[PATCH V7 0/4] arm64: binman: use binman symbols for imx
V7: Rebased with follwoing patchset applied. [1] i.MX93 patchset: https://patchwork.ozlabs.org/project/uboot/cover/20220627032455.28280-1-peng... [2] binman symbols fix: https://patchwork.ozlabs.org/project/uboot/cover/20220618121316.12061-1-alpe...
V6: Drop no-u-boot-any introduced in V5 Drop binman symbol replacement with @ to _, which is not needed Update imx8m config to not select RAM IMAGE and RAM DEVICE Update ddr firmware node name Introduce autoconf.h for binman test
V5: Introduce no-u-boot-any property to drop the X86 guard patch 1 Add blob-ext type for ddr firmware node Include a missing dts change
V4: Fix three boards build failure
V3: Add R-b/T-b Fix build warning
V2: resolve some CI failure include patch 7
binman symbol is a good feature, but only used on X86 for now. This patchset is to use it for i.MX8M platform.
The current imx8m ddr phy firmware consumes lots of space, because we pad them to the largest 32KB and 16KB for IMEM and DMEM.
With this patchset we use binman symbols to get firmware location and size, we could save near 36KB with i.MX8MP-EVK.
Please help check and test
Peng Fan (4): arm: dts: imx8m: update binman ddr firmware node name ddr: imx8m: helper: load ddr firmware according to binman symbols arm: dts: imx8m: shrink ddr firmware size to actual file size imx: imx8mm-icore: migrate to use BINMAN
arch/arm/dts/imx8mm-u-boot.dtsi | 16 +++---- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 20 ++++---- .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 8 ++-- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 20 ++++---- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 20 ++++---- .../dts/imx8mn-var-som-symphony-u-boot.dtsi | 16 +++---- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 16 +++---- arch/arm/dts/imx8mp-u-boot.dtsi | 20 ++++---- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 20 ++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 16 +++---- arch/arm/mach-imx/imx8m/Kconfig | 1 + .../mach-imx/imx8m/imximage-8mm-lpddr4.cfg | 10 +--- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 2 +- configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 2 +- drivers/ddr/imx/phy/helper.c | 47 ++++++++++++++++--- 15 files changed, 141 insertions(+), 93 deletions(-)
We are migrating to use binman symbols, the current names are inconsistent across different boards, so unify them.
Also add `type = "blob-ext";`, since the new names are not valid binman types.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Alper Nebi Yasak alpernebiyasak@gmail.com [Alper: Edit commit message] Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 4 ++-- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mp-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 8 ++++---- 10 files changed, 58 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 9f66cdb65a9..86f8e1a284b 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -39,25 +39,25 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + ddr-1d-imem-fw { filename = "lpddr4_pmu_train_1d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d-dmem { + ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d-imem { + ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d-dmem { + ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index eb1dd8debba..d28bb2b2ffe 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -147,24 +147,28 @@ align-end = <4>; };
- blob_1: blob-ext@1 { + ddr-1d-imem-fw { filename = "lpddr4_pmu_train_1d_imem.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; + type = "blob-ext"; }; };
diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index 46a9d7fd78b..dc4cec250ef 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -111,13 +111,13 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + ddr-1d-imem-fw { filename = "ddr3_imem_1d.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d_dmem { + ddr-1d-dmem-fw { filename = "ddr3_dmem_1d.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 4d0ecb07d4f..30ef8bc47d9 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -155,24 +155,28 @@ align-end = <4>; };
- blob_1: blob-ext@1 { + ddr-1d-imem-fw { filename = "ddr4_imem_1d_201810.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + ddr-1d-dmem-fw { filename = "ddr4_dmem_1d_201810.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + ddr-2d-imem-fw { filename = "ddr4_imem_2d_201810.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + ddr-2d-dmem-fw { filename = "ddr4_dmem_2d_201810.bin"; size = <0x4000>; + type = "blob-ext"; }; };
diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi index 593cf06eb95..31c05e45cfb 100644 --- a/arch/arm/dts/imx8mn-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -36,24 +36,28 @@ align-end = <4>; };
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index 6e37622cca7..b8df6f749b0 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -130,25 +130,25 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + ddr-1d-imem-fw { filename = "ddr4_imem_1d.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d_dmem { + ddr-1d-dmem-fw { filename = "ddr4_dmem_1d.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d_imem { + ddr-2d-imem-fw { filename = "ddr4_imem_2d.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d_dmem { + ddr-2d-dmem-fw { filename = "ddr4_dmem_2d.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 35819553879..bcf2abd0676 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -126,25 +126,25 @@ filename = "u-boot-spl.bin"; };
- 1d_dmem { + ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d_imem { + ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d_dmem { + ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 20edd90cfad..dc57ee20411 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -61,24 +61,28 @@ align-end = <4>; };
- blob_1: blob-ext@1 { + ddr-1d-imem-fw { filename = "lpddr4_pmu_train_1d_imem_202006.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem_202006.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; size = <0x4000>; + type = "blob-ext"; }; };
diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index e2f4b0e740d..bc7e9756c23 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -28,24 +28,28 @@ align-end = <4>; };
diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 912a3d4a356..462c470091a 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -46,25 +46,25 @@ filename = "u-boot-spl.bin"; };
By reading binman symbols, we no need hard coded IMEM_LEN/DMEM_LEN after we update the binman dtsi to drop 0x8000/0x4000 length for the firmware.
