[PATCH 0/3] Add support for the GST ESPRESSOBin-Ultra board
Kerma Gérald (3): cmd: mvebu: Implement the Marvell hw_info command arm: mvebu: mvebu_armada-37xx: Define the loadaddr environment variable arm: mvebu: Initial ESPRESSOBin-Ultra board support
arch/arm/dts/Makefile | 1 + .../arm/dts/armada-3720-espressobin-ultra.dts | 202 ++++++++++++ board/Marvell/mvebu_armada-37xx/MAINTAINERS | 9 + board/Marvell/mvebu_armada-37xx/board.c | 92 +++++- cmd/mvebu/Kconfig | 23 ++ cmd/mvebu/Makefile | 2 + cmd/mvebu/hw_info.c | 312 ++++++++++++++++++ .../mvebu_espressobin-ultra-88f3720_defconfig | 92 ++++++ include/configs/mvebu_armada-37xx.h | 1 + lib/hashtable.c | 2 +- 10 files changed, 729 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-ultra.dts create mode 100644 cmd/mvebu/hw_info.c create mode 100644 configs/mvebu_espressobin-ultra-88f3720_defconfig
The hw_info command is implemented to enable parsing Marvell hw_info formatted environments. This format is often used on Marvell Armada A37XX based devices to store parameters like the board serial number, factory MAC addresses and some other information. These parameters are usually written to the flash in the factory.
Currently the command supports reading/writing parameters and dumping the current hw_info parameters. EEPROM config pattern and checksum aren't supported.
This functionality has been tested on the GST ESPRESSOBin-Ultra board successfully, both reading the stock U-Boot parameters in mainline U-Boot and reading the parameters written by this command in the stock U-Boot.
Usage example: => hw_info load => saveenv
Signed-off-by: Kerma Gérald gandalf@gk2.net Cc: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Robert Marko robert.marko@sartura.hr --- cmd/mvebu/Kconfig | 23 ++++ cmd/mvebu/Makefile | 2 + cmd/mvebu/hw_info.c | 312 ++++++++++++++++++++++++++++++++++++++++++++ lib/hashtable.c | 2 +- 4 files changed, 338 insertions(+), 1 deletion(-) create mode 100644 cmd/mvebu/hw_info.c
diff --git a/cmd/mvebu/Kconfig b/cmd/mvebu/Kconfig index 7c42c75afb..d87220d44c 100644 --- a/cmd/mvebu/Kconfig +++ b/cmd/mvebu/Kconfig @@ -9,6 +9,29 @@ config CMD_MVEBU_BUBT For details about bubt command please see the documentation in doc/mvebu/cmd/bubt.txt
+config CMD_MVEBU_HW_INFO + bool "hw_info" + depends on SPI_FLASH && ENV_IS_IN_SPI_FLASH && ARCH_MVEBU + default n + help + Enable loading of the Marvell hw_info parameters from the + SPI flash hw_info area. Parameters (usually the board serial + number and MAC addresses) are then imported into the + existing U-Boot environment. + Implementation of this command is compatible with the + original Marvell U-Boot command. Reading and writing is + supported. + EEPROM config pattern and checksum aren't supported. + +config CMD_MVEBU_HW_INFO_OFFSET + hex "Marvell hw_info SPI flash offset" + depends on CMD_MVEBU_HW_INFO + default 0x3E0000 + help + This option defines the SPI flash offset of the Marvell + hw_info area. This defaults to 0x3E0000 on most Armada + A3720 platforms. + choice prompt "Flash for image" default MVEBU_SPI_BOOT diff --git a/cmd/mvebu/Makefile b/cmd/mvebu/Makefile index ca96ad01d9..c988dca38c 100644 --- a/cmd/mvebu/Makefile +++ b/cmd/mvebu/Makefile @@ -6,3 +6,5 @@
