[U-Boot] [PATCH v2] [NEXT] da830: fixup ARM relocation support
Fixes build breakage in da830evm after commit 97003756249bd790910417eb66f0039bbf06a02c "da8xx: fixup ARM relocation support"
The da8xx fixup commit changed da830/da850 common code to make relocation work in da850, but didn't add the required defines to da830evm_config.h resulting in build failure in the common code.
This patch adds those defines for da830, but makes no sense without also referring to the commit mentioned above.
Signed-off-by: Nick Thompson nick.thompson@ge.com --- Changes since v1: removed CONFIG_SKIP_RELOCATE_UBOOT
include/configs/da830evm.h | 12 +++++++++--- 1 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h index 160ece2..ca44e09 100644 --- a/include/configs/da830evm.h +++ b/include/configs/da830evm.h @@ -41,15 +41,13 @@ #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) #define CONFIG_SYS_HZ 1000 #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SKIP_RELOCATE_UBOOT /* to a proper address, init done */
/* * Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ -#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ -#define PHYS_SDRAM_1_SIZE (64 << 20) /* SDRAM size 64MB */ +#define PHYS_SDRAM_1 0xc0000000 /* SDRAM Start */ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest start addr */ #define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) /* 16MB test */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ @@ -281,4 +279,12 @@ "mtdparts=davinci_nand.1:" PART_BOOT PART_PARAMS PART_KERNEL PART_REST #endif
+#define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* max size from SPRS586*/ + +/* additions for new relocation code, must be added to all boards */ +#undef CONFIG_SYS_ARM_WITHOUT_RELOC +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 0x1000 - CONFIG_SYS_GBL_DATA_SIZE) + #endif /* __CONFIG_H */
This makes the da830 setup equivalent to the da850 setup in -next; with the potential possibility that CONFIG_SKIP_RELOCATE_UBOOT could be defined.
Reviewed-by: Ben Gardiner bengardiner@nanometrics.ca
Best Regards, Ben Gardiner
--- Nanometrics Inc. http://www.nanometrics.ca
Ben Gardiner
Nick Thompson
