[U-Boot] [PATCH] Fix compile breakage in recent git
Fix compile breakage from commit 0bf202ec586d4466c900e987720fa635c594d689
image.c:207:2: error: #endif without #if
Signed-off-by: Steve Sakoman steve@sakoman.com Signed-off-by: Dirk Behme dirk.behme@gmail.com
Index: foo/common/image.c =================================================================== --- foo.orig/common/image.c +++ foo/common/image.c @@ -204,7 +204,6 @@ void memmove_wd (void *to, void *from, s memmove (to, from, len); #endif /* CONFIG_HW_WATCHDOG || CONFIG_WATCHDOG */ } -#endif /* USE_HOSTCC */
/** * image_multi_count - get component (sub-image) count
I've already sent a patch to address this. See:
http://lists.denx.de/pipermail/u-boot/2008-August/000115.html
- k
Okay, thanks.
Yes, seems that our patch isn't sufficent to fix broken git. Later build stops with
bootm.c: In function 'do_bootm_linux': bootm.c:140: error: 'bootm_headers_t' has no member named 'autostart' bootm.c:160: error: 'bootm_headers_t' has no member named 'autostart'
Dirk
Dirk Behme
dirk.behmeï¼ googlemail.com
Kumar Gala