And that could save binary size for many KBs.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Alper Nebi Yasak alpernebiyasak@gmail.com [Alper: Check BINMAN_SYMS_OK instead] Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- drivers/ddr/imx/phy/helper.c | 47 +++++++++++++++++++++++++++++++----- 1 file changed, 41 insertions(+), 6 deletions(-)
diff --git a/drivers/ddr/imx/phy/helper.c b/drivers/ddr/imx/phy/helper.c index 60d650e3089..e9e0294f87d 100644 --- a/drivers/ddr/imx/phy/helper.c +++ b/drivers/ddr/imx/phy/helper.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <binman_sym.h> #include <log.h> #include <spl.h> #include <asm/global_data.h> @@ -24,15 +25,30 @@ DECLARE_GLOBAL_DATA_PTR; #define DMEM_OFFSET_ADDR 0x00054000 #define DDR_TRAIN_CODE_BASE_ADDR IP2APB_DDRPHY_IPS_BASE_ADDR(0)
+binman_sym_declare(ulong, ddr_1d_imem_fw, image_pos); +binman_sym_declare(ulong, ddr_1d_imem_fw, size); + +binman_sym_declare(ulong, ddr_1d_dmem_fw, image_pos); +binman_sym_declare(ulong, ddr_1d_dmem_fw, size); + +#if !IS_ENABLED(CONFIG_IMX8M_DDR3L) +binman_sym_declare(ulong, ddr_2d_imem_fw, image_pos); +binman_sym_declare(ulong, ddr_2d_imem_fw, size); + +binman_sym_declare(ulong, ddr_2d_dmem_fw, image_pos); +binman_sym_declare(ulong, ddr_2d_dmem_fw, size); +#endif + /* We need PHY iMEM PHY is 32KB padded */ void ddr_load_train_firmware(enum fw_type type) { u32 tmp32, i; u32 error = 0; unsigned long pr_to32, pr_from32; - unsigned long fw_offset = type ? IMEM_2D_OFFSET : 0; + uint32_t fw_offset = type ? IMEM_2D_OFFSET : 0; unsigned long imem_start = (unsigned long)&_end + fw_offset; unsigned long dmem_start; + unsigned long imem_len = IMEM_LEN, dmem_len = DMEM_LEN;
#ifdef CONFIG_SPL_OF_CONTROL if (gd->fdt_blob && !fdt_check_header(gd->fdt_blob)) { @@ -42,11 +58,30 @@ void ddr_load_train_firmware(enum fw_type type) } #endif
- dmem_start = imem_start + IMEM_LEN; + dmem_start = imem_start + imem_len; + + if (BINMAN_SYMS_OK) { + switch (type) { + case FW_1D_IMAGE: + imem_start = binman_sym(ulong, ddr_1d_imem_fw, image_pos); + imem_len = binman_sym(ulong, ddr_1d_imem_fw, size); + dmem_start = binman_sym(ulong, ddr_1d_dmem_fw, image_pos); + dmem_len = binman_sym(ulong, ddr_1d_dmem_fw, size); + break; + case FW_2D_IMAGE: +#if !IS_ENABLED(CONFIG_IMX8M_DDR3L) + imem_start = binman_sym(ulong, ddr_2d_imem_fw, image_pos); + imem_len = binman_sym(ulong, ddr_2d_imem_fw, size); + dmem_start = binman_sym(ulong, ddr_2d_dmem_fw, image_pos); + dmem_len = binman_sym(ulong, ddr_2d_dmem_fw, size); +#endif + break; + } + }
pr_from32 = imem_start; pr_to32 = IMEM_OFFSET_ADDR; - for (i = 0x0; i < IMEM_LEN; ) { + for (i = 0x0; i < imem_len; ) { tmp32 = readl(pr_from32); writew(tmp32 & 0x0000ffff, DDR_TRAIN_CODE_BASE_ADDR + ddrphy_addr_remap(pr_to32)); pr_to32 += 1; @@ -59,7 +94,7 @@ void ddr_load_train_firmware(enum fw_type type)
pr_from32 = dmem_start; pr_to32 = DMEM_OFFSET_ADDR; - for (i = 0x0; i < DMEM_LEN; ) { + for (i = 0x0; i < dmem_len; ) { tmp32 = readl(pr_from32); writew(tmp32 & 0x0000ffff, DDR_TRAIN_CODE_BASE_ADDR + ddrphy_addr_remap(pr_to32)); pr_to32 += 1; @@ -73,7 +108,7 @@ void ddr_load_train_firmware(enum fw_type type) debug("check ddr_pmu_train_imem code\n"); pr_from32 = imem_start; pr_to32 = IMEM_OFFSET_ADDR; - for (i = 0x0; i < IMEM_LEN; ) { + for (i = 0x0; i < imem_len; ) { tmp32 = (readw(DDR_TRAIN_CODE_BASE_ADDR + ddrphy_addr_remap(pr_to32)) & 0x0000ffff); pr_to32 += 1; tmp32 += ((readw(DDR_TRAIN_CODE_BASE_ADDR + @@ -95,7 +130,7 @@ void ddr_load_train_firmware(enum fw_type type) debug("check ddr4_pmu_train_dmem code\n"); pr_from32 = dmem_start; pr_to32 = DMEM_OFFSET_ADDR; - for (i = 0x0; i < DMEM_LEN;) { + for (i = 0x0; i < dmem_len;) { tmp32 = (readw(DDR_TRAIN_CODE_BASE_ADDR + ddrphy_addr_remap(pr_to32)) & 0x0000ffff); pr_to32 += 1; tmp32 += ((readw(DDR_TRAIN_CODE_BASE_ADDR +
