[U-Boot] [PATCH 1/2] da8xx: ea20: Add the configuration define for the exact SoC variant
Signed-off-by: Tomas Novotny tomas@novotny.cz Cc: Tom Rini trini@ti.com Cc: Stefano Babic sbabic@denx.de --- The second patch in this series adds pinmux for the da830. This pinmux is selected when CONFIG_SOC_DA850 is not set. Although ea20 has its own gpio pinmux (because gpio_request() is not used), this patch is added to prevent possible problems in the future.
include/configs/ea20.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/ea20.h b/include/configs/ea20.h index d3eb596..03dfe0a 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -42,6 +42,7 @@ #define CONFIG_MACH_DAVINCI_DA850_EVM #define CONFIG_ARM926EJS /* arm926ejs CPU core */ #define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SOC_DA850 /* TI DA850 SoC */ #define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE
The pinmux was generated from linux/arch/arm/mach-davinci/da830.c as of kernel version 3.7.5. If the driver is used for the da850, then SoC variant must be specified by CONFIG_SOC_DA850.
Signed-off-by: Tomas Novotny tomas@novotny.cz Cc: Tom Rini trini@ti.com --- I'm not sure with selected #defines, so suggestions are welcome. Now the pinmux for da850 gpios is used by default. This patch may change this behaviour and da850 pinmux is selected when there is CONFIG_SOC_DA850. This is true for all mainline da8xx boards, so everything should be ok.
arch/arm/include/asm/arch-davinci/gpio.h | 4 + drivers/gpio/da8xx_gpio.c | 133 ++++++++++++++++++++++++++++++ 2 files changed, 137 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/gpio.h b/arch/arm/include/asm/arch-davinci/gpio.h index ef65ffb..fbbb1f3 100644 --- a/arch/arm/include/asm/arch-davinci/gpio.h +++ b/arch/arm/include/asm/arch-davinci/gpio.h @@ -67,7 +67,11 @@ struct davinci_gpio_bank {
#define gpio_status() gpio_info() #define GPIO_NAME_SIZE 20 +#if defined(CONFIG_SOC_DA8XX) && !defined(CONFIG_SOC_DA850) +#define MAX_NUM_GPIOS 128 +#else #define MAX_NUM_GPIOS 144 +#endif #define GPIO_BANK(gp) (davinci_gpio_bank01 + ((gp) >> 5)) #define GPIO_BIT(gp) ((gp) & 0x1F)
diff --git a/drivers/gpio/da8xx_gpio.c b/drivers/gpio/da8xx_gpio.c index 84d2b77..271b8d9 100644 --- a/drivers/gpio/da8xx_gpio.c +++ b/drivers/gpio/da8xx_gpio.c @@ -33,6 +33,138 @@ static struct gpio_registry {
#define pinmux(x) (&davinci_syscfg_regs->pinmux[x])
+#if defined(CONFIG_SOC_DA8XX) && !defined(CONFIG_SOC_DA850) +static const struct pinmux_config gpio_pinmux[] = { + { pinmux(13), 8, 6 }, /* GP0[0] */ + { pinmux(13), 8, 7 }, + { pinmux(14), 8, 0 }, + { pinmux(14), 8, 1 }, + { pinmux(14), 8, 2 }, + { pinmux(14), 8, 3 }, + { pinmux(14), 8, 4 }, + { pinmux(14), 8, 5 }, + { pinmux(14), 8, 6 }, + { pinmux(14), 8, 7 }, + { pinmux(15), 8, 0 }, + { pinmux(15), 8, 1 }, + { pinmux(15), 8, 2 }, + { pinmux(15), 8, 3 }, + { pinmux(15), 8, 4 }, + { pinmux(15), 8, 5 }, + { pinmux(15), 8, 6 }, /* GP1[0] */ + { pinmux(15), 8, 7 }, + { pinmux(16), 8, 0 }, + { pinmux(16), 8, 1 }, + { pinmux(16), 8, 2 }, + { pinmux(16), 8, 3 }, + { pinmux(16), 8, 4 }, + { pinmux(16), 8, 5 }, + { pinmux(16), 8, 6 }, + { pinmux(16), 8, 7 }, + { pinmux(17), 8, 0 }, + { pinmux(17), 8, 1 }, + { pinmux(17), 8, 2 }, + { pinmux(17), 8, 3 }, + { pinmux(17), 8, 4 }, + { pinmux(17), 8, 5 }, + { pinmux(17), 8, 6 }, /* GP2[0] */ + { pinmux(17), 8, 7 }, + { pinmux(18), 8, 0 }, + { pinmux(18), 8, 1 }, + { pinmux(18), 8, 2 }, + { pinmux(18), 8, 3 }, + { pinmux(18), 8, 4 }, + { pinmux(18), 8, 5 }, + { pinmux(18), 8, 6 }, + { pinmux(18), 8, 7 }, + { pinmux(19), 8, 0 }, + { pinmux(9), 8, 2 }, + { pinmux(9), 8, 3 }, + { pinmux(9), 8, 4 }, + { pinmux(9), 8, 5 }, + { pinmux(9), 8, 6 }, + { pinmux(10), 8, 1 }, /* GP3[0] */ + { pinmux(10), 8, 2 }, + { pinmux(10), 8, 3 }, + { pinmux(10), 8, 4 }, + { pinmux(10), 8, 5 }, + { pinmux(10), 8, 6 }, + { pinmux(10), 8, 7 }, + { pinmux(11), 8, 0 }, + { pinmux(11), 8, 1 }, + { pinmux(11), 8, 2 }, + { pinmux(11), 8, 3 }, + { pinmux(11), 8, 4 }, + { pinmux(9), 8, 7 }, + { pinmux(2), 8, 6 }, + { pinmux(11), 8, 5 }, + { pinmux(11), 8, 6 }, + { pinmux(12), 8, 4 }, /* GP4[0] */ + { pinmux(12), 8, 5 }, + { pinmux(12), 8, 6 }, + { pinmux(12), 8, 7 }, + { pinmux(13), 8, 0 }, + { pinmux(13), 8, 1 }, + { pinmux(13), 8, 2 }, + { pinmux(13), 8, 3 }, + { pinmux(13), 8, 4 }, + { pinmux(13), 8, 5 }, + { pinmux(11), 8, 7 }, + { pinmux(12), 8, 0 }, + { pinmux(12), 8, 1 }, + { pinmux(12), 8, 2 }, + { pinmux(12), 8, 3 }, + { pinmux(9), 8, 1 }, + { pinmux(7), 8, 3 }, /* GP5[0] */ + { pinmux(7), 8, 4 }, + { pinmux(7), 8, 5 }, + { pinmux(7), 8, 6 }, + { pinmux(7), 8, 7 }, + { pinmux(8), 8, 0 }, + { pinmux(8), 8, 1 }, + { pinmux(8), 8, 2 }, + { pinmux(8), 8, 3 }, + { pinmux(8), 8, 4 }, + { pinmux(8), 8, 5 }, + { pinmux(8), 8, 6 }, + { pinmux(8), 8, 7 }, + { pinmux(9), 8, 0 }, + { pinmux(7), 8, 1 }, + { pinmux(7), 8, 2 }, + { pinmux(5), 8, 1 }, /* GP6[0] */ + { pinmux(5), 8, 2 }, + { pinmux(5), 8, 3 }, + { pinmux(5), 8, 4 }, + { pinmux(5), 8, 5 }, + { pinmux(5), 8, 6 }, + { pinmux(5), 8, 7 }, + { pinmux(6), 8, 0 }, + { pinmux(6), 8, 1 }, + { pinmux(6), 8, 2 }, + { pinmux(6), 8, 3 }, + { pinmux(6), 8, 4 }, + { pinmux(6), 8, 5 }, + { pinmux(6), 8, 6 }, + { pinmux(6), 8, 7 }, + { pinmux(7), 8, 0 }, + { pinmux(1), 8, 0 }, /* GP7[0] */ + { pinmux(1), 8, 1 }, + { pinmux(1), 8, 2 }, + { pinmux(1), 8, 3 }, + { pinmux(1), 8, 4 }, + { pinmux(1), 8, 5 }, + { pinmux(1), 8, 6 }, + { pinmux(1), 8, 7 }, + { pinmux(2), 8, 0 }, + { pinmux(2), 8, 1 }, + { pinmux(2), 8, 2 }, + { pinmux(2), 8, 3 }, + { pinmux(2), 8, 4 }, + { pinmux(2), 8, 5 }, + { pinmux(0), 1, 0 }, + { pinmux(0), 1, 1 }, +}; +#else static const struct pinmux_config gpio_pinmux[] = { { pinmux(1), 8, 7 }, /* GP0[0] */ { pinmux(1), 8, 6 }, @@ -179,6 +311,7 @@ static const struct pinmux_config gpio_pinmux[] = { { pinmux(18), 8, 3 }, { pinmux(18), 8, 2 }, }; +#endif
int gpio_request(unsigned gpio, const char *label) {
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
On Fri, Feb 01, 2013 at 06:44:06AM -0000, Tomas Novotny wrote:
Signed-off-by: Tomas Novotny tomas@novotny.cz Cc: Tom Rini trini@ti.com Cc: Stefano Babic sbabic@denx.de Acked-by: Stefano Babic sbabic@denx.de
This and 2/2 have been applied to u-boot-ti/master, thanks!
Stefano Babic
Tomas Novotny
