_H__ + +#include <asm/arch/s3c24xx_cpu.h> + +#define s3c24x0_rtc s3c24xx_rtc +#define s3c24x0_get_base_rtc s3c24xx_get_base_rtc + +#define S3C24X0_UART0 S3C24XX_UART0 +#define S3C24X0_UART1 S3C24XX_UART1 +#define S3C24X0_UART2 S3C24XX_UART2 +#define S3C24X0_UART3 S3C24XX_UART3 +#define s3c24x0_uart s3c24xx_uart +#define s3c24x0_get_base_uart s3c24xx_get_base_uart + +#endif diff --git a/arch/arm/include/asm/arch-s3c24xx/s3c24xx.h b/arch/arm/include/asm/arch-s3c24xx/s3c24xx.h new file mode 100644 index 0000000..78c6941 --- /dev/null +++ b/arch/arm/include/asm/arch-s3c24xx/s3c24xx.h @@ -0,0 +1,615 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/****************************************************** + * NAME : s3c24xx.h + * + * Common stuff for SAMSUNG S3C24XX SoC (ARM926EJ core) + ******************************************************/ + +#ifndef __S3C24XX_H__ +#define __S3C24XX_H__ + +/* Base addresses for S3C24XX common modules */ +#define S3C24XX_DRAMCTL_BASE 0x48000000 +#define S3C24XX_USB_HOST_BASE 0x49000000 +#define S3C24XX_DMA_BASE 0x4B000000 +#define S3C24XX_NAND_BASE 0x4E000000 +#define S3C24XX_SMC_BASE 0x4F000000 +#define S3C24XX_UART_BASE 0x50000000 +#define S3C24XX_TIMER_BASE 0x51000000 +#define S3C24XX_WATCHDOG_BASE 0x53000000 +#define S3C24XX_I2C_BASE 0x54000000 +#define S3C24XX_I2S_BASE 0x55000000 +#define S3C24XX_GPIO_BASE 0x56000000 +#define S3C24XX_RTC_BASE 0x57000000 +#define S3C24XX_ADC_BASE 0x58000000 + +/* Mobile DRAM Controller */ +struct s3c24xx_dramctl { + u32 bankcfg; + u32 bankcon1; + u32 bankcon2; + u32 bankcon3; + u32 refresh; + u32 timeout; +}; + +#define BANKCFG_VAL_DDR2 0x00049253 + +#define BANKCON1_VAL_DDR2 0x44000040 +#define BANKCON1_INIT_NORMAL 0x0 +#define BANKCON1_INIT_PALL 0x1 +#define BANKCON1_INIT_MRS 0x2 +#define BANKCON1_INIT_EMRS 0x3 + +#define BANKCON2_VAL_DDR2 0x005D0035 + +#define BANKCON3_VAL_EMRS1 0x44000000 +#define BANKCON3_EMRS1_CAS3 (3<<4) +#define BANKCON3_EMRS1_OCD7 (7<<23) +#define BANKCON3_VAL_EMRS2 0x80000000 +#define BANKCON3_VAL_EMRS3 0xC0000000 +#define BANKCON3_VAL_MRS 0x44000030 +#define BANKCON3_MRS_DLL_RESET (1<<8) + +/* USB Host Controller */ +struct s3c24xx_usb_host { + u32 HcRevision; + u32 HcControl; + u32 HcCommonStatus; + u32 HcInterruptStatus; + u32 HcInterruptEnable; + u32 HcInterruptDisable; + u32 HcHCCA; + u32 HcPeriodCuttendED; + u32 HcControlHeadED; + u32 HcControlCurrentED; + u32 HcBulkHeadED; + u32 HcBuldCurrentED; + u32 HcDoneHead; + u32 HcRmInterval; + u32 HcFmRemaining; + u32 HcFmNumber; + u32 HcPeriodicStart; + u32 HcLSThreshold; + u32 HcRhDescriptorA; + u32 HcRhDescriptorB; + u32 HcRhStatus; + u32 HcRhPortStatus1; + u32 HcRhPortStatus2; +}; + +/* DMA Controller */ +struct s3c24xx_dma { + u32 disrc; + u32 disrcc; + u32 didst; + u32 didstc; + u32 dcon; + u32 dstat; + u32 dcsrc; + u32 dcdst; + u32 dmasktrig; + u32 dmareqsel0; +}; + +/* NAND Flash Controller */ +struct s3c24xx_nand { + u32 nfconf; + u32 nfcont; + u32 nfcmmd; + u32 nfaddr; + u32 nfdata; + u32 nfmeccd[2]; + u32 nfseccd; + u32 nfsblk; + u32 nfeblk; + u32 nfstat; + u32 nfeccerr[2]; + u32 nfmecc[2]; + u32 nfsecc; + u32 nfmlcbitpt; +#if !(defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413)) + u32 nf8eccerr[3]; + u32 nfm8ecc[4]; + u32 nfmlc8bitpt[2]; +#endif +}; + +#if defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413) +#define NFCONF_ECCTYPE_MASK (1<<24) +#define NFCONF_ECCTYPE_1BIT (0<<24) +#define NFCONF_ECCTYPE_4BIT (1<<24) +#else +#define NFCONF_ECCTYPE_MASK (3<<23) +#define NFCONF_ECCTYPE_1BIT (0<<23) +#define NFCONF_ECCTYPE_8BIT (1<<23) +#define NFCONF_ECCTYPE_4BIT (2<<23) +#endif +#define NFCONF_TACLS_MASK (7<<12) +#define NFCONF_TWRPH0_MASK (7<<8) +#define NFCONF_TWRPH1_MASK (7<<4) +#define NFCONF_TACLS(x) ((x)<<12) +#define NFCONF_TWRPH0(x) ((x)<<8) +#define NFCONF_TWRPH1(x) ((x)<<4) + +#define NFCONT_ENABLE (1<<0) +#define NFCONT_NCE0 (1<<1) +#define NFCONT_NCE1 (1<<2) +#define NFCONT_INITSECC (1<<4) +#define NFCONT_INITMECC (1<<5) +#define NFCONT_SECCLOCK (1<<6) +#define NFCONT_MECCLOCK (1<<7) +#define NFCONT_WP (1<<16) +#define NFCONT_ECC_ENC (1<<18) + +#define NFSTAT_RNB (1<<0) + +/* SMC */ +struct s3c24xx_smc { + u32 smbidcy; + u32 smbwstrd; + u32 smbwstwr; + u32 smbwstoen; + u32 smbwstwen; + u32 smbc; + u32 smbs; + u32 smbwstbrd; +}; + +#define SMBC_RBLE (1<<0) +#define SMBC_WAIT_POL (1<<1) +#define SMBC_WAIT_EN (1<<2) +#define SMBC_MW_MASK (0x3<<4) +#define SMBC_MW_16BIT (1<<4) +#define SMBC_MW_8BIT (0<<4) +#define SMBC_DRNCS (1<<7) +#define SMBC_RSMAVD_RD (1<<12) +#define SMBC_DRNOWE (1<<15) +#define SMBC_RSMAVD_WR (1<<20) + +/* UART */ +struct s3c24xx_uart { + u32 ulcon; + u32 ucon; + u32 ufcon; + u32 umcon; + u32 utrstat; + u32 uerstat; + u32 ufstat; + u32 umstat; +#ifdef __BIG_ENDIAN + u8 _res1[3]; + u8 utxh; + u8 _res2[3]; + u8 urxh; +#else /* Little Endian */ + u8 utxh; + u8 _res1[3]; + u8 urxh; + u8 _res2[3]; +#endif + u32 ubrdiv; + u32 udivslot; +}; + +#define ULCON_8N1 0x03 + +#define UCON_POLL 0x005 + +#define UMCON_NOAFC 0 + +#define UFCON_FIFOMODE (1<<0) +#define UFCON_RESETRX (1<<1) +#define UFCON_RESETTX (1<<2) + +#define UTRSTAT_RXDR (1<<0) +#define UTRSTAT_TXFE (1<<1) +#define UTRSTAT_TXE (1<<2) + +/* PWM Timer */ +struct s3c24xx_timer { + u32 tcntb; + u32 tcmpb; + u32 tcnto; +}; + +struct s3c24xx_timers { + u32 tcfg0; + u32 tcfg1; + u32 tcon; + struct s3c24xx_timer ch[4]; + u32 tcntb4; + u32 tcnto4; +}; + +#define TCFG0_PRESCALER1_MASK (0xFF<<8) +#define TCFG0_PRESCALER1(x) ((x)<<8) + +#define TCFG1_MUX4_DIV2 (0<<16) +#define TCFG1_MUX4_DIV4 (1<<16) +#define TCFG1_MUX4_DIV8 (2<<16) +#define TCFG1_MUX4_DIV16 (3<<16) +#define TCFG1_MUX4_TCLK1 (4<<16) +#define TCFG1_MUX4_MASK (0xF<<16) + +#define TCON_T4START (1<<20) +#define TCON_T4MANUALUPD (1<<21) +#define TCON_T4RELOAD (1<<22) + +/* Watchdog Timer */ +struct s3c24xx_watchdog { + u32 wtcon; + u32 wtdat; + u32 wtcnt; +}; + +#define WTCON_DISABLE_VAL 0 +#define WTCON_RSTEN (1<<0) +#define WTCON_INTEN (1<<2) +#define WTCON_ENABLE (1<<5) + +/* IIC-Bus Interface */ +struct s3c24xx_i2c { + u32 iiccon; + u32 iicstat; + u32 iicadd; + u32 iicds; + u32 iiclc; +}; + +/* IIS-Bus Interface */ +struct s3c24xx_i2s { + u32 iiscon; + u32 iismod; + u32 iisfic; + u32 iispsr; + u32 iistxd; + u32 iisrxd; +}; + +/* I/O Ports */ +struct s3c24xx_gpio { +#if defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413) + u32 gpacon; + u32 gpadat; + u32 _res1[2]; + u32 gpbcon; + u32 gpbdat; + u32 gpbdn; + u32 gpbslpcon; + u32 gpccon; + u32 gpcdat; + u32 gpcdn; + u32 gpcslpcon; + u32 gpdcon; + u32 gpddat; + u32 gpddn; + u32 gpdslpcon; + u32 gpecon; + u32 gpedat; + u32 gpedn; + u32 gpeslpcon; + u32 gpfcon; + u32 gpfdat; + u32 gpfdn; + u32 _res2; + u32 gpgcon; + u32 gpgdat; + u32 gpgdn; + u32 gpgslpcon; + u32 gphcon; + u32 gphdat; + u32 gphdn; + u32 gphslpcon; + u32 gpjcon; + u32 gpjdat; + u32 gpjdn; + u32 gpjslpcon; + + u32 misccr; + u32 dclkcon; + u32 extint[3]; + u32 eintflt[4]; + u32 eintmask; + u32 eintpend; + u32 gstatus[6]; + u32 mstcon; + u32 mslcon; + u32 dsc[2]; +#else + u32 gpacon; + u32 gpadat; + u32 _res1[2]; + u32 gpbcon; + u32 gpbdat; + u32 gpbudp; + u32 gpbsel; + u32 gpccon; + u32 gpcdat; + u32 gpcudp; + u32 _res2; + u32 gpdcon; + u32 gpddat; + u32 gpdudp; + u32 _res3; + u32 gpecon; + u32 gpedat; + u32 gpeudp; + u32 gpesel; + u32 gpfcon; + u32 gpfdat; + u32 gpfudp; + u32 _res4; + u32 gpgcon; + u32 gpgdat; + u32 gpgudp; + u32 _res5; + u32 gphcon; + u32 gphdat; + u32 gphudp; + u32 _res6; + + u32 misccr; + u32 dclkcon; + u32 extint[3]; + u32 _res7[2]; + u32 eintflt2; + u32 eintflt3; + u32 eintmask; + u32 eintpend; + u32 gstatus[2]; + u32 _res8[3]; + u32 dsc[4]; + + u32 gpjcon; + u32 gpjdat; + u32 gpjudp; + u32 gpjsel; + u32 gpkcon; + u32 gpkdat; + u32 gpkudp; + u32 _res9; + u32 gplcon; + u32 gpldat; + u32 gpludp; + u32 gplsel; + u32 gpmcon; + u32 gpmdat; + u32 gpmudp; + u32 _res10; + + u32 dsc3; + u32 pddmcon; + u32 pdsmcon; +#endif +}; + +#define GPACON_NRCS1 (1<<12) +#define GPACON_CLE (1<<17) +#define GPACON_ALE (1<<18) +#define GPACON_NFWE (1<<19) +#define GPACON_NFRE (1<<20) +#define GPACON_NRSTOUT (1<<21) +#define GPACON_NFCE (1<<22) + +#define GPCCON_MASK(x) (0x3 << ((x) * 2)) +#define GPCCON_OUTPUT(x) (0x1 << ((x) * 2)) +#define GPCDAT(x) (1 << (x)) + +#define GPHCON_MASK(x) (0x3 << ((x) * 2)) +#define GPHCON_TXD(x) (0x2 << ((x) * 4)) +#define GPHCON_RXD(x) (0x2 << (((x) * 4) + 2)) + +/* RTC */ +struct s3c24xx_rtc { +#ifdef __BIG_ENDIAN + u8 _res1[67]; + u8 rtccon; + u8 _res2[3]; + u8 ticnt0; +#if defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413) + u8 _res3[4]; +#else + u8 _res3[3]; + u8 ticnt2; +#endif + u8 _res4[3]; + u8 ticnt1; + u8 _res5[3]; + u8 rtcalm; + u8 _res6[3]; + u8 almsec; + u8 _res7[3]; + u8 almmin; + u8 _res8[3]; + u8 almhour; + u8 _res9[3]; + u8 almdate; + u8 _res10[3]; + u8 almmon; + u8 _res11[3]; + u8 almyear; + u8 _res12[7]; + u8 bcdsec; + u8 _res13[3]; + u8 bcdmin; + u8 _res14[3]; + u8 bcdhour; + u8 _res15[3]; + u8 bcddate; + u8 _res16[3]; + u8 bcdday; + u8 _res17[3]; + u8 bcdmon; + u8 _res18[3]; + u8 bcdyear; +#if !(defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413)) + u8 _res19[3]; + u8 tickcnt; +#endif +#else /* little endian */ + u8 _res0[64]; + u8 rtccon; + u8 _res1[3]; + u8 ticnt0; + u8 _res2[3]; +#if defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413) + u8 _res3[4]; +#else + u8 ticnt2; + u8 _res3[3]; +#endif + u8 ticnt1; + u8 _res4[3]; + u8 rtcalm; + u8 _res5[3]; + u8 almsec; + u8 _res6[3]; + u8 almmin; + u8 _res7[3]; + u8 almhour; + u8 _res8[3]; + u8 almdate; + u8 _res9[3]; + u8 almmon; + u8 _res10[3]; + u8 almyear; + u8 _res11[7]; + u8 bcdsec; + u8 _res12[3]; + u8 bcdmin; + u8 _res13[3]; + u8 bcdhour; + u8 _res14[3]; + u8 bcddate; + u8 _res15[3]; + u8 bcdday; + u8 _res16[3]; + u8 bcdmon; + u8 _res17[3]; + u8 bcdyear; + u8 _res18[3]; +#if !(defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413)) + u8 tickcnt; + u8 _res19[3]; +#endif +#endif +}; + +#define RTCCON_RTCEN (1<<0) +#define RTCCON_CNTSEL (1<<2) +#define RTCCON_CLKRST (1<<3) +#define RTCCON_TICSEL (1<<4) + +/* ADC & Touch Screen Interface */ +struct s3c24xx_adc { + u32 adccon; + u32 adctsc; + u32 adcdly; + u32 adcdat0; + u32 adcdat1; +#if !(defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413)) + u32 adcupdn; + u32 adcmux; +#endif +}; + +static inline struct s3c24xx_dramctl *s3c24xx_get_base_dramctl(void) +{ + return (struct s3c24xx_dramctl *)S3C24XX_DRAMCTL_BASE; +} + +static inline struct s3c24xx_usb_host *s3c24xx_get_base_usb_host(void) +{ + return (struct s3c24xx_usb_host *)S3C24XX_USB_HOST_BASE; +} + +static inline struct s3c24xx_dma *s3c24xx_get_base_dma(enum s3c24xx_dmas n) +{ +#if defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413) + return (struct s3c24xx_dma *)(S3C24XX_DMA_BASE + (n * 0x40)); +#else + return (struct s3c24xx_dma *)(S3C24XX_DMA_BASE + (n * 0x100)); +#endif +} + +static inline struct s3c24xx_nand *s3c24xx_get_base_nand(void) +{ + return (struct s3c24xx_nand *)S3C24XX_NAND_BASE; +} + +static inline struct s3c24xx_smc *s3c24xx_get_base_smc(enum s3c24xx_smcs n) +{ + return (struct s3c24xx_smc *)(S3C24XX_SMC_BASE + (n * 0x20)); +} + +static inline struct