obj-$(CONFIG_CMD_MVEBU_BUBT) += bubt.o obj-$(CONFIG_CMD_MVEBU_COMPHY_RX_TRAINING) += comphy_rx_training.o +obj-$(CONFIG_CMD_MVEBU_HW_INFO) += hw_info.o + diff --git a/cmd/mvebu/hw_info.c b/cmd/mvebu/hw_info.c new file mode 100644 index 0000000000..1ef49d78d4 --- /dev/null +++ b/cmd/mvebu/hw_info.c @@ -0,0 +1,312 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Marvell hw_info command + * Helper command for interfacing with the Marvell hw_info parameters + * + * Copyright (c) 2021 Sartura Ltd. + * Copyright (c) 2018 Marvell International Ltd. + * + * Author: Luka Kovacic luka.kovacic@sartura.hr + */ + +#include <command.h> +#include <common.h> +#include <env.h> +#include <env_internal.h> +#include <spi.h> +#include <spi_flash.h> + +#define HW_INFO_SPI_FLASH_OFFSET CONFIG_CMD_MVEBU_HW_INFO_OFFSET + +#define HW_INFO_MAX_ENV_SIZE 0x1F0 +#define HW_INFO_ENV_OFFSET 0xA +#define HW_INFO_ENV_SEP 0x20 + +#define HW_INFO_MAX_NAME_LEN 32 + +static char hw_info_allowed_parameters[][HW_INFO_MAX_NAME_LEN] = { + "pcb_slm", + "pcb_rev", + "eco_rev", + "pcb_sn", + "ethaddr", + "eth1addr", + "eth2addr", + "eth3addr", + "eth4addr", + "eth5addr", + "eth6addr", + "eth7addr", + "eth8addr", + "eth9addr", +}; + +static int hw_info_allowed_param_count = (sizeof(hw_info_allowed_parameters) / + sizeof(hw_info_allowed_parameters[0])); + +static int hw_info_check_parameter(char *name) +{ + int idx; + + for (idx = 0; idx < hw_info_allowed_param_count; idx++) { + if (strcmp(name, hw_info_allowed_parameters[idx]) == 0) + return 0; + } + + return -EINVAL; +} + +static int read_spi_flash_offset(char *buf, int offset) +{ + struct spi_flash *flash; + int ret; + + flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, + CONFIG_SF_DEFAULT_CS, + CONFIG_SF_DEFAULT_SPEED, + CONFIG_SF_DEFAULT_MODE); + + if (!flash) { + printf("Error - unable to probe SPI flash.\n"); + return -EIO; + } + + ret = spi_flash_read(flash, offset, HW_INFO_MAX_ENV_SIZE, buf); + if (ret) { + printf("Error - unable to read hw_info environment from SPI flash.\n"); + return ret; + } + + return ret; +} + +static int write_spi_flash_offset(char *buf, int offset, ssize_t size) +{ + ssize_t safe_size, erase_size; + struct spi_flash *flash; + int ret; + + flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, + CONFIG_SF_DEFAULT_CS, + CONFIG_SF_DEFAULT_SPEED, + CONFIG_SF_DEFAULT_MODE); + + if (!flash) { + printf("Error - unable to probe SPI flash.\n"); + return -EIO; + } + + safe_size = size > HW_INFO_MAX_ENV_SIZE ? HW_INFO_MAX_ENV_SIZE : size; + erase_size = safe_size + + (flash->erase_size - safe_size % flash->erase_size); + ret = spi_flash_erase(flash, HW_INFO_SPI_FLASH_OFFSET, erase_size); + if (ret) { + printf("Error - unable to erase the hw_info area on SPI flash.\n"); + return ret; + } + ret = spi_flash_write(flash, offset, safe_size, buf); + if (ret) { + printf("Error - unable to write hw_info parameters to SPI flash.\n"); + return ret; + } + + return ret; +} + +static int cmd_hw_info_dump(void) +{ + char buffer[HW_INFO_MAX_ENV_SIZE]; + struct hsearch_data htab; + char *res = NULL; + ssize_t len; + int ret = 0; + + ret = read_spi_flash_offset(buffer, HW_INFO_SPI_FLASH_OFFSET + + HW_INFO_ENV_OFFSET); + if (ret) + goto err; + memset(&htab, 0, sizeof(htab)); + if (!hcreate_r(HW_INFO_MAX_ENV_SIZE, &htab)) { + ret = -ENOMEM; + goto err; + } + if (!himport_r(&htab, buffer, HW_INFO_MAX_ENV_SIZE, + HW_INFO_ENV_SEP, H_NOCLEAR, 0, 