[U-Boot] Fix fsl_elbc_nand driver
This is my best try. I have test it with my old u-boot, but not with master. Do not have a bench for it. This is not very important patch. I do not find any other ONFI user in u-boot. Andrei
From d76b4ae8e866affa15dd9da860574d0600969d57 Mon Sep 17 00:00:00 2001
From: Andrei Yakimov ayakimov@iptec-inc.com Date: Mon, 18 May 2015 18:50:12 -0700 Subject: [PATCH] ONFI detect reading only first parameter page.
NAND_CMD_PARAM read only first parameter page. Need to read all 3 (as per ONFI spec) due to no error correction for this area
Signed-off-by: Andrei Yakimov ayakimov@iptec-inc.com ---
drivers/mtd/nand/fsl_elbc_nand.c | 9 +++++---- drivers/mtd/nand/fsl_ifc_nand.c | 10 ++++++---- 2 files changed, 11 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c index e85832d..8ac470f 100644 --- a/drivers/mtd/nand/fsl_elbc_nand.c +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -336,11 +336,12 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, (FIR_OP_RBW << FIR_OP2_SHIFT)); out_be32(&lbc->fcr, command << FCR_CMD0_SHIFT); /* - * although currently it's 8 bytes for READID, we always read - * the maximum 256 bytes(for PARAM) + * although currently it's 8 bytes for READID + * param page containg at least 3 copy for + * robustnes, we need to read them all. */ - out_be32(&lbc->fbcr, 256); - ctrl->read_bytes = 256; + out_be32(&lbc->fbcr, (command == NAND_CMD_PARAM) ? 786 : 8); + ctrl->read_bytes = (command == NAND_CMD_PARAM) ? 786 : 8; ctrl->use_mdr = 1; ctrl->mdr = column; set_addr(mtd, 0, 0, 0); diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 79fa88b..ee96a62 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -459,11 +459,13 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, ifc_out32(&ifc->ifc_nand.row3, column);
/* - * although currently it's 8 bytes for READID, we always read - * the maximum 256 bytes(for PARAM) + * although currently it's 8 bytes for READID + * param page containg at least 3 copy for + * robustnes, we need to read them all. */ - ifc_out32(&ifc->ifc_nand.nand_fbcr, 256); - ctrl->read_bytes = 256; + ifc_out32(&ifc->ifc_nand.nand_fbcr, + (command == NAND_CMD_PARAM) ? 786 : 8); + ctrl->read_bytes = (command == NAND_CMD_PARAM) ? 786 : 8;
set_addr(mtd, 0, 0, 0); fsl_ifc_run_command(mtd);
A bench?
From d76b4ae8e866affa15dd9da860574d0600969d57 Mon Sep 17 00:00:00 2001 From: Andrei Yakimov ayakimov@iptec-inc.com Date: Mon, 18 May 2015 18:50:12 -0700 Subject: [PATCH] ONFI detect reading only first parameter page.
*/* robustnes, we need to read them all.
786? Not 768?
-Scott
Andrei Yakimov
Scott Wood