Hi Tom, Simon, Peng,
A terrible question popped into my head while thinking about binman symbols, and I feel obliged to ask. Would this be considered 'linking' these proprietary blobs to a GPL-licensed U-Boot SPL binary?
No, I don't think so. This isn't any different than the other types of technical implementations done to allow for GPL things to start / find / load / get information back from non-GPL things.
After we switch to use BINMAN_SYMBOLS, there is no need to pad the file size to 0x8000 and 0x4000. After we use BINMAN_SYMBOLS, the u-boot-spl-ddr.bin shrink about 36KB with i.MX8MP-EVK.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 4 ++-- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mp-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 8 ++++---- 10 files changed, 38 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 86f8e1a284b..8c48678625d 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -41,25 +41,25 @@
ddr-1d-imem-fw { filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; };
ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index d28bb2b2ffe..5f839524028 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -149,26 +149,26 @@
ddr-1d-imem-fw { filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; };
ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index dc4cec250ef..c4ae7ca4f31 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -113,13 +113,13 @@
ddr-1d-imem-fw { filename = "ddr3_imem_1d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
ddr-1d-dmem-fw { filename = "ddr3_dmem_1d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 30ef8bc47d9..78773c198e4 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -157,26 +157,26 @@
ddr-1d-imem-fw { filename = "ddr4_imem_1d_201810.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
ddr-1d-dmem-fw { filename = "ddr4_dmem_1d_201810.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; };
ddr-2d-imem-fw { filename = "ddr4_imem_2d_201810.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
ddr-2d-dmem-fw { filename = "ddr4_dmem_2d_201810.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi index 31c05e45cfb..e15a41f1190 100644 --- a/arch/arm/dts/imx8mn-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -38,26 +38,26 @@
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index b8df6f749b0..ed1ab10ded3 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -132,25 +132,25 @@
ddr-1d-imem-fw { filename = "ddr4_imem_1d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
ddr-1d-dmem-fw { filename = "ddr4_dmem_1d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; };
ddr-2d-imem-fw { filename = "ddr4_imem_2d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
ddr-2d-dmem-fw { filename = "ddr4_dmem_2d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index bcf2abd0676..9fb38714523 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -128,25 +128,25 @@
ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index dc57ee20411..adb24cccc3b 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -63,26 +63,26 @@
ddr-1d-imem-fw { filename = "lpddr4_pmu_train_1d_imem_202006.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
ddr-1d-dmem-fw { filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; };
ddr-2d-imem-fw { filename = "lpddr4_pmu_train_2d_imem_202006.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