0, NULL)) { + ret = -EFAULT; + goto err_htab; + } + + len = hexport_r(&htab, '\n', H_HIDE_DOT, &res, 0, 0, NULL); + if (len > 0) { + printf("Parameters (hw_info):\n"); + puts(res); + free(res); + ret = 0; + goto ret_htab; + } +ret_htab: + hdestroy_r(&htab); + return ret; +err_htab: + hdestroy_r(&htab); +err: + printf("## Error: cannot store hw_info parameters to SPI flash\n"); + return ret; +} + +static int cmd_hw_info_load(bool print_env) +{ + char buffer[HW_INFO_MAX_ENV_SIZE]; + char *res = NULL; + ssize_t len; + int ret = 0; + + ret = read_spi_flash_offset(buffer, HW_INFO_SPI_FLASH_OFFSET + + HW_INFO_ENV_OFFSET); + if (ret) + goto err; + if (!himport_r(&env_htab, buffer, HW_INFO_MAX_ENV_SIZE, + HW_INFO_ENV_SEP, H_NOCLEAR, 0, 0, NULL)) { + ret = -EFAULT; + goto err; + } + + printf("Successfully imported the Marvell hw_info parameters.\n"); + if (!print_env) + return 0; + + len = hexport_r(&env_htab, '\n', H_HIDE_DOT, &res, 0, 0, NULL); + if (len > 0) { + printf("Updated environment:\n"); + puts(res); + free(res); + return 0; + } +err: + printf("## Error: cannot import hw_info parameters\n"); + return ret; +} + +static int cmd_hw_info_store(char *name) +{ + char buffer[HW_INFO_MAX_ENV_SIZE]; + struct env_entry e, *ep, *rv; + struct hsearch_data htab; + char *res = NULL; + ssize_t len; + int ret = 0; + + ret = hw_info_check_parameter(name); + if (ret) { + printf("Invalid parameter %s, stopping.\n", name); + goto err; + } + + ret = read_spi_flash_offset(buffer, HW_INFO_SPI_FLASH_OFFSET + + HW_INFO_ENV_OFFSET); + if (ret) + goto err; + memset(&htab, 0, sizeof(htab)); + if (!hcreate_r(HW_INFO_MAX_ENV_SIZE, &htab)) { + ret = -ENOMEM; + goto err; + } + if (!himport_r(&htab, buffer, HW_INFO_MAX_ENV_SIZE, + HW_INFO_ENV_SEP, H_NOCLEAR, 0, 0, NULL)) { + ret = -EFAULT; + goto err_htab; + } + + e.key = name; + e.data = NULL; + if (!hsearch_r(e, ENV_FIND, &ep, &env_htab, H_HIDE_DOT)) { + ret = -ENOENT; + goto err_htab; + } + if (!ep) { + ret = -ENOENT; + goto err_htab; + } + + printf("Storing %s=%s to hw_info...\n", ep->key, ep->data); + + e.key = ep->key; + e.data = ep->data; + if (!hsearch_r(e, ENV_ENTER, &rv, &htab, H_HIDE_DOT)) { + ret = -EINVAL; + goto err_htab; + } + if (!rv) { + ret = -EINVAL; + goto err_htab; + } + len = hexport_r(&htab, HW_INFO_ENV_SEP, H_MATCH_KEY | H_MATCH_IDENT, + &res, 0, 0, NULL); + if (len <= 0) { + free(res); + goto ret_htab; + } + ret = write_spi_flash_offset(res, HW_INFO_SPI_FLASH_OFFSET + + HW_INFO_ENV_OFFSET, len); + free(res); + if (ret) + goto err_htab; + + printf("Successfully stored the Marvell hw_info parameters.\n"); + return 0; +ret_htab: + hdestroy_r(&htab); + return ret; +err_htab: + hdestroy_r(&htab); +err: + printf("## Error: cannot store hw_info parameters to SPI flash\n"); + return ret; +} + +static int do_hw_info(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + const char *cmd = argv[1]; + + if (argc < 2) + return CMD_RET_USAGE; + + if (!strcmp(cmd, "dump")) { + if (cmd_hw_info_dump()) + return -EINVAL; + } else if (!strcmp(cmd, "load")) { + if (cmd_hw_info_load(true)) + return -EINVAL; + } else if (!strcmp(cmd, "store")) { + if (cmd_hw_info_store(argv[2])) + return -EINVAL; + } else { + return CMD_RET_USAGE; + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + hw_info, 3, 0, do_hw_info, + "Marvell hw_info