[U-Boot] [PATCH v3 00/11] rockchip: add tpl and OPTEE support for rk3229
Add some generic options for TPL support for arm 32bit, and then and TPL support for rk3229(cortex-A7), and then add OPTEE support in SPL.
Tested on latest u-boot-rockchip master.
Changes in v3: - do not init ddr region in spl
Changes in v2: - update subject with ARCH_MEM info - Add new image type like ATF - Using new image type for op-tee - Make the its as common file used for all armv7 with op-tee - update defconfig option
Kever Yang (11): lib: add TPL_OF_LIBFDT option for TPL arm: add option for TPL ARCH_MEM in arm 32bit arm: add a separate stack for TPL rockchip: rk322x: enable tpl support sysreset: enable driver support in SPL/TPL image: add os type for OP-TEE spl: add support to booting with OP-TEE rockchip: rk322x: dts: enable uart2 for SPL/TPL rockchip: add fit source file for pack itb with op-tee rockchip: evb-rk3229: add README file for OP-TEE support rockchip: evb-rk322x: update defconfig with tpl and optee support
arch/arm/Kconfig | 29 +++++++++ arch/arm/dts/rk3229-evb.dts | 1 + arch/arm/lib/crt0.S | 4 +- arch/arm/mach-rockchip/Kconfig | 9 +++ arch/arm/mach-rockchip/Makefile | 3 +- arch/arm/mach-rockchip/fit_spl_optee.its | 50 ++++++++++++++++ arch/arm/mach-rockchip/rk322x-board-spl.c | 63 +++++-------------- arch/arm/mach-rockchip/rk322x-board-tpl.c | 90 ++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds | 13 ++++ board/rockchip/evb_rk3229/README | 72 ++++++++++++++++++++++ common/image.c | 1 + common/spl/Kconfig | 7 +++ common/spl/Makefile | 1 + common/spl/spl.c | 8 +++ common/spl/spl_optee.S | 13 ++++ configs/evb-rk3229_defconfig | 26 +++++++- drivers/sysreset/Kconfig | 18 ++++++ drivers/sysreset/Makefile | 2 +- include/configs/rk322x_common.h | 9 ++- include/image.h | 1 + include/spl.h | 9 +++ lib/Kconfig | 10 ++++ 22 files changed, 381 insertions(+), 58 deletions(-) create mode 100644 arch/arm/mach-rockchip/fit_spl_optee.its create mode 100644 arch/arm/mach-rockchip/rk322x-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds create mode 100644 board/rockchip/evb_rk3229/README create mode 100644 common/spl/spl_optee.S
TPL may need use libfdt for dt decode, add option for it.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
lib/Kconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/lib/Kconfig b/lib/Kconfig index f447c53..b43ef22 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -234,6 +234,16 @@ config SPL_OF_LIBFDT particular compatible nodes. The library operates on a flattened version of the device tree.
+config TPL_OF_LIBFDT + bool "Enable the FDT library for TPL" + default y if TPL_OF_CONTROL + help + This enables the FDT library (libfdt). It provides functions for + accessing binary device tree images in memory, such as adding and + removing nodes and properties, scanning through the tree and finding + particular compatible nodes. The library operates on a flattened + version of the device tree. + config FDT_FIXUP_PARTITIONS bool "overwrite MTD partitions in DTS through defined in 'mtdparts'" depends on OF_LIBFDT
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Some options like TPL_SYS_THUMB_BUILD, TPL_USE_ARCH_MEMCPY and TPL_USE_ARCH_MEMCPY are needed for TPL build in 32bit arm.
Changes in v3: None Changes in v2: - update subject with ARCH_MEM info
arch/arm/Kconfig | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7390995..4069227 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -244,6 +244,17 @@ config SPL_SYS_THUMB_BUILD density. For ARM architectures that support Thumb2 this flag will result in Thumb2 code generated by GCC.
