[U-Boot] [PATCH 00/22] xilinx-ppc4xx: Cleanout and port to DM serial
xilinx-ppc4xx made us of serial uartlite, which was ported to DM. This patch moves port these boards to DM.
Now that Kconfig works really well, there is no need to maintain the specific boards (fx12mm, ml507 and v5fx30teval) or their flash version.
The ppc440 boards have been wired to the ll_temac driver.
A series of cleanouts have been done.
This patchset sits on top of: http://git.denx.de/?p=u-boot/u-boot-microblaze.git;a=shortlog;h=refs/heads/m...
It has been tested on a ppc440 bard.
Hopefully Georg Schardt can test the changes on his fx12mm.
These changes can also be browset at https://github.com/ribalda/u-boot/tree/xilinx-ppc4xx-generic-dm
Regards (and thanks for your patience)!
Ricardo Ribalda (22): ppc: xilinx-ppc440: Remove support for ml507 ppc: xilinx-ppc405: Remove support for fx12mm xilinx-ppc440: Remove support for v5fx30teval .mailmap: Add all the mail alias for Ricardo Ribalda mailaddr: Update mail address ppc: pp405-generic: Simplify Makefile ppc: pp440-generic: Simplify Makefile ppc: ppc440: ppc440-generic_flash_defconfig ppc: ppc405: ppc405-generic_flash_defconfig ppc: xilinx-ppc440-generic: Cleanout header files ppc: xilinx-ppc405-generic: Cleanout header files ppc: xilinx-ppc4xx-generic: Update xparameters.h ppc: dts: Add device tree for xilix-ppc4xx-generic configs/xilinx-ppc405-generic: Typos and size configs/xilinx-ppc440-generic: Typos and size ppc: xilinx-ppc4xx: Port to DM serial ppc: xilinx_ppc405_generic: Remove weak attributes ppc: xilinx_ppc440_generic: Remove weak attributes ppc: xilinx_ppc405_generic: Remove uncalled functions ppc: xilinx_ppc440_generic: Remove uncalled functions net: xilinx_ll_temac: Fix string overflow ppc: xilinx-ppc440-generic: Wire LL_TEMAC driver
.mailmap | 3 ++ arch/powerpc/cpu/ppc4xx/Kconfig | 20 ++++----- arch/powerpc/cpu/ppc4xx/interrupts.c | 2 +- arch/powerpc/cpu/ppc4xx/uic.c | 2 +- arch/powerpc/cpu/ppc4xx/xilinx_irq.c | 2 +- arch/powerpc/dts/Makefile | 2 + arch/powerpc/dts/xilinx-ppc405-generic.dts | 13 ++++++ arch/powerpc/dts/xilinx-ppc440-generic.dts | 13 ++++++ arch/powerpc/include/asm/interrupt.h | 2 +- arch/powerpc/include/asm/xilinx_irq.h | 2 +- board/avnet/fx12mm/Kconfig | 12 ------ board/avnet/fx12mm/MAINTAINERS | 7 --- board/avnet/fx12mm/Makefile | 11 ----- board/avnet/fx12mm/fx12mm.c | 34 --------------- board/avnet/fx12mm/xparameters.h | 35 --------------- board/avnet/v5fx30teval/Kconfig | 12 ------ board/avnet/v5fx30teval/MAINTAINERS | 7 --- board/avnet/v5fx30teval/Makefile | 11 ----- board/avnet/v5fx30teval/v5fx30teval.c | 17 -------- board/avnet/v5fx30teval/xparameters.h | 22 ---------- board/xilinx/ml507/Kconfig | 12 ------ board/xilinx/ml507/MAINTAINERS | 7 --- board/xilinx/ml507/Makefile | 11 ----- board/xilinx/ml507/ml507.c | 17 -------- board/xilinx/ml507/xparameters.h | 23 ---------- board/xilinx/ppc405-generic/MAINTAINERS | 2 +- board/xilinx/ppc405-generic/Makefile | 4 +- .../xilinx/ppc405-generic/xilinx_ppc405_generic.c | 31 ++++++-------- board/xilinx/ppc405-generic/xparameters.h | 7 ++- board/xilinx/ppc440-generic/MAINTAINERS | 2 +- board/xilinx/ppc440-generic/Makefile | 6 +-- board/xilinx/ppc440-generic/init.S | 2 +- .../xilinx/ppc440-generic/xilinx_ppc440_generic.c | 49 ++++++++++++++------- board/xilinx/ppc440-generic/xparameters.h | 15 ++++--- configs/fx12mm_defconfig | 10 ----- configs/fx12mm_flash_defconfig | 9 ---- configs/ml507_defconfig | 9 ---- configs/ml507_flash_defconfig | 8 ---- configs/v5fx30teval_defconfig | 9 ---- configs/v5fx30teval_flash_defconfig | 8 ---- configs/xilinx-ppc405-generic_defconfig | 8 ++++ configs/xilinx-ppc405-generic_flash_defconfig | 8 ---- configs/xilinx-ppc440-generic_defconfig | 17 ++++++-- configs/xilinx-ppc440-generic_flash_defconfig | 8 ---- drivers/hwmon/adt7460.c | 2 +- drivers/net/xilinx_ll_temac.c | 3 +- drivers/serial/Kconfig | 2 +- include/configs/fx12mm.h | 50 ---------------------- include/configs/ml507.h | 38 ---------------- include/configs/v5fx30teval.h | 38 ---------------- include/configs/xilinx-ppc.h | 22 +++------- include/configs/xilinx-ppc405-generic.h | 19 ++++---- include/configs/xilinx-ppc405.h | 22 ---------- include/configs/xilinx-ppc440-generic.h | 27 ++++++++---- include/configs/xilinx-ppc440.h | 17 -------- 55 files changed, 169 insertions(+), 582 deletions(-) create mode 100644 arch/powerpc/dts/xilinx-ppc405-generic.dts create mode 100644 arch/powerpc/dts/xilinx-ppc440-generic.dts delete mode 100644 board/avnet/fx12mm/Kconfig delete mode 100644 board/avnet/fx12mm/MAINTAINERS delete mode 100644 board/avnet/fx12mm/Makefile delete mode 100644 board/avnet/fx12mm/fx12mm.c delete mode 100644 board/avnet/fx12mm/xparameters.h delete mode 100644 board/avnet/v5fx30teval/Kconfig delete mode 100644 board/avnet/v5fx30teval/MAINTAINERS delete mode 100644 board/avnet/v5fx30teval/Makefile delete mode 100644 board/avnet/v5fx30teval/v5fx30teval.c delete mode 100644 board/avnet/v5fx30teval/xparameters.h delete mode 100644 board/xilinx/ml507/Kconfig delete mode 100644 board/xilinx/ml507/MAINTAINERS delete mode 100644 board/xilinx/ml507/Makefile delete mode 100644 board/xilinx/ml507/ml507.c delete mode 100644 board/xilinx/ml507/xparameters.h delete mode 100644 configs/fx12mm_defconfig delete mode 100644 configs/fx12mm_flash_defconfig delete mode 100644 configs/ml507_defconfig delete mode 100644 configs/ml507_flash_defconfig delete mode 100644 configs/v5fx30teval_defconfig delete mode 100644 configs/v5fx30teval_flash_defconfig delete mode 100644 configs/xilinx-ppc405-generic_flash_defconfig delete mode 100644 configs/xilinx-ppc440-generic_flash_defconfig delete mode 100644 include/configs/fx12mm.h delete mode 100644 include/configs/ml507.h delete mode 100644 include/configs/v5fx30teval.h delete mode 100644 include/configs/xilinx-ppc405.h delete mode 100644 include/configs/xilinx-ppc440.h
ml507 is just a specialized version of the xilinx-ppc440-generic
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 ---- board/xilinx/ml507/Kconfig | 12 ------------ board/xilinx/ml507/MAINTAINERS | 7 ------- board/xilinx/ml507/Makefile | 11 ----------- board/xilinx/ml507/ml507.c | 17 ----------------- board/xilinx/ml507/xparameters.h | 23 ----------------------- configs/ml507_defconfig | 9 --------- configs/ml507_flash_defconfig | 8 -------- include/configs/ml507.h | 38 -------------------------------------- 9 files changed, 129 deletions(-) delete mode 100644 board/xilinx/ml507/Kconfig delete mode 100644 board/xilinx/ml507/MAINTAINERS delete mode 100644 board/xilinx/ml507/Makefile delete mode 100644 board/xilinx/ml507/ml507.c delete mode 100644 board/xilinx/ml507/xparameters.h delete mode 100644 configs/ml507_defconfig delete mode 100644 configs/ml507_flash_defconfig delete mode 100644 include/configs/ml507.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index efd316573ce6..ba09b57fca50 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -115,9 +115,6 @@ config TARGET_PIP405 config TARGET_XPEDITE1000 bool "Support xpedite1000"
-config TARGET_ML507 - bool "Support ml507" - config TARGET_XILINX_PPC405_GENERIC bool "Support xilinx-ppc405-generic"
@@ -158,7 +155,6 @@ source "board/mpl/mip405/Kconfig" source "board/mpl/pip405/Kconfig" source "board/t3corp/Kconfig" source "board/xes/xpedite1000/Kconfig" -source "board/xilinx/ml507/Kconfig" source "board/xilinx/ppc405-generic/Kconfig" source "board/xilinx/ppc440-generic/Kconfig"
