[PATCH v2 0/2] cmd: Add support for optee hello world ta command
Enable "optee hello" command which increments the value passed. This provides easy test for establishing a session with OP-TEE TA and verify.
It includes following subcommands: optee hello optee hello <value>; value to increment via OP-TEE HELLO WORLD TA.
Changes in v2: - Added command "optee" and subdommand "hello". - Update the man-page in doc/usage/cmd/optee.rst
Venkatesh Yadav Abbarapu (2): cmd: Add support for optee hello world ta command doc: man-page for optee commands
cmd/Kconfig | 8 +++ cmd/Makefile | 1 + cmd/optee_hello_world_ta.c | 104 +++++++++++++++++++++++++++++++++++++ doc/usage/cmd/optee.rst | 75 ++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 5 files changed, 189 insertions(+) create mode 100644 cmd/optee_hello_world_ta.c create mode 100644 doc/usage/cmd/optee.rst
To enable the OP-TEE side HELLO WORLD example please refer https://optee.readthedocs.io/en/latest/building/gits/optee_examples/optee_ex...
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- cmd/Kconfig | 8 +++ cmd/Makefile | 1 + cmd/optee_hello_world_ta.c | 104 +++++++++++++++++++++++++++++++++++++ 3 files changed, 113 insertions(+) create mode 100644 cmd/optee_hello_world_ta.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 1d7ddb4ed36..f1f8d1b9571 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1446,6 +1446,14 @@ config CMD_OPTEE_RPMB in the Replay Protection Memory Block partition in eMMC by using Persistent Objects in OPTEE
+config CMD_OPTEE_HELLO_WORLD + bool "Enable Hello world TA" + depends on OPTEE + default y + help + Enable the hello world ta command to test the OPTEE by passing + a "value" which should increment by OPTEE TA example. + config CMD_MTD bool "mtd" depends on MTD diff --git a/cmd/Makefile b/cmd/Makefile index d1f369deec0..049147a1442 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -118,6 +118,7 @@ obj-$(CONFIG_CMD_PAUSE) += pause.o obj-$(CONFIG_CMD_SLEEP) += sleep.o obj-$(CONFIG_CMD_MMC) += mmc.o obj-$(CONFIG_CMD_OPTEE_RPMB) += optee_rpmb.o +obj-$(CONFIG_CMD_OPTEE_HELLO_WORLD) += optee_hello_world_ta.o obj-$(CONFIG_CMD_MP) += mp.o obj-$(CONFIG_CMD_MTD) += mtd.o obj-$(CONFIG_CMD_MTDPARTS) += mtdparts.o diff --git a/cmd/optee_hello_world_ta.c b/cmd/optee_hello_world_ta.c new file mode 100644 index 00000000000..7c398bcad2c --- /dev/null +++ b/cmd/optee_hello_world_ta.c @@ -0,0 +1,104 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2024, Advanced Micro Devices, Inc. + */ +#include <command.h> +#include <errno.h> +#include <tee.h> +#include <vsprintf.h> + +static struct udevice *tee; +static u32 session; + +#define TA_HELLO_WORLD_CMD_INC_VALUE 0 +/* This needs to match the UUID of the Hello World TA. */ +#define TA_HELLO_WORLD_UUID \ + { 0x8aaaf200, 0x2450, 0x11e4, \ + { 0xab, 0xe2, 0x00, 0x02, 0xa5, 0xd5, 0xc5, 0x1b} } + +static int hello_world_ta_open_session(void) +{ + const struct tee_optee_ta_uuid uuid = TA_HELLO_WORLD_UUID; + struct tee_open_session_arg arg; + int rc; + + tee = tee_find_device(tee, NULL, NULL, NULL); + if (!tee) + return -ENODEV; + + memset(&arg, 0, sizeof(arg)); + tee_optee_ta_uuid_to_octets(arg.uuid, &uuid); + rc = tee_open_session(tee, &arg, 0, NULL); + if (rc != 0) + session = arg.session; + + return 0; +} + +static int hello_world_ta(unsigned int value) +{ + struct tee_param param[2]; + struct tee_invoke_arg arg; + int status = -EACCES; + + printf("The Hello World TA is going to be called\n"); + + status = hello_world_ta_open_session(); + if (status) { + printf("hello_world_ta_open_session failed(%d)", status); + return status; + } + + arg.func = TA_HELLO_WORLD_CMD_INC_VALUE; + arg.session = session; + + param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INOUT; + param[0].u.value.a = value; + + printf("TA value: %d\n", (int)param[0].u.value.a); + + tee_invoke_func(tee, &arg, 1, param); + + printf("TA value: %d\n", (int)param[0].u.value.a); + + tee_invoke_func(tee, &arg, 1, param); + + printf("TA value: %d\n", (int)param[0].u.value.a); + + status = tee_close_session(tee, session); + + return status; +} + +static int do_optee_hello_world_ta(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret; + int value = 0; + + if (argc != cmdtp->maxargs && argv[1] != NULL) { + debug("do_optee_hello_world_ta: incorrect parameters passed\n"); + return CMD_RET_USAGE; + } + + if (argv[1] != NULL) + value = dectoul(argv[1], NULL); + + ret = hello_world_ta(value); + if (ret) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +U_BOOT_LONGHELP(optee, + "- commands can be verified on OP-TEE\n\n" + "optee hello\n" + "optee hello <value>\n" + "\n" + "With:\n" + "\t<value>: integer value\n" + ); + +U_BOOT_CMD_WITH_SUBCMDS(optee, "OP-TEE commands", optee_help_text, + U_BOOT_SUBCMD_MKENT(hello, 2, 1, do_optee_hello_world_ta));
Hi Venkatesh,
Thank you for the patch.
On ven., déc. 13, 2024 at 16:30, Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com wrote:
If CMD_OPTEE_HELLO_WORLD has hello as a subcommand and we plan to add other commands, shouldn't we give this Kconfig symbol a more generic name?
How about CMD_OPTEE or CMD_OPTEE_TEST?
Maybe others have better recommendations for the naming.
- bool "Enable Hello world TA"
- depends on OPTEE
- default y
Are we sure we want this enabled by default for everyone? It seems indeed like a nice debugging tool, but maybe keep it opt-in?
- help
OPTEE -> OP-TEE
Ditto
Similar remark for the file name.
- (C) Copyright 2024, Advanced Micro Devices, Inc.
- { 0x8aaaf200, 0x2450, 0x11e4, \
- { 0xab, 0xe2, 0x00, 0x02, 0xa5, 0xd5, 0xc5, 0x1b} }
- const struct tee_optee_ta_uuid uuid = TA_HELLO_WORLD_UUID;
- struct tee_open_session_arg arg;
- int rc;
- tee = tee_find_device(tee, NULL, NULL, NULL);
- if (!tee)
return -ENODEV;
- memset(&arg, 0, sizeof(arg));
- tee_optee_ta_uuid_to_octets(arg.uuid, &uuid);
- rc = tee_open_session(tee, &arg, 0, NULL);
- if (rc != 0)
- struct tee_param param[2];
- struct tee_invoke_arg arg;
- int status = -EACCES;
- printf("The Hello World TA is going to be called\n");
- status = hello_world_ta_open_session();
- if (status) {
return status;
- arg.func = TA_HELLO_WORLD_CMD_INC_VALUE;
- arg.session = session;
- param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INOUT;
- param[0].u.value.a = value;
- printf("TA value: %d\n", (int)param[0].u.value.a);
- tee_invoke_func(tee, &arg, 1, param);
- status = tee_close_session(tee, session);
- return status;
- int ret;
- int value = 0;
- if (argc != cmdtp->maxargs && argv[1] != NULL) {
- if (argv[1] != NULL)
- ret = hello_world_ta(value);
- if (ret)
- return CMD_RET_SUCCESS;
"optee hello\n"
"\n"
"With:\n"
-- 2.34.1
On 12/13/24 13:48, Mattijs Korpershoek wrote:
Hi Venkatesh,
- depends on OPTEE
- default y
- help
OPTEE -> OP-TEE
Ditto
- config CMD_MTD bool "mtd" depends on MTD
- int rc;
- if (!tee)
return -ENODEV;
- if (rc != 0)
return rc?
- if (status) {
return status;
Any reason to call it twice? And 3 the same messages will be hard to parse via test. I would also convert dec to hex.
