[U-Boot] [STATUS] v2010.09-rc1 is out / v2010.09 delayed by 2 weeks
Hello everybody:
* U-Boot v2010.09-rc1 was released on Fri, 10 Sep 2010.
* Release "v2010.09" is scheduled in 18 days - on September 28, 2010, i. e. we have a delay against the original plan of about 2 weeks.
For details please see http://www.denx.de/wiki/U-Boot/ReleaseCycle
Please help testing, and check if all your relevant patches have been included.
Thanks.
not sure if you wanted to include these for 2010.09, or wait until after: 11.08.2010 [PATCH] Makefile: restore support for board shortcut targets 19.08.2010 [PATCH v2] MAKEALL: cut down on duplication of targets 15.08.2010 [PATCH 1/4] tools: enable img2srec for "all" target 15.08.2010 [PATCH 2/4] tools: update .gitignore 15.08.2010 [PATCH 3/4] unify toplevel tools targets 15.08.2010 [PATCH 4/4] tools/env: use host build flags -mike
Dear Mike Frysinger,
I've seen these on my list for "next". Should these go into 2010.09?
if you want to keep the tree settled, then keeping them in "next" is OK by me. not that there should be anything wrong with these changes ... -mike
i. e. we have a delay against the original plan of about 2 weeks. Please help testing, and check if all your relevant patches have been included.
Tested on da850evm with NAND enabled; the env.OOB marker was recognized, the environment was loaded and I was able to load and boot a uImage kernel from NAND.
Best Regards, Ben Gardiner
--- Nanometrics Inc. http://www.nanometrics.ca
Dear Ben Gardiner,
In message AANLkTinFDGngQiuLvVEX2d3+=fUDwa4uwf4Y9t9hOpxR@mail.gmail.com you wrote:
Thanks a lot.
Dear Wolfgang,
On 10.09.2010 19:54, Wolfgang Denk wrote:
... check if all your relevant patches have been included.
What's about
http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
? Or if you don't like that, this
http://lists.denx.de/pipermail/u-boot/2010-August/075303.html
Best regards
Dirk
Dear Dirk Behme,
In message 4C8B1A02.4070301@googlemail.com you wrote:
Dear Wolfgang,
What's about
Doesn't apply:
Applying: Remove unused variable bi_env fatal: sha1 information is lacking or useless (common/cmd_bdinfo.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001 Remove unused variable bi_env When you have resolved this problem run "git am --resolved". If you would prefer to skip this patch, instead run "git am --skip". To restore the original branch and stop patching run "git am --abort".
This one has been applied to the "next" branch.
Dear Wolfgang Denk,
Rebasing worked without manual intervention, u-boot still compiles and works for my board (at91sam9xe-based). Code size increased 0x20 bytes.
The following (published) patches are left ahead of master here:
3d70dcf2d8ea7e7a50d5d5d5a0429341db87e38f display_buffer: fix misaligned buffer - urgent!
1110f276e9785d0270cfc9ec316dd475145f95d0 SPI: cmd_spi.c: add options to specify bus and mode - has been posted 26.08.2010
7c7e2813318b84fc4fbec57b23e2ad68ff000564 NET: move legacy enc28j60.c to sidetrack - Ben took that one to net/next on 31.08.2010
With Best Regards, Reinhard
i already merged into my sf branch and will push post 2010.09 if Woflgang doesnt pick it up himself
that's Ben's call to move from net to mainline ... and unless there's a pressing reason for this to be in mainline (i cant see any), keeping it for post release is OK ... -mike
As I recall, the idea Ben and me had was to first sidetrack the old driver and later bring in the new one.
Otherwise, in fact - until that patch is in - I should have it always vomited out together with the new enc28j60 driver's patch as a series.
Reinhard
I see this for "next" - pull requests welcome.
["next" will be out RSN.]
Yeah, I don't see a compelling reason to bring this in now. I'll send a pull request for next soon so the code gets to mainline early in the next cycle.
regards, Ben
Dear Reinhard Meyer,
In message 4C8CCE75.1000505@emk-elektronik.de you wrote:
Dear Wolfgang Denk,
- urgent!
