[u-boot][PATCH] board: at91: sama5d29_curiosity: add initial support for sama5d29_curiosity
Add initial support for sama5d29_curiosity board.
Hardware: SoC: SAMA5D29 500 MHz DRAM: LPDDR2 512 MiB PMIC: MCP16502 Debug: UART0 Flash: QSPI NOR 8 MiB RGB LCD connector Mikrobus connectors x 2 SD-Card connectors x 2 USB 2.0 x 2
Signed-off-by: Mihai Sain mihai.sain@microchip.com --- arch/arm/dts/Makefile | 3 + .../dts/at91-sama5d29_curiosity-u-boot.dtsi | 55 +++++ arch/arm/dts/at91-sama5d29_curiosity.dts | 219 ++++++++++++++++++ arch/arm/mach-at91/Kconfig | 12 + board/atmel/sama5d29_curiosity/Kconfig | 15 ++ board/atmel/sama5d29_curiosity/MAINTAINERS | 8 + board/atmel/sama5d29_curiosity/Makefile | 7 + .../sama5d29_curiosity/sama5d29_curiosity.c | 86 +++++++ configs/sama5d29_curiosity_mmc1_defconfig | 122 ++++++++++ configs/sama5d29_curiosity_mmc_defconfig | 121 ++++++++++ .../sama5d29_curiosity_qspiflash_defconfig | 121 ++++++++++ include/configs/sama5d29_curiosity.h | 20 ++ 12 files changed, 789 insertions(+) create mode 100644 arch/arm/dts/at91-sama5d29_curiosity-u-boot.dtsi create mode 100644 arch/arm/dts/at91-sama5d29_curiosity.dts create mode 100644 board/atmel/sama5d29_curiosity/Kconfig create mode 100644 board/atmel/sama5d29_curiosity/MAINTAINERS create mode 100644 board/atmel/sama5d29_curiosity/Makefile create mode 100644 board/atmel/sama5d29_curiosity/sama5d29_curiosity.c create mode 100644 configs/sama5d29_curiosity_mmc1_defconfig create mode 100644 configs/sama5d29_curiosity_mmc_defconfig create mode 100644 configs/sama5d29_curiosity_qspiflash_defconfig create mode 100644 include/configs/sama5d29_curiosity.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 07b26df275..bf0dc876d4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1169,6 +1169,9 @@ dtb-$(CONFIG_TARGET_SAMA5D27_WLSOM1_EK) += \ dtb-$(CONFIG_TARGET_SAMA5D2_ICP) += \ at91-sama5d2_icp.dtb
+dtb-$(CONFIG_TARGET_SAMA5D29_CURIOSITY) += \ + at91-sama5d29_curiosity.dtb + dtb-$(CONFIG_TARGET_SAMA5D3XEK) += \ sama5d31ek.dtb \ sama5d33ek.dtb \ diff --git a/arch/arm/dts/at91-sama5d29_curiosity-u-boot.dtsi b/arch/arm/dts/at91-sama5d29_curiosity-u-boot.dtsi new file mode 100644 index 0000000000..798761c98a --- /dev/null +++ b/arch/arm/dts/at91-sama5d29_curiosity-u-boot.dtsi @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * at91-sama5d29_curiosity-u-boot.dtsi - Device Tree file for SAMA5D2 SoC u-boot properties. + * + * Copyright (c) 2023, Microchip Technology Inc. and its subsidiaries + * + * Author: Mihai Sain mihai.sain@microchip.com + * + */ + +/ { + chosen { + bootph-all; + }; +}; + +&pinctrl_qspi1_default { + bootph-all; +}; + +&pinctrl_sdmmc0_default { + bootph-all; +}; + +&pinctrl_sdmmc1_default { + bootph-all; +}; + +&hlcdc { + bootph-all; +}; + +&pioA { + bootph-all; +}; + +&qspi1 { + bootph-all; + + flash@0 { + bootph-all; + }; +}; + +&sdmmc0 { + bootph-all; +}; + +&sdmmc1 { + bootph-all; +}; + +&uart0 { + bootph-all; +}; diff --git a/arch/arm/dts/at91-sama5d29_curiosity.dts b/arch/arm/dts/at91-sama5d29_curiosity.dts new file mode 100644 index 0000000000..eff0e9175a --- /dev/null +++ b/arch/arm/dts/at91-sama5d29_curiosity.dts @@ -0,0 +1,219 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * at91-sama5d29_curiosity.dts - Device Tree file for SAMA5D29 CURIOSITY board + * + * Copyright (C) 2023 Microchip Technology Inc. and its subsidiaries + * + * Author: Mihai Sain mihai.sain@microchip.com + * + */ +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/at91.h> +#include "sama5d2.dtsi" +#include "sama5d2-pinfunc.h" + +/ { + model = "Microchip SAMA5D29-Curiosity"; + compatible = "atmel,sama5d29-curiosity", "atmel,sama5d2", "atmel,sama5"; + + chosen { + bootargs = "console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait"; + stdout-path = &uart0; + }; + + memory { + reg = <0x20000000 0x20000000>; // 512 MiB LPDDR2-333 + }; + + clocks { + slow_xtal: slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal: main_xtal { + clock-frequency = <24000000>; + }; + }; + + onewire_tm: onewire { + gpios = <&pioA PIN_PC9 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_onewire_tm_default>; + status = "okay"; + + w1_eeprom: w1_eeprom@0 { + compatible = "maxim,ds24b33"; + status = "okay"; + }; + }; + + ahb { + usb1: ohci@400000 { + num-ports = <3>; + atmel,vbus-gpio = <&pioA PIN_PB13 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_default>; + status = "okay"; + }; + + usb2: ehci@500000 { + status = "okay"; + }; + + sdmmc0: sdio-host@a0000000 { + bus-width = <4>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdmmc0_default>; + status = "okay"; + }; + + sdmmc1: sdio-host@b0000000 { + bus-width = <4>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdmmc1_default>; + status = "okay"; + }; + + apb { + hlcdc: hlcdc@f0000000 { + atmel,vl-bpix = <4>; + atmel,output-mode = <24>; + atmel,guard-time = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd_base &pinctrl_lcd_pwm &pinctrl_lcd_rgb666>; + status = "okay"; + + display-timings { // PDA TM5000 + 800x480 { + clock-frequency = <33000000>; + xres = <800>; + yres = <480>; + hactive = <800>; + vactive = <480>; + hsync-len = <64>; + hfront-porch = <1>; + hback-porch = <64>; + vfront-porch = <1>; + vback-porch = <22>; + vsync-len = <23>; + }; + }; + }; + + qspi1: spi@f0024000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi1_default>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <80000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; + m25p,fast-read; + }; + }; + + uart0: serial@f801c000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0_default>; + status = "okay"; + }; + + pioA: pinctrl@fc038000 { + pinctrl_lcd_base: lcd_base { + pinmux = <PIN_PC30__LCDVSYNC>, + <PIN_PC31__LCDHSYNC>, + <PIN_PD1__LCDDEN>, + <PIN_PD0__LCDPCK>; + bias-disable; + }; + + pinctrl_lcd_pwm: lcd_pwm { + pinmux = <PIN_PC28__LCDPWM>; + bias-disable; + }; + + pinctrl_lcd_rgb666: lcd_rgb666 { + pinmux = <PIN_PC10__LCDDAT2>, + <PIN_PC11__LCDDAT3>, + <PIN_PC12__LCDDAT4>, + <PIN_PC13__LCDDAT5>, + <PIN_PC14__LCDDAT6>, + <PIN_PC15__LCDDAT7>, + <PIN_PC16__LCDDAT10>, + <PIN_PC17__LCDDAT11>, + <PIN_PC18__LCDDAT12>, + <PIN_PC19__LCDDAT13>, + <PIN_PC20__LCDDAT14>, + <PIN_PC21__LCDDAT15>, + <PIN_PC22__LCDDAT18>, + <PIN_PC23__LCDDAT19>, + <PIN_PC24__LCDDAT20>, + <PIN_PC25__LCDDAT21>, + <PIN_PC26__LCDDAT22>, + <PIN_PC27__LCDDAT23>; + bias-disable; + }; + + pinctrl_qspi1_default: qspi1_default { + pinmux = <PIN_PB5__QSPI1_SCK>, + <PIN_PB6__QSPI1_CS>, + <PIN_PB7__QSPI1_IO0>, + <PIN_PB8__QSPI1_IO1>, + <PIN_PB9__QSPI1_IO2>, + <PIN_PB10__QSPI1_IO3>; + bias-pull-up; + }; + + pinctrl_sdmmc0_default: sdmmc0_default { + pinmux = <PIN_PA0__SDMMC0_CK>, + <PIN_PA1__SDMMC0_CMD>, + <PIN_PA2__SDMMC0_DAT0>, + <PIN_PA3__SDMMC0_DAT1>, + <PIN_PA4__SDMMC0_DAT2>, + <PIN_PA5__SDMMC0_DAT3>, + <PIN_PA11__SDMMC0_VDDSEL>, + <PIN_PA13__SDMMC0_CD>; + bias-disable; + }; + + pinctrl_sdmmc1_default: sdmmc1_default { + pinmux = <PIN_PA18__SDMMC1_DAT0>, + <PIN_PA19__SDMMC1_DAT1>, + <PIN_PA20__SDMMC1_DAT2>, + <PIN_PA21__SDMMC1_DAT3>, + <PIN_PA22__SDMMC1_CK>, + <PIN_PA28__SDMMC1_CMD>, + <PIN_PA30__SDMMC1_CD>; + bias-disable; + }; + + pinctrl_uart0_default: uart0_default { + pinmux = <PIN_PB26__URXD0>, + <PIN_PB27__UTXD0>; + bias-disable; + }; + + pinctrl_usb_default: usb_default { + pinmux = <PIN_PA6__GPIO>; + bias-disable; + }; + + pinctrl_usba_vbus: usba_vbus { + pinmux = <PIN_PB13__GPIO>; + bias-disable; + }; + + pinctrl_onewire_tm_default: onewire_tm_default { + pinmux = <PIN_PC9__GPIO>; + bias-pull-up; + }; + }; + }; + }; +}; diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 7c2e4ebbdb..4c65fc0dbd 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -215,6 +215,17 @@ config TARGET_SAMA5D2_ICP a 64Mbit QSPI flash, 3xMikrobus connectors, 4xUSB , EtherCat and WILC3000 devices on board.
+config TARGET_SAMA5D29_CURIOSITY + bool "SAMA5D29 CURIOSITY board" + select SAMA5D2 + select BOARD_EARLY_INIT_F + select BOARD_LATE_INIT + select CPU_V7A + help + The SAMA5D29 Curiosity embeds SAMA5D29 SoC with 4 Gbit LPDDR2-SDRAM, + a 64Mbit QSPI flash with Mac-address, MCP16502 PMIC, RGB LCD connector, + 2 x Mikrobus connectors, 2 x SD-Card connectors, 2 x USB + config TARGET_SAMA5D3_XPLAINED bool "SAMA5D3 Xplained board" select BOARD_EARLY_INIT_F @@ -346,6 +357,7 @@ source "board/atmel/sama5d2_xplained/Kconfig" source "board/atmel/sama5d27_som1_ek/Kconfig" source "board/atmel/sama5d27_wlsom1_ek/Kconfig" source "board/atmel/sama5d2_icp/Kconfig" +source "board/atmel/sama5d29_curiosity/Kconfig" source "board/atmel/sama5d3_xplained/Kconfig" source "board/atmel/sama5d3xek/Kconfig" source "board/atmel/sama5d4_xplained/Kconfig" diff --git a/board/atmel/sama5d29_curiosity/Kconfig b/board/atmel/sama5d29_curiosity/Kconfig new file mode 100644 index 0000000000..64ca237697 --- /dev/null +++ b/board/atmel/sama5d29_curiosity/Kconfig @@ -0,0 +1,15 @@ +if TARGET_SAMA5D29_CURIOSITY + +config SYS_BOARD + default "sama5d29_curiosity" + +config SYS_VENDOR + default "atmel" + +config SYS_SOC + default "at91" + +config SYS_CONFIG_NAME + default "sama5d29_curiosity" + +endif diff --git a/board/atmel/sama5d29_curiosity/MAINTAINERS b/board/atmel/sama5d29_curiosity/MAINTAINERS new file mode 100644 index 0000000000..110c3d2874 --- /dev/null +++ b/board/atmel/sama5d29_curiosity/MAINTAINERS @@ -0,0 +1,8 @@ +SAMA5D29 CURIOSITY BOARD +M: Mihai Sain mihai.sain@microchip.com +S: Maintained +F: board/atmel/sama5d29_curiosity.c +F: include/configs/sama5d29_curiosity.h +F: configs/sama5d29_curiosity_mmc_defconfig +F: configs/sama5d29_curiosity_mmc1_defconfig +F: configs/sama5d29_curiosity_qspiflash_defconfig diff --git a/board/atmel/sama5d29_curiosity/Makefile b/board/atmel/sama5d29_curiosity/Makefile new file mode 100644 index 0000000000..848e1ce149 --- /dev/null +++ b/board/atmel/sama5d29_curiosity/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2023 Microchip Technology Inc. and its subsidiaries +# +# Author: Mihai Sain mihai.sain@microchip.com + +obj-y += sama5d29_curiosity.o diff --git a/board/atmel/sama5d29_curiosity/sama5d29_curiosity.c b/board/atmel/sama5d29_curiosity/sama5d29_curiosity.c new file mode 100644 index 0000000000..d0679317fb --- /dev/null +++ b/board/atmel/sama5d29_curiosity/sama5d29_curiosity.c @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Microchip Technology Inc. and its subsidiaries + * + * Author: Mihai Sain mihai.sain@microchip.com + * + */ + +#include <common.h> +#include <debug_uart.h> +#include <init.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/atmel_pio4.h> +#include <asm/arch/atmel_sdhci.