[U-Boot-Users] [PATCH] 85xx: Remove unused and unconfigured memory test code.
Remove unused and unconfigured DDR test code from FSL 85xx boards. Besides, other common code exists.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8540ads/mpc8540ads.c | 36 ---------------------------- board/freescale/mpc8541cds/mpc8541cds.c | 39 ------------------------------- board/freescale/mpc8544ds/mpc8544ds.c | 39 ------------------------------- board/freescale/mpc8548cds/mpc8548cds.c | 39 ------------------------------- board/freescale/mpc8555cds/mpc8555cds.c | 39 ------------------------------- board/freescale/mpc8560ads/mpc8560ads.c | 36 ---------------------------- board/freescale/mpc8568mds/mpc8568mds.c | 39 ------------------------------- include/configs/MPC8540ADS.h | 1 - include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 2 - include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8560ADS.h | 1 - include/configs/MPC8568MDS.h | 1 - 14 files changed, 0 insertions(+), 275 deletions(-)
diff --git a/board/freescale/mpc8540ads/mpc8540ads.c b/board/freescale/mpc8540ads/mpc8540ads.c index a951b9e..ea1fbd1 100644 --- a/board/freescale/mpc8540ads/mpc8540ads.c +++ b/board/freescale/mpc8540ads/mpc8540ads.c @@ -230,42 +230,6 @@ sdram_init(void) udelay(100); }
- -#if defined(CFG_DRAM_TEST) -int testdram (void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("SDRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("SDRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("SDRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("SDRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("SDRAM test passed.\n"); - return 0; -} -#endif - - #if !defined(CONFIG_SPD_EEPROM) /************************************************************************* * fixed sdram init -- doesn't use serial presence detect. diff --git a/board/freescale/mpc8541cds/mpc8541cds.c b/board/freescale/mpc8541cds/mpc8541cds.c index 62c8d63..b001dbd 100644 --- a/board/freescale/mpc8541cds/mpc8541cds.c +++ b/board/freescale/mpc8541cds/mpc8541cds.c @@ -425,45 +425,6 @@ sdram_init(void) #endif /* enable SDRAM init */ }
-#if defined(CFG_DRAM_TEST) -int -testdram(void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("Testing DRAM from 0x%08x to 0x%08x\n", - CFG_MEMTEST_START, - CFG_MEMTEST_END); - - printf("DRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test passed.\n"); - return 0; -} -#endif - #if defined(CONFIG_PCI) /* For some reason the Tundra PCI bridge shows up on itself as a * different device. Work around that by refusing to configure it. diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index dd10af8..150f867 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -83,45 +83,6 @@ initdram(int board_type) return dram_size; }
-#if defined(CFG_DRAM_TEST) -int -testdram(void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("Testing DRAM from 0x%08x to 0x%08x\n", - CFG_MEMTEST_START, - CFG_MEMTEST_END); - - printf("DRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test passed.\n"); - return 0; -} -#endif - #ifdef CONFIG_PCI1 static struct pci_controller pci1_hose; #endif diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index efe2a3a..0b20ba2 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -250,45 +250,6 @@ sdram_init(void) #endif /* enable SDRAM init */ }
-#if defined(CFG_DRAM_TEST) -int -testdram(void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("Testing DRAM from 0x%08x to 0x%08x\n", - CFG_MEMTEST_START, - CFG_MEMTEST_END); - - printf("DRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test passed.\n"); - return 0; -} -#endif - #if defined(CONFIG_PCI) || defined(CONFIG_PCI1) /* For some reason the Tundra PCI bridge shows up on itself as a * different device. Work around that by refusing to configure it. diff --git a/board/freescale/mpc8555cds/mpc8555cds.c b/board/freescale/mpc8555cds/mpc8555cds.c index 8acbba4..94589c7 100644 --- a/board/freescale/mpc8555cds/mpc8555cds.c +++ b/board/freescale/mpc8555cds/mpc8555cds.c @@ -422,45 +422,6 @@ sdram_init(void) #endif /* enable SDRAM init */ }
