[U-Boot] [PATCH 1/2] enable CONFIG_DISTRO_DEFAULTS for LS-CHLv2 board
Synchronize it with the LS-XHL board.
Signed-off-by: Michael Walle michael@walle.cc --- configs/lschlv2_defconfig | 15 +++------------ 1 file changed, 3 insertions(+), 12 deletions(-)
diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 23e68a00ea..f2763221a1 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -4,31 +4,22 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lschlv2" +CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" +CONFIG_API=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/sda2" +CONFIG_BOOTCOMMAND="run bootcmd_${bootsource}" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y
This patch shows how to enable driver model support for the LS-CHLv2 and LS-XHL boards.
There are a couple of open questions: - do I need the u-boot,dm-pre-reloc tags in the device tree? - should mach/config.h define CONFIG_DM_SEQ_ALIAS? - how can we split this patch or are there any other pending patches which does the same and I didn't catch these.
This patch is based on the http://git.denx.de/u-boot-marvell.git (master branch) and needs the following patches, which are still pending: https://patchwork.ozlabs.org/patch/909618/ https://patchwork.ozlabs.org/patch/909617/ https://patchwork.ozlabs.org/patch/909973/
Signed-off-by: Michael Walle michael@walle.cc Tested-by: Michael Walle michael@walle.cc --- arch/arm/dts/kirkwood-lsxl.dtsi | 4 ++++ arch/arm/mach-kirkwood/include/mach/config.h | 1 - configs/lschlv2_defconfig | 3 +++ configs/lsxhl_defconfig | 3 +++ 4 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/kirkwood-lsxl.dtsi b/arch/arm/dts/kirkwood-lsxl.dtsi index 92b11c75b8..479a750d1d 100644 --- a/arch/arm/dts/kirkwood-lsxl.dtsi +++ b/arch/arm/dts/kirkwood-lsxl.dtsi @@ -8,6 +8,10 @@ stdout-path = &uart0; };
+ aliases { + spi0 = &spi0; + }; + ocp@f1000000 { pinctrl: pin-controller@10000 { pmx_power_hdd: pmx-power-hdd { diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index 98639114db..d2dc1c2e68 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -59,7 +59,6 @@ * SPI Flash configuration */ #ifdef CONFIG_CMD_SF -#define CONFIG_HARD_SPI 1 #ifndef CONFIG_ENV_SPI_BUS # define CONFIG_ENV_SPI_BUS 0 #endif diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index f2763221a1..23e57e61c5 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -23,14 +23,17 @@ CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y CONFIG_MVGBE=y CONFIG_SYS_NS16550=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index b523b68284..73e13d0880 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -23,14 +23,17 @@ CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y CONFIG_MVGBE=y CONFIG_SYS_NS16550=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y
This property is only needed for SPL build targets - which Kirkwood currently is not (AFAIK).
No. It defaults to "y" already. And we should not move options into the config headers anymore but put them into the Kconfig system instead.
I see no need to split this patch. There are the patches from Chris moving Kirkwood to device-tree - which you most likely already know. Most of them are applied.
I think there is no need to add the "Tested-by" tag for the patch author. It should be obvious that you have tested this patch.
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Please use a more descriptive patch subject next time, like:
arm: kirkwood: enable CONFIG_DISTRO_DEFAULTS for LS-CHLv2 board
Thanks, Stefan
Thanks, Stefan
Michael Walle
Stefan Roese
