[U-Boot] [PATCH] rockchip: rk3399: rock960: Update config for TPL
The SPL is now running at SDRAM, and 0x10000 is used by BL31, and the ARM SPL do not support relocate now, we need reserved 0x50000 so that it won't overwrite the code when we load the bl31 to target space. We should remove this after we enable the relocate feature.
The SPL need malloc 0x9000 for MMC as buffer used for transfer data to IRAM(The EMMC DMA can not transfer data to IRAM directly).
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- configs/rock960-rk3399_defconfig | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index cb3c68db6b..f211a65587 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -2,19 +2,21 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ROCKCHIP_RK3399=y -CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x50000 CONFIG_TARGET_ROCK960_RK3399=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL=y CONFIG_SYS_PROMPT="rock960 => " CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y @@ -56,4 +58,6 @@ CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y
hi I am a bit confused about two things 1) is the "ide" (disk read/write/boot) module intended to be PCI-MEM "memory-mapped" oriented concerning the harddrive? or is it PCI_IO oriented? there are too many layers of code and this makes me confused 2) what is the philosophy about initializing the PCI_bridge? and what is u-boot supposed to do concerning the device-tree-blog to be passed to the kernel?
there are pieces of code in the kernel source telling me this
* Older u-boots don't set PCI up properly. * Update the hardware to match the device tree. * The prefetch mem region and non-prefetch mem region * must be contiguous in the host bus. * As required by the PCI binding, PCI #addr/#size must be 3/2. * The parent bus must be 1/1. * Only 32-bit PCI is supported. * All three region types * prefetchable mem * non-prefetchable mem * I/O * must be present
Hi Peter,
I have Rock960 Model A board, I have tied this patch but I cannot get the board to boot up using microSD card with latest u-boot, I have not tried to update the eMMC module with latest u-boot as of now.
But could you share the steps needed to build this images. I follow this script [0] https://pastebin.com/t6y7eWQL
If you could share some input on build the latest u-boot and update the u-boot to microSD card of eMMC.
Is their any latest image available to this board using upstream u-boot and kernel.
Best Regards -Anand
Hi Peter,
Could you update this to '0x0'(drop this line to use default value) since I have
already update this in another mail[0], I can merge them together.
Thanks,
- Kever
[0] https://patchwork.ozlabs.org/patch/1173719/ https://patchwork.ozlabs.org/patch/1173719/
On Mon, Oct 14, 2019 at 9:58 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Peter,
Update sent.
Thanks, Peter
Thanks,
- Kever
Anand Moon
Carlo Pisani
Kever Yang
Peter Robinson