Is in "master".
Scheduled for next.
I'm waiting for his pull req.
In arch/i386/lib/board.c, the declaration of do_go_exec() has changed, thus leading to the following build failure[0]:
board.c: In function 'do_go_exec': board.c:440: error: assignment of read-only location '*(argv + 0xfffffffffffffffffffffffffffffffcu)' cc1: warnings being treated as errors board.c:442: error: passing argument 2 of 'entry' discards qualifiers from pointer target type board.c:442: note: expected 'char **' but argument is of type 'char * const*' make[2]: *** [board.o] Error 1
[0] https://buildd.debian.org/fetch.cgi?pkg=u-boot;ver=2010.09~rc1-1;arch=i386;s...
I have a fix for this in my offline tree. I'm ok with missing this merge window - I'll upload my patches for the next one.
Thanks for catching this though
Regards,
Graeme
Dear Graeme Russ,
In message AANLkTi=iHWNM2hkPU58qOh_FojdXYc1LQbUKEopFcWpu@mail.gmail.com you wrote:
Fixes should go in _now_. This is what this phase of the development cycle is for.
Wolfgang,
On 13/09/10 05:04, Wolfgang Denk wrote:
Dear Graeme Russ,
Pull request sent.
Wolfgang, I was waiting for feedback for some other patches in the series, but have cut the series short to at least get the fixes in.
This is my first ever git push / git pull request and I stuffed up and included one extra patch (removal of unmaintained boards) which is not a fix, but would have gone in next merge - sorry about that
Regards,
Graeme
On Fri, Sep 10, 2010 at 10:54 AM, Wolfgang Denk wd@denx.de wrote:
Hello everybody:
I did a bit of v2010.09-rc1 testing on OMAP3 this evening and things looked good until I tried a simple memory display!
The output froze after the memory address was displayed:
Overo # md 82000000 10 82000000:
I reverted to an earlier version and things worked as expected:
Overo # md 82000000 10 82000000: fdffffff ddffddd7 bd7afdef dbffccff ..........z..... 82000010: fd37cfff 7f7fff6f f5ffdeef fdf7eef7 ..7.o........... 82000020: fabbfdff de17fdcf 7e777df7 ddfd7ddf .........}w~.}.. 82000030: ed77cefe ddf3fcff ff7fcd77 bf7eed93 ..w.....w.....~.
Has anyone else run into this? I need to get some sleep now, but will investigate further in the morning.
Steve
Dear Steve Sakoman,
That _might_ be the unaligned access to the buffer. Try
[PATCH v2] display_buffer: fix misaligned buffer
from 31.08.2010. If that helps its even more important that patch gets mainline asap ;)
Reinhard
Hello everybody:
Hi Steve,
do not worry, this is a known problem. As reported by Rheinard, we need the patch to fix misaligned access. It is was not merged up now, but we need soon before the release:
"3d70dcf2d8ea7e7a50d5d5d5a0429341db87e38f display_buffer: fix misaligned buffer - urgent!"
Best regards, Stefano Babic
Hello everybody:
Hi Steve,
- urgent!"
I tried this patch and it does indeed fix the issue.
I see that Wolfgang has already pushed it to master, so I'll get back to testing the rc-1 on OMAP3 and OMAP4.
Thanks for the quick response!
Steve
Hello everybody:
Hi Wolfgang,
a recent post pointed out to the following patch:
[PATCH] [PATCH v6]Save environment data to mmc.
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/78772
I see no urgency, but I have not seen any opened issues with this patch and first version was sent some months ago. Any chance to get it in the release or should we only mark it for the "next" branch ?
Dear Stefano Babic,
Did you test this? Is this to be considered a formal ACK?
Dear Stefano Babic,
Hi Wolfgang,
Yes, and I tested again on top of v2010.09-rc1.
participants (10)
Ben Gardiner
Ben Warren
Clint Adams
Dirk Behme
Graeme Russ
Mike Frysinger
Reinhard Meyer
Stefano Babic
Steve Sakoman
