[U-Boot] [PATCH v2] net: kirkwood_egiga.c: fixed build warning
if link up detection code is disabled through config option, it gives build warning. This patch fixes the same
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Changelog: v2: unwanted commit in v1 patch removed
drivers/net/kirkwood_egiga.c | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 479035d..07a86cd 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -400,8 +400,10 @@ static int kwgbe_init(struct eth_device *dev) { struct kwgbe_device *dkwgbe = to_dkwgbe(dev); struct kwgbe_registers *regs = dkwgbe->regs; +#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ + && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) int i; - +#endif /* setup RX rings */ kwgbe_init_rx_desc_ring(dkwgbe);
Hi Prafulla,
int i;&& defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN)
Applied to net repo.
thanks, Ben
Ben Warren
Prafulla Wadaskar