- return status;
return tee_close_session.
- int ret;
- int value = 0;
this should be the part of already
367 #define U_BOOT_SUBCMDS_DO_CMD(_cmdname) \ 368 static int do_##_cmdname(struct cmd_tbl *cmdtp, int flag, \ 369 int argc, char *const argv[], \ 370 int *repeatable) \ 371 { \ 372 struct cmd_tbl *subcmd; \ 373 \ 374 /* We need at least the cmd and subcmd names. */ \ 375 if (argc < 2 || argc > CONFIG_SYS_MAXARGS) \ 376 return CMD_RET_USAGE; \ 377 \ 378 subcmd = find_cmd_tbl(argv[1], _cmdname##_subcmds, \ 379 ARRAY_SIZE(_cmdname##_subcmds)); \ 380 if (!subcmd || argc - 1 > subcmd->maxargs) \ 381 return CMD_RET_USAGE; \ 382 \ 383 if (flag == CMD_FLAG_REPEAT && \ 384 !cmd_is_repeatable(subcmd)) \ 385 return CMD_RET_SUCCESS; \ 386 \ 387 return subcmd->cmd_rep(subcmd, flag, argc - 1, \ 388 argv + 1, repeatable); \ 389 }
And this will allow you to have number of args between 2 and maxargs you setup.
values on u-boot prompt are mostly hex that's why I think you should decode hex here.
- if (ret)
"optee hello\n"
"\n"
"With:\n"
-- 2.34.1
M
Provide a man-page for the optee command.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- doc/usage/cmd/optee.rst | 75 +++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 76 insertions(+) create mode 100644 doc/usage/cmd/optee.rst
diff --git a/doc/usage/cmd/optee.rst b/doc/usage/cmd/optee.rst new file mode 100644 index 00000000000..a8a19e3e983 --- /dev/null +++ b/doc/usage/cmd/optee.rst @@ -0,0 +1,75 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +.. index:: + single: optee (command) + +optee command +=========== + +Synopsis +-------- + +:: + + optee hello + optee hello <value> + +Description +----------- + +This is a very simple optee hello command which is going to +increment an integer value. + +value + value to be passed which is going to increment + +To enable the OP-TEE OS side HELLO WORLD example please refer +https://optee.readthedocs.io/en/latest/building/gits/optee_examples/optee_ex... + +Examples +-------- + +:: + + ==> optee hello + The Hello World TA is going to be called + D/TA: TA_CreateEntryPoint:39 has been called + I/TA: Hello World! + TA value: 0 + D/TA: inc_value:105 has been called + I/TA: Got value: 0 from NW + I/TA: Increase value to: 1 + TA value: 1 + D/TA: inc_value:105 has been called + I/TA: Got value: 1 from NW + I/TA: Increase value to: 2 + TA value: 2 + I/TA: Goodbye! + D/TA: TA_DestroyEntryPoint:50 has been called + + ===> optee hello 74 + The Hello World TA is going to be called + D/TA: TA_CreateEntryPoint:39 has been called + I/TA: Hello World! + TA value: 74 + D/TA: inc_value:105 has been called + I/TA: Got value: 74 from NW + I/TA: Increase value to: 75 + TA value: 75 + D/TA: inc_value:105 has been called + I/TA: Got value: 75 from NW + I/TA: Increase value to: 76 + TA value: 76 + I/TA: Goodbye! + D/TA: TA_DestroyEntryPoint:50 has been called + +Configuration +------------- + +The optee command is enabled by CONFIG_OPTEE=y. + +Return value +------------ + +The return value $? is 0 (true) if the command succeeds, 1 (false) otherwise. + diff --git a/doc/usage/index.rst b/doc/usage/index.rst index cb7a23f1170..4dd00f002cd 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -92,6 +92,7 @@ Shell commands cmd/msr cmd/mtest cmd/mtrr + cmd/optee cmd/panic cmd/part cmd/pause
+.. index::
- single: optee (command)
make -j8 pdfdocs
/home/monstr/data/disk/u-boot/doc/usage/cmd/optee.rst:7: WARNING: Title underline too short.
M
Mattijs Korpershoek
Michal Simek