diff --git a/board/xilinx/ml507/Kconfig b/board/xilinx/ml507/Kconfig deleted file mode 100644 index d580a7beafef..000000000000 --- a/board/xilinx/ml507/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_ML507 - -config SYS_BOARD - default "ml507" - -config SYS_VENDOR - default "xilinx" - -config SYS_CONFIG_NAME - default "ml507" - -endif diff --git a/board/xilinx/ml507/MAINTAINERS b/board/xilinx/ml507/MAINTAINERS deleted file mode 100644 index 8b40f4450085..000000000000 --- a/board/xilinx/ml507/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -ML507 BOARD -M: Ricardo Ribalda ricardo.ribalda@uam.es -S: Maintained -F: board/xilinx/ml507/ -F: include/configs/ml507.h -F: configs/ml507_defconfig -F: configs/ml507_flash_defconfig diff --git a/board/xilinx/ml507/Makefile b/board/xilinx/ml507/Makefile deleted file mode 100644 index 9a3809f3c065..000000000000 --- a/board/xilinx/ml507/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2008 -# Ricardo Ribalda,Universidad Autonoma de Madrid, ricardo.ribalda@uam.es -# This work has been supported by: Qtechnology http://qtec.com/ -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += ml507.o - -include $(srctree)/board/xilinx/ppc440-generic/Makefile diff --git a/board/xilinx/ml507/ml507.c b/board/xilinx/ml507/ml507.c deleted file mode 100644 index 83b764b7337b..000000000000 --- a/board/xilinx/ml507/ml507.c +++ /dev/null @@ -1,17 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#include <config.h> -#include <common.h> -#include <asm/processor.h> - - -int checkboard(void) -{ - puts("Xilinx ML507 Board\n"); - return 0; -} diff --git a/board/xilinx/ml507/xparameters.h b/board/xilinx/ml507/xparameters.h deleted file mode 100644 index e30e592bbe12..000000000000 --- a/board/xilinx/ml507/xparameters.h +++ /dev/null @@ -1,23 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * based on xparameters-ml507.h by Xilinx - * - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#ifndef XPARAMETER_H -#define XPARAMETER_H - -#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 -#define XPAR_IIC_EEPROM_BASEADDR 0x81600000 -#define XPAR_INTC_0_BASEADDR 0x81800000 -#define XPAR_UARTLITE_0_BASEADDR 0x84000000 -#define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 -#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 -#define XPAR_CORE_CLOCK_FREQ_HZ 400000000 -#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 -#define XPAR_UARTLITE_0_BAUDRATE 9600 - -#endif diff --git a/configs/ml507_defconfig b/configs/ml507_defconfig deleted file mode 100644 index d1e4e30371bf..000000000000 --- a/configs/ml507_defconfig +++ /dev/null @@ -1,9 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_ML507=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o" -CONFIG_SYS_PROMPT="ml507:/# " -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set diff --git a/configs/ml507_flash_defconfig b/configs/ml507_flash_defconfig deleted file mode 100644 index 442e0ce1fa6a..000000000000 --- a/configs/ml507_flash_defconfig +++ /dev/null @@ -1,8 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_ML507=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set diff --git a/include/configs/ml507.h b/include/configs/ml507.h deleted file mode 100644 index 89a72904b3d7..000000000000 --- a/include/configs/ml507.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/*CPU*/ -#define CONFIG_440 1 -#define CONFIG_XILINX_ML507 1 -#include "../board/xilinx/ml507/xparameters.h" - -/*Mem Map*/ -#define CONFIG_SYS_SDRAM_SIZE_MB 256 - -/*Env*/ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x340000 -#define CONFIG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CONFIG_ENV_OFFSET) - -/*Misc*/ -#define CONFIG_PREBOOT "echo U-Boot is up and runnining;" - -/*Flash*/ -#define CONFIG_SYS_FLASH_SIZE (32*1024*1024) -#define CONFIG_SYS_MAX_FLASH_SECT 259 -#define MTDIDS_DEFAULT "nor0=ml507-flash" -#define MTDPARTS_DEFAULT "mtdparts=ml507-flash:-(user)" - -/*Generic Configs*/ -#include <configs/xilinx-ppc440.h> - -#endif /* __CONFIG_H */
On Tue, Jan 26, 2016 at 6:24 PM, Ricardo Ribalda Delgado ricardo.ribalda@gmail.com wrote:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
It is just a specialized version of the xilinx-ppc405
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 ---- board/avnet/fx12mm/Kconfig | 12 ---------- board/avnet/fx12mm/MAINTAINERS | 7 ------ board/avnet/fx12mm/Makefile | 11 --------- board/avnet/fx12mm/fx12mm.c | 34 --------------------------- board/avnet/fx12mm/xparameters.h | 35 ---------------------------- configs/fx12mm_defconfig | 10 -------- configs/fx12mm_flash_defconfig | 9 -------- include/configs/fx12mm.h | 50 ---------------------------------------- 9 files changed, 172 deletions(-) delete mode 100644 board/avnet/fx12mm/Kconfig delete mode 100644 board/avnet/fx12mm/MAINTAINERS delete mode 100644 board/avnet/fx12mm/Makefile delete mode 100644 board/avnet/fx12mm/fx12mm.c delete mode 100644 board/avnet/fx12mm/xparameters.h delete mode 100644 configs/fx12mm_defconfig delete mode 100644 configs/fx12mm_flash_defconfig delete mode 100644 include/configs/fx12mm.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index ba09b57fca50..120d5cfb3f39 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -55,9 +55,6 @@ config TARGET_YOSEMITE config TARGET_YUCCA bool "Support yucca"
-config TARGET_FX12MM - bool "Support fx12mm" - config TARGET_V5FX30TEVAL bool "Support v5fx30teval"
@@ -136,7 +133,6 @@ source "board/amcc/sequoia/Kconfig" source "board/amcc/walnut/Kconfig" source "board/amcc/yosemite/Kconfig" source "board/amcc/yucca/Kconfig" -source "board/avnet/fx12mm/Kconfig" source "board/avnet/v5fx30teval/Kconfig" source "board/esd/cpci2dp/Kconfig" source "board/esd/cpci405/Kconfig" diff --git a/board/avnet/fx12mm/Kconfig b/board/avnet/fx12mm/Kconfig deleted file mode 100644 index 0b67ebde93b8..000000000000 --- a/board/avnet/fx12mm/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_FX12MM - -config SYS_BOARD - default "fx12mm" - -config SYS_VENDOR - default "avnet" - -config SYS_CONFIG_NAME - default "fx12mm" - -endif diff --git a/board/avnet/fx12mm/MAINTAINERS b/board/avnet/fx12mm/MAINTAINERS deleted file mode 100644 index c92e258df95c..000000000000 --- a/board/avnet/fx12mm/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -FX12MM BOARD -M: Georg Schardt schardt@team-ctech.de -S: Maintained -F: board/avnet/fx12mm/ -F: include/configs/fx12mm.h -F: configs/fx12mm_defconfig -F: configs/fx12mm_flash_defconfig diff --git a/board/avnet/fx12mm/Makefile b/board/avnet/fx12mm/Makefile deleted file mode 100644 index 618b42f8917c..000000000000 --- a/board/avnet/fx12mm/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2008 -# Ricardo Ribalda,Universidad Autonoma de Madrid, ricardo.ribalda@uam.es -# This work has been supported by: Qtechnology http://qtec.com/ -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += fx12mm.o - -include $(srctree)/board/xilinx/ppc405-generic/Makefile diff --git a/board/avnet/fx12mm/fx12mm.c b/board/avnet/fx12mm/fx12mm.c deleted file mode 100644 index 92e1cfb75f3c..000000000000 --- a/board/avnet/fx12mm/fx12mm.c +++ /dev/null @@ -1,34 +0,0 @@ -/* - * (C) Copyright 2008 - * - * Author: Xilinx Inc. - * - * Modified by: - * Georg Schardt schardt@team-ctech.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -#include <common.h> -#include <asm/processor.h> - -int checkboard(void) -{ - char buf[64]; - int i; - int l = getenv_f("serial#", buf, sizeof(buf)); - - if (l < 0) { - printf("Avnet Virtex4 FX12 with no serial #"); - } else { - printf("Avnet Virtex4 FX12 Minimodul # "); - for (i = 0; i < l; ++i) { - if (buf[i] == ' ') - break; - putc(buf[i]); - } - } - putc('\n'); - return 0; -} diff --git a/board/avnet/fx12mm/xparameters.h b/board/avnet/fx12mm/xparameters.h deleted file mode 100644 index 94f682f8ecce..000000000000 --- a/board/avnet/fx12mm/xparameters.h +++ /dev/null @@ -1,35 +0,0 @@ -/* - * (C) Copyright 2008 - * - * Georg Schardt schardt@team-ctech.de - * - * SPDX-License-Identifier: GPL-2.0+ - * - * CAUTION: This file is based on the xparameters.h automatically - * generated by libgen. Version: Xilinx EDK 10.1.02 Build EDK_K_SP2.5 - */ - -#ifndef __XPARAMETER_H__ -#define __XPARAMETER_H__ - -/* RS232 */ -#define XPAR_UARTNS550_0_CLOCK_FREQ_HZ 100000000 -#define XPAR_UARTNS550_0_BASEADDR 0x83E00000 - - -/* INT_C */ -#define XPAR_XPS_INTC_0_DEVICE_ID 0 -#define XPAR_XPS_INTC_0_BASEADDR 0x81800000 -#define XPAR_INTC_MAX_NUM_INTR_INPUTS 2 - -/* CPU core clock */ -#define XPAR_CORE_CLOCK_FREQ_HZ 300000000 -#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 - -/* RAM */ -#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 - -/* FLASH */ -#define XPAR_FLASH_MEM0_BASEADDR 0xFFC00000 - -#endif diff --git a/configs/fx12mm_defconfig b/configs/fx12mm_defconfig deleted file mode 100644 index c714d0d35e4e..000000000000 --- a/configs/fx12mm_defconfig +++ /dev/null @@ -1,10 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_FX12MM=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,INIT_TLB=board/xilinx/ppc405-generic/init.o" -CONFIG_SYS_PROMPT="FX12MM:/# " -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set -CONFIG_SYS_NS16550=y diff --git a/configs/fx12mm_flash_defconfig b/configs/fx12mm_flash_defconfig deleted file mode 100644 index ac3841260d65..000000000000 --- a/configs/fx12mm_flash_defconfig +++ /dev/null @@ -1,9 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_FX12MM=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc405-generic/init.o" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set -CONFIG_SYS_NS16550=y diff --git a/include/configs/fx12mm.h b/include/configs/fx12mm.h deleted file mode 100644 index fa32a2e8cf37..000000000000 --- a/include/configs/fx12mm.h +++ /dev/null @@ -1,50 +0,0 @@ -/* - * (C) Copyright 2008 - * - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com - * - * Georg Schardt schardt@team-ctech.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * Configuration file for the Virtex4FX12 Minimodul by Avnet/Memec, - * see http://www.em.avnet.com - */ - -#ifndef __CONFIG_FX12_H -#define __CONFIG_FX12_H - -#include "../board/avnet/fx12mm/xparameters.h" - -/* cmd config */ -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_FLASH_CFI_MTD - -/* sdram */ -#define CONFIG_SYS_SDRAM_SIZE_MB 64 - -/* environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_SYS_ENV_OFFSET 0xA0000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+CONFIG_SYS_ENV_OFFSET) -#define CONFIG_ENV_OVERWRITE 1 - -/*Misc*/ -#define CONFIG_PREBOOT "echo U-Boot is up and running;" - -/*Flash*/ -#define CONFIG_SYS_FLASH_SIZE (4*1024*1024) -#define CONFIG_SYS_MAX_FLASH_SECT 71 -#define MTDIDS_DEFAULT "nor0=fx12mm-flash" -#define MTDPARTS_DEFAULT "mtdparts=fx12mm-flash:-(user)" - -#include "configs/xilinx-ppc405.h" - -#endif /* __CONFIG_H */