utility", + "hw_info\n" + "\tdump - Dump all hw_info parameters from SPI flash\n" + "\tload - Load all hw_info parameters from hw_info to environment variables\n" + "\tstore <env_name> - Store specific hw_info parameter from envirnoment variable to SPI flash\n" + "\nSupported hw_info parameters:\n" + "\tpcb_slm PCB SLM number\n" + "\tpcb_rev PCB revision number\n" + "\teco_rev ECO revision number\n" + "\tpcb_sn PCB SN\n" + "\tethaddr first MAC address\n" + "\teth1addr second MAC address\n" + "\teth2addr third MAC address\n" + "\teth3addr fourth MAC address\n" + "\teth4addr fifth MAC address\n" + "\teth5addr sixth MAC address\n" + "\teth6addr seventh MAC address\n" + "\teth7addr eighth MAC address\n" + "\teth8addr ninth MAC address\n" + "\teth9addr tenth MAC address\n" +); diff --git a/lib/hashtable.c b/lib/hashtable.c index ff5ff72639..06322e3304 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -794,7 +794,7 @@ static int drop_var_from_set(const char *name, int nvars, char * vars[]) * multi-line values. * * In theory, arbitrary separator characters can be used, but only - * '\0' and '\n' have really been tested. + * '\0', '\n' and 0x20 have been tested. */
int himport_r(struct hsearch_data *htab,
Hi Gerald,
This patch series has been resent and you have with an exception of a small PHY -> COMPHY change just "rebranded" the patches and used your SoB, without acknowledging the previous work.
Link to the original patchset: https://patchwork.ozlabs.org/project/uboot/list/?series=229617
A new patchset will be sent today, which refactors the original patches.
bool "hw_info"
default n
help
supported.
default 0x3E0000
help
A3720 platforms.
- Marvell hw_info command
- Helper command for interfacing with the Marvell hw_info parameters
- Copyright (c) 2021 Sartura Ltd.
- Copyright (c) 2018 Marvell International Ltd.
- Author: Luka Kovacic luka.kovacic@sartura.hr
"pcb_slm",
"pcb_rev",
"eco_rev",
"pcb_sn",
"ethaddr",
"eth1addr",
"eth2addr",
"eth3addr",
"eth4addr",
"eth5addr",
"eth6addr",
"eth7addr",
"eth8addr",
"eth9addr",
int idx;
return -EINVAL;
int ret;
if (!flash) {
return -EIO;
if (ret) {
return ret;
return ret;
int ret;
if (!flash) {
return -EIO;
if (ret) {
return ret;
if (ret) {
return ret;
return ret;
char *res = NULL;
ssize_t len;
int ret = 0;
if (ret)
goto err;
ret = -ENOMEM;
goto err;
ret = -EFAULT;
goto err_htab;
if (len > 0) {
puts(res);
free(res);
ret = 0;
goto ret_htab;
+ret_htab:
hdestroy_r(&htab);
return ret;
+err_htab:
hdestroy_r(&htab);
+err:
return ret;
char *res = NULL;
ssize_t len;
int ret = 0;
if (ret)
goto err;
ret = -EFAULT;
goto err;
if (!print_env)
if (len > 0) {
puts(res);
free(res);
+err:
return ret;
char *res = NULL;
ssize_t len;
int ret = 0;
if (ret) {
goto err;
if (ret)
goto err;
ret = -ENOMEM;
goto err;
ret = -EFAULT;
goto err_htab;
e.key = name;
e.data = NULL;
ret = -ENOENT;
goto err_htab;
if (!ep) {
ret = -ENOENT;
goto err_htab;
e.key = ep->key;
e.data = ep->data;
ret = -EINVAL;
goto err_htab;
if (!rv) {
ret = -EINVAL;
goto err_htab;
&res, 0, 0, NULL);
if (len <= 0) {
free(res);
goto ret_htab;
free(res);
if (ret)
goto err_htab;
+ret_htab:
hdestroy_r(&htab);
return ret;
+err_htab:
hdestroy_r(&htab);
+err:
return ret;
if (argc < 2)
return -EINVAL;
return -EINVAL;
return -EINVAL;
} else {
+U_BOOT_CMD(
"hw_info\n"
"\tpcb_sn PCB SN\n"
- multi-line values.
