[U-Boot] [PATCH] ixp/interrupts: Move conditional compilation to Makefile
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/ixp/Makefile | 3 ++- cpu/ixp/interrupts.c | 8 -------- 2 files changed, 2 insertions(+), 9 deletions(-)
diff --git a/cpu/ixp/Makefile b/cpu/ixp/Makefile index 7e98d87..a673cb1 100644 --- a/cpu/ixp/Makefile +++ b/cpu/ixp/Makefile @@ -27,9 +27,10 @@ LIB = $(obj)lib$(CPU).a
START = start.o COBJS-y += cpu.o -COBJS-y += interrupts.o ifndef CONFIG_USE_IRQ COBJS-y += timer.o +else +COBJS-y += interrupts.o endif
SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/cpu/ixp/interrupts.c b/cpu/ixp/interrupts.c index 621f31b..ee0129e 100644 --- a/cpu/ixp/interrupts.c +++ b/cpu/ixp/interrupts.c @@ -31,8 +31,6 @@
#include <common.h> #include <asm/arch/ixp425.h> - -#ifdef CONFIG_USE_IRQ #include <asm/proc-armv/ptrace.h>
/* @@ -85,20 +83,15 @@ void reset_timer (void) timestamp = 0; }
-#endif /* #ifdef CONFIG_USE_IRQ */ - -#ifdef CONFIG_USE_IRQ void do_irq (struct pt_regs *pt_regs) { int irq = next_irq();
IRQ_HANDLER[irq].m_func(IRQ_HANDLER[irq].m_data); } -#endif
int interrupt_init (void) { -#ifdef CONFIG_USE_IRQ int i;
/* install default interrupt handlers */ @@ -119,7 +112,6 @@ int interrupt_init (void)
/* enable timer irq */ *IXP425_ICMR = (1 << IXP425_TIMER_2_IRQ); -#endif
return (0); }