Thanks, Stefan
It is just a specialized version of xilinx-ppc440
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 ---- board/avnet/v5fx30teval/Kconfig | 12 ----------- board/avnet/v5fx30teval/MAINTAINERS | 7 ------- board/avnet/v5fx30teval/Makefile | 11 ---------- board/avnet/v5fx30teval/v5fx30teval.c | 17 ---------------- board/avnet/v5fx30teval/xparameters.h | 22 -------------------- configs/v5fx30teval_defconfig | 9 --------- configs/v5fx30teval_flash_defconfig | 8 -------- include/configs/v5fx30teval.h | 38 ----------------------------------- 9 files changed, 128 deletions(-) delete mode 100644 board/avnet/v5fx30teval/Kconfig delete mode 100644 board/avnet/v5fx30teval/MAINTAINERS delete mode 100644 board/avnet/v5fx30teval/Makefile delete mode 100644 board/avnet/v5fx30teval/v5fx30teval.c delete mode 100644 board/avnet/v5fx30teval/xparameters.h delete mode 100644 configs/v5fx30teval_defconfig delete mode 100644 configs/v5fx30teval_flash_defconfig delete mode 100644 include/configs/v5fx30teval.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index 120d5cfb3f39..3959585d44c3 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -55,9 +55,6 @@ config TARGET_YOSEMITE config TARGET_YUCCA bool "Support yucca"
-config TARGET_V5FX30TEVAL - bool "Support v5fx30teval" - config TARGET_CPCI2DP bool "Support CPCI2DP"
@@ -133,7 +130,6 @@ source "board/amcc/sequoia/Kconfig" source "board/amcc/walnut/Kconfig" source "board/amcc/yosemite/Kconfig" source "board/amcc/yucca/Kconfig" -source "board/avnet/v5fx30teval/Kconfig" source "board/esd/cpci2dp/Kconfig" source "board/esd/cpci405/Kconfig" source "board/esd/plu405/Kconfig" diff --git a/board/avnet/v5fx30teval/Kconfig b/board/avnet/v5fx30teval/Kconfig deleted file mode 100644 index 079387b707a7..000000000000 --- a/board/avnet/v5fx30teval/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_V5FX30TEVAL - -config SYS_BOARD - default "v5fx30teval" - -config SYS_VENDOR - default "avnet" - -config SYS_CONFIG_NAME - default "v5fx30teval" - -endif diff --git a/board/avnet/v5fx30teval/MAINTAINERS b/board/avnet/v5fx30teval/MAINTAINERS deleted file mode 100644 index 91dde7a5c8f9..000000000000 --- a/board/avnet/v5fx30teval/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -V5FX30TEVAL BOARD -M: Ricardo Ribalda ricardo.ribalda@uam.es -S: Maintained -F: board/avnet/v5fx30teval/ -F: include/configs/v5fx30teval.h -F: configs/v5fx30teval_defconfig -F: configs/v5fx30teval_flash_defconfig diff --git a/board/avnet/v5fx30teval/Makefile b/board/avnet/v5fx30teval/Makefile deleted file mode 100644 index 8c41af02d4f2..000000000000 --- a/board/avnet/v5fx30teval/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# -# (C) Copyright 2008 -# Ricardo Ribalda,Universidad Autonoma de Madrid, ricardo.ribalda@uam.es -# This work has been supported by: Qtechnology http://qtec.com/ -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += v5fx30teval.o - -include $(srctree)/board/xilinx/ppc440-generic/Makefile diff --git a/board/avnet/v5fx30teval/v5fx30teval.c b/board/avnet/v5fx30teval/v5fx30teval.c deleted file mode 100644 index 68b0eb959dea..000000000000 --- a/board/avnet/v5fx30teval/v5fx30teval.c +++ /dev/null @@ -1,17 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#include <config.h> -#include <common.h> -#include <asm/processor.h> - - -int checkboard(void) -{ - puts("Avnet Virtex 5 FX30 Evaluation Board\n"); - return 0; -} diff --git a/board/avnet/v5fx30teval/xparameters.h b/board/avnet/v5fx30teval/xparameters.h deleted file mode 100644 index 95b8c285ad1a..000000000000 --- a/board/avnet/v5fx30teval/xparameters.h +++ /dev/null @@ -1,22 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * based on xparameters.h by Xilinx - * - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#ifndef XPARAMETER_H -#define XPARAMETER_H - -#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 -#define XPAR_INTC_0_BASEADDR 0x81800000 -#define XPAR_UARTLITE_0_BASEADDR 0x84000000 -#define XPAR_FLASH_MEM0_BASEADDR 0xFF000000 -#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 -#define XPAR_CORE_CLOCK_FREQ_HZ 400000000 -#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 -#define XPAR_UARTLITE_0_BAUDRATE 9600 - -#endif diff --git a/configs/v5fx30teval_defconfig b/configs/v5fx30teval_defconfig deleted file mode 100644 index 3e2ce7d2fe76..000000000000 --- a/configs/v5fx30teval_defconfig +++ /dev/null @@ -1,9 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_V5FX30TEVAL=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o" -CONFIG_SYS_PROMPT="v5fx30t:/# " -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set diff --git a/configs/v5fx30teval_flash_defconfig b/configs/v5fx30teval_flash_defconfig deleted file mode 100644 index b9b05e8b3951..000000000000 --- a/configs/v5fx30teval_flash_defconfig +++ /dev/null @@ -1,8 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_V5FX30TEVAL=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set diff --git a/include/configs/v5fx30teval.h b/include/configs/v5fx30teval.h deleted file mode 100644 index 298fa3e6d0a6..000000000000 --- a/include/configs/v5fx30teval.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/*CPU*/ -#define CONFIG_440 1 -#define CONFIG_XILINX_ML507 1 -#include "../board/avnet/v5fx30teval/xparameters.h" - -/*Mem Map*/ -#define CONFIG_SYS_SDRAM_SIZE_MB 64 - -/*Env*/ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x1A0000 -#define CONFIG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CONFIG_ENV_OFFSET) - -/*Misc*/ -#define CONFIG_PREBOOT "echo U-Boot is up and runnining;" - -/*Flash*/ -#define CONFIG_SYS_FLASH_SIZE (16*1024*1024) -#define CONFIG_SYS_MAX_FLASH_SECT 131 -#define MTDIDS_DEFAULT "nor0=v5fx30t-flash" -#define MTDPARTS_DEFAULT "mtdparts=v5fx30t-flash:-(user)" - -/*Generic Configs*/ -#include <configs/xilinx-ppc440.h> - -#endif /* __CONFIG_H */
Thanks, Stefan
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- .mailmap | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/.mailmap b/.mailmap index 02dccfc1aee7..f72fef174825 100644 --- a/.mailmap +++ b/.mailmap @@ -21,6 +21,9 @@ Jagan Teki jagannadha.sutradharudu-teki@xilinx.com Markus Klotzbuecher mk@denx.de Prabhakar Kushwaha prabhakar@freescale.com Rajeshwari Shinde rajeshwari.s@samsung.com +Ricardo Ribalda Delgado ricardo.ribalda@uam.es +Ricardo Ribalda ricardo.ribalda@uam.es +Ricardo Ribalda ricardo.ribalda@gmail.com Sandeep Paulraj s-paulraj@ti.com Shaohui Xie Shaohui.Xie@freescale.com Stefan Roese <stroese>
The old mail address will stop working soon. Update it all the files