- In theory, arbitrary separator characters can be used, but only
- '\0' and '\n' have really been tested.
- '\0', '\n' and 0x20 have been tested.
2.30.2
Kind regards, Luka Kovacic
Héllo Luka,
Le 11/08/2021 à 12:15, Luka Kovacic a écrit :
Hi Gerald,
Yes, it was just a "refresh"...
Great !
Good news if you can take back again on this job...
Thanks for this.
Do not hesitate if you need testing...
bool "hw_info"
default n
help
supported.
default 0x3E0000
help
A3720 platforms.
- choice prompt "Flash for image" default MVEBU_SPI_BOOT
"pcb_slm",
"pcb_rev",
"eco_rev",
"pcb_sn",
"ethaddr",
"eth1addr",
"eth2addr",
"eth3addr",
"eth4addr",
"eth5addr",
"eth6addr",
"eth7addr",
"eth8addr",
"eth9addr",
int idx;
return -EINVAL;
int ret;
if (!flash) {
return -EIO;
if (ret) {
return ret;
return ret;
int ret;
if (!flash) {
return -EIO;
if (ret) {
return ret;
if (ret) {
return ret;
return ret;
char *res = NULL;
ssize_t len;
int ret = 0;
if (ret)
goto err;
ret = -ENOMEM;
goto err;
ret = -EFAULT;
goto err_htab;
if (len > 0) {
puts(res);
free(res);
ret = 0;
goto ret_htab;
+ret_htab:
hdestroy_r(&htab);
return ret;
+err_htab:
hdestroy_r(&htab);
+err:
return ret;
char *res = NULL;
ssize_t len;
int ret = 0;
if (ret)
goto err;
ret = -EFAULT;
goto err;
if (!print_env)
if (len > 0) {
puts(res);
free(res);
+err:
return ret;
char *res = NULL;
ssize_t len;
int ret = 0;
if (ret) {
goto err;
if (ret)
goto err;
ret = -ENOMEM;
goto err;
ret = -EFAULT;
goto err_htab;
e.key = name;
e.data = NULL;
ret = -ENOENT;
goto err_htab;
if (!ep) {
ret = -ENOENT;
goto err_htab;
e.key = ep->key;
e.data = ep->data;
ret = -EINVAL;
goto err_htab;
if (!rv) {
ret = -EINVAL;
goto err_htab;
&res, 0, 0, NULL);
if (len <= 0) {
free(res);
goto ret_htab;
free(res);
if (ret)
goto err_htab;
+ret_htab:
hdestroy_r(&htab);
return ret;
+err_htab:
hdestroy_r(&htab);
+err:
return ret;
if (argc < 2)
return -EINVAL;
return -EINVAL;
return -EINVAL;
} else {
+U_BOOT_CMD(
"hw_info\n"
"\tpcb_sn PCB SN\n"
-- 2.30.2
Add the loadaddr U-Boot environment variable, as this is available in the stock Marvell U-Boot by default on Marvell Armada A37XX platforms.
Signed-off-by: Kerma Gérald gandalf@gk2.net Cc: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Robert Marko robert.marko@sartura.hr --- include/configs/mvebu_armada-37xx.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index c8c34d7d92..83f710efd4 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -103,6 +103,7 @@
/* fdt_addr and kernel_addr are needed for existing distribution boot scripts */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x6000000\0" \ "scriptaddr=0x6d00000\0" \ "pxefile_addr_r=0x6e00000\0" \ "fdt_addr=0x6f00000\0" \
Add initial support for the ESPRESSOBin-Ultra board from Globalscale Technologies, Inc.