ddr-2d-dmem-fw { filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index bc7e9756c23..cb4e36c387d 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -30,26 +30,26 @@
diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 462c470091a..e8b5f83706e 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -48,25 +48,25 @@
Use BINMAN instead of imx specific packing method.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- arch/arm/mach-imx/imx8m/Kconfig | 1 + arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg | 10 +--------- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 2 +- configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 2 +- 4 files changed, 4 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index ef8518c06bd..e01e9e8a96e 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -69,6 +69,7 @@ config TARGET_IMX8MM_EVK
config TARGET_IMX8MM_ICORE_MX8MM bool "Engicam i.Core MX8M Mini SOM" + select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 diff --git a/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg b/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg index e06d53ef417..5dcb8ae72f0 100644 --- a/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg +++ b/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg @@ -3,13 +3,5 @@ * Copyright 2019 NXP */
- -FIT BOOT_FROM sd -LOADER spl/u-boot-spl-ddr.bin 0x7E1000 -SECOND_LOADER u-boot.itb 0x40200000 0x60000 - -DDR_FW lpddr4_pmu_train_1d_imem.bin -DDR_FW lpddr4_pmu_train_1d_dmem.bin -DDR_FW lpddr4_pmu_train_2d_imem.bin -DDR_FW lpddr4_pmu_train_2d_dmem.bin +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index 7d08b244f2c..30f842aef3b 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -20,7 +20,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-ctouch2.dtb" CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index acc5d34659b..721c72c719c 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -20,7 +20,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-edimm2.2.dtb" CONFIG_SPL_HAS_BSS_LINKER_SECTION=y
Hi Peng,
Am 27.06.22 um 05:41 schrieb Peng Fan (OSS):
I tested this on next with the two patchsets mentioned above applied on a kontron-sl-mx8mm board. I get around 38 KiB of SPL size reduction, which is great!
Tested-by: Frieder Schrempf frieder.schrempf@kontron.de
Thanks! Frieder
Subject: Re: [PATCH V7 0/4] arm64: binman: use binman symbols for imx
Hi Peng,
V7: Rebased with follwoing patchset applied. [1] i.MX93 patchset: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatc
hwork.ozlabs.org%2Fproject%2Fuboot%2Fcover%2F20220627032455.28280- 1-pe
ng.fan%40oss.nxp.com%2F&data=05%7C01%7Cpeng.fan%40nxp.com%7 C4d84e7
f4d2a64aa0c42608da581ba444%7C686ea1d3bc2b4c6fa92cd99c5c301635% 7C0%7C0%
7C637919173000954346%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjA wMDAiLCJQI
joiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&s data=95
jEtkvfpG3HVgqTpeodf%2BQXjw5DBnYVpZ7%2BCBaKfp0%3D&reserved= 0
[2] binman symbols fix: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatc
hwork.ozlabs.org%2Fproject%2Fuboot%2Fcover%2F20220618121316.12061- 1-al
pernebiyasak%40gmail.com%2F&data=05%7C01%7Cpeng.fan%40nxp.co m%7C4d
84e7f4d2a64aa0c42608da581ba444%7C686ea1d3bc2b4c6fa92cd99c5c3016 35%7C0%
7C0%7C637919173000954346%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC 4wLjAwMDAiL
CJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&a mp;sdat
a=jdsYVWoijLk0cGEA2xyVtF6AKNj7ajNxSILFLXkypZE%3D&reserved=0
Thanks for testing this patchset.
Thanks, Peng.
Thanks! Frieder
ddr
participants (5)
Alper Nebi Yasak
Frieder Schrempf
Peng Fan
Peng Fan (OSS)
