[U-Boot] [PATCH] mmc: Tinification of the mmc code
Add new configuration option CONFIG_MMC_TINY which strips away all memory allocation within the MMC code and code for handling multiple cards. This allows extremely space-constrained SPL code use the MMC framework.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org --- common/spl/spl_mmc.c | 4 ++++ drivers/mmc/Makefile | 2 ++ drivers/mmc/mmc.c | 59 +++++++++++++++++++++++++++++++++++++++++++++++++++- include/mmc.h | 1 + 4 files changed, 65 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index ae42221..51f0f24 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -300,7 +300,11 @@ int spl_mmc_load_image(u32 boot_device) if (part == 7) part = 0;
+#ifdef CONFIG_MMC_TINY + err = mmc_switch_part(mmc, part); +#else err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); +#endif if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("spl: mmc partition switch failed\n"); diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3da4817..4d986cb 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -10,8 +10,10 @@ obj-$(CONFIG_GENERIC_MMC) += mmc-uclass.o endif
ifndef CONFIG_BLK +ifndef CONFIG_MMC_TINY obj-$(CONFIG_GENERIC_MMC) += mmc_legacy.o endif +endif
obj-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o obj-$(CONFIG_ATMEL_SDHCI) += atmel_sdhci.o diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index d687345..1f240ed 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -21,6 +21,29 @@ #include <div64.h> #include "mmc_private.h"
+#if defined(CONFIG_MMC_TINY) +static struct mmc mmc_static; +struct mmc *find_mmc_device(int dev_num) +{ + return &mmc_static; +} + +void mmc_do_preinit(void) +{ + struct mmc *m = &mmc_static; +#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT + mmc_set_preinit(m, 1); +#endif + if (m->preinit) + mmc_start_init(m); +} + +struct blk_desc *mmc_get_blk_desc(struct mmc *mmc) +{ + return &mmc->block_dev; +} +#endif + __weak int board_mmc_getwp(struct mmc *mmc) { return -1; @@ -238,7 +261,11 @@ static ulong mmc_bread(struct blk_desc *block_dev, lbaint_t start, if (!mmc) return 0;
+#ifdef CONFIG_MMC_TINY + err = mmc_switch_part(mmc, block_dev->hwpart); +#else err = blk_dselect_hwpart(block_dev, block_dev->hwpart); +#endif if (err < 0) return 0;
@@ -568,7 +595,7 @@ static int mmc_set_capacity(struct mmc *mmc, int part_num) return 0; }
-static int mmc_switch_part(struct mmc *mmc, unsigned int part_num) +int mmc_switch_part(struct mmc *mmc, unsigned int part_num) { int ret;
@@ -1585,6 +1612,34 @@ int mmc_unbind(struct udevice *dev) return 0; }
+#elif defined(CONFIG_MMC_TINY) +static struct mmc mmc_static = { + .dsr_imp = 0, + .dsr = 0xffffffff, + .block_dev = { + .if_type = IF_TYPE_MMC, + .removable = 1, + .devnum = 0, + .block_read = mmc_bread, + .block_write = mmc_bwrite, + .block_erase = mmc_berase, + .part_type = 0, + }, +}; + +struct mmc *mmc_create(const struct mmc_config *cfg, void *priv) +{ + struct mmc *mmc = &mmc_static; + + mmc->cfg = cfg; + mmc->priv = priv; + + return mmc; +} + +void mmc_destroy(struct mmc *mmc) +{ +} #else struct mmc *mmc_create(const struct mmc_config *cfg, void *priv) { @@ -1834,8 +1889,10 @@ int mmc_initialize(bd_t *bis) initialized = 1;
#ifndef CONFIG_BLK +#ifndef CONFIG_MMC_TINY mmc_list_init(); #endif +#endif ret = mmc_probe(bis); if (ret) return ret; diff --git a/include/mmc.h b/include/mmc.h index a5c6573..08a59c2 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -444,6 +444,7 @@ struct mmc *find_mmc_device(int dev_num); int mmc_set_dev(int dev_num); void print_mmc_devices(char separator); int get_mmc_num(void); +int mmc_switch_part(struct mmc *mmc, unsigned int part_num); int mmc_hwpart_config(struct mmc *mmc, const struct mmc_hwpart_conf *conf, enum mmc_hwpart_conf_mode mode); int mmc_getcd(struct mmc *mmc);
Hi Marek,
Can CONFIG_MMC_TINY be a Kconfig? Also I suggest CONFIG_SPL_MMC_TINY.