The board is based on the 64-bit dual-core Marvell Armada 3720 SoC. Peripherals: - 5 Gigabit Ethernet ports (WAN has PoE, up to 30W, Topaz 6341 switch) - RTC clock (PCF8563) - USB 3.0 port - USB 2.0 port - 4x LED - UART over Micro-USB - M.2 slot (2280) - Mini PCI-E slot
Additionally, automatic import of the Marvell hw_info parameters is enabled via the recently added hw_info command. The parameters stored in Marvell hw_info are usually the board serial number and MAC addresses.
Signed-off-by: Kerma Gérald gandalf@gk2.net Cc: Luka Kovacic luka.kovacic@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr Cc: Robert Marko robert.marko@sartura.hr Signed-off-by: Kerma Gérald gandalf@gk2.net --- arch/arm/dts/Makefile | 1 + .../arm/dts/armada-3720-espressobin-ultra.dts | 202 ++++++++++++++++++ board/Marvell/mvebu_armada-37xx/MAINTAINERS | 9 + board/Marvell/mvebu_armada-37xx/board.c | 92 +++++++- .../mvebu_espressobin-ultra-88f3720_defconfig | 92 ++++++++ 5 files changed, 390 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-ultra.dts create mode 100644 configs/mvebu_espressobin-ultra-88f3720_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c42715ead4..f21c9c94d3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -213,6 +213,7 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ + armada-3720-espressobin-ultra.dtb \ armada-3720-turris-mox.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ diff --git a/arch/arm/dts/armada-3720-espressobin-ultra.dts b/arch/arm/dts/armada-3720-espressobin-ultra.dts new file mode 100644 index 0000000000..66ceee60c8 --- /dev/null +++ b/arch/arm/dts/armada-3720-espressobin-ultra.dts @@ -0,0 +1,202 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for ESPRESSObin-Ultra board + * Copyright (C) 2016 Marvell + * Copyright (C) 2019 Globalscale technologies, Inc. + * Copyright (C) 2020 Sartura Ltd. + * + * Author: Jason Hung jhung@globalscaletechnologies.com + * Author: Luka Kovacic luka.kovacic@sartura.hr + * Author: Vladimir Vid vladimir.vid@sartura.hr + */ + +/dts-v1/; + +#include "armada-372x.dtsi" + +/ { + model = "Globalscale Marvell ESPRESSOBin Ultra Board"; + compatible = "globalscale,espressobin-ultra", "marvell,armada3720", "marvell,armada3710"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + ethernet0 = ð0; + i2c0 = &i2c0; + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x00000000 0x00000000 0x20000000>; + }; + + vcc_sd_reg0: regulator@0 { + compatible = "regulator-gpio"; + regulator-name = "vcc_sd0"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-type = "voltage"; + states = <1800000 0x1 + 3300000 0x0>; + gpios = <&gpionb 4 GPIO_ACTIVE_HIGH>; + }; + + gpio-leds { + pinctrl-names = "default"; + pinctrl-0 = <&led1_pins>, <&led2_pins>, <&led3_pins>, <&led4_pins>; + compatible = "gpio-leds"; + + led1 { + label = "led1"; + gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + led2 { + label = "led2"; + gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + led3 { + label = "led3"; + gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + led4 { + label = "led4"; + gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + }; +}; + +&pinctrl_nb { + led1_pins: led1-pins { + groups = "pwm0"; + function = "gpio"; + }; + led2_pins: led2-pins { + groups = "pwm1"; + function = "gpio"; + }; + led3_pins: led3-pins { + groups = "pwm2"; + function = "gpio"; + }; + led4_pins: led4-pins { + groups = "pwm3"; + function = "gpio"; + }; +}; + +&comphy { + max-lanes = <3>; + phy0 { + phy-type = <COMPHY_TYPE_USB3_HOST0>; + phy-speed = <COMPHY_SPEED_5G>; + }; + + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + phy-speed = <COMPHY_SPEED_2_5G>; + }; + + phy2 { + phy-type = <COMPHY_TYPE_SATA0>; + phy-speed = <COMPHY_SPEED_5G>; + }; +}; + +ð0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>, <&smi_pins>; + phy-mode = "rgmii"; + phy_addr = <0x3>; + fixed-link { + speed = <1000>; + full-duplex; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&sata { + status = "okay"; +}; + +&sdhci0 { + status = "disabled"; +}; + +/* U11 */ +&sdhci1 { + non-removable; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + marvell,xenon-emmc; + marvell,xenon-tun-count = <9>; + marvell,pad-type = "fixed-1-8v"; + + pinctrl-names = "default"; + pinctrl-0 = <&mmc_pins>; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + mmccard: mmccard@0 { + compatible = "mmc-card"; + reg = <0>; + }; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&spi_quad_pins>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p128", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <50000000>; + m25p,fast-read; + }; +}; + +/* Exported on the micro USB connector through an FTDI */ +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "okay"; +}; + +&usb2 { + status = "okay"; +}; + +&usb3 { + status = "okay"; +}; + +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pins>; + reset-gpios = <&gpiosb 3 GPIO_ACTIVE_LOW>; + status = "okay"; +}; diff --git a/board/Marvell/mvebu_armada-37xx/MAINTAINERS b/board/Marvell/mvebu_armada-37xx/MAINTAINERS index f2c0a582d7..6b1697b942 100644 --- a/board/Marvell/mvebu_armada-37xx/MAINTAINERS +++ b/board/Marvell/mvebu_armada-37xx/MAINTAINERS @@ -10,6 +10,15 @@ M: Konstantin Porotchkin kostap@marvell.com S: Maintained F: configs/mvebu_espressobin-88f3720_defconfig
+ESPRESSOBin-Ultra BOARD +M: Kerma Gerald gandalf@gk2.net +M: Luka Kovacic luka.kovacic@sartura.hr +M: Robert Marko robert.marko@sartura.hr +M: Luka Perkov luka.perkov@sartura.hr +S: Maintained +F: arch/arm/dts/armada-3720-espressobin-ultra.dts +F: configs/mvebu_espressobin-ultra-88f3720_defconfig + uDPU BOARD M: Vladimir Vid vladimir.vid@sartura.hr S: Maintained diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index 2de9c2ac17..21c1eb7b22 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <init.h> #include <mmc.h> +#include <miiphy.h> #include <phy.h> #include <asm/global_data.h> #include <asm/io.h> @@ -55,6 +56,15 @@ DECLARE_GLOBAL_DATA_PTR; #define MVEBU_G2_SMI_PHY_CMD_REG (24) #define MVEBU_G2_SMI_PHY_DATA_REG (25)
+/* Marvell 88E1512 */ +#define MII_MARVELL_PHY_PAGE 22 + +#define MV88E1512_GENERAL_CTRL 20 +#define MV88E1512_MODE_SGMII 1 +#define MV88E1512_RESET_OFFS 15 + +#define ULTRA_MV88E1512_PHYADDR 0x1 + /* * Memory Controller Registers * @@ -282,12 +292,68 @@ static int mii_multi_chip_mode_write(struct mii_dev *bus, int dev_smi_addr, return 0; }
-/* Bring-up board-specific network stuff */ -int board_network_enable(struct mii_dev *bus) +void force_phy_88e1512_sgmii_to_copper(u16 devaddr) { - if (!of_machine_is_compatible("globalscale,espressobin")) - return 0; + const char *name; + u16 reg; + + name = miiphy_get_current_dev(); + if (name) { + /* SGMII-to-Copper mode initialization */ + + /* Select page 18 */ + miiphy_write(name, devaddr, MII_MARVELL_PHY_PAGE, 0x12); + /* In reg 20, write MODE[2:0] = 0x1 (SGMII to Copper) */ + miiphy_read(name, devaddr, MV88E1512_GENERAL_CTRL, ®); + reg &= ~0x7; + reg |= MV88E1512_MODE_SGMII; + miiphy_write(name, devaddr, MV88E1512_GENERAL_CTRL, reg); + /* PHY reset is necessary after changing MODE[2:0] */ + miiphy_read(name, devaddr, MV88E1512_GENERAL_CTRL, ®); + reg |= 1 << MV88E1512_RESET_OFFS; + miiphy_write(name, devaddr, MV88E1512_GENERAL_CTRL, reg); + /* Reset page selection */ + miiphy_write(name, devaddr, MII_MARVELL_PHY_PAGE, 0); + udelay(100); + } +} + +int board_network_enable_espressobin_ultra(struct mii_dev *bus) +{ + int i; + /* Setup 88E1512 SGMII-to-Copper mode */ + force_phy_88e1512_sgmii_to_copper(ULTRA_MV88E1512_PHYADDR);
