[U-Boot] [PATCH] arm926ejs: timer: Replace bss variable by gdr
Reuse the gd->tbl value for timestamp and add gd->lastinc for lastinc bss values in the arm926ejs timers implementation.
The usage of bss values in drivers before initialisation of bss is forbidden. In that special case some data in .rel.dyn gets corrupted.
This patch is similiar to the patch Dirk Behme posted for the armv7/omap-common/timer.c and added suggestions from Reinhard Meyer.
Tested on the arm926ejs mx27 based magnesium board Tested on the arm926ejs kirkwood based suen3 board
Signed-off-by: Heiko Schocher hs@denx.de cc: Albert ARIBAUD albert.aribaud@free.fr cc: Prafulla Wadaskar prafulla@marvell.com cc: Stefano Babic sbabic@denx.de cc: Reinhard Meyer u-boot@emk-elektronik.de
Signed-off-by: Heiko Schocher hs@denx.de --- arch/arm/cpu/arm926ejs/davinci/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/kirkwood/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mb86r0x/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mx25/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mx27/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/omap/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/orion5x/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/spear/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/versatile/timer.c | 6 ++++-- 9 files changed, 36 insertions(+), 18 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/timer.c b/arch/arm/cpu/arm926ejs/davinci/timer.c index 9da7443..d7b1e46 100644 --- a/arch/arm/cpu/arm926ejs/davinci/timer.c +++ b/arch/arm/cpu/arm926ejs/davinci/timer.c @@ -60,8 +60,10 @@ static struct davinci_timer * const timer = #define TIMER_LOAD_VAL (CONFIG_SYS_HZ_CLOCK / CONFIG_SYS_HZ) #define TIM_CLK_DIV 16
-static ulong timestamp; -static ulong lastinc; +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastinc gd->lastinc
int timer_init(void) { diff --git a/arch/arm/cpu/arm926ejs/kirkwood/timer.c b/arch/arm/cpu/arm926ejs/kirkwood/timer.c index 2ec6a93..3e80329 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/timer.c +++ b/arch/arm/cpu/arm926ejs/kirkwood/timer.c @@ -83,8 +83,10 @@ struct kwtmr_registers *kwtmr_regs = (struct kwtmr_registers *)KW_TIMER_BASE; #define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ (CONFIG_SYS_TCLK / 1000))
-static ulong timestamp; -static ulong lastdec; +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastdec gd->lastinc
void reset_timer_masked(void) { diff --git a/arch/arm/cpu/arm926ejs/mb86r0x/timer.c b/arch/arm/cpu/arm926ejs/mb86r0x/timer.c index 9175b71..6966b0d 100644 --- a/arch/arm/cpu/arm926ejs/mb86r0x/timer.c +++ b/arch/arm/cpu/arm926ejs/mb86r0x/timer.c @@ -33,8 +33,10 @@ #define TIMER_LOAD_VAL 0xffffffff #define TIMER_FREQ (CONFIG_MB86R0x_IOCLK / 256)
-static unsigned long long timestamp; -static ulong lastdec; +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastdec gd->lastinc
static inline unsigned long long tick_to_time(unsigned long long tick) { diff --git a/arch/arm/cpu/arm926ejs/mx25/timer.c b/arch/arm/cpu/arm926ejs/mx25/timer.c index 11d41a8..14f0c2d 100644 --- a/arch/arm/cpu/arm926ejs/mx25/timer.c +++ b/arch/arm/cpu/arm926ejs/mx25/timer.c @@ -41,8 +41,10 @@ #include <asm/io.h> #include <asm/arch/imx-regs.h>
/* * "time" is measured in 1 / CONFIG_SYS_HZ seconds, diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 8f1d47b..5c1cf01 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -43,8 +43,10 @@ #define GPTCR_CLKSOURCE_32 (4 << 1) /* Clock source */ #define GPTCR_TEN 1 /* Timer enable */
