[U-Boot] [PATCH] arm64: Fix layerscape mmu setup
With commit 7985cdf we converted all systems except for the Layerscape SoCs to the generic descriptor table based page table setup.
On the Layerscape SoCs however, we just provide an empty table stub and do the setup ourselves. To reserve enough memory for the tables, we need to override the default counting mechanism which would end up with an empty table because we have no maps.
Fixes: 7985cdf Reported-by: York Sun york.sun@nxp.com CC: Alison Wang alison.wang@nxp.com CC: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Alexander Graf agraf@suse.de --- arch/arm/cpu/armv8/cache_v8.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 +++++ 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index d1bd06b..1615542 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -320,7 +320,7 @@ static int count_required_pts(u64 addr, int level, u64 maxaddr) }
/* Returns the estimated required size of all page tables */ -u64 get_page_table_size(void) +__weak u64 get_page_table_size(void) { u64 one_pt = MAX_PTE_ENTRIES * sizeof(u64); u64 size = 0; diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 7404bd9..4b9e209 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -410,6 +410,11 @@ static inline void final_mmu_setup(void) */ }
+u64 get_page_table_size(void) +{ + return 0x10000; +} + int arch_cpu_init(void) { icache_enable();
- return 0x10000;
Tested-by: York Sun york.sun@nxp.com Reviewed-by: York Sun york.sun@nxp.com
Applied to u-boot-fsl-qoriq, awaiting upstream.
Thanks.
York
Alexander Graf
york sun