s3c24xx_uart *s3c24xx_get_base_uart(enum s3c24xx_uarts n) +{ + return (struct s3c24xx_uart *)(S3C24XX_UART_BASE + (n * 0x4000)); +} + +static inline struct s3c24xx_timers *s3c24xx_get_base_timers(void) +{ + return (struct s3c24xx_timers *)S3C24XX_TIMER_BASE; +} + +static inline struct s3c24xx_watchdog *s3c24xx_get_base_watchdog(void) +{ + return (struct s3c24xx_watchdog *)S3C24XX_WATCHDOG_BASE; +} + +static inline struct s3c24xx_i2c *s3c24xx_get_base_i2c(void) +{ + return (struct s3c24xx_i2c *)S3C24XX_I2C_BASE; +} + +static inline struct s3c24xx_i2s *s3c24xx_get_base_i2s(void) +{ + return (struct s3c24xx_i2s *)S3C24XX_I2S_BASE; +} + +static inline struct s3c24xx_gpio *s3c24xx_get_base_gpio(void) +{ + return (struct s3c24xx_gpio *)S3C24XX_GPIO_BASE; +} + +static inline struct s3c24xx_rtc *s3c24xx_get_base_rtc(void) +{ + return (struct s3c24xx_rtc *)S3C24XX_RTC_BASE; +} + +static inline struct s3c24xx_adc *s3c24xx_get_base_adc(void) +{ + return (struct s3c24xx_adc *)S3C24XX_ADC_BASE; +} + +static inline char *s3c24xx_get_cpu_name(void) +{ + return S3C24XX_CPU_NAME; +} + +extern ulong get_ARMCLK(void); + +#endif /*__S3C24XX_H__*/ diff --git a/arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h b/arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h new file mode 100644 index 0000000..59ccfd4 --- /dev/null +++ b/arch/arm/include/asm/arch-s3c24xx/s3c24xx_cpu.h @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#if defined(CONFIG_S3C2412) || defined(CONFIG_S3C2413) +#include <asm/arch/s3c2412.h> +#elif defined(CONFIG_S3C2416) || defined(CONFIG_S3C2450) +#include <asm/arch/s3c2416.h> +#else +#error Please define the S3C24XX SoC type +#endif diff --git a/arch/arm/include/asm/arch-s3c24xx/spl.h b/arch/arm/include/asm/arch-s3c24xx/spl.h new file mode 100644 index 0000000..2741fe7 --- /dev/null +++ b/arch/arm/include/asm/arch-s3c24xx/spl.h @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _ASM_ARCH_SPL_H_ +#define _ASM_SPL_H_ + +#define BOOT_DEVICE_NAND 1 +#define BOOT_DEVICE_MMC1 2 + +#endif diff --git a/include/common.h b/include/common.h index c10d745..b63e814 100644 --- a/include/common.h +++ b/include/common.h @@ -628,6 +628,7 @@ ulong get_OPB_freq (void); ulong get_PCI_freq (void); #endif #if defined(CONFIG_S3C24X0) || \ + defined(CONFIG_S3C24XX) || \ defined(CONFIG_LH7A40X) || \ defined(CONFIG_S3C6400) || \ defined(CONFIG_EP93XX)
S3C2416 and S3C2450 have 4 UARTs insted of 3 found on older chips. This patch adds support to the additional UART port and changes the mapping between CONFIG_SERIAL? and S3C24X0_UART? in order they have a direct correspondence.
Signed-off-by: José Miguel Gonçalves jose.goncalves@inov.pt --- Changes for v2: - New patch
Changes for v3: - None --- drivers/serial/serial_s3c24x0.c | 25 ++++++++++++++++++------- include/configs/VCMA9.h | 2 +- include/configs/smdk2410.h | 2 +- 3 files changed, 20 insertions(+), 9 deletions(-)
diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c index 12bcdd3..280cd2d 100644 --- a/drivers/serial/serial_s3c24x0.c +++ b/drivers/serial/serial_s3c24x0.c @@ -2,6 +2,9 @@ * (C) Copyright 2002 * Gary Jennejohn, DENX Software Engineering, garyj@denx.de * + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or @@ -24,17 +27,20 @@
-#ifdef CONFIG_SERIAL1 +#if defined(CONFIG_SERIAL0) #define UART_NR S3C24X0_UART0
-#elif defined(CONFIG_SERIAL2) +#elif defined(CONFIG_SERIAL1) #define UART_NR S3C24X0_UART1
-#elif defined(CONFIG_SERIAL3) +#elif defined(CONFIG_SERIAL2) #define UART_NR S3C24X0_UART2
+#elif defined(CONFIG_SERIAL3) +#define UART_NR S3C24X0_UART3 + #else -#error "Bad: you didn't configure serial ..." +#error "You didn't configure serial." #endif
#include <asm/io.h> @@ -310,15 +316,20 @@ INIT_S3C_SERIAL_STRUCTURE(1, "s3ser1"); DECLARE_S3C_SERIAL_FUNCTIONS(2); struct serial_device s3c24xx_serial2_device = INIT_S3C_SERIAL_STRUCTURE(2, "s3ser2"); +DECLARE_S3C_SERIAL_FUNCTIONS(3); +struct serial_device s3c24xx_serial3_device = +INIT_S3C_SERIAL_STRUCTURE(3, "s3ser3");
__weak struct serial_device *default_serial_console(void) { -#if defined(CONFIG_SERIAL1) +#if defined(CONFIG_SERIAL0) return &s3c24xx_serial0_device; -#elif defined(CONFIG_SERIAL2) +#elif defined(CONFIG_SERIAL1) return &s3c24xx_serial1_device; -#elif defined(CONFIG_SERIAL3) +#elif defined(CONFIG_SERIAL2) return &s3c24xx_serial2_device; +#elif defined(CONFIG_SERIAL3) + return &s3c24xx_serial3_device; #else #error "CONFIG_SERIAL? missing." #endif diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 6ad4a6b..82db58f 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -122,7 +122,7 @@ * select serial console configuration */ #define CONFIG_S3C24X0_SERIAL -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on VCMA9 */ +#define CONFIG_SERIAL0 1 /* we use SERIAL 0 on VCMA9 */
/* USB support (currently only works with D-cache off) */ #define CONFIG_USB_OHCI diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 8792c85..ea05f16 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -62,7 +62,7 @@ * select serial console configuration */ #define CONFIG_S3C24X0_SERIAL -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SMDK2410 */ +#define CONFIG_SERIAL0 1 /* we use SERIAL 0 on SMDK2410 */
/************************************************************ * USB support (currently only works with D-cache off)
The values stored in the baud rate divisor register (UBRDIVn) and dividing slot register (UDIVSLOTn), are used to determine the serial baudrate. Previously only UBRDIVn was set. This patch initializes also UDIVSLOTn which allows to obtain a more precise baudrate.
