[U-Boot] [PATCH 2/5] common: add blkcache init
From: Angelo Durgehello angelo.dureghello@timesys.com
On m68k, block_cache list is relocated, but next and prev list pointers are not adjusted to the relocated struct list_head address, so the first iteration over the block_cache list hangs.
This patch initializes the block_cache list after relocation.
Signed-off-by: Angelo Durgehello angelo.dureghello@timesys.com --- common/board_r.c | 12 ++++++++++++ drivers/block/blkcache.c | 7 ++++++- include/blk.h | 6 ++++++ 3 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/common/board_r.c b/common/board_r.c index 65720849cd..13e70a5ffb 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -628,6 +628,15 @@ static int initr_bedbug(void) } #endif
+#ifdef CONFIG_BLOCK_CACHE +static int initr_blkcache(void) +{ + blkcache_init(); + + return 0; +} +#endif + static int run_main_loop(void) { #ifdef CONFIG_SANDBOX @@ -832,6 +841,9 @@ static init_fnc_t init_sequence_r[] = { #endif #if defined(CONFIG_PRAM) initr_mem, +#endif +#ifdef CONFIG_BLOCK_CACHE + initr_blkcache, #endif run_main_loop, }; diff --git a/drivers/block/blkcache.c b/drivers/block/blkcache.c index 1fa64989d3..bf0fa1ea6f 100644 --- a/drivers/block/blkcache.c +++ b/drivers/block/blkcache.c @@ -21,13 +21,18 @@ struct block_cache_node { char *cache; };
-static LIST_HEAD(block_cache); +static struct list_head block_cache;
static struct block_cache_stats _stats = { .max_blocks_per_entry = 8, .max_entries = 32 };
+void blkcache_init(void) +{ + INIT_LIST_HEAD(&block_cache); +} + static struct block_cache_node *cache_find(int iftype, int devnum, lbaint_t start, lbaint_t blkcnt, unsigned long blksz) diff --git a/include/blk.h b/include/blk.h index d0c033aece..7070fd6af3 100644 --- a/include/blk.h +++ b/include/blk.h @@ -113,6 +113,12 @@ struct blk_desc { (PAD_SIZE(size, blk_desc->blksz))
#if CONFIG_IS_ENABLED(BLOCK_CACHE) + +/** + * blkcache_init() - initialize the block cache list pointers + */ +void blkcache_init(void); + /** * blkcache_read() - attempt to read a set of blocks from cache *
Hi Angelo,
- blkcache_init();
+} +#endif
Why the extra level of indirection?
It seems you could call blkcache_init from here directly:
- initr_blkcache, #endif run_main_loop, };
- INIT_LIST_HEAD(&block_cache);
- static struct block_cache_node *cache_find(int iftype, int devnum, lbaint_t start, lbaint_t blkcnt, unsigned long blksz)
- blkcache_init() - initialize the block cache list pointers
- blkcache_read() - attempt to read a set of blocks from cache
Hi Eric,
On Sun, Nov 24, 2019 at 5:00 PM Eric Nelson ericnelsonaz@gmail.com wrote:
Hi Angelo,
blkcache_init();
+} +#endif
reason for this is to maintain "initr_" naming convention, used from quite all the initr_ calls, as i.e. static int initr_mmc(void) that's doing the same.
#endif run_main_loop, };initr_blkcache,
Regards, -- Angelo Dureghello
Hi Angelo,
On 11/25/19 2:59 AM, Angelo Dureghello wrote:
Hi Eric,
Hi Angelo,
blkcache_init();
+} +#endif
Okay. I think this isn't a hard rule though (see log_init, stdio_init_tables, etc).
I'm not sure that it would be a bad thing to rename blkcache_init to initr_blkcache to indicate the usage.
Regards,
Angelo Dureghello
Hi Angelo,
Hi Eric,
Hi Angelo,
blkcache_init();
+} +#endif
Regards,
Angelo Dureghello
Angelo Dureghello
Eric Nelson