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- arch/powerpc/cpu/ppc4xx/interrupts.c | 2 +- arch/powerpc/cpu/ppc4xx/uic.c | 2 +- arch/powerpc/cpu/ppc4xx/xilinx_irq.c | 2 +- arch/powerpc/include/asm/interrupt.h | 2 +- arch/powerpc/include/asm/xilinx_irq.h | 2 +- board/xilinx/ppc405-generic/MAINTAINERS | 2 +- board/xilinx/ppc405-generic/Makefile | 2 +- board/xilinx/ppc405-generic/xilinx_ppc405_generic.c | 2 +- board/xilinx/ppc405-generic/xparameters.h | 2 +- board/xilinx/ppc440-generic/MAINTAINERS | 2 +- board/xilinx/ppc440-generic/Makefile | 2 +- board/xilinx/ppc440-generic/init.S | 2 +- board/xilinx/ppc440-generic/xilinx_ppc440_generic.c | 2 +- board/xilinx/ppc440-generic/xparameters.h | 2 +- drivers/hwmon/adt7460.c | 2 +- include/configs/xilinx-ppc.h | 2 +- include/configs/xilinx-ppc405-generic.h | 2 +- include/configs/xilinx-ppc405.h | 2 +- include/configs/xilinx-ppc440-generic.h | 2 +- include/configs/xilinx-ppc440.h | 2 +- 20 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/interrupts.c b/arch/powerpc/cpu/ppc4xx/interrupts.c index d9b565468b60..45997d6eae06 100644 --- a/arch/powerpc/cpu/ppc4xx/interrupts.c +++ b/arch/powerpc/cpu/ppc4xx/interrupts.c @@ -9,7 +9,7 @@ * Travis B. Sawyer, Sandburst Corporation, tsawyer@sandburst.com * * (C) Copyright 2008 (PPC440X05 port for Virtex 5 FX) - * Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * Work supported by Qtechnology (htpp://qtec.com) * * SPDX-License-Identifier: GPL-2.0+ diff --git a/arch/powerpc/cpu/ppc4xx/uic.c b/arch/powerpc/cpu/ppc4xx/uic.c index bd955ed83ff0..fb453b1adfb5 100644 --- a/arch/powerpc/cpu/ppc4xx/uic.c +++ b/arch/powerpc/cpu/ppc4xx/uic.c @@ -9,7 +9,7 @@ * Travis B. Sawyer, Sandburst Corporation, tsawyer@sandburst.com * * (C) Copyright 2008 (PPC440X05 port for Virtex 5 FX) - * Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * Work supported by Qtechnology (htpp://qtec.com) * * SPDX-License-Identifier: GPL-2.0+ diff --git a/arch/powerpc/cpu/ppc4xx/xilinx_irq.c b/arch/powerpc/cpu/ppc4xx/xilinx_irq.c index 71e1be02a678..1a2e917eb23b 100644 --- a/arch/powerpc/cpu/ppc4xx/xilinx_irq.c +++ b/arch/powerpc/cpu/ppc4xx/xilinx_irq.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * Based on interrupts.c Wolfgang Denk-DENX Software Engineering-wd@denx.de * SPDX-License-Identifier: GPL-2.0+ diff --git a/arch/powerpc/include/asm/interrupt.h b/arch/powerpc/include/asm/interrupt.h index 1a6a93384e76..9f370dd83c9d 100644 --- a/arch/powerpc/include/asm/interrupt.h +++ b/arch/powerpc/include/asm/interrupt.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * Based on interrupts.c Wolfgang Denk-DENX Software Engineering-wd@denx.de * diff --git a/arch/powerpc/include/asm/xilinx_irq.h b/arch/powerpc/include/asm/xilinx_irq.h index 333a0372b788..5766bde366ce 100644 --- a/arch/powerpc/include/asm/xilinx_irq.h +++ b/arch/powerpc/include/asm/xilinx_irq.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * Based on interrupts.c Wolfgang Denk-DENX Software Engineering-wd@denx.de * SPDX-License-Identifier: GPL-2.0+ diff --git a/board/xilinx/ppc405-generic/MAINTAINERS b/board/xilinx/ppc405-generic/MAINTAINERS index 2b0c98dc8b73..ba48f50c29bf 100644 --- a/board/xilinx/ppc405-generic/MAINTAINERS +++ b/board/xilinx/ppc405-generic/MAINTAINERS @@ -1,5 +1,5 @@ PPC405-GENERIC BOARD -M: Ricardo Ribalda ricardo.ribalda@uam.es +M: Ricardo Ribalda ricardo.ribalda@gmail.com S: Maintained F: board/xilinx/ppc405-generic/ F: include/configs/xilinx-ppc405-generic.h diff --git a/board/xilinx/ppc405-generic/Makefile b/board/xilinx/ppc405-generic/Makefile index c9da87065747..922946d72341 100644 --- a/board/xilinx/ppc405-generic/Makefile +++ b/board/xilinx/ppc405-generic/Makefile @@ -3,7 +3,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # (C) Copyright 2008 -# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es +# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com # Work supported by Qtechnology http://www.qtec.com # # SPDX-License-Identifier: GPL-2.0+ diff --git a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c index e3dd468f1eb3..8b10dbaed149 100644 --- a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c +++ b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * * SPDX-License-Identifier: GPL-2.0+ diff --git a/board/xilinx/ppc405-generic/xparameters.h b/board/xilinx/ppc405-generic/xparameters.h index f0ff78fca565..e61040785937 100644 --- a/board/xilinx/ppc405-generic/xparameters.h +++ b/board/xilinx/ppc405-generic/xparameters.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * based on xparameters-ml507.h by Xilinx * diff --git a/board/xilinx/ppc440-generic/MAINTAINERS b/board/xilinx/ppc440-generic/MAINTAINERS index 2d0b11af914b..0258c8204ae1 100644 --- a/board/xilinx/ppc440-generic/MAINTAINERS +++ b/board/xilinx/ppc440-generic/MAINTAINERS @@ -1,5 +1,5 @@ PPC440-GENERIC BOARD -M: Ricardo Ribalda ricardo.ribalda@uam.es +M: Ricardo Ribalda ricardo.ribalda@gmail.com S: Maintained F: board/xilinx/ppc440-generic/ F: include/configs/xilinx-ppc440-generic.h diff --git a/board/xilinx/ppc440-generic/Makefile b/board/xilinx/ppc440-generic/Makefile index 0acd95d6e4e2..5ca57a9b0d54 100644 --- a/board/xilinx/ppc440-generic/Makefile +++ b/board/xilinx/ppc440-generic/Makefile @@ -3,7 +3,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # (C) Copyright 2008 -# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es +# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com # Work supported by Qtechnology http://www.qtec.com # # SPDX-License-Identifier: GPL-2.0+ diff --git a/board/xilinx/ppc440-generic/init.S b/board/xilinx/ppc440-generic/init.S index 4598a376843a..f9ff35f51b7a 100644 --- a/board/xilinx/ppc440-generic/init.S +++ b/board/xilinx/ppc440-generic/init.S @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * * SPDX-License-Identifier: GPL-2.0+ diff --git a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c index 74df2f4ff785..3718a76f8022 100644 --- a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c +++ b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * * SPDX-License-Identifier: GPL-2.0+ diff --git a/board/xilinx/ppc440-generic/xparameters.h b/board/xilinx/ppc440-generic/xparameters.h index e30e592bbe12..3c135ec42b37 100644 --- a/board/xilinx/ppc440-generic/xparameters.h +++ b/board/xilinx/ppc440-generic/xparameters.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * based on xparameters-ml507.h by Xilinx * diff --git a/drivers/hwmon/adt7460.c b/drivers/hwmon/adt7460.c index fd05c1779482..9b2c5b69ce55 100644 --- a/drivers/hwmon/adt7460.c +++ b/drivers/hwmon/adt7460.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid, ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid, ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * SPDX-License-Identifier: GPL-2.0+ */ diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index eb400d096074..876750b13820 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * * (C) Copyright 2008 diff --git a/include/configs/xilinx-ppc405-generic.h b/include/configs/xilinx-ppc405-generic.h index 40fa0878a43f..bdb9372abc45 100644 --- a/include/configs/xilinx-ppc405-generic.h +++ b/include/configs/xilinx-ppc405-generic.h @@ -1,7 +1,7 @@ /* * * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * * (C) Copyright 2008 diff --git a/include/configs/xilinx-ppc405.h b/include/configs/xilinx-ppc405.h index a0151fe8f4cb..dcfe56e0483b 100644 --- a/include/configs/xilinx-ppc405.h +++ b/include/configs/xilinx-ppc405.h @@ -1,7 +1,7 @@ /* * * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * * (C) Copyright 2008 diff --git a/include/configs/xilinx-ppc440-generic.h b/include/configs/xilinx-ppc440-generic.h index 95b883407839..769a1deb8a6f 100644 --- a/include/configs/xilinx-ppc440-generic.h +++ b/include/configs/xilinx-ppc440-generic.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * SPDX-License-Identifier: GPL-2.0+ */ diff --git a/include/configs/xilinx-ppc440.h b/include/configs/xilinx-ppc440.h index f45700878ecd..f521387d2289 100644 --- a/include/configs/xilinx-ppc440.h +++ b/include/configs/xilinx-ppc440.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com * This work has been supported by: QTechnology http://qtec.com/ * SPDX-License-Identifier: GPL-2.0+ */
As a result of the specific board removal, the Makefiles can be simplified.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- board/xilinx/ppc405-generic/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/xilinx/ppc405-generic/Makefile b/board/xilinx/ppc405-generic/Makefile index 922946d72341..2800f6862640 100644 --- a/board/xilinx/ppc405-generic/Makefile +++ b/board/xilinx/ppc405-generic/Makefile @@ -9,4 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += ../../xilinx/ppc405-generic/xilinx_ppc405_generic.o +obj-y += xilinx_ppc405_generic.o
Thanks, Stefan
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- board/xilinx/ppc440-generic/Makefile | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/xilinx/ppc440-generic/Makefile b/board/xilinx/ppc440-generic/Makefile index 5ca57a9b0d54..4d5f41029ac6 100644 --- a/board/xilinx/ppc440-generic/Makefile +++ b/board/xilinx/ppc440-generic/Makefile @@ -9,5 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += ../../xilinx/ppc440-generic/xilinx_ppc440_generic.o -extra-y += ../../xilinx/ppc440-generic/init.o +obj-y += xilinx_ppc440_generic.o +extra-y += init.o
