[U-Boot] [PATCH] sun8i: h3: Support H3 variant of Orange Pi Zero Plus 2
Orangepi Zero Plus 2 is an open-source single-board computer, available in two Allwinner SOC variants, H3 and H5. We add support for H3 variant here, as the H5 is already supported.
H3 Orangepi Zero Plus 2 has: - Quad-core Cortex-A7 - 512MB DDR3 - microSD slot and 8GB eMMC - Debug TTL UART - HDMI - Wifi + BT - OTG + power supply
Signed-off-by: Diego Rondini diego.rondini@kynetics.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts | 139 ++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/orangepi_zero_plus2_h3_defconfig | 19 +++ 4 files changed, 165 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts create mode 100644 configs/orangepi_zero_plus2_h3_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 251d32ca62..5c7b8cfcc9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -513,7 +513,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-pc.dtb \ sun8i-h3-orangepi-pc-plus.dtb \ sun8i-h3-orangepi-plus.dtb \ - sun8i-h3-orangepi-plus2e.dtb + sun8i-h3-orangepi-plus2e.dtb \ + sun8i-h3-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN8I_R40) += \ sun8i-r40-bananapi-m2-ultra.dtb \ sun8i-v40-bananapi-m2-berry.dtb diff --git a/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts b/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts new file mode 100644 index 0000000000..f2f7b7a925 --- /dev/null +++ b/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts @@ -0,0 +1,139 @@ +/* + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * Copyright (C) 2018 Diego Rondini diego.rondini@kynetics.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun8i-h3.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi Zero Plus2 H3"; + compatible = "xunlong,orangepi-zero-plus2-h3", "allwinner,sun8i-h3"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&pio 0 9 GPIO_ACTIVE_LOW>; /* PA9 */ + post-power-on-delay-ms = <200>; + }; +}; + +&de { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_vcc3v3>; + vqmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 7 IRQ_TYPE_LEVEL_LOW>; /* PL7 */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index a2adf89b5d..4a89bb0e7b 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -405,6 +405,11 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/orangepi_zero_plus2_defconfig
+ORANGEPI ZERO PLUS 2 H3 BOARD +M: Diego Rondini diego.rondini@kynetics.com +S: Maintained +F: configs/orangepi_zero_plus2_h3_defconfig + ORANGEPI PC 2 BOARD M: Andre Przywara andre.przywara@arm.com S: Maintained diff --git a/configs/orangepi_zero_plus2_h3_defconfig b/configs/orangepi_zero_plus2_h3_defconfig new file mode 100644 index 0000000000..3000a97e73 --- /dev/null +++ b/configs/orangepi_zero_plus2_h3_defconfig @@ -0,0 +1,19 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=672 +# CONFIG_DRAM_ODT_EN is not set +CONFIG_MMC0_CD_PIN="PH13" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_USE_PREBOOT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-zero-plus2" +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
On Wed, Nov 6, 2019 at 3:28 AM Diego Rondini diego.rondini@kynetics.com wrote:
- 512MB DDR3
- Debug TTL UART
- HDMI
- Wifi + BT
Add linux commit details on above commit message.
Sync dts from linux v5.2 commit: "ARM: dts: sunxi: h3/h5: Remove stale pinctrl-names entry" (sha1: 75f9a058838be9880afd75c4cb14e1bf4fe34a0b) Commit: "ARM: dts: sun8i: h3: Refactor the pinctrl node names" (sha1: a4dc791974e568a15f7f37131729b1a6912f4811) has been avoided as it breaks U-Boot build.
Signed-off-by: Diego Rondini diego.rondini@kynetics.com --- Changes in v2: - clarify where the dts comes from --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts | 139 ++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/orangepi_zero_plus2_h3_defconfig | 19 +++ 4 files changed, 165 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts create mode 100644 configs/orangepi_zero_plus2_h3_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d8846df1bd..fc6d66ddab 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -522,7 +522,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-pc.dtb \ sun8i-h3-orangepi-pc-plus.dtb \ sun8i-h3-orangepi-plus.dtb \ - sun8i-h3-orangepi-plus2e.dtb + sun8i-h3-orangepi-plus2e.dtb \ + sun8i-h3-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN8I_R40) += \ sun8i-r40-bananapi-m2-ultra.dtb \ sun8i-v40-bananapi-m2-berry.dtb diff --git a/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts b/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts new file mode 100644 index 0000000000..f2f7b7a925 --- /dev/null +++ b/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts @@ -0,0 +1,139 @@ +/* + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * Copyright (C) 2018 Diego Rondini diego.rondini@kynetics.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun8i-h3.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi Zero Plus2 H3"; + compatible = "xunlong,orangepi-zero-plus2-h3", "allwinner,sun8i-h3"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&pio 0 9 GPIO_ACTIVE_LOW>; /* PA9 */ + post-power-on-delay-ms = <200>; + }; +}; + +&de { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_vcc3v3>; + vqmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 7 IRQ_TYPE_LEVEL_LOW>; /* PL7 */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index a2adf89b5d..4a89bb0e7b 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -405,6 +405,11 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/orangepi_zero_plus2_defconfig
On Tue, Nov 19, 2019 at 2:47 PM Diego Rondini diego.rondini@kynetics.com wrote:
- 512MB DDR3
- Debug TTL UART
- HDMI
- Wifi + BT
Changes in v2:
is the commit message ok now?
Diego Rondini
Diego Rondini
Jagan Teki