+config TPL_SYS_THUMB_BUILD + bool "Build TPL using the Thumb instruction set" + default y if SYS_THUMB_BUILD + depends on TPL && !ARM64 + help + Use this flag to build SPL using the Thumb instruction set for + ARM architectures. Thumb instruction set provides better code + density. For ARM architectures that support Thumb2 this flag will + result in Thumb2 code generated by GCC. + + config SYS_L2CACHE_OFF bool "L2cache off" help @@ -280,6 +291,15 @@ config SPL_USE_ARCH_MEMCPY Such implementation may be faster under some conditions but may increase the binary size.
+config TPL_USE_ARCH_MEMCPY + bool "Use an assembly optimized implementation of memcpy for TPL" + default y if USE_ARCH_MEMCPY + depends on !ARM64 + help + Enable the generation of an optimized version of memcpy. + Such implementation may be faster under some conditions + but may increase the binary size. + config USE_ARCH_MEMSET bool "Use an assembly optimized implementation of memset" default y @@ -298,6 +318,15 @@ config SPL_USE_ARCH_MEMSET Such implementation may be faster under some conditions but may increase the binary size.
+config TPL_USE_ARCH_MEMSET + bool "Use an assembly optimized implementation of memset for TPL" + default y if USE_ARCH_MEMSET + depends on !ARM64 + help + Enable the generation of an optimized version of memset. + Such implementation may be faster under some conditions + but may increase the binary size. + config ARM64_SUPPORT_AARCH32 bool "ARM64 system support AArch32 execution state" default y if ARM64 && !TARGET_THUNDERX_88XX
TPL stack may different from SPL and sys stack, add support for separate one when the board defines it.
arch/arm/lib/crt0.S | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index fa81317..3c1c603 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -70,7 +70,9 @@ ENTRY(_main) * Set up initial C runtime environment and call board_init_f(0). */
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_NEEDS_SEPARATE_STACK) + ldr r0, =(CONFIG_TPL_STACK) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) ldr r0, =(CONFIG_SPL_STACK) #else ldr r0, =(CONFIG_SYS_INIT_SP_ADDR)
Move original spl to tpl, and add spl to load next stage firmware, adapt all the address and option for them.
Serial-changes: 2 - update upon latest source
Changes in v2: None
arch/arm/mach-rockchip/Kconfig | 9 +++ arch/arm/mach-rockchip/Makefile | 3 +- arch/arm/mach-rockchip/rk322x-board-spl.c | 63 +++++-------------- arch/arm/mach-rockchip/rk322x-board-tpl.c | 90 ++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds | 13 ++++ include/configs/rk322x_common.h | 9 ++- 6 files changed, 134 insertions(+), 53 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk322x-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 967290f..dbc197c 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -46,9 +46,18 @@ config ROCKCHIP_RK322X bool "Support Rockchip RK3228/RK3229" select CPU_V7 select SUPPORT_SPL + select SUPPORT_TPL select SPL + select TPL + select TPL_NEEDS_SEPARATE_TEXT_BASE if SPL + select TPL_NEEDS_SEPARATE_STACK if TPL + select SPL_DRIVERS_MISC_SUPPORT + imply SPL_SERIAL_SUPPORT + imply TPL_SERIAL_SUPPORT select ROCKCHIP_BROM_HELPER select DEBUG_UART_BOARD_INIT + select TPL_LIBCOMMON_SUPPORT + select TPL_LIBGENERIC_SUPPORT help The Rockchip RK3229 is a ARM-based SoC with a dual-core Cortex-A7 including NEON and GPU, Mali-400 graphics, several DDR3 options diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index e1b0519..3c14236 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -13,10 +13,11 @@ obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o