Thanks, Stefan
Remove redundant defconfig file. Boot via flash can be configured via Kconfig.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- configs/xilinx-ppc440-generic_flash_defconfig | 8 -------- 1 file changed, 8 deletions(-) delete mode 100644 configs/xilinx-ppc440-generic_flash_defconfig
diff --git a/configs/xilinx-ppc440-generic_flash_defconfig b/configs/xilinx-ppc440-generic_flash_defconfig deleted file mode 100644 index 629903344b77..000000000000 --- a/configs/xilinx-ppc440-generic_flash_defconfig +++ /dev/null @@ -1,8 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_XILINX_PPC440_GENERIC=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set
Thanks, Stefan
Thanks, Stefan
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- configs/xilinx-ppc405-generic_flash_defconfig | 8 -------- 1 file changed, 8 deletions(-) delete mode 100644 configs/xilinx-ppc405-generic_flash_defconfig
diff --git a/configs/xilinx-ppc405-generic_flash_defconfig b/configs/xilinx-ppc405-generic_flash_defconfig deleted file mode 100644 index 37084fb0a82d..000000000000 --- a/configs/xilinx-ppc405-generic_flash_defconfig +++ /dev/null @@ -1,8 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_XILINX_PPC405_GENERIC=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set
Thanks, Stefan
Now that there is only one header file for all ppc440 files, merge header files.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- include/configs/xilinx-ppc440-generic.h | 3 ++- include/configs/xilinx-ppc440.h | 17 ----------------- 2 files changed, 2 insertions(+), 18 deletions(-) delete mode 100644 include/configs/xilinx-ppc440.h
diff --git a/include/configs/xilinx-ppc440-generic.h b/include/configs/xilinx-ppc440-generic.h index 769a1deb8a6f..47bc4aec148e 100644 --- a/include/configs/xilinx-ppc440-generic.h +++ b/include/configs/xilinx-ppc440-generic.h @@ -10,6 +10,7 @@
/*CPU*/ #define CONFIG_440 1 +#define CONFIG_XILINX_440 1 #define CONFIG_XILINX_PPC440_GENERIC 1 #include "../board/xilinx/ppc440-generic/xparameters.h"
@@ -33,6 +34,6 @@ #define MTDPARTS_DEFAULT "mtdparts=ml507-flash:-(user)"
/*Generic Configs*/ -#include <configs/xilinx-ppc440.h> +#include <configs/xilinx-ppc.h>
#endif /* __CONFIG_H */ diff --git a/include/configs/xilinx-ppc440.h b/include/configs/xilinx-ppc440.h deleted file mode 100644 index f521387d2289..000000000000 --- a/include/configs/xilinx-ppc440.h +++ /dev/null @@ -1,17 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com - * This work has been supported by: QTechnology http://qtec.com/ - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#ifndef __CONFIG_GEN_H -#define __CONFIG_GEN_H - -/*CPU*/ -#define CONFIG_440 1 -#define CONFIG_XILINX_440 1 - -#include <configs/xilinx-ppc.h> - -#endif /* __CONFIG_H */
Thanks, Stefan
Now that there is only one header file for all ppc405 files, merge header files.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- include/configs/xilinx-ppc405-generic.h | 5 ++++- include/configs/xilinx-ppc405.h | 22 ---------------------- 2 files changed, 4 insertions(+), 23 deletions(-) delete mode 100644 include/configs/xilinx-ppc405.h
diff --git a/include/configs/xilinx-ppc405-generic.h b/include/configs/xilinx-ppc405-generic.h index bdb9372abc45..e2d189d0ac60 100644 --- a/include/configs/xilinx-ppc405-generic.h +++ b/include/configs/xilinx-ppc405-generic.h @@ -14,6 +14,9 @@
#include "../board/xilinx/ppc405-generic/xparameters.h"
+#define CONFIG_405 1 +#define CONFIG_XILINX_405 1 + /* sdram */ #define CONFIG_SYS_SDRAM_SIZE_MB 256
@@ -37,5 +40,5 @@ #define MTDIDS_DEFAULT "nor0=ppc405-flash" #define MTDPARTS_DEFAULT "mtdpartsa=ppc405-flash:-(user)"
-#include <configs/xilinx-ppc405.h> +#include <configs/xilinx-ppc.h> #endif /* __CONFIG_H */ diff --git a/include/configs/xilinx-ppc405.h b/include/configs/xilinx-ppc405.h deleted file mode 100644 index dcfe56e0483b..000000000000 --- a/include/configs/xilinx-ppc405.h +++ /dev/null @@ -1,22 +0,0 @@ -/* - * - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@gmail.com - * This work has been supported by: QTechnology http://qtec.com/ - * - * (C) Copyright 2008 - * Georg Schardt schardt@team-ctech.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* cpu parameter */ -#define CONFIG_405 1 -#define CONFIG_XILINX_405 1 - -#include <configs/xilinx-ppc.h> - -#endif
Thanks, Stefan
-Remove UART address (It is now part of the dts). -Include dummy ns16550 clock -Fix address to last test
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- board/xilinx/ppc405-generic/xparameters.h | 5 ++--- board/xilinx/ppc440-generic/xparameters.h | 9 ++++----- 2 files changed, 6 insertions(+), 8 deletions(-)
diff --git a/board/xilinx/ppc405-generic/xparameters.h b/board/xilinx/ppc405-generic/xparameters.h index e61040785937..c3df9e51091f 100644 --- a/board/xilinx/ppc405-generic/xparameters.h +++ b/board/xilinx/ppc405-generic/xparameters.h @@ -14,12 +14,11 @@ #define XPAR_IIC_EEPROM_BASEADDR 0x81600000 #define XPAR_INTC_0_BASEADDR 0x81800000 #define XPAR_SPI_0_BASEADDR 0x83400000 -#define XPAR_UARTLITE_0_BASEADDR 0x84000000 #define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 #define XPAR_PLB_CLOCK_FREQ_HZ 100000000 #define XPAR_CORE_CLOCK_FREQ_HZ 400000000 -#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 -#define XPAR_UARTLITE_0_BAUDRATE 9600 +#define XPAR_INTC_MAX_NUM_INTR_INPUTS 32 #define XPAR_SPI_0_NUM_TRANSFER_BITS 8 +#define XPAR_UARTNS550_0_CLOCK_FREQ_HZ 100000000
#endif diff --git a/board/xilinx/ppc440-generic/xparameters.h b/board/xilinx/ppc440-generic/xparameters.h index 3c135ec42b37..9685560673ab 100644 --- a/board/xilinx/ppc440-generic/xparameters.h +++ b/board/xilinx/ppc440-generic/xparameters.h @@ -12,12 +12,11 @@
#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 #define XPAR_IIC_EEPROM_BASEADDR 0x81600000 -#define XPAR_INTC_0_BASEADDR 0x81800000 -#define XPAR_UARTLITE_0_BASEADDR 0x84000000 -#define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 +#define XPAR_INTC_0_BASEADDR 0x87000000 +#define XPAR_FLASH_MEM0_BASEADDR 0xF0000000 #define XPAR_PLB_CLOCK_FREQ_HZ 100000000 #define XPAR_CORE_CLOCK_FREQ_HZ 400000000 -#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 -#define XPAR_UARTLITE_0_BAUDRATE 9600 +#define XPAR_INTC_MAX_NUM_INTR_INPUTS 32 +#define XPAR_UARTNS550_0_CLOCK_FREQ_HZ 100000000
#endif
Thanks, Stefan
Add device tree example file for xilinx-ppc440-generic and xilinx-ppc405-generic
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- arch/powerpc/dts/Makefile | 2 ++ arch/powerpc/dts/xilinx-ppc405-generic.dts | 13 +++++++++++++ arch/powerpc/dts/xilinx-ppc440-generic.dts | 13 +++++++++++++ 3 files changed, 28 insertions(+) create mode 100644 arch/powerpc/dts/xilinx-ppc405-generic.dts create mode 100644 arch/powerpc/dts/xilinx-ppc440-generic.dts
diff --git a/arch/powerpc/dts/Makefile b/arch/powerpc/dts/Makefile index 5d9f5c2822b2..80b4c0c4e374 100644 --- a/arch/powerpc/dts/Makefile +++ b/arch/powerpc/dts/Makefile @@ -3,6 +3,8 @@ #
dtb-$(CONFIG_TARGET_CANYONLANDS) += arches.dtb canyonlands.dtb glacier.dtb +dtb-$(CONFIG_TARGET_XILINX_PPC440_GENERIC) += xilinx-ppc440-generic.dtb +dtb-$(CONFIG_TARGET_XILINX_PPC405_GENERIC) += xilinx-ppc405-generic.dtb
targets += $(dtb-y)
diff --git a/arch/powerpc/dts/xilinx-ppc405-generic.dts b/arch/powerpc/dts/xilinx-ppc405-generic.dts new file mode 100644 index 000000000000..23c89335831e --- /dev/null +++ b/arch/powerpc/dts/xilinx-ppc405-generic.dts @@ -0,0 +1,13 @@ +/dts-v1/; +/ { + #address-cells = <1>; + #size-cells = <1>; + aliases { + console = &uart0; + } ; + uart0: serial@84000000 { + compatible = "xlnx,xps-uartlite-1.00.a"; + interrupts = <0 0>; + reg = <0x84000000 0x10000>; + }; +} ; diff --git a/arch/powerpc/dts/xilinx-ppc440-generic.dts b/arch/powerpc/dts/xilinx-ppc440-generic.dts new file mode 100644 index 000000000000..faae9fffcd0e --- /dev/null +++ b/arch/powerpc/dts/xilinx-ppc440-generic.dts @@ -0,0 +1,13 @@ +/dts-v1/; +/ { + #address-cells = <1>; + #size-cells = <1>; + aliases { + console = &uart0; + } ; + uart0: serial@8b000000 { + compatible = "xlnx,xps-uartlite-1.00.a"; + interrupts = <0 0>; + reg = <0x8b000000 0x10000>; + }; +} ;
Hi Ricardo,
targets += $(dtb-y)
nits: should have a blank line here
#size-cells = <1>;
nits: ditto
aliases {
console = &uart0;
nits: ditto
interrupts = <0 0>;
#size-cells = <1>;
aliases {
console = &uart0;
interrupts = <0 0>;
BTW no /chosen node?