Changes for v3: - Verbose patch description --- drivers/serial/serial_s3c24x0.c | 24 ++++++++++++++++++++---- 1 file changed, 20 insertions(+), 4 deletions(-)
diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c index 280cd2d..c9bc121 100644 --- a/drivers/serial/serial_s3c24x0.c +++ b/drivers/serial/serial_s3c24x0.c @@ -92,16 +92,32 @@ DECLARE_GLOBAL_DATA_PTR; static int hwflow; #endif
+/* + * The values stored in the baud rate divisor register (UBRDIVn) and dividing + * slot register (UDIVSLOTn), are used to determine the serial Tx/Rx clock rate + * (baud rate) as follows: + * DIV_VAL = UBRDIVn + (num of 1’s in UDIVSLOTn) / 16 + * Using UDIVSLOT, which is the factor of floating point divisor, you can make + * more accurate baud rate. Section 2.1.10 of the S3C2416 User's Manual suggests + * using the constants on the following table. + */ +static const int udivslot[] = { + 0x0000, 0x0080, 0x0808, 0x0888, 0x2222, 0x4924, 0x4A52, 0x54AA, + 0x5555, 0xD555, 0xD5D5, 0xDDD5, 0xDDDD, 0xDFDD, 0xDFDF, 0xFFDF, +}; + void _serial_setbrg(const int dev_index) { struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); - unsigned int reg = 0; + u32 pclk; + u32 baudrate; int i;
- /* value is calculated so : (int)(PCLK/16./baudrate) -1 */ - reg = get_PCLK() / (16 * gd->baudrate) - 1; + pclk = get_PCLK(); + baudrate = gd->baudrate;
- writel(reg, &uart->ubrdiv); + writel((pclk / baudrate / 16) - 1, &uart->ubrdiv); + writel(udivslot[(pclk / baudrate) % 16], &uart->udivslot); for (i = 0; i < 100; i++) /* Delay */ ; }
The loop used to make a delay after baudrate setting is not necessary. Moreover it is removed by the GCC optimizer (at least with GCC 4.6).
Changes for v3: - None --- drivers/serial/serial_s3c24x0.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c index c9bc121..ec5d1cb 100644 --- a/drivers/serial/serial_s3c24x0.c +++ b/drivers/serial/serial_s3c24x0.c @@ -111,15 +111,12 @@ void _serial_setbrg(const int dev_index) struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index); u32 pclk; u32 baudrate; - int i;
pclk = get_PCLK(); baudrate = gd->baudrate;
writel((pclk / baudrate / 16) - 1, &uart->ubrdiv); writel(udivslot[(pclk / baudrate) % 16], &uart->udivslot); - for (i = 0; i < 100; i++) - /* Delay */ ; }
#if defined(CONFIG_SERIAL_MULTI)
A better approach to avoid reading the RTC during updates, as sugested in the S3C2416 User's Manual.
Changes for v3: - Removed unneeded parenthesis --- drivers/rtc/s3c24x0_rtc.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/rtc/s3c24x0_rtc.c b/drivers/rtc/s3c24x0_rtc.c index c16ff2e..b31dc53 100644 --- a/drivers/rtc/s3c24x0_rtc.c +++ b/drivers/rtc/s3c24x0_rtc.c @@ -65,20 +65,26 @@ int rtc_get(struct rtc_time *tmp) uchar sec, min, hour, mday, wday, mon, year; __maybe_unused uchar a_sec, a_min, a_hour, a_date, a_mon, a_year, a_armed; + int have_retried = 0;
/* enable access to RTC registers */ SetRTC_Access(RTC_ENABLE);
/* read RTC registers */ do { - sec = readb(&rtc->bcdsec); min = readb(&rtc->bcdmin); hour = readb(&rtc->bcdhour); mday = readb(&rtc->bcddate); wday = readb(&rtc->bcdday); mon = readb(&rtc->bcdmon); year = readb(&rtc->bcdyear); - } while (sec != readb(&rtc->bcdsec)); + sec = readb(&rtc->bcdsec); + /* + * The only way to work out whether the RTC was mid-update + * when we read it is to check the seconds counter. + * If it's zero, then we re-try the entire read. + */ + } while (sec == 0 && !have_retried++);
/* read ALARM registers */ a_sec = readb(&rtc->almsec);
rtc_reset() must set the RTC date to the UNIX Epoch.
Changes for v3: - None --- drivers/rtc/s3c24x0_rtc.c | 15 +++++++++++---- 1 file changed, 11 insertions(+), 4 deletions(-)
diff --git a/drivers/rtc/s3c24x0_rtc.c b/drivers/rtc/s3c24x0_rtc.c index b31dc53..3fd5cec 100644 --- a/drivers/rtc/s3c24x0_rtc.c +++ b/drivers/rtc/s3c24x0_rtc.c @@ -167,10 +167,17 @@ int rtc_set(struct rtc_time *tmp)
void rtc_reset(void) { - struct s3c24x0_rtc *rtc = s3c24x0_get_base_rtc(); - - writeb((readb(&rtc->rtccon) & ~0x06) | 0x08, &rtc->rtccon); - writeb(readb(&rtc->rtccon) & ~(0x08 | 0x01), &rtc->rtccon); + static struct rtc_time tmp = { + .tm_year = 1970, + .tm_mon = 1, + .tm_mday = 1, + .tm_wday = 4, + .tm_hour = 0, + .tm_min = 0, + .tm_sec = 0, + }; + + rtc_set(&tmp); }
#endif
This RTC only supports a 100 years range so rtc_set() should not allow setting years bellow 1970 or above 2069.
Changes for v3: - None --- drivers/rtc/s3c24x0_rtc.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/rtc/s3c24x0_rtc.c b/drivers/rtc/s3c24x0_rtc.c index 3fd5cec..bcd6d44 100644 --- a/drivers/rtc/s3c24x0_rtc.c +++ b/drivers/rtc/s3c24x0_rtc.c @@ -139,6 +139,11 @@ int rtc_set(struct rtc_time *tmp) tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, tmp->tm_hour, tmp->tm_min, tmp->tm_sec); #endif + if (tmp->tm_year < 1970 || tmp->tm_year > 2069) { + puts("ERROR: year should be between 1970 and 2069!\n"); + return -1; + } + year = bin2bcd(tmp->tm_year % 100); mon = bin2bcd(tmp->tm_mon); wday = bin2bcd(tmp->tm_wday);
NAND Flash driver with HW ECC for the S3C24XX SoCs. Currently it only supports SLC NAND chips.