obj-tpl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o +obj-tpl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o -obj-spl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o spl-boot-order.o obj-spl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-spl.o spl-boot-order.o obj-spl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-spl.o spl-boot-order.o diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c index 35f4f97..89af1d9 100644 --- a/arch/arm/mach-rockchip/rk322x-board-spl.c +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -5,77 +5,46 @@ */
#include <common.h> -#include <debug_uart.h> #include <dm.h> -#include <ram.h> #include <spl.h> -#include <asm/io.h> -#include <asm/arch/bootrom.h> -#include <asm/arch/cru_rk322x.h> -#include <asm/arch/grf_rk322x.h> -#include <asm/arch/hardware.h> -#include <asm/arch/timer.h> -#include <asm/arch/uart.h> + +DECLARE_GLOBAL_DATA_PTR;
u32 spl_boot_device(void) { return BOOT_DEVICE_MMC1; } -DECLARE_GLOBAL_DATA_PTR;
-#define GRF_BASE 0x11000000 -#define SGRF_BASE 0x10140000 - -#define DEBUG_UART_BASE 0x11030000 +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +}
void board_debug_uart_init(void) { -static struct rk322x_grf * const grf = (void *)GRF_BASE; - /* Enable early UART2 channel 1 on the RK322x */ - rk_clrsetreg(&grf->gpio1b_iomux, - GPIO1B1_MASK | GPIO1B2_MASK, - GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | - GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); - /* Set channel C as UART2 input */ - rk_clrsetreg(&grf->con_iomux, - CON_IOMUX_UART2SEL_MASK, - CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); }
-#define SGRF_DDR_CON0 0x10150000 void board_init_f(ulong dummy) { - struct udevice *dev; int ret;
- /* - * Debug UART can be used from here if required: - * - * debug_uart_init(); - * printch('a'); - * printhex8(0x1234); - * printascii("string"); - */ - debug_uart_init(); - printascii("SPL Init"); - ret = spl_early_init(); if (ret) { - debug("spl_early_init() failed: %d\n", ret); + printf("spl_early_init() failed: %d\n", ret); hang(); } + preloader_console_init(); +}
- rockchip_timer_init(); - printf("timer init done\n"); - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) { - printf("DRAM init failed: %d\n", ret); - return; - } +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name);
- /* Disable the ddr secure region setting to make it non-secure */ - rk_clrreg(SGRF_DDR_CON0, 0x4000); #if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) back_to_bootrom(BROM_BOOT_NEXTSTAGE); #endif + return 0; } +#endif diff --git a/arch/arm/mach-rockchip/rk322x-board-tpl.c b/arch/arm/mach-rockchip/rk322x-board-tpl.c new file mode 100644 index 0000000..aa14cef --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x-board-tpl.c @@ -0,0 +1,90 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/bootrom.h> +#include <asm/arch/cru_rk322x.h> +#include <asm/arch/grf_rk322x.h> +#include <asm/arch/hardware.h> +#include <asm/arch/timer.h> +#include <asm/arch/uart.h> + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} +DECLARE_GLOBAL_DATA_PTR; + +#define GRF_BASE 0x11000000 +#define SGRF_BASE 0x10140000 +#define DEBUG_UART_BASE 0x11030000 +#define SECURE_TIMER_BASE 0x110d0020 +#define SGRF_DDR_CON0 0x10150000 + +void board_debug_uart_init(void) +{ + static struct rk322x_grf * const grf = (void *)GRF_BASE; + /* Enable early UART2 channel 1 on the RK322x */ + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | + GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); + /* Set channel C as UART2 input */ + rk_clrsetreg(&grf->con_iomux, + CON_IOMUX_UART2SEL_MASK, + CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); +} + +void secure_timer_init(void) +{ + writel(0, SECURE_TIMER_BASE + 0x10); + writel(0xffffffff, SECURE_TIMER_BASE); + writel(0xffffffff, SECURE_TIMER_BASE + 4); + writel(1, SECURE_TIMER_BASE + 0x10); +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + printascii("TPL Init"); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + secure_timer_init(); + rockchip_timer_init(); + printf("timer init done\n"); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + printf("DRAM init failed: %d\n", ret); + return; + } + + /* Disable the ddr secure region setting to make it non-secure */ + rk_clrreg(SGRF_DDR_CON0, 0x4000); +#if defined(CONFIG_TPL_ROCKCHIP_BACK_TO_BROM) && !defined(CONFIG_TPL_BOARD_INIT) + back_to_bootrom(BROM_BOOT_NEXTSTAGE); +#endif +} diff --git a/arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds b/arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds new file mode 100644 index 0000000..841c803 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2017 Rockchip Electronic Co.,Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#undef CONFIG_SPL_TEXT_BASE +#define CONFIG_SPL_TEXT_BASE CONFIG_TPL_TEXT_BASE + +#undef CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_MAX_SIZE CONFIG_TPL_MAX_SIZE + +#include "../../cpu/u-boot-spl.lds" diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index b22169d..5536b58 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -20,11 +20,10 @@
#define CONFIG_SPL_FRAMEWORK #define CONFIG_SYS_NS16550_MEM32 -#define CONFIG_SYS_TEXT_BASE 0x60000000 -#define CONFIG_SYS_INIT_SP_ADDR 0x60100000 -#define CONFIG_SYS_LOAD_ADDR 0x60800800 -#define CONFIG_SPL_STACK 0x10088000 -#define CONFIG_SPL_TEXT_BASE 0x10081004 +#define CONFIG_SYS_TEXT_BASE 0x61000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x61100000 +#define CONFIG_SYS_LOAD_ADDR 0x61800800 +#define CONFIG_SPL_TEXT_BASE 0x60000000
#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (28 << 10) #define CONFIG_ROCKCHIP_CHIP_TAG "RK32"
Serial-changes: 2
Changes in v3:
Changes in v2: None
Serial-changes: 2
See below for requested changes.
Changes in v3:
Changes in v2: None
- select SUPPORT_TPL select SPL
- select TPL
- select TPL_NEEDS_SEPARATE_TEXT_BASE if SPL
- select TPL_NEEDS_SEPARATE_STACK if TPL
- select SPL_DRIVERS_MISC_SUPPORT
- imply SPL_SERIAL_SUPPORT
- imply TPL_SERIAL_SUPPORT select ROCKCHIP_BROM_HELPER select DEBUG_UART_BOARD_INIT
- select TPL_LIBCOMMON_SUPPORT
- select TPL_LIBGENERIC_SUPPORT help The Rockchip RK3229 is a ARM-based SoC with a dual-core Cortex-A7 including NEON and GPU, Mali-400 graphics, several DDR3 options
- return MMCSD_MODE_RAW;
* printch('a');
debug_uart_init();
hang(); }printf("spl_early_init() failed: %d\n", ret);
- preloader_console_init();
- if (ret) {
return;
- /* Just empty function now - can't decide what to choose */
- debug("%s: %s\n", __func__, name);
- (C) Copyright 2017 Rockchip Electronics Co., Ltd
- return BOOT_DEVICE_MMC1;
Most of these defines are not used in the code below. Please remove.
- static struct rk322x_grf * const grf = (void *)GRF_BASE;
- writel(0, SECURE_TIMER_BASE + 0x10);
- writel(0xffffffff, SECURE_TIMER_BASE);
- writel(0xffffffff, SECURE_TIMER_BASE + 4);
- writel(1, SECURE_TIMER_BASE + 0x10);
If possible please use the DM timer class and the rockchip_timer.c driver as a timebase for U-Boot (I assume that the secure timer will be set up by OP-TEE anyway)... this should render this initialisation unnecessary.
- int ret;
* printch('a');
- printascii("TPL Init");
- if (ret) {
hang();
- secure_timer_init();
Again: by using the DM timer drivers, you won't need to call the rockchip_timer_init (as the init will be done by the DM timer).
- if (ret) {
return;
Please use syscon to get the SGRF base-address and access this through the SGRF structure definition.
- back_to_bootrom(BROM_BOOT_NEXTSTAGE);
- Copyright (C) 2017 Rockchip Electronic Co.,Ltd
Serial-changes: 2
Changes in v3:
Changes in v2: None
- select TPL
* printch('a');
debug_uart_init();
}printf("spl_early_init() failed: %d\n", ret); hang();
- if (ret) {
return;
I will remove those non-used next version, thanks.