Regards, Bin
On Tue, Jan 26, 2016 at 1:21 PM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Ricardo,
targets += $(dtb-y)
#size-cells = <1>;
nits: ditto
aliases {
console = &uart0;
nits: ditto
interrupts = <0 0>;
#size-cells = <1>;
aliases {
console = &uart0;
interrupts = <0 0>;
Apparently it is not needed
Regards, Bin
Thanks, Stefan
-Fix typos (runnining -> running) -Increase default size
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- include/configs/xilinx-ppc405-generic.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/configs/xilinx-ppc405-generic.h b/include/configs/xilinx-ppc405-generic.h index e2d189d0ac60..6182b0e7cf05 100644 --- a/include/configs/xilinx-ppc405-generic.h +++ b/include/configs/xilinx-ppc405-generic.h @@ -29,16 +29,16 @@ #define CONFIG_ENV_OVERWRITE 1
/*Misc*/ -#define CONFIG_PREBOOT "echo U-Boot is up and runnining;" +#define CONFIG_PREBOOT "echo U-Boot is up and running;"
/*Flash*/ -#define CONFIG_SYS_FLASH_BASE XPAR_FLASH_MEM0_BASEADDR -#define CONFIG_SYS_FLASH_SIZE (32*1024*1024) -#define CONFIG_SYS_MAX_FLASH_SECT 71 +#define CONFIG_SYS_FLASH_BASE XPAR_FLASH_MEM0_BASEADDR +#define CONFIG_SYS_FLASH_SIZE (128*1024*1024) +#define CONFIG_SYS_MAX_FLASH_SECT 1024 #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 -#define MTDIDS_DEFAULT "nor0=ppc405-flash" -#define MTDPARTS_DEFAULT "mtdpartsa=ppc405-flash:-(user)" +#define MTDIDS_DEFAULT "nor0=flash" +#define MTDPARTS_DEFAULT "mtdparts=flash:-(user)"
Thanks, Stefan
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- include/configs/xilinx-ppc440-generic.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/configs/xilinx-ppc440-generic.h b/include/configs/xilinx-ppc440-generic.h index 47bc4aec148e..2af5f7fc1de5 100644 --- a/include/configs/xilinx-ppc440-generic.h +++ b/include/configs/xilinx-ppc440-generic.h @@ -21,17 +21,17 @@ #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_OFFSET 0x340000 +#define CONFIG_ENV_OFFSET 0x340000 #define CONFIG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CONFIG_ENV_OFFSET)
/*Flash*/ -#define CONFIG_SYS_FLASH_SIZE (32*1024*1024) -#define CONFIG_SYS_MAX_FLASH_SECT 259 -#define MTDIDS_DEFAULT "nor0=ml507-flash" -#define MTDPARTS_DEFAULT "mtdparts=ml507-flash:-(user)" +#define CONFIG_SYS_FLASH_SIZE (128*1024*1024) +#define CONFIG_SYS_MAX_FLASH_SECT 1024 +#define MTDIDS_DEFAULT "nor0=flash" +#define MTDPARTS_DEFAULT "mtdparts=flash:-(user)"
/*Generic Configs*/ #include <configs/xilinx-ppc.h>
Thanks, Stefan
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- arch/powerpc/cpu/ppc4xx/Kconfig | 8 ++++++++ board/xilinx/ppc405-generic/xilinx_ppc405_generic.c | 4 ++++ board/xilinx/ppc440-generic/xilinx_ppc440_generic.c | 4 ++++ configs/xilinx-ppc405-generic_defconfig | 8 ++++++++ configs/xilinx-ppc440-generic_defconfig | 12 ++++++++---- drivers/serial/Kconfig | 2 +- include/configs/xilinx-ppc.h | 20 ++++---------------- 7 files changed, 37 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index 3959585d44c3..36af1b9419b0 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -111,9 +111,17 @@ config TARGET_XPEDITE1000
config TARGET_XILINX_PPC405_GENERIC bool "Support xilinx-ppc405-generic" + select SUPPORT_SPL + select OF_CONTROL + select DM + select DM_SERIAL
config TARGET_XILINX_PPC440_GENERIC bool "Support xilinx-ppc440-generic" + select SUPPORT_SPL + select OF_CONTROL + select DM + select DM_SERIAL
endchoice
diff --git a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c index 8b10dbaed149..32105a823b0b 100644 --- a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c +++ b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c @@ -46,3 +46,7 @@ void __get_sys_info(sys_info_t *sysInfo) return; } void get_sys_info(sys_info_t *) __attribute__((weak, alias("__get_sys_info"))); + +int get_serial_clock(void){ + return XPAR_UARTNS550_0_CLOCK_FREQ_HZ; +} diff --git a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c index 3718a76f8022..f92a3033e14d 100644 --- a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c +++ b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c @@ -39,3 +39,7 @@ void __get_sys_info(sys_info_t *sysInfo) return; } void get_sys_info(sys_info_t *) __attribute__((weak, alias("__get_sys_info"))); + +int get_serial_clock(void){ + return XPAR_UARTNS550_0_CLOCK_FREQ_HZ; +} diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index 53fafc324e68..e7132cd61152 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -7,3 +7,11 @@ CONFIG_SYS_PROMPT="xlx-ppc405:/# " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_MALLOC_SIMPLE=y +CONFIG_XILINX_UARTLITE=y +CONFIG_SYS_NS16550=y +CONFIG_OF_EMBED=y +CONFIG_OF_CONTROL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc440-generic" diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index 79be48a9955e..c66357e08724 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -3,7 +3,11 @@ CONFIG_4xx=y CONFIG_TARGET_XILINX_PPC440_GENERIC=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1" CONFIG_SYS_PROMPT="board:/# " -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_CMD_NFS is not set +CONFIG_SYS_MALLOC_SIMPLE=y +CONFIG_XILINX_UARTLITE=y +CONFIG_SYS_NS16550=y +CONFIG_OF_EMBED=y +CONFIG_OF_CONTROL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc440-generic" diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 82f52dd12330..197686483cc7 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -252,7 +252,7 @@ config UNIPHIER_SERIAL
config XILINX_UARTLITE bool "Xilinx Uarlite support" - depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP) + depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP || 4xx) help If you have a Xilinx based board and want to use the uartlite serial ports, say Y to this option. If unsure, say N. diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 876750b13820..d01d88b33f4d 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -101,22 +101,10 @@ #define CONFIG_SYS_NO_FLASH #endif
-/* serial communication */ -#ifdef XPAR_UARTLITE_0_BASEADDR -#define CONFIG_XILINX_UARTLITE -#define XILINX_UARTLITE_BASEADDR XPAR_UARTLITE_0_BASEADDR -#define CONFIG_BAUDRATE XPAR_UARTLITE_0_BAUDRATE -#define CONFIG_SYS_BAUDRATE_TABLE { CONFIG_BAUDRATE } -#else -#ifdef XPAR_UARTNS550_0_BASEADDR -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 4 -#define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_NS16550_COM1 XPAR_UARTNS550_0_BASEADDR -#define CONFIG_SYS_NS16550_CLK XPAR_UARTNS550_0_CLOCK_FREQ_HZ +#define CONFIG_OF_LIBFDT 1 #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 115200 } -#endif -#endif +/* The following table includes the supported baudrates */ +# define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
Thanks, Stefan
Now that the specific boards have been removed there is no need to maintain the weak functions.