+ /* + * FIXME: remove this code once Topaz driver gets available + * A3720 ESPRESSObin Ultra Board Only + * Configure Topaz switch (88E6341) + * Set port 1,2,3,4,5 to forwarding Mode (through Switch Port registers) + */ + for (i = 0; i <= 5; i++) { + mii_multi_chip_mode_write(bus, 3, MVEBU_PORT_CTRL_SMI_ADDR(i), + MVEBU_SW_PORT_CTRL_REG, + i == 5 ? 0x7c : 0x7f); + } + + /* RGMII Delay on Port 0 (CPU port), force link to 1000Mbps */ + mii_multi_chip_mode_write(bus, 3, MVEBU_PORT_CTRL_SMI_ADDR(0), + MVEBU_SW_LINK_CTRL_REG, 0xe002); + + /* Power up PHY 1, 2, 3, 4, 5 (through Global 2 registers) */ + mii_multi_chip_mode_write(bus, 3, MVEBU_SW_G2_SMI_ADDR, + MVEBU_G2_SMI_PHY_DATA_REG, 0x1140); + for (i = 1; i <= 5; i++) { + mii_multi_chip_mode_write(bus, 3, MVEBU_SW_G2_SMI_ADDR, + MVEBU_G2_SMI_PHY_CMD_REG, 0x9400 + + (MVEBU_PORT_CTRL_SMI_ADDR(i) << 5)); + } + + return 0; +} + +int board_network_enable_espressobin(struct mii_dev *bus) +{ /* * FIXME: remove this code once Topaz driver gets available * A3720 Community Board Only @@ -328,6 +394,16 @@ int board_network_enable(struct mii_dev *bus) return 0; }
+/* Bring-up the board-specific networking */ +int board_network_enable(struct mii_dev *bus) +{ + if (of_machine_is_compatible("globalscale,espressobin")) + return board_network_enable_espressobin(bus); + if (of_machine_is_compatible("globalscale,espressobin-ultra")) + return board_network_enable_espressobin_ultra(bus); + return 0; +} + #if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) int ft_board_setup(void *blob, struct bd_info *bd) { @@ -336,8 +412,12 @@ int ft_board_setup(void *blob, struct bd_info *bd) int parts_off; int part_off;
- /* Fill SPI MTD partitions for Linux kernel on Espressobin */ - if (!of_machine_is_compatible("globalscale,espressobin")) + /* + * Fill SPI MTD partitions for the Linux kernel on ESPRESSOBin and + * ESPRESSOBin Ultra boards. + */ + if (!of_machine_is_compatible("globalscale,espressobin") && + !of_machine_is_compatible("globalscale,espressobin-ultra")) return 0;
spi_off = fdt_node_offset_by_compatible(blob, -1, "jedec,spi-nor"); diff --git a/configs/mvebu_espressobin-ultra-88f3720_defconfig b/configs/mvebu_espressobin-ultra-88f3720_defconfig new file mode 100644 index 0000000000..207f38d300 --- /dev/null +++ b/configs/mvebu_espressobin-ultra-88f3720_defconfig @@ -0,0 +1,92 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x3F0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_CLOCK=25804800 +CONFIG_DEFAULT_DEVICE_TREE="armada-3720-espressobin-ultra" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds, to stop use 's' key\n" +CONFIG_AUTOBOOT_STOP_STR="s" +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_HUSH_PARSER=y +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="if printenv read_board_hw_info; then echo "Marvell hw_info already imported..." ; else setenv read_board_hw_info 1; hw_info load; fi" +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_MVEBU_HW_INFO=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_AHCI_MVEBU=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_GIGE=y +CONFIG_MVNETA=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_AARDVARK=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_37XX=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_MVEBU_A3700_UART=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_SHA1=y +CONFIG_SHA256=y +CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y +CONFIG_LED=y +CONFIG_LED_GPIO=y
Gerald Kerma
Gérald Kerma
Luka Kovacic
