[U-Boot] [GIT PULL] MIPS updates
Hi Wolfgang,
please pull U-Boot/MIPS repository to pick up the following changes.
Thanks in advance,
Shinya
The following changes since commit 2145188bea2df8f2b47a87ec3071b55027e8d0ae: Ben Warren (1): Fix compile error in building MBX860T.
git://git.denx.de/u-boot-mips.git master
Stefan Roese (4): MIPS: Add onenand_init() to board.c and move nand_init() MIPS: Add board_early_init_f() to init_sequence MIPS: Add CONFIG_SKIP_LOWLEVEL_INIT MIPS: Flush data cache upon relocation
cpu/mips/start.S | 32 +++++++++++++++++++++++++------- lib_mips/board.c | 25 ++++++++++++++++++++----- 2 files changed, 45 insertions(+), 12 deletions(-)
diff --git a/cpu/mips/start.S b/cpu/mips/start.S index 6a22302..57db589 100644 --- a/cpu/mips/start.S +++ b/cpu/mips/start.S @@ -243,9 +243,11 @@ reset: mtc0 zero, CP0_COUNT mtc0 zero, CP0_COMPARE
+#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) /* CONFIG0 register */ li t0, CONF_CM_UNCACHED mtc0 t0, CP0_CONFIG +#endif /* !CONFIG_SKIP_LOWLEVEL_INIT */
/* Initialize $gp. */ @@ -255,6 +257,7 @@ reset: 1: lw gp, 0(ra)
+#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) /* Initialize any external memory. */ la t9, lowlevel_init @@ -271,6 +274,7 @@ reset: */ li t0, CONF_CM_CACHABLE_NONCOHERENT mtc0 t0, CP0_CONFIG +#endif /* !CONFIG_SKIP_LOWLEVEL_INIT */
/* Set up temporary stack. */ @@ -307,6 +311,7 @@ relocate_code: la t3, in_ram lw t2, -12(t3) /* t2 <-- uboot_end_data */ move t1, a2 + move s2, a2 /* s2 <-- destination address */
/* * Fix $gp: @@ -316,13 +321,21 @@ relocate_code: move t6, gp sub gp, CONFIG_SYS_MONITOR_BASE add gp, a2 /* gp now adjusted */ - sub t6, gp, t6 /* t6 <-- relocation offset */ + sub s1, gp, t6 /* s1 <-- relocation offset */
/* * t0 = source address * t1 = target address * t2 = source end address */ + + /* + * Save destination address and size for later usage in flush_cache() + */ + move s0, a1 /* save gd in s0 */ + move a0, t1 /* a0 <-- destination addr */ + sub a1, t2, t0 /* a1 <-- size */ + /* On the purple board we copy the code earlier in a special way * in order to solve flash problems */ @@ -338,9 +351,14 @@ relocate_code: /* If caches were enabled, we would have to flush them here. */
+ /* a0 & a1 are already set up for flush_cache(start, size) */ + la t9, flush_cache + jalr t9 + nop + /* Jump to where we've relocated ourselves. */ - addi t0, a2, in_ram - _start + addi t0, s2, in_ram - _start jr t0 nop
@@ -367,7 +385,7 @@ in_ram: 1: lw t1, 0(t4) beqz t1, 2f - add t1, t6 + add t1, s1 sw t1, 0(t4) 2: addi t2, 1 @@ -378,8 +396,8 @@ in_ram: */ lw t1, -12(t0) /* t1 <-- uboot_end_data */ lw t2, -8(t0) /* t2 <-- uboot_end */ - add t1, t6 /* adjust pointers */ - add t2, t6 + add t1, s1 /* adjust pointers */ + add t2, s1
sub t1, 4 1: @@ -387,10 +405,10 @@ in_ram: bltl t1, t2, 1b sw zero, 0(t1) /* delay slot */
- move a0, a1 + move a0, s0 /* a0 <-- gd */ la t9, board_init_r jr t9 - move a1, a2 /* delay slot */ + move a1, s2 /* delay slot */
.end relocate_code
diff --git a/lib_mips/board.c b/lib_mips/board.c index 9c997f1..dfe6831 100644 --- a/lib_mips/board.c +++ b/lib_mips/board.c @@ -30,6 +30,7 @@ #include <net.h> #include <environment.h> #include <nand.h> +#include <onenand_uboot.h> #include <spi.h>
DECLARE_GLOBAL_DATA_PTR; @@ -71,6 +72,15 @@ static ulong mem_malloc_brk; */ unsigned long mips_io_port_base = -1;
+int __board_early_init_f(void) +{ + /* + * Nothing to do in this dummy implementation + */ + return 0; +} +int board_early_init_f(void) __attribute__((weak, alias("__board_early_init_f"))); + /* * The Malloc area is immediately below the monitor copy in DRAM */ @@ -168,6 +178,7 @@ static int init_baudrate (void) typedef int (init_fnc_t) (void);
init_fnc_t *init_sequence[] = { + board_early_init_f, timer_init, env_init, /* initialize environment */ #ifdef CONFIG_INCA_IP @@ -378,6 +389,15 @@ void board_init_r (gd_t *id, ulong dest_addr) mem_malloc_init(); malloc_bin_reloc();
+#ifdef CONFIG_CMD_NAND + puts ("NAND: "); + nand_init (); /* go init the NAND */ +#endif + +#if defined(CONFIG_CMD_ONENAND) + onenand_init(); +#endif + /* relocate environment function pointers etc. */ env_relocate();
@@ -419,11 +439,6 @@ void board_init_r (gd_t *id, ulong dest_addr) } #endif
-#ifdef CONFIG_CMD_NAND - puts ("NAND: "); - nand_init (); /* go init the NAND */ -#endif - #ifdef CONFIG_CMD_SPI puts ("SPI: "); spi_init (); /* go init the SPI */
Dear Shinya Kuribayashi,
Applied, thanks.
Shinya Kuribayashi