Signed-off-by: José Miguel Gonçalves jose.goncalves@inov.pt --- Changes for v2: - Coding style cleanup - Use of clrsetbits_le32() - Use of register bit macros instead of magic numbers
Changes for v3: - Removed magic numbers - Removed a macro to declare a void printf() - Replaced one printf() with a puts() --- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/s3c24xx_nand.c | 246 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 247 insertions(+) create mode 100644 drivers/mtd/nand/s3c24xx_nand.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 29dc20e..791ec44 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -60,6 +60,7 @@ COBJS-$(CONFIG_NAND_MXS) += mxs_nand.o COBJS-$(CONFIG_NAND_NDFC) += ndfc.o COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o +COBJS-$(CONFIG_NAND_S3C24XX) += s3c24xx_nand.o COBJS-$(CONFIG_NAND_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_NAND_SPEAR) += spr_nand.o COBJS-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o diff --git a/drivers/mtd/nand/s3c24xx_nand.c b/drivers/mtd/nand/s3c24xx_nand.c new file mode 100644 index 0000000..3c13709 --- /dev/null +++ b/drivers/mtd/nand/s3c24xx_nand.c @@ -0,0 +1,246 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * Based on drivers/mtd/nand/s3c64xx.c and U-Boot 1.3.4 from Samsung. + * Supports only SLC NAND Flash chips. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <nand.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/s3c24xx_cpu.h> + +#define TACLS_VAL 7 /* CLE & ALE duration setting (0~7) */ +#define TWRPH0_VAL 7 /* TWRPH0 duration setting (0~7) */ +#define TWRPH1_VAL 7 /* TWRPH1 duration setting (0~7) */ + +#define MAX_CHIPS 2 +static int nand_cs[MAX_CHIPS] = { 0, 1 }; + +static void s3c_nand_select_chip(struct mtd_info *mtd, int chip) +{ + struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); + u_long nfcont; + + nfcont = readl(&nand->nfcont); + + switch (chip) { + case -1: + nfcont |= NFCONT_NCE1 | NFCONT_NCE0; + break; + case 0: + nfcont &= ~NFCONT_NCE0; + break; + case 1: + nfcont &= ~NFCONT_NCE1; + break; + default: + return; + } + + writel(nfcont, &nand->nfcont); +} + +/* + * Hardware specific access to control-lines function + */ +static void s3c_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) +{ + struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); + struct nand_chip *this = mtd->priv; + + if (ctrl & NAND_CTRL_CHANGE) { + if (ctrl & NAND_CLE) + this->IO_ADDR_W = &nand->nfcmmd; + else if (ctrl & NAND_ALE) + this->IO_ADDR_W = &nand->nfaddr; + else + this->IO_ADDR_W = &nand->nfdata; + if (ctrl & NAND_NCE) + s3c_nand_select_chip(mtd, *(int *)this->priv); + else + s3c_nand_select_chip(mtd, -1); + } + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); +} + +/* + * Function for checking device ready pin + */ +static int s3c_nand_device_ready(struct mtd_info *mtdinfo) +{ + struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); + + return readl(&nand->nfstat) & NFSTAT_RNB; +} + +#ifdef CONFIG_S3C24XX_NAND_HWECC +/* + * This function is called before encoding ECC codes to ready ECC engine. + */ +static void s3c_nand_enable_hwecc(struct mtd_info *mtd, int mode) +{ + struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); + + /* Set 1-bit ECC */ + clrsetbits_le32(&nand->nfconf, NFCONF_ECCTYPE_MASK, + NFCONF_ECCTYPE_1BIT); + + /* Initialize & unlock ECC */ + clrsetbits_le32(&nand->nfcont, NFCONT_MECCLOCK, NFCONT_INITMECC); +} + +/* + * This function is called immediately after encoding ECC codes. + * This function returns encoded ECC codes. + */ +static int s3c_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, + u_char *ecc_code) +{ + struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); + u_long nfmecc0; + + /* Lock ECC */ + setbits_le32(&nand->nfcont, NFCONT_MECCLOCK); + + /* Return 1-bit ECC */ + nfmecc0 = readl(&nand->nfmecc[0]); + + ecc_code[0] = nfmecc0 & 0xff; + ecc_code[1] = (nfmecc0 >> 8) & 0xff; + ecc_code[2] = (nfmecc0 >> 16) & 0xff; + ecc_code[3] = (nfmecc0 >> 24) & 0xff; + + return 0; +} + +/* + * This function determines whether read data is good or not. + * On SLC, must write ECC codes to controller before reading status bit. + * If status bit is good, return 0. + * If a correctable error occured, correct it and return 1. + * If an uncorrectable error occured, return -1. + */ +static int s3c_nand_correct_data(struct mtd_info *mtd, u_char *dat, + u_char *read_ecc, u_char *calc_ecc) +{ + struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); + int ret; + u_long nfeccerr0, nfmeccdata0, nfmeccdata1, err_byte_addr; + u_char err_type, repaired; + + /* SLC: Write ECC to compare */ + nfmeccdata0 = (((u_long) read_ecc[1]) << 16) | read_ecc[0]; + nfmeccdata1 = (((u_long) read_ecc[3]) << 16) | read_ecc[2]; + writel(nfmeccdata0, &nand->nfmeccd[0]); + writel(nfmeccdata1, &nand->nfmeccd[1]); + + /* Read ECC status */ + nfeccerr0 = readl(&nand->nfeccerr[0]); + err_type = nfeccerr0 & 0x3; + + switch (err_type) { + case 0: /* No error */ + ret = 0; + break; + + case 1: + /* + * 1 bit error (Correctable) + * (nfeccerr0 >> 7) & 0x7ff :error byte number + * (nfeccerr0 >> 4) & 0x7 :error bit number + */ + err_byte_addr = (nfeccerr0 >> 7) & 0x7ff; + repaired = dat[err_byte_addr] ^ (1 << ((nfeccerr0 >> 4) & 0x7)); + + printf("S3C24XX NAND: 1 bit error detected at byte %ld. " + "Correcting from 0x%02x to 0x%02x\n", + err_byte_addr, dat[err_byte_addr], repaired); + + dat[err_byte_addr] = repaired; + + ret = 1; + break; + + case 2: /* Multiple error */ + case 3: /* ECC area error */ + puts("S3C24XX NAND: ECC uncorrectable error detected.\n"); + ret = -1; + break; + } + + return ret; +} +#endif /* CONFIG_S3C24XX_NAND_HWECC */ + +/* + * Board-specific NAND initialization. + */ +int board_nand_init(struct nand_chip *nand) +{ + static int chip_n; + struct s3c24xx_nand *const nand_reg = s3c24xx_get_base_nand(); + + if (chip_n == 0) { + /* Extend NAND timings to the maximum */ + clrsetbits_le32(&nand_reg->nfconf, + NFCONF_TACLS_MASK | NFCONF_TWRPH0_MASK | + NFCONF_TWRPH1_MASK, + NFCONF_TACLS(TACLS_VAL) | + NFCONF_TWRPH0(TWRPH0_VAL) | + NFCONF_TWRPH1(TWRPH1_VAL)); + + /* Disable chip selects and soft lock, enable controller */ + clrsetbits_le32(&nand_reg->nfcont, NFCONT_WP, + NFCONT_NCE1 | NFCONT_NCE0 | NFCONT_ENABLE); + } else if (chip_n >= MAX_CHIPS) { + return -ENODEV; + } + + nand->IO_ADDR_R = &nand_reg->nfdata; + nand->IO_ADDR_W = &nand_reg->nfdata; + nand->cmd_ctrl = s3c_nand_hwcontrol; + nand->dev_ready = s3c_nand_device_ready; + nand->select_chip = s3c_nand_select_chip; + nand->options = 0; +#ifdef CONFIG_SPL_BUILD + nand->read_buf = nand_read_buf; +#endif + +#ifdef CONFIG_S3C24XX_NAND_HWECC + nand->ecc.hwctl = s3c_nand_enable_hwecc; + nand->ecc.calculate = s3c_nand_calculate_ecc; + nand->ecc.correct = s3c_nand_correct_data; + nand->ecc.mode = NAND_ECC_HW_OOB_FIRST; + nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE; + nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES; +#else + nand->ecc.mode = NAND_ECC_SOFT; +#endif /* ! CONFIG_S3C24XX_NAND_HWECC */ + + nand->priv = nand_cs + chip_n++; + + return 0; +}
Changes for v2:
Changes for v3:
- (C) Copyright 2012 INOV - INESC Inovacao
- Jose Goncalves jose.goncalves@inov.pt
- Based on drivers/mtd/nand/s3c64xx.c and U-Boot 1.3.4 from Samsung.
- Supports only SLC NAND Flash chips.
- project.
- MA 02111-1307 USA
Please use space, not tab, as a word separator (after the second #define).
This needs explanation (and const). Better would be to use a priv struct, as discussed before.
- struct s3c24xx_nand *const nand = s3c24xx_get_base_nand();
- u_long nfcont;
s/u_long/u32/
- nfcont = readl(&nand->nfcont);
- switch (chip) {
- case -1:
break;
- case 0:
break;
- case 1:
break;
- default:
return;
error message on default?
- writel(nfcont, &nand->nfcont);
- Hardware specific access to control-lines function
- struct nand_chip *this = mtd->priv;
- if (ctrl & NAND_CTRL_CHANGE) {
else
else
- if (cmd != NAND_CMD_NONE)
As discussed earlier, do you really need to mess with IO_ADDR_W or can you do it the way ndfc.c does?
I.e.:
static void s3c_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct s3c24xx_nand *const nand = s3c24xx_get_base_nand(); struct nand_chip *this = mtd->priv;
if (cmd == NAND_CMD_NONE) return;
if (ctrl & NAND_CLE) writeb(cmd, &nand->nfcmmd); else writeb(cmd, &nand->nfaddr); }
- Board-specific NAND initialization.