I agree DM is good framework in U-Boot proper, but maybe not in TPL/SPL. Framework cost more code space and running time, but we get benefit for its comment code and compatibility. To be honest, I don't like use too much framework in TPL which is in IRAM, I want to make it as simple as possible, and also need clear enough with comments. I will consider what to use framework and what to use hard code in TPL/SPL, we need to balance it but not use DM everywhere: DEBUG_UART/SERIAL/SYSCON/PINCTRL/CLOCK/
Secure timer must be setup before trust(OPTEE/ATF) for all rockchip platform now, U-Boot proper can not access it, it's the clock source of arm generic timer. we can consider using arm generic timer as time base and drop rockchip_timer.c when we use DM framework, I think the rockchp_timer.c is used for chip like rk3036 who can not use any framework because of the IRAM size limit.
- int ret;
* printch('a');
- if (ret) {
hang();
- if (ret) {
return;
Sorry, I don't think this one time init, need introduce syscon(more code space and instructions with no any other help), it's different in different soc, and it's only available in TPL or SPL(if no TPL support). I would like to make it as-is and with clear enough comments.
Thanks, - Kever
SPL/TPL also need use sysreset for some feature like panic callback.
drivers/sysreset/Kconfig | 18 ++++++++++++++++++ drivers/sysreset/Makefile | 2 +- 2 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index a6d48e8..a61a7d3 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -13,6 +13,24 @@ config SYSRESET to effect a reset. The uclass will try all available drivers when reset_walk() is called.
+config SPL_SYSRESET + bool "Enable support for system reset drivers in SPL mode" + depends on SYSRESET && SPL_DM + help + Enable system reset drivers which can be used to reset the CPU or + board. Each driver can provide a reset method which will be called + to effect a reset. The uclass will try all available drivers when + reset_walk() is called. + +config TPL_SYSRESET + bool "Enable support for system reset drivers in TPL mode" + depends on SYSRESET && TPL_DM + help + Enable system reset drivers which can be used to reset the CPU or + board. Each driver can provide a reset method which will be called + to effect a reset. The uclass will try all available drivers when + reset_walk() is called. + if SYSRESET
config SYSRESET_PSCI diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index 2e9598e..00be747 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_SYSRESET) += sysreset-uclass.o +obj-$(CONFIG_$(SPL_TPL_)SYSRESET) += sysreset-uclass.o obj-$(CONFIG_SYSRESET_PSCI) += sysreset_psci.o obj-$(CONFIG_SYSRESET_SYSCON) += sysreset_syscon.o obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o
OP-TEE is an open source trust OS maintained here: https://github.com/OP-TEE/optee_os
Changes in v3: None Changes in v2: - Add new image type like ATF
common/image.c | 1 + include/image.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/common/image.c b/common/image.c index 4bcf6b3..597c025 100644 --- a/common/image.c +++ b/common/image.c @@ -91,6 +91,7 @@ static const table_entry_t uimage_arch[] = {
static const table_entry_t uimage_os[] = { { IH_OS_INVALID, "invalid", "Invalid OS", }, + { IH_OS_OP_TEE, "op-tee", "OP-TEE" }, { IH_OS_ARM_TRUSTED_FIRMWARE, "arm-trusted-firmware", "ARM Trusted Firmware" }, { IH_OS_LINUX, "linux", "Linux", }, #if defined(CONFIG_LYNXKDI) || defined(USE_HOSTCC) diff --git a/include/image.h b/include/image.h index a128a62..141ed00 100644 --- a/include/image.h +++ b/include/image.h @@ -153,6 +153,7 @@ enum { IH_OS_PLAN9, /* Plan 9 */ IH_OS_OPENRTOS, /* OpenRTOS */ IH_OS_ARM_TRUSTED_FIRMWARE, /* ARM Trusted Firmware */ + IH_OS_OP_TEE, /* OP-TEE */
IH_OS_COUNT, };
