[PATCH v3 1/5] usb: ohci-generic: ignore ENOSYS and ENOTSUPP errors from clk and reset
If a machine doesn't have CONFIG_CLK set the call to clk_get_bulk() returns '-ENOSYS' error which should be handled the same way as '-ENOENT' error. The same applies to reset_get_bulk() and 'ENOTSUPP'.
Signed-off-by: Piotr Wojtaszczyk piotr.wojtaszczyk@timesys.com --- Changes for v3: - Removed extra parenthesis around error checks
Changes for v2: - Changed logic style from !(== || ==) to (!= && !=)
drivers/usb/host/ohci-generic.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index ceed1911a9..d67fce2d02 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -28,7 +28,7 @@ static int ohci_usb_probe(struct udevice *dev) int err, ret;
ret = clk_get_bulk(dev, &priv->clocks); - if (ret && ret != -ENOENT) { + if (ret && ret != -ENOENT && ret != -ENOSYS) { dev_err(dev, "Failed to get clocks (ret=%d)\n", ret); return ret; } @@ -40,7 +40,7 @@ static int ohci_usb_probe(struct udevice *dev) }
err = reset_get_bulk(dev, &priv->resets); - if (err && err != -ENOENT) { + if (err && err != -ENOENT && err != -ENOTSUPP) { dev_err(dev, "failed to get resets (err=%d)\n", err); goto clk_err; } @@ -72,7 +72,7 @@ reset_err: dev_err(dev, "failed to release resets (ret=%d)\n", ret); clk_err: ret = clk_release_bulk(&priv->clocks); - if (ret) + if (ret && ret != -ENOSYS) dev_err(dev, "failed to release clocks (ret=%d)\n", ret);
return err; @@ -95,7 +95,11 @@ static int ohci_usb_remove(struct udevice *dev) if (ret) return ret;
- return clk_release_bulk(&priv->clocks); + ret = clk_release_bulk(&priv->clocks); + if (ret && ret != -ENOSYS) + return ret; + + return 0; }
static const struct udevice_id ohci_usb_ids[] = {
Piotr Wojtaszczyk
