[PATCH 2/8] net: dc2114x: get mac address from environment
Let this old driver work like the other newer network card drivers, loading the MAC address from environment, which could be more flexible to set.
Signed-off-by: Hanyuan Zhao zhaohy22@mails.tsinghua.edu.cn --- drivers/net/dc2114x.c | 16 ++++++++++++---- 1 file changed, 12 insertions(+), 4 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 3704d2e655..7f0715429f 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -478,8 +478,16 @@ static int dc2114x_start(struct udevice *dev) { struct eth_pdata *plat = dev_get_plat(dev); struct dc2114x_priv *priv = dev_get_priv(dev); + int rval;
- memcpy(priv->enetaddr, plat->enetaddr, sizeof(plat->enetaddr)); + if(!priv->enetaddr) { + rval = eth_env_get_enetaddr("ethaddr", priv->enetaddr); + + if (!rval) { + printf("dc2114x: Err: please set a valid MAC address\n"); + return -EINVAL; + } + }
#if !CONFIG_IS_ENABLED(TULIP_SUPPORT_NON_PCI) /* Ensure we're not sleeping. */ @@ -574,9 +582,6 @@ static int dc2114x_probe(struct udevice *dev) iobase &= ~0xf;
debug("dc2114x: DEC 2114x PCI Device @0x%x\n", iobase); - - priv->devno = dev; - priv->enetaddr = plat->enetaddr; priv->iobase = (void __iomem *)dm_pci_mem_to_phys(dev, iobase);
command = PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; @@ -589,6 +594,9 @@ static int dc2114x_probe(struct udevice *dev)
dm_pci_write_config8(dev, PCI_LATENCY_TIMER, 0x60); #endif + + priv->devno = dev; + priv->enetaddr = plat->enetaddr; return 0; }
Hanyuan Zhao
