RE: [U-Boot-Users] printf question
This usually works even on cranky compilers:
unsigned char x = 0xC2; printf("this is the problem %02X\n", (unsigned int)x);
In message DCEAAC0833DD314AB0B58112AD99B93B06DA9D@ismail.innsys.innovsys.com you wrote:
But we agree that the conversion "unsigned char" ==> "unsigned int" must result in exactly the same result, no matter if done implicitely or by explicit cast?
If this doesn't work it means that the toolchain is broken and/or misconfigured. Maybe there is no valid prototype for printf() active, etc., but this should be visible when compiling with warnings turned on.
I agree, unsigned char should be promoted to unsigned int.
However, char can be unsigned or signed depending on the platform. On a platform where char is signed by default and having a value of 0x80 or more, compiler can simply sign extend the value to promote to an integer before passing it to printf. So, a value like 0xC2 (-62 as 8-bit value) will be promoted to 0xffffffc2 (-62 as 32-bit value) on a 32-bit computer with twos complement arithmetic. %02X can only suppress leaving zeros so additional f's will be printed.
Best regards, Tolunay Orkun
Must, not should.
But the variable in question was of type "unsigned char", which leaves no room for implementation-specific behaviour.
We are talking about a format element which expects an "unsigned int" argument, and an "unsigned char" argument. There was no constant expression involved.
Oops? %02X will _add_ leading zeroes if the result is too short, but it will never supress anything.
[Maybe we should take this to c.l.c ;-)]
Must, not should.
Agreed. Poor choice of words...
In that case, compiler is generating incorrect code. Sign extension should not have been done.
My bad. The thing that I was trying to say was that since char is promoted to int, 0's in the higher order 3 bytes will not be printed by %02X format specification but if any one of those higher order bytes was non-zero (as a result of sign extension) the output will overflow from the 2 character field.
OK.
Rune Torgersen
Tolunay Orkun