if (CONFIG_IS_ENABLED(MMC_TINY))
to avoid #ifdef
return &mmc_static;
if (m->preinit)
mmc_start_init(m);
+} +#endif
.dsr_imp = 0,
.dsr = 0xffffffff,
.block_dev = {
.removable = 1,
.devnum = 0,
.part_type = 0,
mmc->cfg = cfg;
mmc->priv = priv;
return mmc;
#ifndef CONFIG_BLK +#ifndef CONFIG_MMC_TINY mmc_list_init(); #endif +#endif ret = mmc_probe(bis); if (ret) return ret; diff --git a/include/mmc.h b/include/mmc.h index a5c6573..08a59c2 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -444,6 +444,7 @@ struct mmc *find_mmc_device(int dev_num); int mmc_set_dev(int dev_num); void print_mmc_devices(char separator); int get_mmc_num(void); +int mmc_switch_part(struct mmc *mmc, unsigned int part_num); int mmc_hwpart_config(struct mmc *mmc, const struct mmc_hwpart_conf *conf, enum mmc_hwpart_conf_mode mode); int mmc_getcd(struct mmc *mmc); -- 2.7.0
This is partially undoing the legacy block device work. How much does this patch save?
On 06/10/2016 02:34 AM, Simon Glass wrote:
Hi Marek,
Hi!
It can, but how do I assure it's enabled only for SPL build ?
to avoid #ifdef
The compiler complains about missing symbols blk_dselect_hwpart() and such, so I will opt for the ifdef .
return &mmc_static;
if (m->preinit)
mmc_start_init(m);
+} +#endif
.dsr_imp = 0,
.dsr = 0xffffffff,
.block_dev = {
.removable = 1,
.devnum = 0,
.part_type = 0,
mmc->cfg = cfg;
mmc->priv = priv;
return mmc;
It does save enough to make my SPL fit on my device, which is a few kiB. I didn't measure it precisely because the block stuff starts requiring malloc support (which my SPL does not have) and pulls in more and more code which blows the SPL size.
Hi Marek,
Hi Marek,
Hi!
depends on SPL
and in the code:
#if CONFIG_IS_ENABLED(MMC_TINY)
will do it.
to avoid #ifdef
That's odd. It should not care about things which are not compiled in.
return &mmc_static;
if (m->preinit)
mmc_start_init(m);
+} +#endif
.dsr_imp = 0,
.dsr = 0xffffffff,
.block_dev = {
.removable = 1,
.devnum = 0,
.part_type = 0,
mmc->cfg = cfg;
mmc->priv = priv;
return mmc;
The legacy block support should not require malloc().
Can you give me instructions on how to try all this (perhaps point me to a tree?). I'd like to dig into it a little.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org --- V2: Switch the MMC_TINY option to Kconfig --- common/spl/spl_mmc.c | 6 +++++- drivers/mmc/Kconfig | 16 ++++++++++++++ drivers/mmc/Makefile | 6 ++++++ drivers/mmc/mmc.c | 61 ++++++++++++++++++++++++++++++++++++++++++++++++++-- include/mmc.h | 1 + 5 files changed, 87 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index dcfd842..6508b3e 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -300,7 +300,11 @@ int spl_mmc_load_image(u32 boot_device) if (part == 7) part = 0;
- err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); + if (CONFIG_IS_ENABLED(MMC_TINY)) + err = mmc_switch_part(mmc, part); + else + err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); + if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("spl: mmc partition switch failed\n"); diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index c80efc3..365057b 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -16,6 +16,22 @@ config DM_MMC appear as block devices in U-Boot and can support filesystems such as EXT4 and FAT.