/* * "time" is measured in 1 / CONFIG_SYS_HZ seconds, diff --git a/arch/arm/cpu/arm926ejs/omap/timer.c b/arch/arm/cpu/arm926ejs/omap/timer.c index 7d4b6e6..88a0ee6 100644 --- a/arch/arm/cpu/arm926ejs/omap/timer.c +++ b/arch/arm/cpu/arm926ejs/omap/timer.c @@ -42,8 +42,10 @@ /* macro to read the 32 bit timer */ #define READ_TIMER (*(volatile ulong *)(CONFIG_SYS_TIMERBASE+8))
int timer_init (void) { diff --git a/arch/arm/cpu/arm926ejs/orion5x/timer.c b/arch/arm/cpu/arm926ejs/orion5x/timer.c index 089ef47..bbab226 100644 --- a/arch/arm/cpu/arm926ejs/orion5x/timer.c +++ b/arch/arm/cpu/arm926ejs/orion5x/timer.c @@ -90,8 +90,10 @@ static inline ulong read_timer(void) / (CONFIG_SYS_TCLK / 1000); }
void reset_timer_masked(void) { diff --git a/arch/arm/cpu/arm926ejs/spear/timer.c b/arch/arm/cpu/arm926ejs/spear/timer.c index 06858b4..66cf4de 100644 --- a/arch/arm/cpu/arm926ejs/spear/timer.c +++ b/arch/arm/cpu/arm926ejs/spear/timer.c @@ -36,8 +36,10 @@ static struct gpt_regs *const gpt_regs_p = static struct misc_regs *const misc_regs_p = (struct misc_regs *)CONFIG_SPEAR_MISCBASE;
int timer_init(void) { diff --git a/arch/arm/cpu/arm926ejs/versatile/timer.c b/arch/arm/cpu/arm926ejs/versatile/timer.c index 81d6749..2e243b1 100644 --- a/arch/arm/cpu/arm926ejs/versatile/timer.c +++ b/arch/arm/cpu/arm926ejs/versatile/timer.c @@ -42,8 +42,10 @@ /* macro to read the 32 bit timer */ #define READ_TIMER (*(volatile ulong *)(CONFIG_SYS_TIMERBASE+4))
#define TIMER_ENABLE (1 << 7) #define TIMER_MODE_MSK (1 << 6)
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Friday, December 10, 2010 3:03 PM To: u-boot@lists.denx.de Cc: Heiko Schocher; Albert ARIBAUD; Prafulla Wadaskar; Stefano Babic; Reinhard Meyer Subject: [PATCH] arm926ejs: timer: Replace bss variable by gdr
Acked-by: Prafulla Wadaskar prafulla@marvell.com
Regards.. Prafulla . .
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Signed-off-by: Heiko Schocherhs@denx.de cc: Albert ARIBAUDalbert.aribaud@free.fr cc: Prafulla Wadaskarprafulla@marvell.com cc: Stefano Babicsbabic@denx.de cc: Reinhard Meyeru-boot@emk-elektronik.de
static inline unsigned long long tick_to_time(unsigned long long tick) { diff --git a/arch/arm/cpu/arm926ejs/mx25/timer.c b/arch/arm/cpu/arm926ejs/mx25/timer.c index 11d41a8..14f0c2d 100644 --- a/arch/arm/cpu/arm926ejs/mx25/timer.c +++ b/arch/arm/cpu/arm926ejs/mx25/timer.c @@ -41,8 +41,10 @@ #include<asm/io.h> #include<asm/arch/imx-regs.h>
- "time" is measured in 1 / CONFIG_SYS_HZ seconds,
diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 8f1d47b..5c1cf01 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -43,8 +43,10 @@ #define GPTCR_CLKSOURCE_32 (4<< 1) /* Clock source */ #define GPTCR_TEN 1 /* Timer enable */
#define TIMER_ENABLE (1<< 7) #define TIMER_MODE_MSK (1<< 6)
Applied to u-boot-arm, with a trivial merge for davinci.
Amicalement,
/* * "time" is measured in 1 / CONFIG_SYS_HZ seconds, diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 8f1d47b..5c1cf01 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -43,8 +43,10 @@ #define GPTCR_CLKSOURCE_32 (4<< 1) /* Clock source */ #define GPTCR_TEN 1 /* Timer enable */
Correction -- can't apply it *and* retain correct authorship in commit. Heiko, can you post a rebased version?