- static int chip_n;
- struct s3c24xx_nand *const nand_reg = s3c24xx_get_base_nand();
- if (chip_n == 0) {
NFCONF_TWRPH1_MASK,
controller */
NFCONT_ENABLE);
- } else if (chip_n >= MAX_CHIPS) {
return -ENODEV;
- nand->IO_ADDR_R = &nand_reg->nfdata;
- nand->IO_ADDR_W = &nand_reg->nfdata;
- nand->cmd_ctrl = s3c_nand_hwcontrol;
- nand->dev_ready = s3c_nand_device_ready;
- nand->select_chip = s3c_nand_select_chip;
- nand->options = 0;
- nand->read_buf = nand_read_buf;
- nand->ecc.hwctl = s3c_nand_enable_hwecc;
- nand->ecc.calculate = s3c_nand_calculate_ecc;
- nand->ecc.correct = s3c_nand_correct_data;
- nand->ecc.mode = NAND_ECC_HW_OOB_FIRST;
- nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE;
- nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES;
+#else
- nand->ecc.mode = NAND_ECC_SOFT;
- nand->priv = nand_cs + chip_n++;
Please consider using the new SELF_INIT mechanism.
-Scott
Changes for v2:
Changes for v3:
- project.
- MA 02111-1307 USA
OK.
- u_long nfcont;
s/u_long/u32/
Didn't catch this...
- switch (chip) {
- case -1:
break;
- case 0:
break;
- case 1:
break;
- default:
return;
OK.
else
else
I will take a look at ndfc.c. Most of this driver was copy-paste from s3c64xx.c driver and an older patched U-Boot sources from Samsung, so I did not make any real code examination after it started to work...
I.e.:
if (cmd == NAND_CMD_NONE) return; if (ctrl & NAND_CLE) writeb(cmd, &nand->nfcmmd); else writeb(cmd, &nand->nfaddr);
NFCONF_TWRPH1_MASK,
return -ENODEV;
+#else
Can you explain and/or point_to_resources for what this means (I'm a U-Boot newbie)...
Best regards, José Gonçalves
OK.
- u_long nfcont;
s/u_long/u32/
Replace u_long with u32.
- switch (chip) {
- case -1:
break;
- case 0:
break;
- case 1:
break;
- default:
return;
OK.
else
else
I.e.:
Oh sorry -- the above is missing the NCE part. Before the NAND_CMD_NONE check insert:
if (ctrl & NAND_CTRL_CHANGE) { if (ctrl & NAND_NCE) s3c_nand_select_chip(mtd, *(const int *)this->priv); else s3c_nand_select_chip(mtd, -1); }
NFCONF_TWRPH1_MASK,
return -ENODEV;
+#else
See CONFIG_SYS_NAND_SELF_INIT in doc/README.nand
I'd like the old way to be removed at some point.
-Scott
OK.
- u_long nfcont;
s/u_long/u32/
OK (didn't expected a regex expression in that context...)
- switch (chip) {
- case -1:
break;
- case 0:
break;
- case 1:
break;
- default:
return;
OK.
else
else
I.e.:
NFCONF_TWRPH1_MASK,
return -ENODEV;
+#else
From what I've seen there is an incompatibility between the SPL simple nand driver and the SELF_INIT mechanism. The nand_init() function in drivers/mtd/nand/nand_spl_simple.c calls board_nand_init() with a pointer to a struct nand_chip as an argument (the old way). This needs to be changed to be able to use that SPL driver. Can you give me an hint on the proper way to handle this?
Hmm... yes, this will need some work. Go ahead and leave it for now.
-Scott
Samsung's S3C24XX SoCs need this in order to generate a binary image with a padded SPL concatenated with U-Boot.
Signed-off-by: José Miguel Gonçalves jose.goncalves@inov.pt --- Changes for v2: - None
Changes for v3: - Changed new binary target name from u-boot-ubl.bin to u-boot-pad.bin --- Makefile | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index 8738d55..86dedca 100644 --- a/Makefile +++ b/Makefile @@ -433,14 +433,15 @@ $(obj)u-boot.sha1: $(obj)u-boot.bin $(obj)u-boot.dis: $(obj)u-boot $(OBJDUMP) -d $< > $@
-$(obj)u-boot.ubl: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin +$(obj)u-boot-pad.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $(obj)spl/u-boot-spl $(obj)spl/u-boot-spl-pad.bin - cat $(obj)spl/u-boot-spl-pad.bin $(obj)u-boot.bin > $(obj)u-boot-ubl.bin - $(obj)tools/mkimage -n $(UBL_CONFIG) -T ublimage \ - -e $(CONFIG_SYS_TEXT_BASE) -d $(obj)u-boot-ubl.bin $(obj)u-boot.ubl - rm $(obj)u-boot-ubl.bin + cat $(obj)spl/u-boot-spl-pad.bin $(obj)u-boot.bin > $(obj)u-boot-pad.bin rm $(obj)spl/u-boot-spl-pad.bin
+$(obj)u-boot.ubl: $(obj)spl/u-boot-pad.bin + $(obj)tools/mkimage -n $(UBL_CONFIG) -T ublimage \ + -e $(CONFIG_SYS_TEXT_BASE) -d $(obj)u-boot-pad.bin $(obj)u-boot.ubl + $(obj)u-boot.ais: $(obj)spl/u-boot-spl.bin $(obj)u-boot.img $(obj)tools/mkimage -s -n /dev/null -T aisimage \ -e $(CONFIG_SPL_TEXT_BASE) \
The MINI2416 board is based on a Samsung's S3C2416 SoC and has 64MB DDR2 SDRAM, 256MB NAND Flash, a LAN9220 Ethernet Controller and a WM8731 Audio CODEC. This U-Boot port was implemented and tested on a unit bought to Boardcon (http://www.armdesigner.com/) but there are some other chinese providers that can supply it with a selectable NAND chip from 128MB to 1GB.
Signed-off-by: José Miguel Gonçalves jose.goncalves@inov.pt --- Changes for v2: - Coding style cleanup - Use of Use of clrbits_le32(), setbits_le32() and clrsetbits_le32() - Use of register bit macros instead of magic numbers - Use of serial and rtc drivers implemented for s3c24x0
Changes for v3: - Changed target name from u-boot-ubl.bin to u-boot-pad.bin - Removed magic numbers - Changes to support new SPL framework --- MAINTAINERS | 4 + board/boardcon/mini2416/Makefile | 47 ++++++++ board/boardcon/mini2416/config.mk | 4 + board/boardcon/mini2416/mini2416.c | 104 ++++++++++++++++ board/boardcon/mini2416/mini2416_spl.c | 202 ++++++++++++++++++++++++++++++++ board/boardcon/mini2416/u-boot-spl.lds | 63 ++++++++++ boards.cfg | 1 + include/configs/mini2416.h | 202 +++++++++++++++++++++++++++++++ 8 files changed, 627 insertions(+) create mode 100644 board/boardcon/mini2416/Makefile create mode 100644 board/boardcon/mini2416/config.mk create mode 100644 board/boardcon/mini2416/mini2416.c create mode 100644 board/boardcon/mini2416/mini2416_spl.c create mode 100644 board/boardcon/mini2416/u-boot-spl.lds create mode 100644 include/configs/mini2416.h
diff --git a/MAINTAINERS b/MAINTAINERS index c5a6f2f..80ad29e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -653,6 +653,10 @@ Fabio Estevam fabio.estevam@freescale.com mx53ard i.MX53 mx53smd i.MX53
+José Gonçalves jose.goncalves@inov.pt + + mini2416 ARM926EJS (S3C2416 SoC) + Daniel Gorsulowski daniel.gorsulowski@esd.eu