Fix also CamelCase to make checkpatch happy
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- .../xilinx/ppc405-generic/xilinx_ppc405_generic.c | 22 ++++++++-------------- 1 file changed, 8 insertions(+), 14 deletions(-)
diff --git a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c index 32105a823b0b..5c19ac0e6a34 100644 --- a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c +++ b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c @@ -10,42 +10,36 @@ #include <common.h> #include <asm/processor.h>
-ulong __get_PCI_freq(void) +ulong get_PCI_freq(void) { return 0; }
-ulong get_PCI_freq(void) __attribute__((weak, alias("__get_PCI_freq"))); - -int __board_pre_init(void) +int board_pre_init(void) { return 0; } -int board_pre_init(void) __attribute__((weak, alias("__board_pre_init")));
-int __checkboard(void) +int checkboard(void) { puts("Xilinx PPC405 Generic Board\n"); return 0; } -int checkboard(void) __attribute__((weak, alias("__checkboard")));
-phys_size_t __initdram(int board_type) +phys_size_t initdram(int board_type) { return get_ram_size(XPAR_DDR2_SDRAM_MEM_BASEADDR, CONFIG_SYS_SDRAM_SIZE_MB * 1024 * 1024); } -phys_size_t initdram(int) __attribute__((weak, alias("__initdram")));
-void __get_sys_info(sys_info_t *sysInfo) +void get_sys_info(sys_info_t *sys_info) { - sysInfo->freqProcessor = XPAR_CORE_CLOCK_FREQ_HZ; - sysInfo->freqPLB = XPAR_PLB_CLOCK_FREQ_HZ; - sysInfo->freqPCI = 0; + sys_info->freqProcessor = XPAR_CORE_CLOCK_FREQ_HZ; + sys_info->freqPLB = XPAR_PLB_CLOCK_FREQ_HZ; + sys_info->freqPCI = 0;
return; } -void get_sys_info(sys_info_t *) __attribute__((weak, alias("__get_sys_info")));
int get_serial_clock(void){ return XPAR_UARTNS550_0_CLOCK_FREQ_HZ;
Thanks, Stefan
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- board/xilinx/ppc440-generic/xilinx_ppc440_generic.c | 18 +++++++----------- 1 file changed, 7 insertions(+), 11 deletions(-)
diff --git a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c index f92a3033e14d..52c63f20583e 100644 --- a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c +++ b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c @@ -10,35 +10,31 @@ #include <common.h> #include <asm/processor.h>
-int __checkboard(void) +int checkboard(void) { puts("Xilinx PPC440 Generic Board\n"); return 0; } -int checkboard(void) __attribute__((weak, alias("__checkboard")));
Thanks, Stefan
board_pre_init was not called because CONFIG_BOARD_EARLY_INIT_F was not set. Remove unused function.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- board/xilinx/ppc405-generic/xilinx_ppc405_generic.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c index 5c19ac0e6a34..3729f07624a3 100644 --- a/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c +++ b/board/xilinx/ppc405-generic/xilinx_ppc405_generic.c @@ -15,11 +15,6 @@ ulong get_PCI_freq(void) return 0; }
-int board_pre_init(void) -{ - return 0; -} - int checkboard(void) { puts("Xilinx PPC405 Generic Board\n");
Thanks, Stefan
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- board/xilinx/ppc440-generic/xilinx_ppc440_generic.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c index 52c63f20583e..0e3ab94e31ef 100644 --- a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c +++ b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c @@ -10,11 +10,6 @@ #include <common.h> #include <asm/processor.h>
-int board_pre_init(void) -{ - return 0; -} - int checkboard(void) { puts("Xilinx PPC440 Generic Board\n");
Thanks, Stefan
Size of this snprintf "lltemac.%lx" is bigger than 16 characters. Replacing it with "ll_tem.%lx"
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- drivers/net/xilinx_ll_temac.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c index 7cc86571e495..ca09546ab59f 100644 --- a/drivers/net/xilinx_ll_temac.c +++ b/drivers/net/xilinx_ll_temac.c @@ -303,7 +303,8 @@ int xilinx_ll_temac_initialize(bd_t *bis, struct ll_temac_info *devinf) if (devinf->devname) { strncpy(dev->name, devinf->devname, sizeof(dev->name)); } else { - snprintf(dev->name, sizeof(dev->name), "lltemac.%lx", devinf->base_addr); + snprintf(dev->name, sizeof(dev->name), "ll_tem.%lx", + devinf->base_addr); devinf->devname = dev->name; }
... and added to my TODO list to check over everyone else too.
If the xparameters file contains a LL_TEMAC definition compile its driver and the net commands.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- .../xilinx/ppc440-generic/xilinx_ppc440_generic.c | 22 ++++++++++++++++++++++ board/xilinx/ppc440-generic/xparameters.h | 4 ++++ configs/xilinx-ppc440-generic_defconfig | 5 +++++ include/configs/xilinx-ppc440-generic.h | 10 ++++++++++ 4 files changed, 41 insertions(+)
diff --git a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c index 0e3ab94e31ef..d8233529304d 100644 --- a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c +++ b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c @@ -8,6 +8,7 @@
#include <config.h> #include <common.h> +#include <netdev.h> #include <asm/processor.h>
int checkboard(void) @@ -34,3 +35,24 @@ void get_sys_info(sys_info_t *sys_info) int get_serial_clock(void){ return XPAR_UARTNS550_0_CLOCK_FREQ_HZ; } + +int board_eth_init(bd_t *bis) +{ + int ret = 0; + + puts("Init xilinx temac\n"); +#ifdef XPAR_LLTEMAC_0_BASEADDR + ret |= xilinx_ll_temac_eth_init(bis, XPAR_LLTEMAC_0_BASEADDR, + XILINX_LL_TEMAC_M_SDMA_DCR | XILINX_LL_TEMAC_M_SDMA_PLB, + XPAR_LLTEMAC_0_LLINK_CONNECTED_BASEADDR); + +#endif + +#ifdef XPAR_LLTEMAC_1_BASEADDR + ret |= xilinx_ll_temac_eth_init(bis, XPAR_LLTEMAC_1_BASEADDR, + XILINX_LL_TEMAC_M_SDMA_DCR | XILINX_LL_TEMAC_M_SDMA_PLB, + XPAR_LLTEMAC_1_LLINK_CONNECTED_BASEADDR); +#endif + + return ret; +} diff --git a/board/xilinx/ppc440-generic/xparameters.h b/board/xilinx/ppc440-generic/xparameters.h index 9685560673ab..b45a6a1d7668 100644 --- a/board/xilinx/ppc440-generic/xparameters.h +++ b/board/xilinx/ppc440-generic/xparameters.h @@ -18,5 +18,9 @@ #define XPAR_CORE_CLOCK_FREQ_HZ 400000000 #define XPAR_INTC_MAX_NUM_INTR_INPUTS 32 #define XPAR_UARTNS550_0_CLOCK_FREQ_HZ 100000000 +#define XPAR_LLTEMAC_0_LLINK_CONNECTED_BASEADDR 0x80 +#define XPAR_LLTEMAC_1_LLINK_CONNECTED_BASEADDR 0x98 +#define XPAR_LLTEMAC_0_BASEADDR 0x83000000 +#define XPAR_LLTEMAC_1_BASEADDR 0x83000040
#endif diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index c66357e08724..64b55ee1359e 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -11,3 +11,8 @@ CONFIG_OF_CONTROL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc440-generic" +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_NETCONSOLE=y + diff --git a/include/configs/xilinx-ppc440-generic.h b/include/configs/xilinx-ppc440-generic.h index 2af5f7fc1de5..8b9d37f42e03 100644 --- a/include/configs/xilinx-ppc440-generic.h +++ b/include/configs/xilinx-ppc440-generic.h @@ -33,6 +33,16 @@ #define MTDIDS_DEFAULT "nor0=flash" #define MTDPARTS_DEFAULT "mtdparts=flash:-(user)"
+/*Net*/ +#ifdef XPAR_LLTEMAC_0_BASEADDR +#define CONFIG_XILINX_LL_TEMAC +#define CONFIG_MII +#define CONFIG_PHYLIB +#define CONFIG_PHY_MARVELL +#define CONFIG_NET_RANDOM_ETHADDR +#define CONFIG_LIB_RAND +#endif + /*Generic Configs*/ #include <configs/xilinx-ppc.h>
Hi Ricardo,
int ret = 0;
No DM ethernet driver for LLTEMAC?
return ret;
+/*Net*/
nits: /* Net */
I believe we can move part of these into boards' defconfig files, and if with DM ethernet plus OF control we can always enable the driver.
Regards, Bin
Hello Bin
Hi Ricardo,
int ret = 0;
Not as far as I know
return ret;
+/*Net*/
nits: /* Net */
I want to build it only when the core is present. This is checked with the definitions from the xparameters.h file, obtained by the fpga syntesis tool.
Regards, Bin
Thanks!
On 26.1.2016 13:43, Ricardo Ribalda Delgado wrote:
Hello Bin
Hi Ricardo,
int ret = 0;
I have removed ll_temac support from Microblaze and as we discussed before we are not going to support ppc platforms. That's why if someone wants to use this driver it has to invest time to move it to DM or will be removed at some point in future.
Thanks, Michal
hello
We are using the driver and can take a look if we can port it to DM. But it wont be in this or next week sorry.