OP-TEE is an open source trusted OS, in armv7, its loading and running are like this: loading: - SPL load both OP-TEE and U-Boot running: - SPL run into OP-TEE in secure mode; - OP-TEE run into U-Boot in non-secure mode;
More detail: https://github.com/OP-TEE/optee_os and search for 'boot arguments' for detail entry parameter in: core/arch/arm/kernel/generic_entry_a32.S
Changes in v3: None Changes in v2: - Using new image type for op-tee
common/spl/Kconfig | 7 +++++++ common/spl/Makefile | 1 + common/spl/spl.c | 8 ++++++++ common/spl/spl_optee.S | 13 +++++++++++++ include/spl.h | 9 +++++++++ 5 files changed, 38 insertions(+) create mode 100644 common/spl/spl_optee.S
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index aef0034..c9a1ebb 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -725,6 +725,13 @@ config SPL_ATF is loaded by SPL(which is considered as BL2 in ATF terminology). More detail at: https://github.com/ARM-software/arm-trusted-firmware
+config SPL_OPTEE + bool "Support OP-TEE Trusted OS" + depends on ARM + help + OP-TEE is an open source Trusted OS which is loaded by SPL. + More detail at: https://github.com/OP-TEE/optee_os + config TPL bool depends on SUPPORT_TPL diff --git a/common/spl/Makefile b/common/spl/Makefile index 9bf8a2d..9918a2e 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_$(SPL_TPL_)UBI) += spl_ubi.o obj-$(CONFIG_$(SPL_TPL_)NET_SUPPORT) += spl_net.o obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += spl_mmc.o obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o +obj-$(CONFIG_$(SPL_TPL_)OPTEE) += spl_optee.o obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o obj-$(CONFIG_$(SPL_TPL_)FAT_SUPPORT) += spl_fat.o obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o diff --git a/common/spl/spl.c b/common/spl/spl.c index 76c1963..2c8942b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -436,6 +436,12 @@ void board_init_r(gd_t *dummy1, ulong dummy2) spl_invoke_atf(&spl_image); break; #endif +#if CONFIG_IS_ENABLED(OPTEE) + case IH_OS_OP_TEE: + debug("Jumping to U-Boot via OP-TEE\n"); + spl_optee_entry(0, 0, 0, (void *)spl_image.entry_point); + break; +#endif #ifdef CONFIG_SPL_OS_BOOT case IH_OS_LINUX: debug("Jumping to Linux\n"); @@ -450,6 +456,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) debug("SPL malloc() used %#lx bytes (%ld KB)\n", gd->malloc_ptr, gd->malloc_ptr / 1024); #endif + + debug("loaded - jumping to U-Boot...\n"); #ifdef CONFIG_BOOTSTAGE_STASH int ret;
diff --git a/common/spl/spl_optee.S b/common/spl/spl_optee.S new file mode 100644 index 0000000..4f7f8ba --- /dev/null +++ b/common/spl/spl_optee.S @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2017 Rockchip Electronic Co.,Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/linkage.h> +#include <asm/assembler.h> + +ENTRY(spl_optee_entry) + ldr lr, =CONFIG_SYS_TEXT_BASE + mov pc, r3 +ENDPROC(spl_optee_entry) diff --git a/include/spl.h b/include/spl.h index c14448b..551ce43 100644 --- a/include/spl.h +++ b/include/spl.h @@ -288,6 +288,15 @@ int spl_mmc_load_image(struct spl_image_info *spl_image, void spl_invoke_atf(struct spl_image_info *spl_image);
/** + * spl_optee_entry - entry function for optee + * entry arg0, pagestore + * entry arg1, (ARMv7 standard bootarg #1) + * entry arg2, device tree address, (ARMv7 standard bootarg #2) + * entry arg3, non-secure entry address (ARMv7 bootarg #0) + */ +void spl_optee_entry(void *arg0, void *arg1, void *arg2, void *arg3); + +/** * board_return_to_bootrom - allow for boards to continue with the boot ROM * * If a board (e.g. the Rockchip RK3368 boards) provide some
running:
running:
See below for requested changed.
+config SPL_OPTEE
- bool "Support OP-TEE Trusted OS"
- depends on ARM
- help
- case IH_OS_OP_TEE:
Why are you passing '0' for "arg2, device tree address"? This should be the device-tree pointer from the spl_image...
