[U-Boot] u-boot can boot Linux in zImage format while not in uImage format
Hi All, I am meeting a strange issue. The u-boot can boot device tree supported Linux in zImage format and can not boot in uImage format. The detail information as following:
1. set the bootargs 2. tftp 0x21000000 dtb, and tftp 0x22000000 uImage, then bootm 0x22000000 - 0x21000000, it can not boot up. Stop at "Starting kernel..." 3. tftp 0x21000000 dtb, and tftp 0x22000000 zImage, then bootz 0x22000000 - 0x21000000, it boot successfully.
I check the memory usage, no overlap. I try other memory address, won't fix. I check all parameters pass to kernel is right.
Any possible reason will cause this issue?
Best Regards, Bo Shen
- set the bootargs
- tftp 0x21000000 dtb, and tftp 0x22000000 uImage, then bootm 0x22000000
Maybe your uImage was generated with the incorrect LOADADDR?
Hi Fabio,
- set the bootargs
The uImage is ok, test with bootstrap boot it directly.
Add log with debug information ---8>--- ## Booting kernel from Legacy Image at 22000000 ... Image Name: Linux-3.10.0-rc7+ Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1514568 Bytes = 1.4 MiB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK kernel data at 0x22000040, len = 0x00171c48 (1514568) ## Skipping init Ramdisk ## No init Ramdisk ramdisk start = 0x00000000, ramdisk end = 0x00000000 * fdt: cmdline image address = 0x21000000 ## Checking for 'FDT'/'FDT Image' at 21000000 * fdt: raw FDT blob ## Flattened Device Tree blob at 21000000 Booting using the fdt blob at 0x21000000 of_flat_tree at 0x21000000 size 0x000024bf Initial value for argc=3 Final value for argc=3 Loading Kernel Image ... OK OK kernel loaded at 0x20008000, end = 0x20179c48 using: FDT ## initrd_high = 0xffffffff, copy_to_ram = 1 ramdisk load start = 0x00000000, ramdisk load end = 0x00000000 ## device tree at 21000000 ... 210024be (len=21695 [0x54BF]) Loading Device Tree to 27b2c000, end 27b314be ... OK Initial value for argc=3 Final value for argc=3 No alias for ethernet0 Using machid 0xffffffff from environment ## Transferring control to Linux (at address 20008000)...
Starting kernel ... ---<8---
Dear Bo Shen,
Are you sure this is a working Linux kernel image? An uncomporessed size of 1.4 MiB seems a bit too small to me?
Hi Wolfgang Denk,
On 06/27/2013 01:39 PM, Wolfgang Denk wrote:
Dear Bo Shen,
Sure, this is a working Linux kernel image.
As to test u-boot, I remove most driver from Linux kernel. Then, for many times tftp, it will save me amount of time.
Bo Shen
Fabio Estevam
