[PATCH] cmd: sf: Handle unaligned 'update' start offset
Currently the 'sf update' command fails in case the 'start' offset is not aligned to SPI NOR erase block size. Add the missing alignment calculation. In case the start offset is in the middle of erase block, round start address down to the nearest aligned one, compare only the updated data between what is in the SPI NOR and what is being written, copy new data at offset of the compare buffer, and write back the entire erase block.
This is useful e.g. on i.MX6Q where the u-boot-with-spl.imx is at offset 0x400 in the SPI NOR, while the SPI NOR may have erase block size e.g. 0x1000 bytes.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Bin Meng bmeng.cn@gmail.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Jan Kiszka jan.kiszka@siemens.com Cc: Pratyush Yadav p.yadav@ti.com Cc: Sean Anderson seanga2@gmail.com --- cmd/sf.c | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/cmd/sf.c b/cmd/sf.c index bd102f5af9d..f9b2d9a47a7 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -179,16 +179,18 @@ static const char *spi_flash_update_block(struct spi_flash *flash, u32 offset, size_t len, const char *buf, char *cmp_buf, size_t *skipped) { char *ptr = (char *)buf; + u32 start_offset = offset % flash->sector_size; + u32 read_offset = offset - start_offset;
- debug("offset=%#x, sector_size=%#x, len=%#zx\n", - offset, flash->sector_size, len); + debug("offset=%#x+%#x, sector_size=%#x, len=%#zx\n", + read_offset, start_offset, flash->sector_size, len); /* Read the entire sector so to allow for rewriting */ - if (spi_flash_read(flash, offset, flash->sector_size, cmp_buf)) + if (spi_flash_read(flash, read_offset, flash->sector_size, cmp_buf)) return "read"; /* Compare only what is meaningful (len) */ - if (memcmp(cmp_buf, buf, len) == 0) { - debug("Skip region %x size %zx: no change\n", - offset, len); + if (memcmp(cmp_buf + start_offset, buf, len) == 0) { + debug("Skip region %x+%x size %zx: no change\n", + start_offset, read_offset, len); *skipped += len; return NULL; } @@ -197,7 +199,7 @@ static const char *spi_flash_update_block(struct spi_flash *flash, u32 offset, return "erase"; /* If it's a partial sector, copy the data into the temp-buffer */ if (len != flash->sector_size) { - memcpy(cmp_buf, buf, len); + memcpy(cmp_buf + start_offset, buf, len); ptr = cmp_buf; } /* Write one complete sector */ @@ -238,6 +240,8 @@ static int spi_flash_update(struct spi_flash *flash, u32 offset,
for (; buf < end && !err_oper; buf += todo, offset += todo) { todo = min_t(size_t, end - buf, flash->sector_size); + todo = min_t(size_t, end - buf, + flash->sector_size - (offset % flash->sector_size)); if (get_timer(last_update) > 100) { printf(" \rUpdating, %zu%% %lu B/s", 100 - (end - buf) / scale,
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
Jagan Teki