Also: 0 is not the same as NULL ... the arguments are all defined to have void* type, so 0 is not the correct type.
break;
- debug("loaded - jumping to U-Boot...\n");
- ldr lr, =CONFIG_SYS_TEXT_BASE
- mov pc, r3
- spl_optee_entry - entry function for optee
- entry arg0, pagestore
- entry arg1, (ARMv7 standard bootarg #1)
- entry arg2, device tree address, (ARMv7 standard bootarg #2)
- entry arg3, non-secure entry address (ARMv7 bootarg #0)
This doesn't look like a documentation comment for a U-Boot function. Also: the purpose of arg0 and arg1 are not clear from this comment.
- board_return_to_bootrom - allow for boards to continue with the boot ROM
- If a board (e.g. the Rockchip RK3368 boards) provide some
running:
+config SPL_OPTEE
- depends on ARM
- help
I will add dt pointer for entry next version.
break;
- mov pc, r3
This is a copy from OP-TEE project, we only use the entry address now. https://github.com/OP-TEE/optee_os/blob/master/core/arch/arm/kernel/generic_...
Thanks, - Kever
boot ROM
running:
+config SPL_OPTEE
- depends on ARM
- help
break;
- mov pc, r3
This is a copy from OP-TEE project, we only use the entry address now. https://github.com/OP-TEE/optee_os/blob/master/core/arch/arm/kernel/generic_... https://github.com/OP-TEE/optee_os/blob/master/core/arch/arm/kernel/generic_entry_a32.S#L208
You can add a back-reference to the original source (i.e. the link into the OP-TEE GIT) as well, which may be a good idea so people know what this links up with.
However, you should reformat the comment here anyway: (a) U-Boot documentation should be consistent (automated tools may harvest the comments documenting our exposed functions) (b) The meaning of the arguments should be understandable to anyone reading the U-Boot source-code without referring to the source of OP-TEE.
Regards, Philipp.
When we use DM_SERIAL for serial driver, we need enable the dts node for the debug console.
arch/arm/dts/rk3229-evb.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index ae0b0a4..fe4abe9 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -83,6 +83,7 @@ };
&uart2 { + u-boot,dm-pre-reloc; status = "okay"; };
We package U-Boot and OP-TEE into one itb file for SPL, so that we can support OP-TEE in SPL.
Changes in v3: None Changes in v2: - Make the its as common file used for all armv7 with op-tee
arch/arm/mach-rockchip/fit_spl_optee.its | 50 ++++++++++++++++++++++++++++++++ 1 file changed, 50 insertions(+) create mode 100644 arch/arm/mach-rockchip/fit_spl_optee.its
diff --git a/arch/arm/mach-rockchip/fit_spl_optee.its b/arch/arm/mach-rockchip/fit_spl_optee.its new file mode 100644 index 0000000..3aeecb8 --- /dev/null +++ b/arch/arm/mach-rockchip/fit_spl_optee.its @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2017 Rockchip Electronic Co.,Ltd + * + * Simple U-boot fit source file containing U-Boot, dtb and optee + */ + +/dts-v1/; + +/ { + description = "Simple image with OP-TEE support"; + #address-cells = <1>; + + images { + uboot@1 { + description = "U-Boot"; + data = /incbin/("../../../u-boot-nodtb.bin"); + type = "standalone"; + os = "U-Boot"; + arch = "arm"; + compression = "none"; + load = <0x61000000>; + }; + optee@1 { + description = "OP-TEE"; + data = /incbin/("../../../tee.bin"); + type = "firmware"; + arch = "arm"; + os = "op-tee"; + compression = "none"; + load = <0x68400000>; + entry = <0x68400000>; + }; + fdt@1 { + description = "dtb"; + data = /incbin/("../../../u-boot.dtb"); + type = "flat_dt"; + compression = "none"; + }; + }; + + configurations { + default = "conf@1"; + conf@1 { + description = "Rockchip armv7 with OP-TEE"; + firmware = "optee@1"; + loadables = "uboot@1"; + fdt = "fdt@1"; + }; + }; +};
Detail of step by step to bring up the board with OP-TEE support.
