Pull request: u-boot-riscv/master 20200825
Hi Tom,
Please pull some riscv updates:
- Sipeed Maix support S-mode. - Provide command sbi. - Use fdtdec_get_addr_size_auto_parent to get fu540 cache base address. - Fix a compiler error with CONFIG_SPL_SMP=n. - Fix sifive ram driver 32 compiler warnings. - Fix kendryte/pll.h redefine nop() warning.
Thanks Rick
https://travis-ci.org/github/rickchen36/u-boot-riscv/builds/720564636
The following changes since commit 1aa3966173fe92fa3c46638ee8eb8b8491f521d6:
Merge tag 'u-boot-clk-24Aug2020' of https://gitlab.denx.de/u-boot/custodians/u-boot-clk (2020-08-24 09:06:02 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to c92b50a44b95e706b9c0c97544bd7504fe6d36e9:
cmd: provide command sbi (2020-08-25 09:34:47 +0800)
---------------------------------------------------------------- Bin Meng (2): riscv: fu540: Use correct API to get L2 cache controller base address ram: sifive: Fix compiler warnings for 32-bit
Heinrich Schuchardt (4): clk: kendryte/pll.h: do not redefine nop() riscv: fix building with CONFIG_SPL_SMP=n configs: defconfig for Sipeed Maix in S-mode cmd: provide command sbi
arch/riscv/cpu/fu540/cache.c | 3 ++- arch/riscv/include/asm/sbi.h | 2 ++ arch/riscv/lib/sbi.c | 36 ++++++++++++++++++++++++++++++++++++ arch/riscv/lib/spl.c | 2 +- board/sipeed/maix/MAINTAINERS | 2 +- cmd/Kconfig | 6 ++++++ cmd/riscv/Makefile | 1 + cmd/riscv/sbi.c | 82 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/sipeed_maix_smode_defconfig | 10 ++++++++++ doc/board/sipeed/maix.rst | 49 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/ram/sifive/fu540_ddr.c | 4 ++-- include/kendryte/pll.h | 5 +++++ 12 files changed, 197 insertions(+), 5 deletions(-) create mode 100644 cmd/riscv/sbi.c create mode 100644 configs/sipeed_maix_smode_defconfig
On Tue, Aug 25, 2020 at 10:31:04AM +0800, uboot@andestech.com wrote:
Hi Tom,
Thanks Rick
uboot@andestech.com
