[U-Boot] [PATCH 1/1] x86: provide CONFIG_BUILD_ROM
Up to now we depended on an exported variable to build u-boot.rom. What we build should be specified by the configuration file.
With this patch the export variable is deprecated and replaced by the Kconfig option CONFIG_BUILD_ROM.
This option depends on CONFIG_X86 and is selected in qemu-x86_defconfig.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Kconfig | 10 ++++++++++ Makefile | 2 +- configs/qemu-x86_defconfig | 1 + doc/README.x86 | 2 +- 4 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/Kconfig b/Kconfig index 238fa3e1ed..7b782298bf 100644 --- a/Kconfig +++ b/Kconfig @@ -158,6 +158,16 @@ config PHYS_64BIT This can be used not only for 64bit SoCs, but also for large physical address extention on 32bit SoCs.
+config BUILD_ROM + bool "Build U-BOOT as BIOS replacement" + depends on X86 + default n + help + This option allows to BUILD a ROM version of U-BOOT. + The build process generally requires several binary blobs + which are not shipped in the U-Boot source tree. + Please, see doc/README.x86 for detials. + endmenu # General setup
menu "Boot images" diff --git a/Makefile b/Makefile index 8250b3409a..50fe0003f5 100644 --- a/Makefile +++ b/Makefile @@ -796,7 +796,7 @@ ALL-$(CONFIG_REMAKE_ELF) += u-boot.elf ALL-$(CONFIG_EFI_APP) += u-boot-app.efi ALL-$(CONFIG_EFI_STUB) += u-boot-payload.efi
-ifneq ($(BUILD_ROM),) +ifneq ($(BUILD_ROM)$(CONFIG_BUILD_ROM),) ALL-$(CONFIG_X86_RESET_VECTOR) += u-boot.rom endif
diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index d84e1d7dc9..60c2e3c404 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_BUILD_ROM=y CONFIG_MAX_CPUS=2 CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y diff --git a/doc/README.x86 b/doc/README.x86 index c542a6965c..4971f4b95e 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -81,7 +81,7 @@ shipped in the U-Boot source tree. Due to this reason, the u-boot.rom build is not turned on by default in the U-Boot source tree. Firstly, you need turn it on by enabling the ROM build:
-$ export BUILD_ROM=y +CONFIG_BUILD_ROM=y
This tells the Makefile to build u-boot.rom as a target.
Hi Heinrich,
On Sun, Sep 17, 2017 at 7:57 PM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
+config BUILD_ROM
nits: U-Boot
depends on X86
default n
nits: this is not needed as 'n' is the default one.
help
nits: U-Boot
We should also enable this on qemu-x86_64_defconfig.
For non-QEMU targets, this requires an additional step after we do 'make xxx_defconfig', I am not sure if that's convenient.
Simon, what do you think about this patch?
Regards, Bin
On 09/19/2017 07:54 AM, Bin Meng wrote:
Hi Heinrich,
+config BUILD_ROM
nits: U-Boot
depends on X86
default n
help
nits: U-Boot
You still can export BUILD_ROM.
Would you prefer to make CONFIG_BUILD_ROM 'default y'? Probably you always want to build u-boot.rom for an X86 system.
Best regards
Heinrich
Regards, Bin
Hi Heinrich,
On Tue, Sep 19, 2017 at 2:15 PM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Heinrich,
+config BUILD_ROM
nits: U-Boot
depends on X86
default n
help
nits: U-Boot
OK.
No. That will break buildman testing as the required binary blobs are not in the U-Boot tree.
Regards, Bin
Bin Meng
