[U-Boot] [PATCH] [RFC] blk: Increase cache element size
Cache up to 4 kiB entries. 4 kiB is the default block size on ext4, yet the underlying block layer devices usually report support for 512B . In most cases, the 512B support is emulated (ie. SD cards, SSDs, USB sticks etc.) and the real block size of those devices is much bigger.
To avoid performance degradation with such devices and FS setup, bump the maximum cache entry size to 4 kiB.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org --- drivers/block/blkcache.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/blkcache.c b/drivers/block/blkcache.c index 294511fcdb..1fa64989d3 100644 --- a/drivers/block/blkcache.c +++ b/drivers/block/blkcache.c @@ -24,7 +24,7 @@ struct block_cache_node { static LIST_HEAD(block_cache);
static struct block_cache_stats _stats = { - .max_blocks_per_entry = 2, + .max_blocks_per_entry = 8, .max_entries = 32 };
I'll pick this up post v2018.09 if no one objects, thanks!
I object. I was hoping there'd be some discussion on how to solve this in a future-proof manner ... it's only a matter of time until someone uses ext4 with 8k blocks on an SSD ...
In general, sure? In specific, mkfs.ext4 1.42.13 man page says 1/2/4KiB are the only valid values of block size, and based on having to whack this for some other projects it's pretty common for OpenEmbedded at least to spit out 1KiB block size images. So unless you know of cases today (or tomorrow, but not next year) where 8KiB is common or likely, we should probably just bump this for now and maybe make it a tunable so it's easily changed?
OE spits 4k , that's how I triggered it, meta/classes/image_types.bbclass:EXTRA_IMAGECMD_ext2 ?= "-i 4096" meta/classes/image_types.bbclass:EXTRA_IMAGECMD_ext3 ?= "-i 4096" meta/classes/image_types.bbclass:EXTRA_IMAGECMD_ext4 ?= "-i 4096"
It is already tunable, see blkcache config in blkcache command.
But what I'd like to see is somehow the FS and the underlying storage negotiating the best settings. Can we get the FS block size from the block cache perspective ?
That's bytes-per-inode, I was referring to block size which is -b and dynamic unless specified.
Good questions that I don't have an answer to.
Right. Although, I think we mostly care about caching the inodes, not blocks, since the inodes are accessed repeatedly.
What we can do is extend fs_devread() and blk_dread() with a new flag, bool cachable, to allow FS and other upper layers which read block devices to mark blocks that should specifically be cached as such. The block cache would then cache the block no matter what size it has.
The FS implementations should know which data should be cached because they will be accessed repeatedly and which data are not, so they can set the flag accordingly.
The other users of blk_dread() would need to be examined. Possibly the best solution right now to avoid problems would be to apply this patch first. Then, second, add the flag to blk_dread() and set it accordingly where applicable AND make the block cache cache blocks which are either <= 8 kiB OR with cachable flag. Then finally, probably in next release, drop the <= 8 kiB condition and cache only blocks which are flagged as cachable to avoid polluting the block cache with useless small crumbs of data.
The downside is, the blk_dread() would look a bit asymmetrical compared to the other functions with the cachable flag in it's parameters.
Thoughts ?
> Cache up to 4 kiB entries. 4 kiB is the default block size on ext4, yet > the underlying block layer devices usually report support for 512B . In > most cases, the 512B support is emulated (ie. SD cards, SSDs, USB sticks > etc.) and the real block size of those devices is much bigger. > > To avoid performance degradation with such devices and FS setup, bump > the maximum cache entry size to 4 kiB. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Tom Rini trini@konsulko.com > Cc: Simon Glass sjg@chromium.org
OK, so it's the inode block.
Thoughts ?
Frankly, this sounds rather complicated when we might just need to increase the size of what we can cache a bit. We aren't a long running facility and so long as it's tunable, it's also most likely being used in machines where we have enough DDR that we can a few more kilobytes.
On 08/15/2018 04:30 PM, Tom Rini wrote: > On Wed, Aug 08, 2018 at 01:20:29PM +0200, Marek Vasut wrote: > >> Cache up to 4 kiB entries. 4 kiB is the default block size on ext4, yet >> the underlying block layer devices usually report support for 512B . In >> most cases, the 512B support is emulated (ie. SD cards, SSDs, USB sticks >> etc.) and the real block size of those devices is much bigger. >> >> To avoid performance degradation with such devices and FS setup, bump >> the maximum cache entry size to 4 kiB. >> >> Signed-off-by: Marek Vasut marex@denx.de >> Cc: Tom Rini trini@konsulko.com >> Cc: Simon Glass sjg@chromium.org > > Reviewed-by: Tom Rini trini@konsulko.com > > I'll pick this up post v2018.09 if no one objects, thanks!
Thoughts ?
It maybe increase the performance slightly though by not polluting the cache with which shouldn't be there. Might even be useful in SPL.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
