[U-Boot] [PATCH 1/2] ARM: imx6qlogic: Cleanup board_init_f and enable spl_early_init
According to the the documentation, call spl_early_init from board_init_f to make the device tree and driver model early before board_init_r. Per the workflow found in crt0.S, we don't need to clear BSS in board_init_f nor do we need to call board_init_r since that will be done for us.
This patch removes the unneeded function calls from board_init_f and enables early access to device tree and DM which will permit the use of SPL_DM_SERIAL in the future.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index 6e3ffa72d7..2eea7aade5 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -347,13 +347,9 @@ void board_init_f(ulong dummy) /* setup GP timer */ timer_init();
+ spl_early_init(); + /* UART clocks enabled and gd valid - init serial console */ preloader_console_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - /* load/boot image from boot device */ - board_init_r(NULL, 0); } #endif
With spl_early_init() now enabled in board_init_f, the preloader_console_init() function can correctly initialize the serial port based on the device tree during SPL. This patch enables DM_SERIAL in both U-Boot and SPL.
diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index b95c9783a4..2c77b9c218 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_MX6LOGICPD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -84,6 +83,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_USB=y CONFIG_DM_USB=y
Unrelated change?
Unrelated change?
It appears to be an artifact of the make savedefconfig. Newer updates make CONFIG_SYS_MALLOC_F_LEN=0x2000 by default, so savedefconfig just removed it. I will do a V2 patch serial splitting the first patch into two separate parts, then I'll remove this artifact from the 2nd patch.
adam
Hi Adam,
spl_early_init();
I would suggest splitting these changes in two different patches.
Adam Ford
Fabio Estevam