+config SPL_MMC_TINY + bool "Tiny MMC framework in SPL" + default n + help + Enable MMC framework tinification support. This option is useful if + if your SPL is extremely size constrained. Heed the warning, enable + this option if and only if you know exactly what you are doing, if + you are reading this help text, you most likely have no idea :-) + + The MMC framework is reduced to bare minimum to be useful. No malloc + support is needed for the MMC framework operation with this option + enabled. The framework supports exactly one MMC device and exactly + one MMC driver. The MMC driver can be adjusted to avoid any malloc + operations too, which can remove the need for malloc support in SPL + and thus further reduce footprint. + config MSM_SDHCI bool "Qualcomm SDHCI controller" depends on DM_MMC diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3da4817..89578d2 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -10,8 +10,14 @@ obj-$(CONFIG_GENERIC_MMC) += mmc-uclass.o endif
ifndef CONFIG_BLK +ifdef CONFIG_SPL_BUILD +ifndef CONFIG_SPL_MMC_TINY obj-$(CONFIG_GENERIC_MMC) += mmc_legacy.o endif +else +obj-$(CONFIG_GENERIC_MMC) += mmc_legacy.o +endif +endif
obj-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o obj-$(CONFIG_ATMEL_SDHCI) += atmel_sdhci.o diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index a4a2161..4875f45 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -21,6 +21,29 @@ #include <div64.h> #include "mmc_private.h"
+#if CONFIG_IS_ENABLED(MMC_TINY) +static struct mmc mmc_static; +struct mmc *find_mmc_device(int dev_num) +{ + return &mmc_static; +} + +void mmc_do_preinit(void) +{ + struct mmc *m = &mmc_static; +#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT + mmc_set_preinit(m, 1); +#endif + if (m->preinit) + mmc_start_init(m); +} + +struct blk_desc *mmc_get_blk_desc(struct mmc *mmc) +{ + return &mmc->block_dev; +} +#endif + __weak int board_mmc_getwp(struct mmc *mmc) { return -1; @@ -238,7 +261,11 @@ static ulong mmc_bread(struct blk_desc *block_dev, lbaint_t start, if (!mmc) return 0;
- err = blk_dselect_hwpart(block_dev, block_dev->hwpart); + if (CONFIG_IS_ENABLED(MMC_TINY)) + err = mmc_switch_part(mmc, block_dev->hwpart); + else + err = blk_dselect_hwpart(block_dev, block_dev->hwpart); + if (err < 0) return 0;
@@ -1576,6 +1603,34 @@ int mmc_unbind(struct udevice *dev) return 0; }
+#elif CONFIG_IS_ENABLED(MMC_TINY) +static struct mmc mmc_static = { + .dsr_imp = 0, + .dsr = 0xffffffff, + .block_dev = { + .if_type = IF_TYPE_MMC, + .removable = 1, + .devnum = 0, + .block_read = mmc_bread, + .block_write = mmc_bwrite, + .block_erase = mmc_berase, + .part_type = 0, + }, +}; + +struct mmc *mmc_create(const struct mmc_config *cfg, void *priv) +{ + struct mmc *mmc = &mmc_static; + + mmc->cfg = cfg; + mmc->priv = priv; + + return mmc; +} + +void mmc_destroy(struct mmc *mmc) +{ +} #else struct mmc *mmc_create(const struct mmc_config *cfg, void *priv) { @@ -1825,8 +1880,10 @@ int mmc_initialize(bd_t *bis) initialized = 1;
#ifndef CONFIG_BLK +#if !CONFIG_IS_ENABLED(MMC_TINY) mmc_list_init(); #endif +#endif ret = mmc_probe(bis); if (ret) return ret; diff --git a/include/mmc.h b/include/mmc.h index 7fdfc32..3f6f9d2 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -443,6 +443,7 @@ struct mmc *find_mmc_device(int dev_num); int mmc_set_dev(int dev_num); void print_mmc_devices(char separator); int get_mmc_num(void); +int mmc_switch_part(struct mmc *mmc, unsigned int part_num); int mmc_hwpart_config(struct mmc *mmc, const struct mmc_hwpart_conf *conf, enum mmc_hwpart_conf_mode mode); int mmc_getcd(struct mmc *mmc);
Hi Marek,
What's the status of these patches? Can they run with DM and CONFIG_BLK?
On 10/28/2016 01:31 AM, Simon Glass wrote:
Hi Marek,
Probably broken due to the changes in the MMC subsys. I have a rebased version, but I didn't test it on the hardware itself. If you want to test them, I can send you the patch(es).
H iMarek,
Hi Marek,
Yes I can do that - can you push them to a tree somewhere?
On 10/28/2016 03:36 AM, Simon Glass wrote:
H iMarek,
Hi Marek,
I forwarded you the tarball.
On 06/10/2016 03:16 AM, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi!
depends on SPL
and in the code:
will do it.
Ah right, thanks.
to avoid #ifdef
Must've been some oddity indeed.
return &mmc_static;
if (m->preinit)
mmc_start_init(m);
+} +#endif
.dsr_imp = 0,
.dsr = 0xffffffff,
.block_dev = {
.removable = 1,
.devnum = 0,
.part_type = 0,
mmc->cfg = cfg;
mmc->priv = priv;
return mmc;
But it does require convoluted list handling, which takes a lot of space.
Sent off-list.
