Re: [U-Boot-Users] [DNX#2006073042000029] [PATCH 04/08]: tsi108 on chip Ether [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006073042000029] was created:
<snip>
On Jul 28, 2006, at 4:53 AM, Zang Roy-r61911 wrote:
Tundra tsi108 on chip Ethernet controller support
Signed-off-by: Alexandre Bounine alexandreb@tundra.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
board/mpc7448hpc2/tsi108_eth.c | 1042 ++++++++++++++++++++++++++++++++++++++++ 1 files changed, 1042 insertions(+), 0 deletions(-)
It seems limiting to have drivers for a chipset under a board dir. What happens if/when future boards using the same chipset start to show up?
- k
diff --git a/board/mpc7448hpc2/tsi108_eth.c b/board/mpc7448hpc2/tsi108_eth.c new file mode 100644 index 0000000..196c4b4 --- /dev/null +++ b/board/mpc7448hpc2/tsi108_eth.c @@ -0,0 +1,1042 @@ +/
- Copyright (c) 2005 Freescale Semiconductor, Inc.
- project.
- MA 02111-1307 USA
- Description:
- Ethernet interface for Tundra TSI108 bridge chip
+#include <common.h>
+#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(CONFIG_NET_MULTI) \
- && defined(CONFIG_TSI108_ETH)
+#if !defined(CONFIG_TSI108_ETH_NUM_PORTS) || (CONFIG_TSI108_ETH_NUM_PORTS > 2) +#error "CONFIG_TSI108_ETH_NUM_PORTS must be defined as 1 or 2" +#endif
+#include <malloc.h> +#include <net.h> +#include <asm/cache.h>
+#ifdef DEBUG +#define TSI108_ETH_DEBUG 7 +#else +#define TSI108_ETH_DEBUG 0 +#endif
+#if TSI108_ETH_DEBUG > 0 +#define debug_lev(lev, fmt, args...) if (lev <= TSI108_ETH_DEBUG) printf("%s %d: " fmt, __FUNCTION__, __LINE__, ##args) +#else +#define debug_lev(lev, fmt, args...) do{}while(0) +#endif
+#define RX_PRINT_ERRORS +#define TX_PRINT_ERRORS
+#define ETH_BASE (CFG_TSI108_CSR_BASE + 0x6000)
+#define ETH_PORT_OFFSET 0x400
+#define __REG32(base, offset) (*((volatile u32 *)((char *)(base) + (offset))))
+#define reg_MAC_CONFIG_1(base) __REG32(base, 0x00000000) +#define MAC_CONFIG_1_TX_ENABLE (0x00000001) +#define MAC_CONFIG_1_SYNC_TX_ENABLE (0x00000002) +#define MAC_CONFIG_1_RX_ENABLE (0x00000004) +#define MAC_CONFIG_1_SYNC_RX_ENABLE (0x00000008)
</snip>
Your U-Boot support team
DENX Support System