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/sama5d2.h> + +extern void at91_pda_detect(void); + +DECLARE_GLOBAL_DATA_PTR; + +static void rgb_leds_init(void) +{ + atmel_pio4_set_pio_output(AT91_PIO_PORTA, 7, 0); /* LED RED */ + atmel_pio4_set_pio_output(AT91_PIO_PORTA, 8, 0); /* LED GREEN */ + atmel_pio4_set_pio_output(AT91_PIO_PORTA, 9, 1); /* LED BLUE */ +} + +static void board_usb_hw_init(void) +{ + atmel_pio4_set_pio_output(AT91_PIO_PORTA, 6, 1); +} + +int board_late_init(void) +{ + at91_video_show_board_info(); + + at91_pda_detect(); + + return 0; +} + +static void board_uart0_hw_init(void) +{ + atmel_pio4_set_c_periph(AT91_PIO_PORTB, 26, ATMEL_PIO_PUEN_MASK); /* URXD0 */ + atmel_pio4_set_c_periph(AT91_PIO_PORTB, 27, 0); /* UTXD0 */ + + at91_periph_clk_enable(ATMEL_ID_UART0); +} + +void board_debug_uart_init(void) +{ + board_uart0_hw_init(); +} + +int board_early_init_f(void) +{ + debug_uart_init(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + + rgb_leds_init(); + + board_usb_hw_init(); + + return 0; +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} diff --git a/configs/sama5d29_curiosity_mmc1_defconfig b/configs/sama5d29_curiosity_mmc1_defconfig new file mode 100644 index 0000000000..380b9a64d7 --- /dev/null +++ b/configs/sama5d29_curiosity_mmc1_defconfig @@ -0,0 +1,122 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_AT91=y +CONFIG_TEXT_BASE=0x26f00000 +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_SYS_MALLOC_F_LEN=0x40000 +CONFIG_TARGET_SAMA5D29_CURIOSITY=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20044000 +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d29_curiosity" +CONFIG_SYS_PROMPT="[root@sama5d29 ~]$ " +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_BASE=0xf801c000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_SYS_LOAD_ADDR=0x22000000 +CONFIG_DEBUG_UART=y +CONFIG_SYS_MEMTEST_START=0x20000000 +CONFIG_SYS_MEMTEST_END=0x30000000 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +# CONFIG_BOOTSTD is not set +CONFIG_QSPI_BOOT=y +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk1p2 rw rootwait" +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="fatload mmc 1:1 0x21000000 at91-sama5d29_curiosity.dtb; fatload mmc 1:1 0x22000000 zImage; bootz 0x22000000 - 0x21000000" +CONFIG_BOARD_TYPES=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT_HUSH_PS2="[root@sama5d29 ~]$ " +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_BOOTM_LEN=0x2000000 +CONFIG_CMD_XXD=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEM_SEARCH=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_STRINGS=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_CMD_CAT=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SPREAD=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_MTDIDS_DEFAULT="nor0=nor0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nor0:256k(bootstrap)ro,1M(u-boot)ro,256k(env)ro,512k(dtb)ro,6M(kernel)ro" +CONFIG_OF_CONTROL=y +# CONFIG_OF_TAG_MIGRATE is not set +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_USE_HOSTNAME=y +CONFIG_HOSTNAME="SAMA5D29" +CONFIG_VERSION_VARIABLE=y +# CONFIG_NET is not set +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_ATMEL_PIO4=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_SST=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_RESET_AT91=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_AT91=y +CONFIG_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_CMD_DHRYSTONE=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/sama5d29_curiosity_mmc_defconfig b/configs/sama5d29_curiosity_mmc_defconfig new file mode 100644 index 0000000000..3a81e58d6e --- /dev/null +++ b/configs/sama5d29_curiosity_mmc_defconfig @@ -0,0 +1,121 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_AT91=y +CONFIG_TEXT_BASE=0x26f00000 +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_SYS_MALLOC_F_LEN=0x40000 +CONFIG_TARGET_SAMA5D29_CURIOSITY=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20044000 +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d29_curiosity" +CONFIG_SYS_PROMPT="[root@sama5d29 ~]$ " +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_BASE=0xf801c000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_SYS_LOAD_ADDR=0x22000000 +CONFIG_DEBUG_UART=y +CONFIG_SYS_MEMTEST_START=0x20000000 +CONFIG_SYS_MEMTEST_END=0x30000000 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +# CONFIG_BOOTSTD is not set +CONFIG_QSPI_BOOT=y +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait" +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="fatload mmc 0:1 0x21000000 at91-sama5d29_curiosity.dtb; fatload mmc 0:1 0x22000000 zImage; bootz 0x22000000 - 0x21000000" +CONFIG_BOARD_TYPES=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT_HUSH_PS2="[root@sama5d29 ~]$ " +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_BOOTM_LEN=0x2000000 +CONFIG_CMD_XXD=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEM_SEARCH=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_STRINGS=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_CMD_CAT=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SPREAD=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_MTDIDS_DEFAULT="nor0=nor0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nor0:256k(bootstrap)ro,1M(u-boot)ro,256k(env)ro,512k(dtb)ro,6M(kernel)ro" +CONFIG_OF_CONTROL=y +# CONFIG_OF_TAG_MIGRATE is not set +CONFIG_ENV_IS_IN_FAT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_USE_HOSTNAME=y +CONFIG_HOSTNAME="SAMA5D29" +CONFIG_VERSION_VARIABLE=y +# CONFIG_NET is not set +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_ATMEL_PIO4=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_SST=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_RESET_AT91=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_AT91=y +CONFIG_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_CMD_DHRYSTONE=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/sama5d29_curiosity_qspiflash_defconfig b/configs/sama5d29_curiosity_qspiflash_defconfig new file mode 100644 index 0000000000..a712bfccf3 --- /dev/null +++ b/configs/sama5d29_curiosity_qspiflash_defconfig @@ -0,0 +1,121 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_AT91=y +CONFIG_TEXT_BASE=0x26f00000 +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_SYS_MALLOC_F_LEN=0x40000 +CONFIG_TARGET_SAMA5D29_CURIOSITY=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20044000 +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d29_curiosity" +CONFIG_SYS_PROMPT="[root@sama5d29 ~]$ " +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_BASE=0xf801c000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_SYS_LOAD_ADDR=0x22000000 +CONFIG_DEBUG_UART=y +CONFIG_SYS_MEMTEST_START=0x20000000 +CONFIG_SYS_MEMTEST_END=0x30000000 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +# CONFIG_BOOTSTD is not set +CONFIG_QSPI_BOOT=y +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait" +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="sf probe 0; sf read 0x21000000 0x180000 0x80000; sf read 0x22000000 0x200000 0x600000; bootz 0x22000000 - 0x21000000" +CONFIG_BOARD_TYPES=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT_HUSH_PS2="[root@sama5d29 ~]$ " +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_BOOTM_LEN=0x2000000 +CONFIG_CMD_XXD=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEM_SEARCH=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_STRINGS=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_CMD_CAT=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SPREAD=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_MTDIDS_DEFAULT="nor0=nor0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nor0:256k(bootstrap)ro,1M(u-boot)ro,256k(env)ro,512k(dtb)ro,6M(kernel)ro" +CONFIG_OF_CONTROL=y +# CONFIG_OF_TAG_MIGRATE is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_USE_HOSTNAME=y +CONFIG_HOSTNAME="SAMA5D29" +CONFIG_VERSION_VARIABLE=y +# CONFIG_NET is not set +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_ATMEL_PIO4=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_SST=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_RESET_AT91=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_AT91=y +CONFIG_TIMER=y +CONFIG_ATMEL_TCB_TIMER=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_CMD_DHRYSTONE=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/sama5d29_curiosity.h b/include/configs/sama5d29_curiosity.h new file mode 100644 index 0000000000..a3be919824 --- /dev/null +++ b/include/configs/sama5d29_curiosity.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration file for the SAMA5D29 CURIOSITY board. + * + * Copyright (C) 2023 Microchip Technology Inc. and its subsidiaries + * + * Author: Mihai Sain mihai.sain@microchip.com + * + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CFG_SYS_AT91_SLOW_CLOCK 32768 +#define CFG_SYS_AT91_MAIN_CLOCK 24000000 + +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE 0x20000000 + +#endif
Hello Mihai,
Thank you for the patch.
However, the at91 maintainer tree nowadays has a big problem, I cannot apply patches because the size of the SPL will overflow. There is a pending patch that fixes it, but it has not been tested. Here you can help, and test this integration branch (at least on sama5d2 ICP, but if you can test on multiple boards, it's even better) :
https://source.denx.de/u-boot/custodians/u-boot-at91/-/tree/testing?ref_type...
Once this is tested you can reply with a Tested-by: tag, and we can move along. Without testing the patch that fixes the size restraint (it's the CONFIG_LTO patch), the tree is stalled.
One small nitpick below, and I am looking forward for your reply,
Eugen
Can you remove this. It looks like a Linux prompt and might be confusing for people
(and everywhere below)
Hello Eugen,
Thank you for applying the patch.
For this board we don't want to use SPL. I will send v2 patch to remove the custom prompt. Thanks.
Best regards, Mihai Sain
-----Original Message----- From: Eugen Hristev eugen.hristev@collabora.com Sent: Monday, July 24, 2023 11:13 AM To: Mihai Sain - M19926 Mihai.Sain@microchip.com; u-boot@lists.denx.de Cc: Cristian Birsan - M91496 Cristian.Birsan@microchip.com Subject: Re: [u-boot][PATCH] board: at91: sama5d29_curiosity: add initial support for sama5d29_curiosity
EXTERNAL EMAIL: Do not click links or open attachments unless you know the content is safe
Hello Mihai,
Eugen
On 7/24/23 11:49, Mihai.Sain@microchip.com wrote:
Hello Eugen,
As I said, I won't be applying any patches to at91 tree unless someone helps with the testing below. SPL for this board has nothing to do with my request.
These also have to be removed:
as they are forbidden to set in the config file and appear to be unused anyway.
Eugen
Hello Mihai,
Eugen
Eugen Hristev
Mihai Sain
