[U-Boot] [PATCH] Nokia RX-51: Do not call secure PPA routine on non secure devices
Since commit 41623c91b09a0c865fab41acdaff30f060f29ad6 u-boot running in qemu is crashing in function do_omap3_emu_romcode_call(). RX-51 board uses this function for Cortex-A8 errata 430973 workaround (Set IBE bit in ACR) which is needed only on real secure device and not in qemu.
This board patch just disable calling secure PPA routine on non secure devices. Qemu implements GP device and with this patch u-boot is working in qemu again.
Signed-off-by: Pali Rohár pali.rohar@gmail.com --- board/nokia/rx51/rx51.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index b6b8ad6..08fcaf2 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -422,8 +422,12 @@ int misc_init_r(void) /* * Cortex-A8(r1p0..r1p2) errata 430973 workaround * Set IBE bit in Auxiliary Control Register + * + * Call this routine only on real secure device + * Qemu does not implement secure PPA and crash */ - omap3_update_aux_cr_secure_rx51(1 << 6, 0); + if (get_device_type() == HS_DEVICE) + omap3_update_aux_cr_secure_rx51(1 << 6, 0);
return 0; }
Acked-by: Pavel Machek pavel@ucw.cz
*/* Qemu does not implement secure PPA and crash
Hi Pali Rohár,
Have you tested this patch on a secure device (as the nokia n900)?
Regards,
Georges
return 0; }
Yes, and it is working (linux kernel was booted without problem).
On Thursday 08 January 2015 22:53:18 Georges Savoundararadj wrote:
Hi Pali Rohár,
Regards,
Georges
Signed-off-by: Pali Rohár pali.rohar@gmail.com Acked-by: Pavel Machek pavel@ucw.cz
Pali Rohár
Pavel Machek
