[U-Boot] [PATCH v2] sunxi: video: Improve monitor video-mode option handling
Add a sunxi_monitor enum and parse the monitor option string into this enum once, rather then doing strcmp-s on it in various places. This also adds checking for it being a valid value.
This also adds new "none" and "lcd" values in preparation for lcd support.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- Changes in v2: -Add a sunxi_get_mon_desc helper to convert from the monitor enum to strings --- drivers/video/sunxi_display.c | 63 ++++++++++++++++++++++++++++++++----------- 1 file changed, 47 insertions(+), 16 deletions(-)
diff --git a/drivers/video/sunxi_display.c b/drivers/video/sunxi_display.c index ced5ce5..84ecef9 100644 --- a/drivers/video/sunxi_display.c +++ b/drivers/video/sunxi_display.c @@ -21,9 +21,19 @@
DECLARE_GLOBAL_DATA_PTR;
+enum sunxi_monitor { + sunxi_monitor_none, + sunxi_monitor_dvi, + sunxi_monitor_hdmi, + sunxi_monitor_lcd, + sunxi_monitor_vga, +}; +#define SUNXI_MONITOR_LAST sunxi_monitor_vga + struct sunxi_display { GraphicDevice graphic_device; bool enabled; + enum sunxi_monitor monitor; } sunxi_display;
/* @@ -159,7 +169,7 @@ static int sunxi_hdmi_edid_get_block(int block, u8 *buf) return r; }
-static int sunxi_hdmi_edid_get_mode(struct ctfb_res_modes *mode, char *monitor) +static int sunxi_hdmi_edid_get_mode(struct ctfb_res_modes *mode) { struct edid1_info edid1; struct edid_cea861_info cea681[4]; @@ -241,14 +251,14 @@ static int sunxi_hdmi_edid_get_mode(struct ctfb_res_modes *mode, char *monitor) }
/* Check for basic audio support, if found enable hdmi output */ - strcpy(monitor, "dvi"); + sunxi_display.monitor = sunxi_monitor_dvi; for (i = 0; i < ext_blocks; i++) { if (cea681[i].extension_tag != EDID_CEA861_EXTENSION_TAG || cea681[i].revision < 2) continue;
if (EDID_CEA861_SUPPORTS_BASIC_AUDIO(cea681[i])) - strcpy(monitor, "hdmi"); + sunxi_display.monitor = sunxi_monitor_hdmi; }
return 0; @@ -489,7 +499,7 @@ static void sunxi_hdmi_setup_info_frames(const struct ctfb_res_modes *mode) }
static void sunxi_hdmi_mode_set(const struct ctfb_res_modes *mode, - bool hdmi_mode, int clk_div, int clk_double) + int clk_div, int clk_double) { struct sunxi_hdmi_reg * const hdmi = (struct sunxi_hdmi_reg *)SUNXI_HDMI_BASE; @@ -498,7 +508,7 @@ static void sunxi_hdmi_mode_set(const struct ctfb_res_modes *mode, /* Write clear interrupt status bits */ writel(SUNXI_HDMI_IRQ_STATUS_BITS, &hdmi->irq);
- if (hdmi_mode) + if (sunxi_display.monitor == sunxi_monitor_hdmi) sunxi_hdmi_setup_info_frames(mode);
/* Set input sync enable */ @@ -549,7 +559,7 @@ static void sunxi_engines_init(void) #endif }
-static void sunxi_mode_set(const struct ctfb_res_modes *mode, char *monitor, +static void sunxi_mode_set(const struct ctfb_res_modes *mode, unsigned int address) { struct sunxi_de_be_reg * const de_be = @@ -559,11 +569,10 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, char *monitor, struct sunxi_hdmi_reg * const hdmi = (struct sunxi_hdmi_reg *)SUNXI_HDMI_BASE; int clk_div, clk_double; - bool hdmi_mode = strcmp(monitor, "hdmi") == 0;
sunxi_composer_mode_set(mode, address); sunxi_lcdc_mode_set(mode, &clk_div, &clk_double); - sunxi_hdmi_mode_set(mode, hdmi_mode, clk_div, clk_double); + sunxi_hdmi_mode_set(mode, clk_div, clk_double);
setbits_le32(&de_be->reg_ctrl, SUNXI_DE_BE_REG_CTRL_LOAD_REGS); setbits_le32(&de_be->mode, SUNXI_DE_BE_MODE_START); @@ -574,6 +583,18 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, char *monitor, setbits_le32(&hdmi->video_ctrl, SUNXI_HDMI_VIDEO_CTRL_ENABLE); }
+static const char *sunxi_get_mon_desc(enum sunxi_monitor monitor) +{ + switch (monitor) { + case sunxi_monitor_none: return "none"; + case sunxi_monitor_dvi: return "dvi"; + case sunxi_monitor_hdmi: return "hdmi"; + case sunxi_monitor_lcd: return "lcd"; + case sunxi_monitor_vga: return "vga"; + } + return NULL; /* never reached */ +} + void *video_hw_init(void) { static GraphicDevice *graphic_device = &sunxi_display.graphic_device; @@ -581,8 +602,8 @@ void *video_hw_init(void) struct ctfb_res_modes edid_mode; const char *options; unsigned int depth; - int ret, hpd, edid; - char monitor[16]; + int i, ret, hpd, edid; + char mon[16];
memset(&sunxi_display, 0, sizeof(struct sunxi_display));
@@ -593,8 +614,18 @@ void *video_hw_init(void) video_get_ctfb_res_modes(RES_MODE_1024x768, 24, &mode, &depth, &options); hpd = video_get_option_int(options, "hpd", 1); edid = video_get_option_int(options, "edid", 1); - video_get_option_string(options, "monitor", monitor, sizeof(monitor), - "dvi"); + sunxi_display.monitor = sunxi_monitor_dvi; + video_get_option_string(options, "monitor", mon, sizeof(mon), + sunxi_get_mon_desc(sunxi_display.monitor)); + for (i = 0; i <= SUNXI_MONITOR_LAST; i++) { + if (strcmp(mon, sunxi_get_mon_desc(i)) == 0) { + sunxi_display.monitor = i; + break; + } + } + if (i > SUNXI_MONITOR_LAST) + printf("Unknown monitor: '%s', falling back to '%s'\n", + mon, sunxi_get_mon_desc(sunxi_display.monitor));
/* Always call hdp_detect, as it also enables various clocks, etc. */ ret = sunxi_hdmi_hpd_detect(); @@ -607,7 +638,7 @@ void *video_hw_init(void)
/* Check edid if requested and we've a cable plugged in */ if (edid && ret) { - if (sunxi_hdmi_edid_get_mode(&edid_mode, monitor) == 0) + if (sunxi_hdmi_edid_get_mode(&edid_mode) == 0) mode = &edid_mode; }
@@ -615,13 +646,13 @@ void *video_hw_init(void) printf("Only non-interlaced modes supported, falling back to 1024x768\n"); mode = &res_mode_init[RES_MODE_1024x768]; } else { - printf("Setting up a %dx%d %s console\n", - mode->xres, mode->yres, monitor); + printf("Setting up a %dx%d %s console\n", mode->xres, + mode->yres, sunxi_get_mon_desc(sunxi_display.monitor)); }
sunxi_display.enabled = true; sunxi_engines_init(); - sunxi_mode_set(mode, monitor, gd->fb_base - CONFIG_SYS_SDRAM_BASE); + sunxi_mode_set(mode, gd->fb_base - CONFIG_SYS_SDRAM_BASE);
/* * These are the only members of this structure that are used. All the
Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
