[U-Boot-Users] A question about initialization of SDRAM
Dear all: I am trying to use ELDK to make a u-boot on the board with MPC852T.
There is declaration of rtx in cpu/mpc8xx/fec.c: ***************************************************************** typedef volatile struct CommonBufferDescriptor { cbd_t rxbd[PKTBUFSRX]; /* Rx BD */ cbd_t txbd[TX_BUF_CNT]; /* Tx BD */ } RTXBD;
static RTXBD *rtx = NULL; ******************************************************************
And "rtx" is used in function fec_init(): ****************************************************************** if (!rtx) { #ifdef CFG_ALLOC_DPRAM rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + dpram_alloc_align (sizeof (RTXBD), 8)); #else rtx = (RTXBD *) (immr->im_cpm.cp_dpmem + CPM_FEC_BASE); #endif } *******************************************************************
I think that "rtx" should be NULL at the first time fec_init() is entered,so the rtx will be given the value. but after the ELDK make the u-boot, "rtx" isn't NULL at the first time fec_init() is entered, it is 0xffffffff.
Then I make some points in the u-boot source program, and finally find that: Before the word "memctl->memc_mbmr = 0xD0924114" in the function initdram, rtx is NULL(0x0),but after that it is 0xffffffff. Part of the fuction initdram is below: ******************************************************************** long int initdram (int board_type) { volatile immap_t *immap = (immap_t *) CFG_IMMR; volatile memctl8xx_t *memctl = &immap->im_memctl; volatile iop8xx_t *iop8xxctl=&immap->im_ioport; long int size8, size9; long int Msize; long int size_b0 = 0; long int size_b1 = 0; memctl->memc_mptpr = 0x0800; memctl->memc_mstat = 0x0000; upmconfig (UPMB, (uint *) sdram_table, sizeof (sdram_table) / sizeof (uint)); memctl->memc_mptpr = 0x0800;
memctl->memc_mbmr = 0xD0924114;//---------------------------rtx is changed to 0xfffffffff from here!!!!!!!! Msize=0xD0924114; size_b0 = 0x02000000;
/* * The following value is used as an address (i.e. opcode) for * the LOAD MODE REGISTER COMMAND during SDRAM initialisation. If * the port size is 32bit the SDRAM does NOT "see" the lower two * address lines, i.e. mar=0x00000088 -> opcode=0x00000022 for * MICRON SDRAMs: * -> 0 00 010 0 010 * | | | | +- Burst Length = 4 * | | | +----- Burst Type = Sequential * | | +------- CAS Latency = 2 * | +----------- Operating Mode = Standard * +-------------- Write Burst Mode = Programmed Burst Length */ memctl->memc_mar = 0x00000088; memctl->memc_mcr = 0x8080A105; udelay(1);
memctl->memc_mbmr =(Msize & 0xfffffff0) | 0x00000008;//((Msize | 0x00000008) & 0xfffffffb); memctl->memc_mcr = 0x8080A130; udelay(1);
memctl->memc_mbmr =Msize ; udelay(200); size_b1 = 0;
I wonder what happens in "memctl->memc_mbmr = 0xD0924114;",would you please explain it to me ? Thanks!
Liam 2005-11-17
"the board with MPC852T"? There is many such boards, most of them differnt.
What makes you think so? The code is running perfectly fine on many boards. Which specific problem do you see?
Looks as if there was a bug in the SDRAM init sequence for your board.
Please see the processor's User's Manual; read the memory controller section.
蔡潋滟
