[U-Boot] [PATCH v2 1/2] mmc: fsl_esdhc: Update esdhc driver for iMX6SX
The reset value of "uSDHCx_INT_STATUS_EN" register is changed to 0 on iMX6SX. So the fsl_esdhc driver must update to set the register, otherwise no state can be detected.
Signed-off-by: Ye.Li B37916@freescale.com --- Changes since v1: - Remove codes which set INT_STATUS_EN register according PIO or DMA mode.
drivers/mmc/fsl_esdhc.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 97d0389..bca86a8 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -23,6 +23,13 @@
DECLARE_GLOBAL_DATA_PTR;
+#define SDHCI_IRQ_EN_BITS (IRQSTATEN_CC | IRQSTATEN_TC | \ + IRQSTATEN_CINT | \ + IRQSTATEN_CTOE | IRQSTATEN_CCE | IRQSTATEN_CEBE | \ + IRQSTATEN_CIE | IRQSTATEN_DTOE | IRQSTATEN_DCE | \ + IRQSTATEN_DEBE | IRQSTATEN_BRR | IRQSTATEN_BWR | \ + IRQSTATEN_DINT) + struct fsl_esdhc { uint dsaddr; /* SDMA system address register */ uint blkattr; /* Block attributes register */ @@ -558,6 +565,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_HCKEN | SYSCTL_IPGEN | SYSCTL_CKEN);
+ writel(SDHCI_IRQ_EN_BITS, ®s->irqstaten); memset(&cfg->cfg, 0, sizeof(cfg->cfg));
voltage_caps = 0;
Ye.Li
