[PATCH 0/2] efi_loader: link partition to block device
We provide a UEFI driver for block devices. When ConnectController() is called for a handle with the EFI_BLOCK_IO_PROTOCOL this driver creates the partitions. When DisconnectController() is called the handles for the partitions have to be deleted. This requires that the child controllers (partitions) open the EFI_BLOCK_IO_PROTOCOL of the controller (block IO device) with attribute EFI_OPEN_PROTOCOL_BY_CHILD_CONTROLLER.
Heinrich Schuchardt (2): efi_loader: make efi_protocol_open() non-static efi_loader: link partition to block device
include/efi_loader.h | 5 +++++ lib/efi_loader/efi_boottime.c | 2 +- lib/efi_loader/efi_disk.c | 20 ++++++++++++++++++++ 3 files changed, 26 insertions(+), 1 deletion(-)
-- 2.29.2
Provide efi_protocol_open() as library function.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_loader.h | 5 +++++ lib/efi_loader/efi_boottime.c | 2 +- 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 4c6eb8616d..365f3d01dc 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -500,6 +500,11 @@ efi_status_t efi_search_protocol(const efi_handle_t handle, efi_status_t efi_add_protocol(const efi_handle_t handle, const efi_guid_t *protocol, void *protocol_interface); +/* Open protocol */ +efi_status_t efi_protocol_open(struct efi_handler *handler, + void **protocol_interface, void *agent_handle, + void *controller_handle, uint32_t attributes); + /* Delete protocol from a handle */ efi_status_t efi_remove_protocol(const efi_handle_t handle, const efi_guid_t *protocol, diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 9bd63b6e52..03053e8660 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2779,7 +2779,7 @@ static void EFIAPI efi_set_mem(void *buffer, size_t size, uint8_t value) * * Return: status code */ -static efi_status_t efi_protocol_open( +efi_status_t efi_protocol_open( struct efi_handler *handler, void **protocol_interface, void *agent_handle, void *controller_handle, uint32_t attributes) -- 2.29.2
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_disk.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 7bd1ccec45..496ef29dd8 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -376,6 +376,23 @@ static efi_status_t efi_disk_add_dev( /* Fill in object data */ if (part) { struct efi_device_path *node = efi_dp_part_node(desc, part); + struct efi_handler *handler; + void *protocol_interface; + + /* Parent must expose EFI_BLOCK_IO_PROTOCOL */ + ret = efi_search_protocol(parent, &efi_block_io_guid, &handler); + if (ret != EFI_SUCCESS) + goto error; + + /* + * Link the partition (child controller) to the block device + * (controller). + */ + ret = efi_protocol_open(handler, &protocol_interface, NULL, + &diskobj->header, + EFI_OPEN_PROTOCOL_BY_CHILD_CONTROLLER); + if (ret != EFI_SUCCESS) + goto error;
diskobj->dp = efi_dp_append_node(dp_parent, node); efi_free_pool(node); @@ -453,6 +470,9 @@ static efi_status_t efi_disk_add_dev( } } return EFI_SUCCESS; +error: + efi_delete_handle(&diskobj->header); + return ret; }
/** -- 2.29.2