-#if defined(CFG_DRAM_TEST) -int -testdram(void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("Testing DRAM from 0x%08x to 0x%08x\n", - CFG_MEMTEST_START, - CFG_MEMTEST_END); - - printf("DRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test passed.\n"); - return 0; -} -#endif - #ifdef CONFIG_PCI /* For some reason the Tundra PCI bridge shows up on itself as a * different device. Work around that by refusing to configure it diff --git a/board/freescale/mpc8560ads/mpc8560ads.c b/board/freescale/mpc8560ads/mpc8560ads.c index 8d4b8a8..6f65499 100644 --- a/board/freescale/mpc8560ads/mpc8560ads.c +++ b/board/freescale/mpc8560ads/mpc8560ads.c @@ -433,42 +433,6 @@ sdram_init(void) udelay(100); }
- -#if defined(CFG_DRAM_TEST) -int testdram (void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("SDRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("SDRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("SDRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("SDRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("SDRAM test passed.\n"); - return 0; -} -#endif - - #if !defined(CONFIG_SPD_EEPROM) /************************************************************************* * fixed sdram init -- doesn't use serial presence detect. diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index 4568aa1..f1928ab 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -292,45 +292,6 @@ sdram_init(void) #endif /* enable SDRAM init */ }
-#if defined(CFG_DRAM_TEST) -int -testdram(void) -{ - uint *pstart = (uint *) CFG_MEMTEST_START; - uint *pend = (uint *) CFG_MEMTEST_END; - uint *p; - - printf("Testing DRAM from 0x%08x to 0x%08x\n", - CFG_MEMTEST_START, - CFG_MEMTEST_END); - - printf("DRAM test phase 1:\n"); - for (p = pstart; p < pend; p++) - *p = 0xaaaaaaaa; - - for (p = pstart; p < pend; p++) { - if (*p != 0xaaaaaaaa) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test phase 2:\n"); - for (p = pstart; p < pend; p++) - *p = 0x55555555; - - for (p = pstart; p < pend; p++) { - if (*p != 0x55555555) { - printf ("DRAM test fails at: %08x\n", (uint) p); - return 1; - } - } - - printf("DRAM test passed.\n"); - return 0; -} -#endif - #if defined(CONFIG_PCI) #ifndef CONFIG_PCI_PNP static struct pci_config_table pci_mpc8568mds_config_table[] = { diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 5719759..37f062f 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -89,7 +89,6 @@
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */
-#undef CFG_DRAM_TEST /* memory test, takes time */ #define CFG_MEMTEST_START 0x00200000 /* memtest region */ #define CFG_MEMTEST_END 0x00400000
diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 5b3ea05..65a34cc 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -75,7 +75,6 @@ extern unsigned long get_clock_freq(void);
-#undef CFG_DRAM_TEST /* memory test, takes time */ #define CFG_MEMTEST_START 0x00200000 /* memtest works on */ #define CFG_MEMTEST_END 0x00400000
diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index ffe9e00..d5006b5 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -86,10 +86,8 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
-#undef CFG_DRAM_TEST /* memory test, takes time */ #define CFG_MEMTEST_START 0x00200000 /* memtest works on */ #define CFG_MEMTEST_END 0x00400000 -#define CFG_ALT_MEMTEST #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index fc8ad88..51c9064 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -89,7 +89,6 @@ extern unsigned long get_clock_freq(void);
diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index e838345..797644f 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -75,7 +75,6 @@ extern unsigned long get_clock_freq(void);
diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 9c95cc6..52e9362 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -84,7 +84,6 @@
#define CFG_INIT_DBCR DBCR_IDM /* Enable Debug Exceptions */
diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index a7c69d2..9e6bb44 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -80,7 +80,6 @@ extern unsigned long get_clock_freq(void);
Kumar Gala
