[U-Boot] [PATCH 1/2] travis: Remove or32 toolchain info
or32 is not supported by U-Boot anymore.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
.travis.yml | 1 - 1 file changed, 1 deletion(-)
diff --git a/.travis.yml b/.travis.yml index 2b759c9..c0154da 100644 --- a/.travis.yml +++ b/.travis.yml @@ -66,7 +66,6 @@ before_script: - if [[ "${TOOLCHAIN}" == *m68k* ]]; then ./tools/buildman/buildman --fetch-arch m68k ; fi - if [[ "${TOOLCHAIN}" == *microblaze* ]]; then ./tools/buildman/buildman --fetch-arch microblaze ; fi - if [[ "${TOOLCHAIN}" == *mips* ]]; then ./tools/buildman/buildman --fetch-arch mips ; fi - - if [[ "${TOOLCHAIN}" == *or32* ]]; then ./tools/buildman/buildman --fetch-arch or32 ; fi - if [[ "${TOOLCHAIN}" == *sh* ]]; then ./tools/buildman/buildman --fetch-arch sh2 ; fi - if [[ "${TOOLCHAIN}" == *x86_64* ]]; then ./tools/buildman/buildman --fetch-arch x86_64;
Currently this uses x86_64 version toolchain for x86 build in travis-ci. Change it to i386 version to avoid updating the buildman toolchain path every time when the toolchain version number is changed, eg: from 7.3.0 to 8.1.0.
.travis.yml | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/.travis.yml b/.travis.yml index c0154da..b0b6f29 100644 --- a/.travis.yml +++ b/.travis.yml @@ -67,9 +67,9 @@ before_script: - if [[ "${TOOLCHAIN}" == *microblaze* ]]; then ./tools/buildman/buildman --fetch-arch microblaze ; fi - if [[ "${TOOLCHAIN}" == *mips* ]]; then ./tools/buildman/buildman --fetch-arch mips ; fi - if [[ "${TOOLCHAIN}" == *sh* ]]; then ./tools/buildman/buildman --fetch-arch sh2 ; fi - - if [[ "${TOOLCHAIN}" == *x86_64* ]]; then - ./tools/buildman/buildman --fetch-arch x86_64; - echo -e "\n[toolchain-prefix]\nx86 = ${HOME}/.buildman-toolchains/gcc-7.3.0-nolibc/x86_64-linux/bin/x86_64-linux-" >> ~/.buildman; + - if [[ "${TOOLCHAIN}" == *i386* ]]; then + ./tools/buildman/buildman --fetch-arch i386; + echo -e "\n[toolchain-alias]\nx86 = i386" >> ~/.buildman; fi - if [[ "${TOOLCHAIN}" == arc ]]; then wget https://github.com/foss-for-synopsys-dwc-arc-processors/toolchain/releases/d... && @@ -207,7 +207,7 @@ matrix: - name: "buildman sandbox x86" env: - BUILDMAN="sandbox x86" - TOOLCHAIN="x86_64" + TOOLCHAIN="i386" - name: "buildman kirkwood (excluding openrd)" env: - BUILDMAN="kirkwood -x openrd" @@ -320,19 +320,19 @@ matrix: env: - TEST_PY_BD="sandbox" BUILDMAN="^sandbox$" - TOOLCHAIN="x86_64" + TOOLCHAIN="i386" - name: "test/py sandbox_spl" env: - TEST_PY_BD="sandbox_spl" TEST_PY_TEST_SPEC="test_ofplatdata" BUILDMAN="^sandbox$" - TOOLCHAIN="x86_64" + TOOLCHAIN="i386" TEST_PY_TOOLS="yes" - name: "test/py sandbox_flattree" env: - TEST_PY_BD="sandbox_flattree" BUILDMAN="^sandbox_flattree$" - TOOLCHAIN="x86_64" + TOOLCHAIN="i386" - name: "test/py vexpress_ca15_tc2" env: - TEST_PY_BD="vexpress_ca15_tc2" @@ -405,7 +405,7 @@ matrix: TEST_PY_TEST_SPEC="not sleep" QEMU_TARGET="i386-softmmu" BUILDMAN="^qemu-x86$" - TOOLCHAIN="x86_64" + TOOLCHAIN="i386" BUILD_ROM="yes" - name: "test/py zynq_zc702" env:
I'm surprised this is fine, doesn't it break 64bit x86 targets?
Hi Tom,
No, in fact I have always been using the i386 toolchain to test qemu-x86_64 target on my local machine. U-Boot x86 makefile fragments have been toolchain agnostic for some time.
Regards, Bin
On Tue, Oct 09, 2018 at 09:21:05AM +0800, Bin Meng wrote:
Hi Tom,
Ah, OK, thanks. Yes, this will make upgrades easier too.
Bin Meng
