[PATCH 0/4] mmc: fsl_esdhc: ls1028a workarounds
This patchset fixes HS400 mode on LS1028A SoC which is broken since commit 8ee802f899ef ("mmc: fsl_esdhc: make sure delay chain locked for HS400"). Well, before it might just have worked by accident.
=> run bootcmd_mmc0 fsl_esdhc: delay chain lock timeout Select HS400 failed -110 unable to select a mode : -5
Because the sl28 board already uses that mode, MMC boot is broken. The first patch disables HS400 mode on this board. Tom, patch 1 should go into the master branch for the 2021.04 release.
Patches 2 and 3 introduce the actual workarounds, patch 4 will then reenable the HS400 mode on the sl28 board. I don't expect that this will make it into the next release.
Michael Walle (4): board: sl28: disable HS400 mode mmc: fsl_esdhc: add workaround for erratum A-011334 mmc: fsl_esdhc: add pulse width detection workaround board: sl28: enable HS400 mode again
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 2 ++ drivers/mmc/Kconfig | 6 +++++ drivers/mmc/fsl_esdhc.c | 31 +++++++++++++++++++++-- include/fsl_esdhc.h | 3 +++ 4 files changed, 40 insertions(+), 2 deletions(-)
Since commit 8ee802f899ef ("mmc: fsl_esdhc: make sure delay chain locked for HS400") HS400 mode is unreliable on LS1028A SoCs. Some workarounds are missing for this SoC.
Disable HS400 mode for now.
Signed-off-by: Michael Walle michael@walle.cc --- configs/kontron_sl28_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index 1c781e091c..0c6c1911d9 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -70,7 +70,7 @@ CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_I2C_MUX=y CONFIG_DM_MMC=y -CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_FSL_ESDHC_SUPPORT_ADMA2=y CONFIG_DM_SPI_FLASH=y
It seems that this patch doesn't need. Because CONFIG_MMC_HS400_SUPPORT is re-enabling with [PATCH 4/4]. How about dropping Drop [PATCH 1/4] and [PATCH 4/4]?
Best Regards, Jaehoon Chung
Am 2021-03-17 23:49, schrieb Jaehoon Chung:
Please read the cover letter, if patch 2/4 and 3/4 will make it into the 2021.04 relase, sure both can be dropped. But if not, patch 1/4 is intented to go into the release while 2/4, 3/4 and 4/4 might get into the next relase.
The reason is that I favor a working mmc boot in the next u-boot release for this board ;)
-michael
Sorry. I didn't read your cover-letter. At next time, i will read cover-letter, too. :)
-michael
LS1028A SoCs are restricted in what divider values are allowed for HS400 mode. This is basically a port from the corresponding linux driver.
Signed-off-by: Michael Walle michael@walle.cc --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + drivers/mmc/Kconfig | 3 +++ drivers/mmc/fsl_esdhc.c | 25 ++++++++++++++++++++++- 3 files changed, 28 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index ae0b7b21e8..c0190a233e 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -47,6 +47,7 @@ config ARCH_LS1028A select SYS_FSL_ERRATUM_A009663 if !TFABOOT select SYS_FSL_ERRATUM_A009942 if !TFABOOT select SYS_FSL_ERRATUM_A050382 + select SYS_FSL_ERRATUM_A011334 select RESV_RAM if GIC_V3_ITS imply PANIC_HANG
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index f8ca52efb6..0b6755fd90 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -812,3 +812,6 @@ config SYS_FSL_ERRATUM_ESDHC135
config SYS_FSL_ERRATUM_ESDHC_A001 bool + +config SYS_FSL_ERRATUM_A011334 + bool diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 6014e1c5ca..09ea1a9de9 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -518,6 +518,24 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) while (sdhc_clk / (div * pre_div) > clock && div < 16) div++;
+ if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_A011334) && + clock == 200000000 && mmc->selected_mode == MMC_HS_400) { + u32 div_ratio = pre_div * div; + + if (div_ratio <= 4) { + pre_div = 4; + div = 1; + } else if (div_ratio <= 8) { + pre_div = 4; + div = 2; + } else if (div_ratio <= 12) { + pre_div = 4; + div = 3; + } else { + printf("unsupported clock division.\n"); + } + } + mmc->clock = sdhc_clk / pre_div / div; priv->clock = mmc->clock;
@@ -1063,9 +1081,14 @@ static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) struct fsl_esdhc_plat *plat = dev_get_plat(dev); struct fsl_esdhc_priv *priv = dev_get_priv(dev); struct fsl_esdhc *regs = priv->esdhc_regs; + struct mmc *mmc = &plat->mmc; u32 val, irqstaten; int i;
+ if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_A011334) && + plat->mmc.hs400_tuning) + set_sysctl(priv, mmc, mmc->clock); + esdhc_tuning_block_enable(priv, true); esdhc_setbits32(®s->autoc12err, EXECUTE_TUNING);
@@ -1073,7 +1096,7 @@ static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) esdhc_write32(®s->irqstaten, IRQSTATEN_BRR);
for (i = 0; i < MAX_TUNING_LOOP; i++) { - mmc_send_tuning(&plat->mmc, opcode, NULL); + mmc_send_tuning(mmc, opcode, NULL); mdelay(1);
val = esdhc_read32(®s->autoc12err);
HS400 mode on the LS1028A SoC isn't reliable. The linux driver has a workaroung for the pulse width detection. Apply this workaround in u-boot, too.