Regards!
Hello Bin
Hi Ricardo,
int ret = 0;
Thanks, Michal
-- Michal Simek, Ing. (M.Eng), OpenPGP -> KeyID: FE3D1F91 w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel - Microblaze cpu - http://www.monstr.eu/fdt/ Maintainer of Linux kernel - Xilinx Zynq ARM architecture Microblaze U-BOOT custodian and responsible for u-boot arm zynq platform
On 26.1.2016 15:37, Ricardo Ribalda Delgado wrote:
hello
That's not a problem at all. Currently it wired just to xilinx ppc platforms. No pressure on it at all. Simon probably knows when all these non DM drivers will go away.
Thanks, Michal
On 26.1.2016 11:24, Ricardo Ribalda Delgado wrote:
xilinx-ppc4xx made us of serial uartlite, which was ported to DM. This patch moves port these boards to DM.
Now that Kconfig works really well, there is no need to maintain the specific boards (fx12mm, ml507 and v5fx30teval) or their flash version.
The ppc440 boards have been wired to the ll_temac driver.
A series of cleanouts have been done.
This patchset sits on top of: http://git.denx.de/?p=u-boot/u-boot-microblaze.git;a=shortlog;h=refs/heads/m...
It has been tested on a ppc440 bard.
Hopefully Georg Schardt can test the changes on his fx12mm.
These changes can also be browset at https://github.com/ribalda/u-boot/tree/xilinx-ppc4xx-generic-dm
Regards (and thanks for your patience)!
Ricardo Ribalda (22): ppc: xilinx-ppc440: Remove support for ml507 ppc: xilinx-ppc405: Remove support for fx12mm xilinx-ppc440: Remove support for v5fx30teval .mailmap: Add all the mail alias for Ricardo Ribalda mailaddr: Update mail address ppc: pp405-generic: Simplify Makefile ppc: pp440-generic: Simplify Makefile ppc: ppc440: ppc440-generic_flash_defconfig ppc: ppc405: ppc405-generic_flash_defconfig ppc: xilinx-ppc440-generic: Cleanout header files ppc: xilinx-ppc405-generic: Cleanout header files ppc: xilinx-ppc4xx-generic: Update xparameters.h ppc: dts: Add device tree for xilix-ppc4xx-generic configs/xilinx-ppc405-generic: Typos and size configs/xilinx-ppc440-generic: Typos and size ppc: xilinx-ppc4xx: Port to DM serial ppc: xilinx_ppc405_generic: Remove weak attributes ppc: xilinx_ppc440_generic: Remove weak attributes ppc: xilinx_ppc405_generic: Remove uncalled functions ppc: xilinx_ppc440_generic: Remove uncalled functions net: xilinx_ll_temac: Fix string overflow ppc: xilinx-ppc440-generic: Wire LL_TEMAC driver
.mailmap | 3 ++ arch/powerpc/cpu/ppc4xx/Kconfig | 20 ++++----- arch/powerpc/cpu/ppc4xx/interrupts.c | 2 +- arch/powerpc/cpu/ppc4xx/uic.c | 2 +- arch/powerpc/cpu/ppc4xx/xilinx_irq.c | 2 +- arch/powerpc/dts/Makefile | 2 + arch/powerpc/dts/xilinx-ppc405-generic.dts | 13 ++++++ arch/powerpc/dts/xilinx-ppc440-generic.dts | 13 ++++++ arch/powerpc/include/asm/interrupt.h | 2 +- arch/powerpc/include/asm/xilinx_irq.h | 2 +- board/avnet/fx12mm/Kconfig | 12 ------ board/avnet/fx12mm/MAINTAINERS | 7 --- board/avnet/fx12mm/Makefile | 11 ----- board/avnet/fx12mm/fx12mm.c | 34 --------------- board/avnet/fx12mm/xparameters.h | 35 --------------- board/avnet/v5fx30teval/Kconfig | 12 ------ board/avnet/v5fx30teval/MAINTAINERS | 7 --- board/avnet/v5fx30teval/Makefile | 11 ----- board/avnet/v5fx30teval/v5fx30teval.c | 17 -------- board/avnet/v5fx30teval/xparameters.h | 22 ---------- board/xilinx/ml507/Kconfig | 12 ------ board/xilinx/ml507/MAINTAINERS | 7 --- board/xilinx/ml507/Makefile | 11 ----- board/xilinx/ml507/ml507.c | 17 -------- board/xilinx/ml507/xparameters.h | 23 ---------- board/xilinx/ppc405-generic/MAINTAINERS | 2 +- board/xilinx/ppc405-generic/Makefile | 4 +- .../xilinx/ppc405-generic/xilinx_ppc405_generic.c | 31 ++++++-------- board/xilinx/ppc405-generic/xparameters.h | 7 ++- board/xilinx/ppc440-generic/MAINTAINERS | 2 +- board/xilinx/ppc440-generic/Makefile | 6 +-- board/xilinx/ppc440-generic/init.S | 2 +- .../xilinx/ppc440-generic/xilinx_ppc440_generic.c | 49 ++++++++++++++------- board/xilinx/ppc440-generic/xparameters.h | 15 ++++--- configs/fx12mm_defconfig | 10 ----- configs/fx12mm_flash_defconfig | 9 ---- configs/ml507_defconfig | 9 ---- configs/ml507_flash_defconfig | 8 ---- configs/v5fx30teval_defconfig | 9 ---- configs/v5fx30teval_flash_defconfig | 8 ---- configs/xilinx-ppc405-generic_defconfig | 8 ++++ configs/xilinx-ppc405-generic_flash_defconfig | 8 ---- configs/xilinx-ppc440-generic_defconfig | 17 ++++++-- configs/xilinx-ppc440-generic_flash_defconfig | 8 ---- drivers/hwmon/adt7460.c | 2 +- drivers/net/xilinx_ll_temac.c | 3 +- drivers/serial/Kconfig | 2 +- include/configs/fx12mm.h | 50 ---------------------- include/configs/ml507.h | 38 ---------------- include/configs/v5fx30teval.h | 38 ---------------- include/configs/xilinx-ppc.h | 22 +++------- include/configs/xilinx-ppc405-generic.h | 19 ++++---- include/configs/xilinx-ppc405.h | 22 ---------- include/configs/xilinx-ppc440-generic.h | 27 ++++++++---- include/configs/xilinx-ppc440.h | 17 -------- 55 files changed, 169 insertions(+), 582 deletions(-) create mode 100644 arch/powerpc/dts/xilinx-ppc405-generic.dts create mode 100644 arch/powerpc/dts/xilinx-ppc440-generic.dts delete mode 100644 board/avnet/fx12mm/Kconfig delete mode 100644 board/avnet/fx12mm/MAINTAINERS delete mode 100644 board/avnet/fx12mm/Makefile delete mode 100644 board/avnet/fx12mm/fx12mm.c delete mode 100644 board/avnet/fx12mm/xparameters.h delete mode 100644 board/avnet/v5fx30teval/Kconfig delete mode 100644 board/avnet/v5fx30teval/MAINTAINERS delete mode 100644 board/avnet/v5fx30teval/Makefile delete mode 100644 board/avnet/v5fx30teval/v5fx30teval.c delete mode 100644 board/avnet/v5fx30teval/xparameters.h delete mode 100644 board/xilinx/ml507/Kconfig delete mode 100644 board/xilinx/ml507/MAINTAINERS delete mode 100644 board/xilinx/ml507/Makefile delete mode 100644 board/xilinx/ml507/ml507.c delete mode 100644 board/xilinx/ml507/xparameters.h delete mode 100644 configs/fx12mm_defconfig delete mode 100644 configs/fx12mm_flash_defconfig delete mode 100644 configs/ml507_defconfig delete mode 100644 configs/ml507_flash_defconfig delete mode 100644 configs/v5fx30teval_defconfig delete mode 100644 configs/v5fx30teval_flash_defconfig delete mode 100644 configs/xilinx-ppc405-generic_flash_defconfig delete mode 100644 configs/xilinx-ppc440-generic_flash_defconfig delete mode 100644 include/configs/fx12mm.h delete mode 100644 include/configs/ml507.h delete mode 100644 include/configs/v5fx30teval.h delete mode 100644 include/configs/xilinx-ppc405.h delete mode 100644 include/configs/xilinx-ppc440.h
All looks good to me. For all Reviewed-by: Michal Simek michal.simek@xilinx.com
I need patches up to 12 to be apply first.
What's the your way to mainline? Are you sending pull request to Tom or this is going via PPC tree? Anyway I am happy to take this series as the part of my Xilinx pull request with Microblaze and zynq changes.
Thanks, Michal
Hello Michal
Thanks for your fast review :).
Usually my patches were through Stefan Roese (sorry, I forgot to add you as cc in the patchset :( ) In this case, as it depends on yuour patches I do not know what should be the right path.
Tom, Stefan what do you propose?
Regards!
Thanks, Michal
On Tue, Jan 26, 2016 at 01:14:44PM +0100, Ricardo Ribalda Delgado wrote:
Hello Michal
I would be quite happy for all of these to come in via Michal's tree. I'll try and review everything shortly as well. Thanks!
Hello Michal
I'll try to review the patches later today. Or very early tomorrow. And, if Tom also sees no problems, then I also agree to push them via Michal's tree.
Thanks, Stefan
Hello Michal
Thanks guys will wait for you and will compose that branch you are done.
Thanks, Michal
participants (5)
Bin Meng
Michal Simek
Stefan Roese
