[PATCH] sunxi: defconfig: Add X96 Mate TV box
The X96 Mate TV box is a TV box with the Allwinner H616 SoC. It is available with up to 4GB of DRAM and 64GB eMMC. The DRAM chips require a different configuration when compared to the OrangePi Zero2, we must not use read/write training and write leveling.
Add a defconfig for the box, so that we can easily build U-Boot for it. We synced the .dts file already from the kernel tree.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- configs/x96_mate_defconfig | 15 +++++++++++++++ 1 file changed, 15 insertions(+) create mode 100644 configs/x96_mate_defconfig
diff --git a/configs/x96_mate_defconfig b/configs/x96_mate_defconfig new file mode 100644 index 00000000000..4276f4f543b --- /dev/null +++ b/configs/x96_mate_defconfig @@ -0,0 +1,15 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h616-x96-mate" +CONFIG_SPL=y +CONFIG_DRAM_SUN50I_H616_READ_CALIBRATION=y +CONFIG_MACH_SUN50I_H616=y +CONFIG_MMC0_CD_PIN="PF6" +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_SUPPORT_EMMC_BOOT=y
Hi Andre,
Dne sreda, 12. oktober 2022 ob 18:26:10 CEST je Andre Przywara napisal(a):
Reviewed-by: Jernej Skrabec jernej.skrabec@gmail.com
Best regards, Jernej
2.25.1
Andre Przywara
Jernej Škrabec