This will make HS400 mode work reliably on the LS1028A SoC.
Signed-off-by: Michael Walle michael@walle.cc --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + drivers/mmc/Kconfig | 3 +++ drivers/mmc/fsl_esdhc.c | 6 +++++- include/fsl_esdhc.h | 3 +++ 4 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index c0190a233e..9d1ba4c771 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -48,6 +48,7 @@ config ARCH_LS1028A select SYS_FSL_ERRATUM_A009942 if !TFABOOT select SYS_FSL_ERRATUM_A050382 select SYS_FSL_ERRATUM_A011334 + select SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND select RESV_RAM if GIC_V3_ITS imply PANIC_HANG
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 0b6755fd90..f7620c9cd1 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -815,3 +815,6 @@ config SYS_FSL_ERRATUM_ESDHC_A001
config SYS_FSL_ERRATUM_A011334 bool + +config SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND + bool diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 09ea1a9de9..7501fdb71e 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -71,7 +71,8 @@ struct fsl_esdhc { uint sdtimingctl; /* SD timing control register */ char reserved8[20]; /* reserved */ uint dllcfg0; /* DLL config 0 register */ - char reserved9[12]; /* reserved */ + uint dllcfg1; /* DLL config 1 register */ + char reserved9[8]; /* reserved */ uint dllstat0; /* DLL status 0 register */ char reserved10[664];/* reserved */ uint esdhcctl; /* eSDHC control register */ @@ -767,6 +768,9 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) /* Set timout to the maximum value */ esdhc_clrsetbits32(®s->sysctl, SYSCTL_TIMEOUT_MASK, 14 << 16);
+ if (IS_ENABLED(CONFIG_SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND)) + esdhc_clrbits32(®s->dllcfg1, DLL_PD_PULSE_STRETCH_SEL); + return 0; }
diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 850a304bd7..f86afe5dad 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -190,6 +190,9 @@ #define DLL_RESET 0x40000000 #define DLL_FREQ_SEL 0x08000000
+/* DLL config 1 register */ +#define DLL_PD_PULSE_STRETCH_SEL 0x80000000 + /* DLL status 0 register */ #define DLL_STS_SLV_LOCK 0x08000000
- select SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND select RESV_RAM if GIC_V3_ITS imply PANIC_HANG
How about using QUIRK instead of WORKAROUD
- bool
- uint dllcfg1; /* DLL config 1 register */
- char reserved9[8]; /* reserved */ uint dllstat0; /* DLL status 0 register */ char reserved10[664];/* reserved */ uint esdhcctl; /* eSDHC control register */
- if (IS_ENABLED(CONFIG_SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND))
Am 2021-03-17 23:47, schrieb Jaehoon Chung:
There is already a CONFIG_FSL_ESDHC_33V_IO_RELIABILITY_WORKAROUND, so I chose that for consistency reasons.
-michael
Then i don't have any objection. Thanks!
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
-michael
Now that it is working reliable on the LS1028A SoC, reenable support for it.
diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index 0c6c1911d9..1c781e091c 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -70,7 +70,7 @@ CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_I2C_MUX=y CONFIG_DM_MMC=y -CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_FSL_ESDHC_SUPPORT_ADMA2=y CONFIG_DM_SPI_FLASH=y
Jaehoon Chung
Michael Walle