meesc ARM926EJS (AT91SAM9263 SoC) diff --git a/board/boardcon/mini2416/Makefile b/board/boardcon/mini2416/Makefile new file mode 100644 index 0000000..bf92ba1 --- /dev/null +++ b/board/boardcon/mini2416/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2012 INOV - INESC Inovacao +# Jose Goncalves jose.goncalves@inov.pt +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifdef CONFIG_SPL_BUILD +COBJS += mini2416_spl.o +else +COBJS += mini2416.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/boardcon/mini2416/config.mk b/board/boardcon/mini2416/config.mk new file mode 100644 index 0000000..ff08568 --- /dev/null +++ b/board/boardcon/mini2416/config.mk @@ -0,0 +1,4 @@ +PAD_TO := 0x2000 +ifndef CONFIG_SPL_BUILD +ALL-y += $(obj)u-boot-pad.bin +endif diff --git a/board/boardcon/mini2416/mini2416.c b/board/boardcon/mini2416/mini2416.c new file mode 100644 index 0000000..b2c049b --- /dev/null +++ b/board/boardcon/mini2416/mini2416.c @@ -0,0 +1,104 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/s3c24xx_cpu.h> + +#define SMBIDCY1_VAL 0 /* Idle Cycle */ +#define SMBWSTWR1_VAL 14 /* Write Wait State */ +#define SMBWSTOEN1_VAL 2 /* Output Enable Assertion Delay */ +#define SMBWSTWEN1_VAL 2 /* Write Enable Assertion Delay */ +#define SMBWSTRD1_VAL 14 /* Read Wait State */ + +DECLARE_GLOBAL_DATA_PTR; + +static void ether_if_init(void) +{ + /* Ethernet chip is on memory bank 1 */ + struct s3c24xx_smc *const smc = s3c24xx_get_base_smc(S3C24XX_SMC1); + struct s3c24xx_gpio *const gpio = s3c24xx_get_base_gpio(); + + /* Set bus timings */ + writel(SMBIDCY1_VAL, &smc->smbidcy); + writel(SMBWSTWR1_VAL, &smc->smbwstwr); + writel(SMBWSTOEN1_VAL, &smc->smbwstoen); + writel(SMBWSTWEN1_VAL, &smc->smbwstwen); + writel(SMBWSTRD1_VAL, &smc->smbwstrd); + + /* Init SMC control register */ + clrsetbits_le32(&smc->smbc, + (SMBC_RSMAVD_WR | SMBC_RSMAVD_RD | SMBC_MW_MASK | + SMBC_WAIT_POL), + (SMBC_DRNOWE | SMBC_DRNCS | SMBC_MW_16BIT | + SMBC_WAIT_EN | SMBC_RBLE)); + + /* Enable CS pin */ + setbits_le32(&gpio->gpacon, GPACON_NRCS1); +} + +int board_init(void) +{ + struct s3c24xx_gpio *const gpio = s3c24xx_get_base_gpio(); + + /* Turn LED on */ + clrbits_le32(&gpio->gpcdat, GPCDAT(5)); + + /* Init interface with Ethernet chip */ + ether_if_init(); + + /* Arch number of MINI2416 Board */ + gd->bd->bi_arch_number = MACH_TYPE_MINI2416; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + printf("\nBoard: MINI2416\n"); + return 0; +} +#endif + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} +#endif diff --git a/board/boardcon/mini2416/mini2416_spl.c b/board/boardcon/mini2416/mini2416_spl.c new file mode 100644 index 0000000..9e91790 --- /dev/null +++ b/board/boardcon/mini2416/mini2416_spl.c @@ -0,0 +1,202 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <spl.h> +#include <version.h> +#include <nand.h> +#include <asm/io.h> +#include <asm/arch/s3c24xx_cpu.h> + +/* FCLK = 800 MHz, HCLK = 133 MHz, PCLK = 66 MHz */ +#define M_MDIV 400 +#define M_PDIV 3 +#define M_SDIV 1 +#define ARMDIV 1 +#define PREDIV 2 +#define HCLKDIV 1 +#define M_LTIME 0x0E10 + +/* EPLLclk = 96MHz */ +#define E_MDIV 32 +#define E_PDIV 1 +#define E_SDIV 2 +#define E_LTIME 0x1780 + +DECLARE_GLOBAL_DATA_PTR; + +static inline void asm_delay(ulong loops) +{ + asm volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b" : "=r" (loops) : "0"(loops)); +} + +static inline void watchdog_disable(void) +{ + struct s3c24xx_watchdog *const watchdog = s3c24xx_get_base_watchdog(); + + writel(WTCON_DISABLE_VAL, &watchdog->wtcon); +} + +static void pinmux_init(void) +{ + struct s3c24xx_gpio *const gpio = s3c24xx_get_base_gpio(); + + /* Init LED pin and turn LED off (LED on GPC5) */ + clrsetbits_le32(&gpio->gpccon, GPCCON_MASK(5), GPCCON_OUTPUT(5)); + setbits_le32(&gpio->gpcdat, GPCDAT(5)); + + /* Init UART pins */ + clrsetbits_le32(&gpio->gphcon, GPHCON_MASK(0) | GPHCON_MASK(1) | + GPHCON_MASK(2) | GPHCON_MASK(3) | GPHCON_MASK(4) | + GPHCON_MASK(5) | GPHCON_MASK(6) | GPHCON_MASK(7), + GPHCON_TXD(0) | GPHCON_RXD(0) | GPHCON_TXD(1) | + GPHCON_RXD(1) | GPHCON_TXD(2) | GPHCON_RXD(2) | + GPHCON_TXD(3) | GPHCON_RXD(3)); + + /* Init NAND interface */ + setbits_le32(&gpio->gpacon, GPACON_CLE | GPACON_ALE | GPACON_NFWE | + GPACON_NFRE | GPACON_NRSTOUT | GPACON_NFCE); +} + +static void pll_init(void) +{ + struct s3c2416_sysctl *const sysctl = s3c2416_get_base_sysctl(); + + /* Configure clocks division ratio */ + clrsetbits_le32(&sysctl->clkdiv0, + CLKDIV0_ARMDIV_MASK | CLKDIV0_PREDIV_MASK | + CLKDIV0_HCLKDIV_MASK, + CLKDIV0_ARMDIV(ARMDIV) | CLKDIV0_PREDIV(PREDIV) | + CLKDIV0_HALFHCLK | CLKDIV0_PCLKDIV | + CLKDIV0_HCLKDIV(HCLKDIV)); + + /* Set MPLL lock time */ + writel(M_LTIME, &sysctl->lockcon0); + + /* Configure MPLL */ + writel(MPLLCON_MDIV(M_MDIV) | MPLLCON_PDIV(M_PDIV) | + PLLCON_SDIV(M_SDIV), &sysctl->mpllcon); + + /* Set EPLL lock time */ + writel(E_LTIME, &sysctl->lockcon1); + + /* Configure EPLL */ + writel(EPLLCON_MDIV(E_MDIV) | EPLLCON_PDIV(E_PDIV) | + PLLCON_SDIV(E_SDIV), &sysctl->epllcon); + + /* MSYSCLK = MPLL and ESYSCLK = EPLL */ + setbits_le32(&sysctl->clksrc, + CLKSRC_MSYSCLK_MPLL | CLKSRC_ESYSCLK_EPLL); +} + +static void dramctl_init(void) +{ + struct s3c24xx_dramctl *const dramctl = s3c24xx_get_base_dramctl(); + + /* Step 1: Init BANKCFG & BANKCON1 */ + writel(BANKCFG_VAL_DDR2, &dramctl->bankcfg); + writel(BANKCON1_VAL_DDR2, &dramctl->bankcon1); + + /* Step 2: Init BANKCON2 */ + writel(BANKCON2_VAL_DDR2, &dramctl->bankcon2); + + /* Step 3: Issue a PALL command */ + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_PALL, &dramctl->bankcon1); + + /* Step 4: Issue a EMRS2 command */ + writel(BANKCON3_VAL_EMRS2, &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_EMRS, &dramctl->bankcon1); + + /* Step 5: Issue a EMRS3 command */ + writel(BANKCON3_VAL_EMRS3, &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_EMRS, &dramctl->bankcon1); + + /* Step 6: Issue a EMRS1 command */ + writel(BANKCON3_VAL_EMRS1, &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_EMRS, &dramctl->bankcon1); + + /* Step 7: Issue a MRS command */ + writel(BANKCON3_VAL_MRS | BANKCON3_MRS_DLL_RESET, &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_MRS, &dramctl->bankcon1); + + /* Step 8: Issue a PALL command */ + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_PALL, &dramctl->bankcon1); + + /* Step 9: Write 0xFF into the refresh timer */ + writel(0xFF, &dramctl->refresh); + + /* Step 10: Wait more than 120 clocks */ + asm_delay(256); + + /* Step 11: Issue a MRS command */ + writel(BANKCON3_VAL_MRS, &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_MRS, &dramctl->bankcon1); + + /* Step 12: Issue a EMRS1 command */ + writel(BANKCON3_VAL_EMRS1 | BANKCON3_EMRS1_OCD7 | BANKCON3_EMRS1_CAS3, + &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_EMRS, &dramctl->bankcon1); + + writel(BANKCON3_VAL_EMRS1 | BANKCON3_EMRS1_CAS3, &dramctl->bankcon3); + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_EMRS, &dramctl->bankcon1); + + /* Step 13: Write 0x87 into the refresh timer */ + writel(0x87, &dramctl->refresh); + + /* Step 14: Normal Mode */ + writel(BANKCON1_VAL_DDR2 | BANKCON1_INIT_NORMAL, &dramctl->bankcon1); +} + +#ifndef CONFIG_SPL_LIBCOMMON_SUPPORT +#ifdef CONFIG_SPL_SERIAL_SUPPORT +void puts(const char *str) +{ + serial_puts(str); +} +#else +void puts(const char *str) +{ +} +#endif +#endif + +void spl_board_init(void) +{ + watchdog_disable(); + pinmux_init(); + pll_init(); + preloader_console_init(); + dramctl_init(); +} + +u32 spl_boot_device(void) +{ +#ifdef CONFIG_SPL_NAND_SIMPLE + puts("Loading U-Boot from NAND Flash...