board/rockchip/evb_rk3229/README | 72 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+) create mode 100644 board/rockchip/evb_rk3229/README
diff --git a/board/rockchip/evb_rk3229/README b/board/rockchip/evb_rk3229/README new file mode 100644 index 0000000..46c54c2 --- /dev/null +++ b/board/rockchip/evb_rk3229/README @@ -0,0 +1,72 @@ +Get the Source and prebuild binary +================================== + + > mkdir ~/evb_rk3229 + > cd ~/evb_rk3229 + > git clone git://git.denx.de/u-boot.git + > git clone https://github.com/OP-TEE/optee_os.git + > git clone https://github.com/rockchip-linux/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git + +Compile the OP-TEE +=============== + + > cd optee_os + > make clean + > make CROSS_COMPILE_ta_arm32=arm-none-eabi- PLATFORM=rockchip-rk322x + Get tee.bin in this step, copy it to U-Boot root dir: + > cp out/arm-plat-rockchip/core/tee-pager.bin ../u-boot/tee.bin + +Compile the U-Boot +================== + + > cd ../u-boot + > export CROSS_COMPILE=arm-linux-gnueabihf- + > export ARCH=arm + > make evb-rk3229_defconfig + > make + > make u-boot.itb + + Get tpl/u-boot-tpl.bin, spl/u-boot-spl.bin and u-boot.itb in this step. + +Compile the rkdeveloptool +======================= + Follow instructions in latest README + > cd ../rkdeveloptool + > autoreconf -i + > ./configure + > make + > sudo make install + + Get rkdeveloptool in you Host in this step. + +Both origin binaries and Tool are ready now, choose either option 1 or +option 2 to deploy U-Boot. + +Package the image +================= + + > cd ../u-boot + > tools/mkimage -n rk322x -T rksd -d tpl/u-boot-spl.bin idbloader.img + > cat spl/u-boot-spl.bin >> idbloader.img + + Get idbloader.img in this step. + +Flash the image to eMMC +======================= +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > cd .. + > rkdeveloptool db rkbin/rk32/rk322x_loader_v1.04.232.bin + > rkdeveloptool wl 64 u-boot/idbloader.img + > rkdeveloptool wl 0x4000 u-boot/u-boot.itb + > rkdeveloptool rd + +Flash the image to SD card +========================== + > dd if=u-boot/idbloader.img of=/dev/sdb seek=64 + > dd if=u-boot/u-boot.itb of=/dev/sdb seek=16384 + +You should be able to get U-Boot log message with OP-TEE boot info. + +For more detail, please reference to: +http://opensource.rock-chips.com/wiki_Boot_option
Enable all the options for TPL/SPL and OPTEE.
Changes in v3: None Changes in v2: - update defconfig option
configs/evb-rk3229_defconfig | 26 +++++++++++++++++++++++--- 1 file changed, 23 insertions(+), 3 deletions(-)
diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index b226f66..025822d 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -4,14 +4,27 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_ROCKCHIP_RK322X=y -CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds" +CONFIG_TPL_TEXT_BASE=0x10081000 +CONFIG_TPL_MAX_SIZE=28672 +CONFIG_TPL_STACK=0x10088000 +CONFIG_TPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 CONFIG_TARGET_EVB_RK3229=y -CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_SPL_STACK_R_ADDR=0x60600000 CONFIG_DEFAULT_DEVICE_TREE="rk3229-evb" CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_SOURCE="arch/arm/mach-rockchip/fit_spl_optee.its" # CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x4000 +CONFIG_SPL_OPTEE=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_GPT=y @@ -19,14 +32,19 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_TPL_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y +CONFIG_TPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -35,12 +53,14 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RK322X=y CONFIG_RAM=y CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_BASE=0x11030000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Rockchip"
Hi Kever,
Am Dienstag, 19. Dezember 2017, 16:53:13 CET schrieb Kever Yang:
With the now added timer initialization, this works actually pretty well :-).
On my rk3229 tv-box board (some nexbox thing or so), I now get u-boot loading mainline op-tee and when starting a kernel both core bringuo via psci and arch-timer working nicely.
So this series Tested-by: Heiko Stuebner heiko@sntech.de
Thanks Heiko
Dr. Philipp Tomsich
Heiko Stuebner
Kever Yang
Philipp Tomsich