Amicalement,
Hello Albert,
Ok, I rebase this patch against current mainline, and send a new version.
bye, Heiko
Signed-off-by: Heiko Schocher hs@denx.de cc: Albert ARIBAUD albert.aribaud@free.fr cc: Prafulla Wadaskar prafulla@marvell.com cc: Stefano Babic sbabic@denx.de cc: Reinhard Meyer u-boot@emk-elektronik.de --- - changes since v1: rebased and fixed an trivial merge issue in arch/arm/cpu/arm926ejs/davinci/timer.c
arch/arm/cpu/arm926ejs/davinci/timer.c | 4 ++++ arch/arm/cpu/arm926ejs/kirkwood/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mb86r0x/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mx25/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mx27/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/omap/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/orion5x/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/spear/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/versatile/timer.c | 6 ++++-- 9 files changed, 36 insertions(+), 16 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/timer.c b/arch/arm/cpu/arm926ejs/davinci/timer.c index 1c6fa4a..9fff95e 100644 --- a/arch/arm/cpu/arm926ejs/davinci/timer.c +++ b/arch/arm/cpu/arm926ejs/davinci/timer.c @@ -62,6 +62,10 @@ static struct davinci_timer * const timer = #define TIMER_LOAD_VAL 0xffffffff
#define TIM_CLK_DIV 16 +DECLARE_GLOBAL_DATA_PTR; + +#define timestamp gd->tbl +#define lastinc gd->lastinc
--- - changes since v1: rebased and fixed an trivial merge issue in arch/arm/cpu/arm926ejs/davinci/timer.c - changes since v2: removed changes in arch/arm/cpu/arm926ejs/davinci/timer.c complete, as this is fixed in the meantime
arch/arm/cpu/arm926ejs/kirkwood/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mb86r0x/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mx25/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/mx27/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/omap/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/orion5x/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/spear/timer.c | 6 ++++-- arch/arm/cpu/arm926ejs/versatile/timer.c | 6 ++++-- 8 files changed, 32 insertions(+), 16 deletions(-)
Hi Heiko,
Applied to u-boot-arm, thanks.
Amicalement,
Hello,
Am 21.01.2011 09:56, schrieb Heiko Schocher:
I'm the only one who doesn't like such defines? They might be handy for quick fixes, but in regard to style and readablity I don't like them. When looking at teh code where they will used, you won't see the actual place where they are stored. And in more complex expression they might become dangerous to use because they hide the operator "->".
Regards,
Alexander
Le 22/01/2011 06:39, Alexander Holler a écrit :
Hello,
I accept the patch because it un-breaks support for ARM cpus, and I prefer a working fix to a perfect fix in this specific, transitional, situation.
However a general rework of ARM timer code is in order so that all SoCs and CPUs share the same set of gd variables with the same names and the same logic; and when we get that, this code shall move along.
About this rework, as the saying goes... "Patches Welcome ©". :)
Regards,
Alexander
Amicalement,
Dear Albert ARIBAUD,
There were several suggestions about that in the past (including from me) that involve rework everywhere HZ related timeouts are used. I still prefer a method as follows (because it does not need repeated mul/div calculations nor necessarily 64 bit arithmetic):
u32 timeout = timeout_init(100); /* 100ms timeout */
do {...} while (!timed_out(timeout));
Internally it would be like:
timeout_init(x): return fast_tick + (x * fast_tick_rate) / CONFIG_SYS_HZ; /* this might need 64 bit precision in some implementations */
time_out(x): return ((i32)(x - fast_tick)) < 0;
If the tick were really high speed (and then 64 bits), fast_tick could be derived by shifting the tick some bits to the right.
But, as long as we cannot agree on something, there will be no time spent to make patches...
Best Regards, Reinhard
Am 22.01.2011 08:46, schrieb Albert ARIBAUD:
Hello,
My experience is that such quick fixes (or workarounds) usually manifests (because they become forgotten) and later on might even be copied to other places. ;)
Anyway, I'll have to thank for that patch, because it fixes at least one of the problems I have while trying to chainload a 2010.12 from a 2010.12 on a kirkwood system.
Regards, and again, thanks for the patch, even if I found it ugly,
Alexander
Hello Alexander,
Hello,
As this is a open source project, feel free to work with us, that this get not forgotten!
Yes, it is not the best solution, but it fixes a bug. The patch is some days old (and made as a quick fix), and I vote also to make a better approach for timers on arm, but in the time this patch was pending none did a better (accepted) approach...
As I said above, feel free to post a patch with a better approach.
bye, Heiko
participants (6)
Albert ARIBAUD
Alexander Holler
Heiko Schocher
Prafulla Wadaskar
Reinhard Meyer
Stefano Babic
