Hi, I have a problem that I am trying to solve with U-boot. What I have is a Ubicom processor with 128 MB of ram, and USB. What I need to do is load a 12 MB file into ram, and then program the flash with it. This version of u-boot was supplied by Ubicom for their chip. Every time I try to load the file into ram from a FAT formatted USB drive, no matter what the starting address, u-boot crashes. What I need to know is this even possible? Has anyone else had this problem? Should I attempt to try the latest version of u-boot? Ubicom has been no help at all.
Dennis Kerrisk | Senior Linux Firmware Engineer | PS Audio 4826 Sterling Drive, Boulder, CO 80301 Ph 720-406-8946 x123 www.psaudio.comhttp://www.psaudio.com dennis@psaudio.commailto:jim@psaudio.com
Dear Dennis Kerrisk,
In message E1318E0A083BFB4497F69194D590CD8C586EEE98@MANDI.psaudio.com you wrote:
Please restrict your line length to some 70 characters or so.
version of u-boot was supplied by Ubicom for their chip. Every time I try t o load the file into ram from a FAT formatted USB drive, no matter what the starting address, u-boot crashes. What I need to know is this even possible? Has anyone else had this problem ? Should I attempt to try the latest version of u-boot? Ubicom has been no help at all.
Of course it is possible that U-Boot crashes, for example when there are hardware problems, or when there are bugs in the port to your board, or eventually even if you are running into a bug in common code.
If your board is supported in mainline, then running the latest version is strongly recommended.
Unfortunately the Ubicom board is not supported in the mainline. So I would have to report it. Does this work on a board that supports Mainline code? I would like to eliminate that as the problem. My guess Is that there is a bug in the Ubicom port, probably dealing with The USB. I seem to be able load small files 40k with no problem. I really would like to know if anyone has loaded large files With mainline code so I can eliminate u-boot code .
Dennis Kerrisk | Senior Linux Firmware Engineer | PS Audio 4826 Sterling Drive, Boulder, CO 80301 Ph 720-406-8946 x123 www.psaudio.com dennis@psaudio.com
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Tuesday, September 07, 2010 8:59 AM To: Dennis Kerrisk Cc: 'u-boot@lists.denx.de' Subject: Re: [U-Boot] USB and FAT
In message E1318E0A083BFB4497F69194D590CD8C586EF0EA@MANDI.psaudio.com you wrote:
Yes, this works well on many boards.
Dennis Kerrisk
