[U-Boot] Watchdog DM - ENOMEM(out of memory) error
I am trying to convert watchdog driver(omap3_wdt) on TI AM33XX platform to Driver Model.
I am getting the following error:
U-Boot 2019.07-rc4-00179-g77f6e2d-dirty (Jun 27 2019 - 15:11:15 +0530)
CPU : AM335X-GP rev 2.1 Model: TI AM335x BeagleBone Black DRAM: 512 MiB WDT: Started with servicing (60s timeout) Error binding driver 'omap_timer': -12 Error binding driver 'omap_timer': -12 Error binding driver 'omap_timer': -12 Error binding driver 'omap_timer': -12
The watchdog DM driver has successfully got binded (checked the debug log).
The error is related to ENOMEM(out of memory). After a bit of search on the mailing lists I found out that may be tweaking CONFIG_SYS_MALLOC_F_LEN might resolve the error.
CONFIG_SYS_MALLOC_F_LEN is defined as 0x1000 initially, I changed it to 0x2000, 0x40000 and 0x8000 but the result stays the same..
Any pointers on what could be the issue ?
Regards
The error is after the trace "DRAM: 512 MiB" , so after relocation!.
And in this case the CONFIG_SYS_MALLOC_LEN is used.
FYI: CONFIG_SYS_MALLOC_F_LEN is used before relocation (tag '_F_ ')
Regards
Patrick
-- Sent from: http://u-boot.10912.n7.nabble.com/
Hi Patrick,
thanks for the pointer and I understood your point.
CONFIG_SYS_MALLOC_LEN is defined as SZ_32M which should be enough i guess ?
still trying to figure out what is causing that error.
On Thu, 27 Jun 2019 at 23:23, Suniel Mahesh sunil.m@techveda.org wrote:
Hi Patrick,
This is very strange, particularly the fact that the error reports.
Hi Simon,
Hi Patrick,
This patch should fix this error:
https://patchwork.ozlabs.org/patch/1100435/
Thanks, Stefan
patrick.delaunay
Stefan Roese
Suniel Mahesh