\n"); + return BOOT_DEVICE_NAND; +#else + puts("Unknown boot device\n"); + hang(); +#endif +} diff --git a/board/boardcon/mini2416/u-boot-spl.lds b/board/boardcon/mini2416/u-boot-spl.lds new file mode 100644 index 0000000..d339b0d --- /dev/null +++ b/board/boardcon/mini2416/u-boot-spl.lds @@ -0,0 +1,63 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .iram : ORIGIN = CONFIG_SPL_TEXT_BASE, \ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + CPUDIR/start.o (.text) + *(.text*) + } > .iram + + . = ALIGN(4); + .rodata : + { + *(SORT_BY_ALIGNMENT(.rodata*)) + } > .iram + + . = ALIGN(4); + .data : + { + *(SORT_BY_ALIGNMENT(.data*)) + } > .iram + + . = ALIGN(4); + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sram +} diff --git a/boards.cfg b/boards.cfg index fdb84ad..823d5e6 100644 --- a/boards.cfg +++ b/boards.cfg @@ -185,6 +185,7 @@ omap730p2_cs0boot arm arm926ejs omap730p2 ti omap omap730p2_cs3boot arm arm926ejs omap730p2 ti omap omap730p2:CS3_BOOT edminiv2 arm arm926ejs - LaCie orion5x dkb arm arm926ejs - Marvell pantheon +mini2416 arm arm926ejs mini2416 boardcon s3c24xx spear300 arm arm926ejs spear300 spear spear spear3xx_evb:spear300 spear300_nand arm arm926ejs spear300 spear spear spear3xx_evb:spear300,nand spear300_usbtty arm arm926ejs spear300 spear spear spear3xx_evb:spear300,usbtty diff --git a/include/configs/mini2416.h b/include/configs/mini2416.h new file mode 100644 index 0000000..5c51f90 --- /dev/null +++ b/include/configs/mini2416.h @@ -0,0 +1,202 @@ +/* + * (C) Copyright 2012 INOV - INESC Inovacao + * Jose Goncalves jose.goncalves@inov.pt + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * SoC Configuration + */ +#define CONFIG_ARM926EJS /* ARM926EJS CPU Core */ +#define CONFIG_S3C24XX /* SAMSUNG S3C24XX Family */ +#define CONFIG_S3C2416 /* SAMSUNG S3C2416 SoC */ +#define CONFIG_SYS_CLK_FREQ 12000000 +#define CONFIG_SYS_HZ 1000 + +/* + * Memory Information + */ +#define CONFIG_SYS_IRAM_BASE 0x00000000 /* Steppingstone base address */ +#define CONFIG_SYS_IRAM_SIZE (8 << 10) /* 8KB of Steppingstone */ +#define CONFIG_SYS_IRAM_END (CONFIG_SYS_IRAM_BASE + CONFIG_SYS_IRAM_SIZE) + +#define CONFIG_SYS_SRAM_BASE 0x00002000 /* SRAM base address */ +#define CONFIG_SYS_SRAM_SIZE (56 << 10) /* 56KB of SRAM */ +#define CONFIG_SYS_SRAM_END (CONFIG_SYS_SRAM_BASE + CONFIG_SYS_SRAM_SIZE) + +#define CONFIG_SYS_SDRAM_BASE 0x30000000 /* DDR2 SDRAM base address */ +#define CONFIG_SYS_SDRAM_SIZE (64 << 20) /* 64MB of DDR2 SDRAM */ +#define CONFIG_SYS_SDRAM_END (CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_SDRAM_SIZE) + +/* + * Linux Interface + */ +#define MACH_TYPE_MINI2416 3850 +#define CONFIG_MACH_TYPE MACH_TYPE_MINI2416 +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySAC3,115200n8" +#define CONFIG_BOOTCOMMAND "" /* TBD */ + +/* + * SPL + */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_TEXT_BASE 0x00000000 /* CONFIG_SYS_IRAM_BASE */ +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_IRAM_SIZE +#define CONFIG_SPL_BSS_START_ADDR CONFIG_SYS_SRAM_BASE +#define CONFIG_SPL_BSS_MAX_SIZE (CONFIG_SYS_SRAM_SIZE - (8 << 10)) +#define CONFIG_SPL_STACK CONFIG_SYS_SRAM_END /* 8KB for stack */ + +/* + * Monitor Interface + */ +#define CONFIG_SYS_PROMPT "MINI2416 # " +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_CMDLINE_EDITING + +/* + * Command Definition + */ +#define CONFIG_SYS_NO_FLASH /* No NOR Flash */ +#include <config_cmd_default.h> +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MISC +#define CONFIG_CMD_NAND +#define CONFIG_CMD_PING + +/* + * Miscellaneous Settings + */ +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + (1 << 20)) +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_SDRAM_END - (1 << 20)) +#define CONFIG_SYS_MONITOR_LEN (256 << 10) +#define CONFIG_SYS_TEXT_BASE 0x33F00000 /* CONFIG_SYS_MONITOR_BASE */ +#define CONFIG_SYS_MALLOC_LEN (384 << 10) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SRAM_END - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MONITOR_BASE + +/* + * NAND Flash + */ +#ifdef CONFIG_CMD_NAND + +#define CONFIG_NAND_S3C24XX +#define CONFIG_S3C24XX_NAND_HWECC +#define CONFIG_SYS_NAND_BASE 0x4E000010 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/* SPL NAND Driver */ +#define CONFIG_SYS_NAND_PAGE_SIZE (2 << 10) +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 4 +#define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55} +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_HW_ECC_OOBFIRST +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_MAX_SIZE +#define CONFIG_SYS_NAND_U_BOOT_SIZE (CONFIG_SYS_MONITOR_LEN - \ + CONFIG_SPL_MAX_SIZE) + +#endif + +/* + * Serial Driver + */ +#define CONFIG_S3C24X0_SERIAL +#define CONFIG_SERIAL3 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Ethernet + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_SMC911X +#define CONFIG_SMC911X_BASE 0x08000000 +#define CONFIG_SMC911X_16_BIT +#define CONFIG_ETHADDR FE:11:22:33:44:55 +#define CONFIG_OVERWRITE_ETHADDR_ONCE +#define CONFIG_IPADDR 192.168.0.10 +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_SERVERIP 192.168.0.1 +#define CONFIG_GATEWAYIP 192.168.0.1 +#endif + +/* + * RTC + */ +#ifdef CONFIG_CMD_DATE +#define CONFIG_RTC_S3C24X0 +#endif + +/* + * Environment + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET CONFIG_SYS_MONITOR_LEN +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#else +#define CONFIG_ENV_IS_NOWHERE +#endif + +/* + * File System + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#endif + +#endif /* __CONFIG_H */
Scott Wood
